Up to 20% off select tools
iPhone 6 Vibrator Replacement
Views: 68K
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
151
All Time:
68,368
Comments: 294
286 comments on steps, 8 guide comments.
Go to guide comments
Completed: 65
65 people have marked this guide "completed." Will you be next?
Favorites: 24
24 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes - 1 hour
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to restore silent alerts and replace a faulty vibrator in your iPhone 6.
This guide instructs you to detach the front panel assembly; this is intended to prevent damage to the display cables. If you feel comfortable supporting the display carefully while removing the vibrator motor from the iPhone, you can skip the display removal and go directly to the vibrator motor removal steps.
    1. iPhone 6 Vibrator Replacement, Pentalobe Screws: step 1, image 1 of 1
      • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
      Ask FixBot
    1. iPhone 6 Vibrator Replacement, Anti-Clamp instructions: step 2, image 1 of 3 iPhone 6 Vibrator Replacement, Anti-Clamp instructions: step 2, image 2 of 3 iPhone 6 Vibrator Replacement, Anti-Clamp instructions: step 2, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    2. iPhone 6 Vibrator Replacement: step 3, image 1 of 3 iPhone 6 Vibrator Replacement: step 3, image 2 of 3 iPhone 6 Vibrator Replacement: step 3, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    1. iPhone 6 Vibrator Replacement, Manual Opening Procedure: step 4, image 1 of 1
      Clampy - Anti-Clamp
      $24.95
      Buy
      • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
      • Press a suction cup onto the screen, just above the home button.
      • Be sure the cup is pressed securely onto the screen to get a tight seal.
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      Ask FixBot
    2. iPhone 6 Vibrator Replacement: step 5, image 1 of 1
      • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
      • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
      • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
      • There are several clips holding the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
      Ask FixBot
    3. iPhone 6 Vibrator Replacement: step 6, image 1 of 2 iPhone 6 Vibrator Replacement: step 6, image 2 of 2
      • Pull the plastic nub to release the vacuum seal on the suction cup.
      • Remove the suction cup from the display assembly.
      Ask FixBot
    4. iPhone 6 Vibrator Replacement, Opening up the phone: step 7, image 1 of 3 iPhone 6 Vibrator Replacement, Opening up the phone: step 7, image 2 of 3 iPhone 6 Vibrator Replacement, Opening up the phone: step 7, image 3 of 3
      • Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
      • Several clips along the top edge of the front panel form a partial hinge.
      • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
      Ask FixBot
    5. iPhone 6 Vibrator Replacement: step 8, image 1 of 3 iPhone 6 Vibrator Replacement: step 8, image 2 of 3 iPhone 6 Vibrator Replacement: step 8, image 3 of 3
      • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
      • In a pinch, an unopened canned beverage works well for this.
      • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
      Ask FixBot
    6. iPhone 6 Vibrator Replacement, Removing the battery connector bracket screws: step 9, image 1 of 1
      Magnetic Project Mat
      $16.96
      Buy
      • Remove the following Phillips screws from the battery connector bracket:
      • One 2.2 mm screw
      • One 3.2 mm screw
      • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
      Ask FixBot
    7. iPhone 6 Vibrator Replacement: step 10, image 1 of 1
      • Remove the metal battery connector bracket from the iPhone.
      Ask FixBot
    8. iPhone 6 Vibrator Replacement, Disconnecting the battery connector: step 11, image 1 of 1
      • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
      • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
      Ask FixBot
    9. iPhone 6 Vibrator Replacement, Removing the front panel assembly cable bracket screws: step 12, image 1 of 1
      • Remove the following five Phillips screws securing the front panel assembly cable bracket:
      • Three 1.2 mm screws
      • One 1.7 mm screw
      • One 3.1 mm screw
      • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
      Ask FixBot
    10. iPhone 6 Vibrator Replacement: step 13, image 1 of 1
      • Remove the front panel assembly cable bracket from the logic board.
      Ask FixBot
    11. iPhone 6 Vibrator Replacement: step 14, image 1 of 2 iPhone 6 Vibrator Replacement: step 14, image 2 of 2
      • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
      • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
      Ask FixBot
    12. iPhone 6 Vibrator Replacement: step 15, image 1 of 2 iPhone 6 Vibrator Replacement: step 15, image 2 of 2
      • Use a spudger or a fingernail to disconnect the home button cable connector.
      Ask FixBot
    13. iPhone 6 Vibrator Replacement: step 16, image 1 of 2 iPhone 6 Vibrator Replacement: step 16, image 2 of 2
      • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
      • Use a spudger or a fingernail to disconnect the display data cable connector.
      • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
      Ask FixBot
    14. iPhone 6 Vibrator Replacement: step 17, image 1 of 2 iPhone 6 Vibrator Replacement: step 17, image 2 of 2
      • Use the flat end of a spudger to disconnect the digitizer cable connector.
      • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
      Ask FixBot
    15. iPhone 6 Vibrator Replacement, Separating front panel assembly and rear case: step 18, image 1 of 1
      • Remove the front panel assembly from the rear case.
      Ask FixBot
    1. iPhone 6 Vibrator Replacement, Vibrator: step 19, image 1 of 1
      • Remove the two 1.6 mm Phillips #00 screws securing the vibrator to the rear case.
      Ask FixBot
    2. iPhone 6 Vibrator Replacement: step 20, image 1 of 2 iPhone 6 Vibrator Replacement: step 20, image 2 of 2
      • Remove the vibrator from the iPhone.
      Ask FixBot
65 other people completed this guide.
Author
with
Sam Goldheart
478,979 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
8 Guide Comments
Why do I need to remove the screen if the vibration device is in the open side of the iPhone ? Can't I just leave the screen connected and replace the vibrator ??
salpeme - Reply Share
You can certainly do that! We added a note to the introduction to make that more clear.
Jeff Suovanen - Reply Share
You know that feeds the vibrator voltage?
samuel vaquereno - Reply Share
Even with the battery off?
joeygates27 - Reply Share
I replaced my vibrator but its still not working correctly. It does vibrate but not fully if that makes sense. its like a slight vibrate rather than a strong one.. Ideas?
Todd - Reply Share
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 151
All Time: 68,368
