Up to 20% off select tools
iPhone 6 Plus SIM Card Replacement
Views: 27K
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
121
All Time:
27,165
Comments: 2
2 guide comments.
Go to guide comments
Completed: 35
35 people have marked this guide "completed." Will you be next?
Favorites: 12
12 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove or replace the SIM card in your iPhone 6 Plus.
    1. iPhone 6 Plus SIM Card Replacement, SIM Card: step 1, image 1 of 2 iPhone 6 Plus SIM Card Replacement, SIM Card: step 1, image 2 of 2
      • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
      • Press to eject the tray.
      • This may require a significant amount of force.
      Ask FixBot
    2. iPhone 6 Plus SIM Card Replacement: step 2, image 1 of 1
      • Remove the SIM Card tray assembly from the iPhone.
      • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
      Ask FixBot
35 other people completed this guide.
Author
with
Walter Galan
712,028 Reputation
1,203 Guides authored
2 Guide Comments
This granny jammed the SIM card into unlocked iPhone 6s + without the metal slide Is it possible to retrieve it?
Bee Ring - Reply Share
Hi Bee Ring! If you’re not having any luck shaking the phone to get it out, try inserting a piece of tape in to the slot, double-sided if possible, to try to grab the card, you can also try long thin tweezers. You might also take it down to your provider and see if they have any tricks. If it’s absolutely not coming out, you may need to open the phone, you can follow this SIM eject lever guide, you should need to remove the screen, just open it and look at step 21. You can try to push the SIM card out of the slot with a toothpick, you may need to remove that eject lever. Best of luck!
Sam Goldheart - Reply Share
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 121
All Time: 27,165
