iPhone 6s Plus Speaker Replacement
    1. iPhone 6s Plus Speaker Replacement, SIM Tray: step 1, image 1 of 2 iPhone 6s Plus Speaker Replacement, SIM Tray: step 1, image 2 of 2
      • Insert a SIM eject tool into the hole in the SIM tray.
      • Press to eject the SIM tray.
      Ask FixBot
    2. iPhone 6s Plus Speaker Replacement: step 2, image 1 of 1
      • Remove the SIM tray.
      • When reinserting the SIM tray, be sure to orient the tray such that the SIM eject hole is on the bottom.
      Ask FixBot
    1. iPhone 6s Plus Speaker Replacement, Pentalobe Screws: step 3, image 1 of 1
      • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
      Ask FixBot
    1. iPhone 6s Plus Speaker Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPhone 6s Plus Speaker Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPhone 6s Plus Speaker Replacement, Anti-Clamp instructions: step 4, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    2. iPhone 6s Plus Speaker Replacement: step 5, image 1 of 3 iPhone 6s Plus Speaker Replacement: step 5, image 2 of 3 iPhone 6s Plus Speaker Replacement: step 5, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    1. iPhone 6s Plus Speaker Replacement, Opening Procedure: step 6, image 1 of 1
      Clampy - Anti-Clamp
      $24.95
      Buy
      • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
      • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
      • Heat softens the adhesive securing the display, making it easier to open.
      Ask FixBot
    2. iPhone 6s Plus Speaker Replacement: step 7, image 1 of 1
      • Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
      • Apply a suction cup to the lower left corner of the display assembly.
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      Ask FixBot
    3. iPhone 6s Plus Speaker Replacement: step 8, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 8, image 2 of 2
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
      • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
      Ask FixBot
    4. iPhone 6s Plus Speaker Replacement: step 9, image 1 of 3 iPhone 6s Plus Speaker Replacement: step 9, image 2 of 3 iPhone 6s Plus Speaker Replacement: step 9, image 3 of 3
      • The safest place to pry from is the notch in the front panel above the headphone jack.
      • While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
      Ask FixBot
    5. iPhone 6s Plus Speaker Replacement: step 10, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 10, image 2 of 2
      • Twist the spudger to widen the gap between the front panel and the rear case.
      Ask FixBot
    6. iPhone 6s Plus Speaker Replacement: step 11, image 1 of 3 iPhone 6s Plus Speaker Replacement: step 11, image 2 of 3 iPhone 6s Plus Speaker Replacement: step 11, image 3 of 3
      • While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
      Ask FixBot
    7. iPhone 6s Plus Speaker Replacement: step 12, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 12, image 2 of 2
      • Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
      Ask FixBot
    8. iPhone 6s Plus Speaker Replacement: step 13, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 13, image 2 of 2
      • Insert the flat tip of the spudger under the right edge of the display.
      • Slide the spudger up the right side.
      Ask FixBot
    9. iPhone 6s Plus Speaker Replacement: step 14, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 14, image 2 of 2
      • Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
      • Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
      Ask FixBot
    10. iPhone 6s Plus Speaker Replacement: step 15, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 15, image 2 of 2
      • Pull up on the small nub on the suction cup to remove it from the display.
      Ask FixBot
    11. iPhone 6s Plus Speaker Replacement: step 16, image 1 of 3 iPhone 6s Plus Speaker Replacement: step 16, image 2 of 3 iPhone 6s Plus Speaker Replacement: step 16, image 3 of 3
      • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
      • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
      • Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
      • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
      • In a pinch, you can use an unopened canned beverage to support the display.
      Ask FixBot
    1. iPhone 6s Plus Speaker Replacement, Battery Connector: step 17, image 1 of 1
      Magnetic Project Mat
      $19.95
      Buy
      • Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
      • One 2.9 mm screw
      • One 2.3 mm screw
      • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
      Ask FixBot
    2. iPhone 6s Plus Speaker Replacement: step 18, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 18, image 2 of 2
      • Remove the battery connector bracket.
      Ask FixBot
    3. iPhone 6s Plus Speaker Replacement: step 19, image 1 of 3 iPhone 6s Plus Speaker Replacement: step 19, image 2 of 3 iPhone 6s Plus Speaker Replacement: step 19, image 3 of 3
      • Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
      Ask FixBot
    4. iPhone 6s Plus Speaker Replacement: step 20, image 1 of 3 iPhone 6s Plus Speaker Replacement: step 20, image 2 of 3 iPhone 6s Plus Speaker Replacement: step 20, image 3 of 3
      • Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
      Ask FixBot
    1. iPhone 6s Plus Speaker Replacement, Display Assembly: step 21, image 1 of 1
      • Remove the following Phillips screws:
      • Three 1.3 mm screws
      • One 1.6 mm screw
      • One 3.0 mm screw
      • During reassembly, it's critical to place this 3.0 mm screw in the top-right corner of the bracket. Placing it anywhere else may damage the logic board.
      Ask FixBot
    2. iPhone 6s Plus Speaker Replacement: step 22, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 22, image 2 of 2
      • Remove the display cable bracket.
      Ask FixBot
    3. iPhone 6s Plus Speaker Replacement: step 23, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 23, image 2 of 2
      • Be careful to only pry up on the connector itself and not the socket on the logic board.
      • Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
      Ask FixBot
    4. iPhone 6s Plus Speaker Replacement: step 24, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 24, image 2 of 2
      • Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board.
      • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
      Ask FixBot
    5. iPhone 6s Plus Speaker Replacement: step 25, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 25, image 2 of 2
      • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
      • Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
      Ask FixBot
    6. iPhone 6s Plus Speaker Replacement: step 26, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 26, image 2 of 2
      Ask FixBot
    1. iPhone 6s Plus Speaker Replacement, Speaker: step 27, image 1 of 2 iPhone 6s Plus Speaker Replacement, Speaker: step 27, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the antenna cable from the bottom of the logic board.
      Ask FixBot
    2. iPhone 6s Plus Speaker Replacement: step 28, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 28, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the Lightning connector cable from the logic board.
      Ask FixBot
    3. iPhone 6s Plus Speaker Replacement: step 29, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 29, image 2 of 2
      • Remove the three Phillips screws securing the Lightning connector bracket:
      • Two 3.5 mm screws
      • One 2.7 mm screw
      • Remove the bracket.
      Ask FixBot
    4. iPhone 6s Plus Speaker Replacement: step 30, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 30, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the antenna cable from the Lightning connector assembly.
      Ask FixBot
    5. iPhone 6s Plus Speaker Replacement: step 31, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 31, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the antenna cable from the top of the logic board.
      Ask FixBot
    6. iPhone 6s Plus Speaker Replacement: step 32, image 1 of 3 iPhone 6s Plus Speaker Replacement: step 32, image 2 of 3 iPhone 6s Plus Speaker Replacement: step 32, image 3 of 3
      • Carefully lift the antenna cable and de-route it from the edge of the phone. Use the point of a spudger to help lift the cable free it from the retaining clips.
      • If the cable does not have enough room to lift up, loosen this Phillips screw securing the logic board so that the board can give more wiggle room.
      • Be sure to re-tighten this screw during re-installation.
      • If the cable snags near the SIM reader, it's likely caught on the SIM tray ejection mechanism. Use the point of a spudger to slide the plastic rod out of the way.
      • During re-installation, be sure to route the antenna cable underneath the logic board corner.
      • During reassembly, you can also re-insert the SIM card tray after re-routing the antenna cable.
      • If you feel any resistance, stop and make sure that the tray isn't snagging the antenna cable.
      Ask FixBot
    7. iPhone 6s Plus Speaker Replacement: step 33, image 1 of 2 iPhone 6s Plus Speaker Replacement: step 33, image 2 of 2
      • Remove the six Phillips screws securing the speaker to the rear case:
      • One 2.5 mm screw
      • Two 2.7 mm screws
      • One 1.5 mm screw
      • One 1.7 mm screw
      • One 2.6 mm screw securing the speaker to the bottom edge of the rear case.
      Ask FixBot
    8. iPhone 6s Plus Speaker Replacement: step 34, image 1 of 3 iPhone 6s Plus Speaker Replacement: step 34, image 2 of 3 iPhone 6s Plus Speaker Replacement: step 34, image 3 of 3
      • Insert the flat end of a spudger between the long edge of the speaker module and the case wall.
      • Pry gently to loosen the speaker module.
      • Once the module is loose, lift and remove the speaker module and the attached antenna cable from the phone.
      Ask FixBot
    1. iPhone 6s Plus Speaker Replacement, Wi-Fi Diversity Antenna: step 35, image 1 of 3 iPhone 6s Plus Speaker Replacement, Wi-Fi Diversity Antenna: step 35, image 2 of 3 iPhone 6s Plus Speaker Replacement, Wi-Fi Diversity Antenna: step 35, image 3 of 3
      Buy
      • Use a pair of tweezers to begin peeling the antenna cables off of the speaker.
      Ask FixBot
    2. iPhone 6s Plus Speaker Replacement: step 36, image 1 of 3 iPhone 6s Plus Speaker Replacement: step 36, image 2 of 3 iPhone 6s Plus Speaker Replacement: step 36, image 3 of 3
      • Continue peeling the antenna cables off the long side of the speaker
      • At this point, the clip holding the antenna cables may fall off the speaker. If it does, be sure to keep track of it for reassembly.
      Ask FixBot
    3. iPhone 6s Plus Speaker Replacement: step 37, image 1 of 3 iPhone 6s Plus Speaker Replacement: step 37, image 2 of 3 iPhone 6s Plus Speaker Replacement: step 37, image 3 of 3
      • Use the flat end of a spudger to pry the Wi-Fi diversity antenna off the speaker.
      • Remove the antenna.
      Ask FixBot
    1. iPhone 6s Plus Speaker Replacement, Speaker: step 38, image 1 of 1
      • The speaker remains.
      Ask FixBot
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our iPhone 6s Plus Answers community for troubleshooting help.
37 other people completed this guide.
Arthur Shi
350,889 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
4 Guide Comments
It is possible to perform this repair without separating the display from the back, and without removing the logic board (which means you need not remove the camera, cellular antenna cabling, audio cabling, and other components). I carefully completed steps 1-15, 38-39, 50-52, and 54-60. It's also not necessary to disconnect the WiFi diversity cable from the logic board . This saves a lot of time and greatly reduces the risk of damaging delicate parts.
Mark Cousins - Reply Share
I second Mark's comment. In fact, if you are inexperienced with repairing small electronics, I highly advise against removing (or even touching) the logic board, as it is certainly the most expensive part, and among the most easily damaged.
Talon - Reply Share
Agree with the other commenters. It would be insane to perform all of these repair steps for just the loudspeaker. Press the back button in your browser and watch the Loudspeaker repair video, not this ridiculous guide. Or use this guide and after removing the display, skip to step 50. This is like taking the engine out of your car to change the wipers.
Peter G - Reply Share
This guide has been updated! Unnecessary steps have been trimmed.
Arthur Shi - Reply Share
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 153
All Time: 49,868
