iPhone 7 Earpiece Speaker Replacement
Video Overview
    1. iPhone 7 Earpiece Speaker Replacement, Pentalobe Screws: step 1, image 1 of 1
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
    1. iPhone 7 Earpiece Speaker Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 7 Earpiece Speaker Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 7 Earpiece Speaker Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 7 Earpiece Speaker Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPhone 7 Earpiece Speaker Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPhone 7 Earpiece Speaker Replacement, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    2. iPhone 7 Earpiece Speaker Replacement: step 4, image 1 of 3 iPhone 7 Earpiece Speaker Replacement: step 4, image 2 of 3 iPhone 7 Earpiece Speaker Replacement: step 4, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    3. iPhone 7 Earpiece Speaker Replacement: step 5, image 1 of 2 iPhone 7 Earpiece Speaker Replacement: step 5, image 2 of 2
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    4. iPhone 7 Earpiece Speaker Replacement, Heat the display: step 6, image 1 of 1
      • The next three steps show how to separate the screen using a suction cup.
      • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
      • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
      Ask FixBot
    5. iPhone 7 Earpiece Speaker Replacement, Separate the display: step 7, image 1 of 2 iPhone 7 Earpiece Speaker Replacement, Separate the display: step 7, image 2 of 2
      • Apply a suction cup to the lower half of the front panel, just above the home button.
      • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
      Ask FixBot
    6. iPhone 7 Earpiece Speaker Replacement: step 8, image 1 of 3 iPhone 7 Earpiece Speaker Replacement: step 8, image 2 of 3 iPhone 7 Earpiece Speaker Replacement: step 8, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    7. iPhone 7 Earpiece Speaker Replacement: step 9, image 1 of 3 iPhone 7 Earpiece Speaker Replacement: step 9, image 2 of 3 iPhone 7 Earpiece Speaker Replacement: step 9, image 3 of 3
      • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
      • Stop near the top left corner of the display.
      • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
      Ask FixBot
    8. iPhone 7 Earpiece Speaker Replacement, Screen information: step 10, image 1 of 1
      • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
      Ask FixBot
    9. iPhone 7 Earpiece Speaker Replacement: step 11, image 1 of 3 iPhone 7 Earpiece Speaker Replacement: step 11, image 2 of 3 iPhone 7 Earpiece Speaker Replacement: step 11, image 3 of 3
      • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Ask FixBot
    10. iPhone 7 Earpiece Speaker Replacement: step 12, image 1 of 2 iPhone 7 Earpiece Speaker Replacement: step 12, image 2 of 2
      • Gently pull up on the suction cup to lift up the bottom edge of the display.
      • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Ask FixBot
    11. iPhone 7 Earpiece Speaker Replacement: step 13, image 1 of 3 iPhone 7 Earpiece Speaker Replacement: step 13, image 2 of 3 iPhone 7 Earpiece Speaker Replacement: step 13, image 3 of 3
      • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
      Ask FixBot
    12. iPhone 7 Earpiece Speaker Replacement: step 14, image 1 of 2 iPhone 7 Earpiece Speaker Replacement: step 14, image 2 of 2
      • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
      Ask FixBot
    13. iPhone 7 Earpiece Speaker Replacement: step 15, image 1 of 3 iPhone 7 Earpiece Speaker Replacement: step 15, image 2 of 3 iPhone 7 Earpiece Speaker Replacement: step 15, image 3 of 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      Ask FixBot
    1. iPhone 7 Earpiece Speaker Replacement, Battery Disconnection: step 16, image 1 of 1
      Tri-point Y000 Screwdriver
      $5.99
      Buy
      Ask FixBot
    2. iPhone 7 Earpiece Speaker Replacement: step 17, image 1 of 1
      • Remove the lower connector bracket.
      Ask FixBot
    3. iPhone 7 Earpiece Speaker Replacement: step 18, image 1 of 3 iPhone 7 Earpiece Speaker Replacement: step 18, image 2 of 3 iPhone 7 Earpiece Speaker Replacement: step 18, image 3 of 3
      • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
      • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
      Ask FixBot
    1. iPhone 7 Earpiece Speaker Replacement, Display Assembly: step 19, image 1 of 3 iPhone 7 Earpiece Speaker Replacement, Display Assembly: step 19, image 2 of 3 iPhone 7 Earpiece Speaker Replacement, Display Assembly: step 19, image 3 of 3
      • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
      • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
      • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
      • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
      Ask FixBot
    2. iPhone 7 Earpiece Speaker Replacement: step 20, image 1 of 3 iPhone 7 Earpiece Speaker Replacement: step 20, image 2 of 3 iPhone 7 Earpiece Speaker Replacement: step 20, image 3 of 3
      • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
      • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
      Ask FixBot
    3. iPhone 7 Earpiece Speaker Replacement: step 21, image 1 of 2 iPhone 7 Earpiece Speaker Replacement: step 21, image 2 of 2
      • Disconnect the front panel sensor assembly connector from its socket on the logic board.
      • This press connector should also be reconnected one end at a time to minimize the risk of bending.
      Ask FixBot
    4. iPhone 7 Earpiece Speaker Replacement: step 22, image 1 of 1
      Ask FixBot
    1. iPhone 7 Earpiece Speaker Replacement, Earpiece Speaker: step 23, image 1 of 1
      • Remove the three Phillips screws securing the earpiece bracket to the front panel:
      • Two 2.6 mm screws
      • One 1.7 mm screw
      Ask FixBot
    2. iPhone 7 Earpiece Speaker Replacement: step 24, image 1 of 1
      • Remove the earpiece speaker bracket.
      Ask FixBot
    3. iPhone 7 Earpiece Speaker Replacement: step 25, image 1 of 2 iPhone 7 Earpiece Speaker Replacement: step 25, image 2 of 2
      • Lift the front facing camera out of the way to access the earpiece speaker.
      Ask FixBot
    4. iPhone 7 Earpiece Speaker Replacement: step 26, image 1 of 1
      • Remove the two Phillips screws securing the earpiece speaker to the front panel:
      • One 1.9 mm screw
      • One 2.5 mm screw
      Ask FixBot
    5. iPhone 7 Earpiece Speaker Replacement: step 27, image 1 of 1
      • Remove the earpiece speaker.
      Ask FixBot
155 other people completed this guide.
Evan Noronha
229,664 Reputation
166 Guides authored
11 Guide Comments
how to remove sensor
Sharath kumar - Reply Share
I successfully replaced the earpiece but after completing everything the iphone stopped charging ,what could be the reason?
please help.
Thanks in advance:)
Rishabh Madaan - Reply Share
Check your battery cable. Make sure it is seated properly to the motherboard.
jiggy0215 - Reply Share
Hello,
instructions were great and easy to follow. I have managed to replace my ear speaker which i bought from your store, but the problem with distorted sound still exists.
Is there maybe some kind of failure on my motherboard on device or something else?
Luka Liker - Reply Share
Hi I have a question- what is the speaker attached to that is making it work? From the video it looks like it isn’t attached to any wires that connect to the rest of the phone, but maybe I am not looking closely. I am wondering because I broke the front camera ribbon and would like to know if that should affect my speaker?
Thanks
Sam Norton - Reply Share
Past 24 Hours: 2
Past 7 Days: 41
Past 30 Days: 243
All Time: 157,615
