iPhone 6s Speaker Replacement
    1. iPhone 6s Speaker Replacement, SIM Tray: step 1, image 1 of 2 iPhone 6s Speaker Replacement, SIM Tray: step 1, image 2 of 2
      • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
      • Press to eject the tray.
      • This may require a significant amount of force.
      Ask FixBot
    2. iPhone 6s Speaker Replacement: step 2, image 1 of 1
      • Remove the SIM Card tray assembly from the iPhone.
      • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
      Ask FixBot
    1. iPhone 6s Speaker Replacement, Pentalobe Screws: step 3, image 1 of 1
      • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.
      Ask FixBot
    1. iPhone 6s Speaker Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPhone 6s Speaker Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPhone 6s Speaker Replacement, Anti-Clamp instructions: step 4, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    2. iPhone 6s Speaker Replacement: step 5, image 1 of 3 iPhone 6s Speaker Replacement: step 5, image 2 of 3 iPhone 6s Speaker Replacement: step 5, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    1. iPhone 6s Speaker Replacement, Opening Procedure: step 6, image 1 of 1
      Clampy - Anti-Clamp
      $24.95
      Buy
      • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
      • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
      • Heat softens the adhesive securing the display, making it easier to open.
      Ask FixBot
    2. iPhone 6s Speaker Replacement: step 7, image 1 of 1
      • Opening the display on the 6s separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
      • Apply a suction cup to the lower left corner of the display assembly.
      • Take care not to place the suction cup over the home button.
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      Ask FixBot
    3. iPhone 6s Speaker Replacement: step 8, image 1 of 2 iPhone 6s Speaker Replacement: step 8, image 2 of 2
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
      • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
      • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
      • If you have any trouble, heat the front of the iPhone using an iOpener, hair dryer, or heat gun until it's slightly too hot to touch. This will help soften the adhesive securing the edges of the display.
      Ask FixBot
    4. iPhone 6s Speaker Replacement: step 9, image 1 of 2 iPhone 6s Speaker Replacement: step 9, image 2 of 2
      • There is a notch on the underside of the display, just above the headphone jack. This is the safest place to begin prying the phone open.
      • Place the flat edge of a spudger into the gap between the screen and rear case, directly above the headphone jack.
      Ask FixBot
    5. iPhone 6s Speaker Replacement: step 10, image 1 of 2 iPhone 6s Speaker Replacement: step 10, image 2 of 2
      • Twist the spudger to widen the gap between the front panel assembly and the rest of the phone.
      Ask FixBot
    6. iPhone 6s Speaker Replacement: step 11, image 1 of 2 iPhone 6s Speaker Replacement: step 11, image 2 of 2
      • Insert the flat end of the spudger on the left side of the phone, between the display assembly and rear case.
      • Slide the spudger up the side of the phone to separate the adhesive and pop the clips free.
      Ask FixBot
    7. iPhone 6s Speaker Replacement: step 12, image 1 of 2 iPhone 6s Speaker Replacement: step 12, image 2 of 2
      • Remove the spudger and reinsert it on the bottom edge, where you pried the phone open.
      • Slide the spudger to the right, along the bottom edge of the phone.
      Ask FixBot
    8. iPhone 6s Speaker Replacement: step 13, image 1 of 2 iPhone 6s Speaker Replacement: step 13, image 2 of 2
      • Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone.
      Ask FixBot
    9. iPhone 6s Speaker Replacement: step 14, image 1 of 2 iPhone 6s Speaker Replacement: step 14, image 2 of 2
      • Use the suction cup to open the display, breaking the last of the adhesive.
      • Don't open the display more than 90º, as it is still connected at the top by three cables that may break if stretched.
      Ask FixBot
    10. iPhone 6s Speaker Replacement: step 15, image 1 of 2 iPhone 6s Speaker Replacement: step 15, image 2 of 2
      • Pull up on the nub on the top side of the suction cup to remove it from the front panel.
      Ask FixBot
    11. iPhone 6s Speaker Replacement: step 16, image 1 of 3 iPhone 6s Speaker Replacement: step 16, image 2 of 3 iPhone 6s Speaker Replacement: step 16, image 3 of 3
      • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
      • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
      • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
      • In a pinch, you can use an unopened canned beverage to hold the display.
      • During reassembly, pause here if you wish to replace the adhesive around the edges of the display.
      • During reassembly, the camera end of the screen body needs to hook under the edge of the body. The hooks of the screen frame need to be under the rim of the main body and snugged toward the camera end to easily close the cover and have it properly clip.
      • These hooks are not really a proper hinge but clasps that need to be under the rim of the main phone frame/edge!! This way the screen easily will return to its closed state nicely gently snapping into place.
      • During reassembly, reverse order for getting the screen clipped back in means pressing along the right side top to bottom corner. Then the left.
      Ask FixBot
    1. iPhone 6s Speaker Replacement, Battery Connector: step 17, image 1 of 1
      Magnetic Project Mat
      $19.95
      Buy
      • Remove two Phillips screws securing the battery connector bracket, of the following lengths:
      • One 2.9 mm screw
      • One 2.2 mm screw
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      Ask FixBot
    2. iPhone 6s Speaker Replacement: step 18, image 1 of 2 iPhone 6s Speaker Replacement: step 18, image 2 of 2
      • Remove the battery connector bracket from the iPhone.
      Ask FixBot
    3. iPhone 6s Speaker Replacement: step 19, image 1 of 3 iPhone 6s Speaker Replacement: step 19, image 2 of 3 iPhone 6s Speaker Replacement: step 19, image 3 of 3
      • Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
      Ask FixBot
    4. iPhone 6s Speaker Replacement: step 20, image 1 of 2 iPhone 6s Speaker Replacement: step 20, image 2 of 2
      • Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
      Ask FixBot
    1. iPhone 6s Speaker Replacement, Unfasten the display cable bracket: step 21, image 1 of 1
      • Remove the following four Phillips screws securing the display cable bracket:
      • Three 1.2 mm screws
      • One 2.8 mm screw
      Ask FixBot
    2. iPhone 6s Speaker Replacement: step 22, image 1 of 2 iPhone 6s Speaker Replacement: step 22, image 2 of 2
      • Remove the display cable bracket.
      Ask FixBot
    3. iPhone 6s Speaker Replacement: step 23, image 1 of 2 iPhone 6s Speaker Replacement: step 23, image 2 of 2
      • Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board.
      Ask FixBot
    4. iPhone 6s Speaker Replacement: step 24, image 1 of 2 iPhone 6s Speaker Replacement: step 24, image 2 of 2
      • Disconnect the digitizer cable by prying it straight up from its socket on the logic board.
      • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
      Ask FixBot
    5. iPhone 6s Speaker Replacement: step 25, image 1 of 2 iPhone 6s Speaker Replacement: step 25, image 2 of 2
      • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
      • Disconnect the display cable by prying it straight up from its socket on the logic board.
      Ask FixBot
    6. iPhone 6s Speaker Replacement: step 26, image 1 of 1
      Ask FixBot
    1. iPhone 6s Speaker Replacement, Speaker: step 27, image 1 of 2 iPhone 6s Speaker Replacement, Speaker: step 27, image 2 of 2
      • Use the point of a spudger to lift and disconnect the antenna cable from the bottom end of the logic board.
      • To reconnect antenna cables like these to the socket, carefully align the connector to the socket, then use the flat end of a spudger to press down. It should click in place. If not, check for alignment. Do not use excessive force.
      Ask FixBot
    2. iPhone 6s Speaker Replacement: step 28, image 1 of 2 iPhone 6s Speaker Replacement: step 28, image 2 of 2
      • Use the point of a spudger to lift up and disconnect the Lightning connector ribbon cable from its socket on the logic board.
      Ask FixBot
    3. iPhone 6s Speaker Replacement: step 29, image 1 of 2 iPhone 6s Speaker Replacement: step 29, image 2 of 2
      • If you are following this guide to replace the Lightning connector, you can choose to keep the antenna cable connected and skip this step and the next one. Be very careful not to strain the delicate antenna cable when you move the loudspeaker around.
      • Use the point of a spudger to lift and disconnect the antenna cable from its socket near the top of the logic board.
      Ask FixBot
    4. iPhone 6s Speaker Replacement: step 30, image 1 of 3 iPhone 6s Speaker Replacement: step 30, image 2 of 3 iPhone 6s Speaker Replacement: step 30, image 3 of 3
      • Carefully lift the antenna cable and de-route it from the edge of the phone. Use the point of a spudger to help lift the cable to free it from the retaining clips.
      • If the cable does not have enough room to lift up, loosen this Phillips screw securing the logic board so that the board can give more wiggle room.
      • Be sure to re-tighten this screw during re-installation.
      • During re-installation, be sure to route the antenna cable underneath the logic board corner.
      • During re-installation, you can also re-insert the SIM card tray after re-routing the antenna cable.
      • If you feel any resistance, stop and make sure that the tray isn't snagging the antenna cable.
      Ask FixBot
    5. iPhone 6s Speaker Replacement: step 31, image 1 of 1
      • Remove the following Phillips screws securing the speaker to the rear case:
      • Two 2.6 mm screws
      • One 2.3 mm screw
      • This screw may be covered by some tape.
      • One 2.3 mm screw
      • This screw is different from the prior one. Be sure not to mix the two together.
      • One 3.0 mm screw
      Ask FixBot
    6. iPhone 6s Speaker Replacement: step 32, image 1 of 3 iPhone 6s Speaker Replacement: step 32, image 2 of 3 iPhone 6s Speaker Replacement: step 32, image 3 of 3
      • Insert the flat end of a spudger between the long edge of the speaker module and the case wall.
      • Pry gently to loosen the speaker module.
      • Once the module is loose, lift and remove the speaker module from the phone.
      Ask FixBot
    1. iPhone 6s Speaker Replacement, Wi-Fi Diversity Antenna: step 33, image 1 of 2 iPhone 6s Speaker Replacement, Wi-Fi Diversity Antenna: step 33, image 2 of 2
      • Remove the tape covering the antenna cable on the edge of the speaker.
      Ask FixBot
    2. iPhone 6s Speaker Replacement: step 34, image 1 of 2 iPhone 6s Speaker Replacement: step 34, image 2 of 2
      • Remove the cable clip from the left side of the speaker.
      Ask FixBot
    3. iPhone 6s Speaker Replacement: step 35, image 1 of 3 iPhone 6s Speaker Replacement: step 35, image 2 of 3 iPhone 6s Speaker Replacement: step 35, image 3 of 3
      • Prepare an iOpener and lay it over the antenna to soften the adhesive securing it to the speaker.
      • Use a plastic opening pick to break up the adhesive securing the antenna to the speaker.
      Ask FixBot
    4. iPhone 6s Speaker Replacement: step 36, image 1 of 1
      • Remove the antenna from the speaker.
      Ask FixBot
    1. iPhone 6s Speaker Replacement, Speaker: step 37, image 1 of 1
      • Only the speaker remains.
      Ask FixBot
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our iPhone 6s Answers community for troubleshooting help.
61 other people completed this guide.
Arthur Shi
350,917 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
10 Guide Comments
I did the steps right .. Thanks dude it was easy. but sadly the problem was not solved yet. My iPhone 6s has a loudspeaker issue I can play the sound with low sound volume only. I changed the loudspeaker but the sound still the same.
Thanks for you the top explanation
Ammoriz - Reply Share
Ammoriz, you should have cleaned out the speaker port with pressured air from the inside
canberk - Reply Share
Skip steps 16 to 34. Those steps are unnecessary and are added work. Make sure you prop up the front display securely.
benandem98 - Reply Share
The steps as posted in this guide are far too cumbersome. This fix is super easy.. here you go
1) Complete Steps 1-15 as shown
2) Scroll all.... the way down
3) Pick it back up at step 34-53 **before putting your new speaker back in, just give the ports a cleaning with a toothpick or the tweezers provided by iFixit.
Total time was maybe 30 mins.. It's easy no worries
norejko - Reply Share
Is iPhone 6 Speaker compatible with an iPhone 6S?
Manik Singh - Reply Share
Past 24 Hours: 7
Past 7 Days: 40
Past 30 Days: 163
All Time: 97,253
