iPhone 6 Antenna Flex Cable Replacement
    1. iPhone 6 Antenna Flex Cable Replacement, Pentalobe Screws: step 1, image 1 of 1
      • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
      Ask FixBot
    1. iPhone 6 Antenna Flex Cable Replacement, Anti-Clamp instructions: step 2, image 1 of 3 iPhone 6 Antenna Flex Cable Replacement, Anti-Clamp instructions: step 2, image 2 of 3 iPhone 6 Antenna Flex Cable Replacement, Anti-Clamp instructions: step 2, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    2. iPhone 6 Antenna Flex Cable Replacement: step 3, image 1 of 3 iPhone 6 Antenna Flex Cable Replacement: step 3, image 2 of 3 iPhone 6 Antenna Flex Cable Replacement: step 3, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    1. iPhone 6 Antenna Flex Cable Replacement, Manual Opening Procedure: step 4, image 1 of 1
      Clampy - Anti-Clamp
      $24.95
      Buy
      • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
      • Press a suction cup onto the screen, just above the home button.
      • Be sure the cup is pressed securely onto the screen to get a tight seal.
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      Ask FixBot
    2. iPhone 6 Antenna Flex Cable Replacement: step 5, image 1 of 1
      • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
      • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
      • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
      • There are several clips holding the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
      Ask FixBot
    3. iPhone 6 Antenna Flex Cable Replacement: step 6, image 1 of 2 iPhone 6 Antenna Flex Cable Replacement: step 6, image 2 of 2
      • Pull the plastic nub to release the vacuum seal on the suction cup.
      • Remove the suction cup from the display assembly.
      Ask FixBot
    4. iPhone 6 Antenna Flex Cable Replacement, Opening up the phone: step 7, image 1 of 3 iPhone 6 Antenna Flex Cable Replacement, Opening up the phone: step 7, image 2 of 3 iPhone 6 Antenna Flex Cable Replacement, Opening up the phone: step 7, image 3 of 3
      • Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
      • Several clips along the top edge of the front panel form a partial hinge.
      • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
      Ask FixBot
    5. iPhone 6 Antenna Flex Cable Replacement: step 8, image 1 of 3 iPhone 6 Antenna Flex Cable Replacement: step 8, image 2 of 3 iPhone 6 Antenna Flex Cable Replacement: step 8, image 3 of 3
      • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
      • In a pinch, an unopened canned beverage works well for this.
      • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
      Ask FixBot
    6. iPhone 6 Antenna Flex Cable Replacement, Removing the battery connector bracket screws: step 9, image 1 of 1
      Magnetic Project Mat
      $19.95
      Buy
      • Remove the following Phillips screws from the battery connector bracket:
      • One 2.2 mm screw
      • One 3.2 mm screw
      • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
      Ask FixBot
    7. iPhone 6 Antenna Flex Cable Replacement: step 10, image 1 of 1
      • Remove the metal battery connector bracket from the iPhone.
      Ask FixBot
    8. iPhone 6 Antenna Flex Cable Replacement, Disconnecting the battery connector: step 11, image 1 of 1
      • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
      • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
      Ask FixBot
    9. iPhone 6 Antenna Flex Cable Replacement, Removing the front panel assembly cable bracket screws: step 12, image 1 of 1
      • Remove the following five Phillips screws securing the front panel assembly cable bracket:
      • Three 1.2 mm screws
      • One 1.7 mm screw
      • One 3.1 mm screw
      • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
      Ask FixBot
    10. iPhone 6 Antenna Flex Cable Replacement: step 13, image 1 of 1
      • Remove the front panel assembly cable bracket from the logic board.
      Ask FixBot
    11. iPhone 6 Antenna Flex Cable Replacement: step 14, image 1 of 2 iPhone 6 Antenna Flex Cable Replacement: step 14, image 2 of 2
      • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
      • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
      Ask FixBot
    12. iPhone 6 Antenna Flex Cable Replacement: step 15, image 1 of 2 iPhone 6 Antenna Flex Cable Replacement: step 15, image 2 of 2
      • Use a spudger or a fingernail to disconnect the home button cable connector.
      Ask FixBot
    13. iPhone 6 Antenna Flex Cable Replacement: step 16, image 1 of 2 iPhone 6 Antenna Flex Cable Replacement: step 16, image 2 of 2
      • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
      • Use a spudger or a fingernail to disconnect the display data cable connector.
      • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
      Ask FixBot
    14. iPhone 6 Antenna Flex Cable Replacement: step 17, image 1 of 2 iPhone 6 Antenna Flex Cable Replacement: step 17, image 2 of 2
      • Use the flat end of a spudger to disconnect the digitizer cable connector.
      • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
      Ask FixBot
    15. iPhone 6 Antenna Flex Cable Replacement, Separating front panel assembly and rear case: step 18, image 1 of 1
      • Remove the front panel assembly from the rear case.
      Ask FixBot
    1. iPhone 6 Antenna Flex Cable Replacement, SIM Card: step 19, image 1 of 2 iPhone 6 Antenna Flex Cable Replacement, SIM Card: step 19, image 2 of 2
      • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
      • Press to eject the tray.
      • This may require a significant amount of force.
      Ask FixBot
    2. iPhone 6 Antenna Flex Cable Replacement: step 20, image 1 of 1
      • Remove the SIM card tray assembly from the iPhone.
      • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
      Ask FixBot
    1. iPhone 6 Antenna Flex Cable Replacement, Logic Board: step 21, image 1 of 2 iPhone 6 Antenna Flex Cable Replacement, Logic Board: step 21, image 2 of 2
      • Use the flat end of a spudger to disconnect the Lightning connector assembly cable and fold it out of the way of the speaker.
      Ask FixBot
    2. iPhone 6 Antenna Flex Cable Replacement: step 22, image 1 of 2 iPhone 6 Antenna Flex Cable Replacement: step 22, image 2 of 2
      • Use the point of a spudger to lift the antenna cable connector up off of its socket on the logic board.
      Ask FixBot
    3. iPhone 6 Antenna Flex Cable Replacement: step 23, image 1 of 1
      • Remove the following Phillips screws from the upper cable bracket:
      • One 2.9 mm screw
      • One 2.2 mm screw
      Ask FixBot
    4. iPhone 6 Antenna Flex Cable Replacement: step 24, image 1 of 2 iPhone 6 Antenna Flex Cable Replacement: step 24, image 2 of 2
      • Remove the upper cable bracket from the iPhone.
      Ask FixBot
    5. iPhone 6 Antenna Flex Cable Replacement: step 25, image 1 of 3 iPhone 6 Antenna Flex Cable Replacement: step 25, image 2 of 3 iPhone 6 Antenna Flex Cable Replacement: step 25, image 3 of 3
      • When disconnecting the following connectors, only pry up on the connector, not the socket on the logic board or you risk permanent damage.
      • Use the flat end of a spudger to lift the power button and flash assembly cable connector up off of its socket.
      • Lift the volume control cable connector up out of its socket on the logic board.
      Ask FixBot
    6. iPhone 6 Antenna Flex Cable Replacement: step 26, image 1 of 1
      • Remove the following four Phillips screws from the Wi-Fi antenna:
      • One 1.5 mm screw
      • One 1.4 mm screw
      • Two 2.1 mm screws
      Ask FixBot
    7. iPhone 6 Antenna Flex Cable Replacement: step 27, image 1 of 2 iPhone 6 Antenna Flex Cable Replacement: step 27, image 2 of 2
      Buy
      • Remove the Wi-Fi antenna from the iPhone.
      • Be careful not to touch any metal to metal contact points with your bare fingers—use tweezers or gloves. Finger oils may disrupt conductivity. If you do touch any of these components, clean them with a degreaser like windex or isopropyl alcohol before reassembly.
      Ask FixBot
    8. iPhone 6 Antenna Flex Cable Replacement: step 28, image 1 of 1
      • Remove the two 1.6 mm Phillips screws from the grounding bracket.
      Ask FixBot
    9. iPhone 6 Antenna Flex Cable Replacement: step 29, image 1 of 2 iPhone 6 Antenna Flex Cable Replacement: step 29, image 2 of 2
      • Remove the grounding bracket from the iPhone.
      Ask FixBot
    10. iPhone 6 Antenna Flex Cable Replacement: step 30, image 1 of 2 iPhone 6 Antenna Flex Cable Replacement: step 30, image 2 of 2
      • Remove the following Phillips screws securing the angled logic board bracket.
      • One 2.6 mm screw
      • One 1.3 mm screw, located horizontally in the upper sidewall of the iPhone.
      Ask FixBot
    11. iPhone 6 Antenna Flex Cable Replacement: step 31, image 1 of 2 iPhone 6 Antenna Flex Cable Replacement: step 31, image 2 of 2
      • Remove the angled logic board bracket.
      Ask FixBot
    12. iPhone 6 Antenna Flex Cable Replacement: step 32, image 1 of 1
      • Remove the single 1.2 mm Phillips screw securing the antenna interconnect cable to the logic board.
      Ask FixBot
    13. iPhone 6 Antenna Flex Cable Replacement: step 33, image 1 of 2 iPhone 6 Antenna Flex Cable Replacement: step 33, image 2 of 2
      • Use the point of a spudger to fold the antenna interconnect cable up out of the way of the logic board.
      Ask FixBot
    14. iPhone 6 Antenna Flex Cable Replacement: step 34, image 1 of 3 iPhone 6 Antenna Flex Cable Replacement: step 34, image 2 of 3 iPhone 6 Antenna Flex Cable Replacement: step 34, image 3 of 3
      • Use the flat end of a spudger to lift the camera cable connector straight up out of its socket on the logic board.
      • Be sure to only pry on the connector not the socket itself or you can cause permanent damage to the logic board.
      • Fold the camera cable up out of the way of the logic board.
      Ask FixBot
    15. iPhone 6 Antenna Flex Cable Replacement: step 35, image 1 of 1
      Standoff Screwdriver for iPhones
      $5.49
      Buy
      • Remove the following screws securing the logic board to the rear case:
      • Two 1.9 mm Phillips screws
      • One 2.3 mm standoff screw
      • Standoff screws are best removed using a standoff screwdriver or bit.
      • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
      Ask FixBot
    16. iPhone 6 Antenna Flex Cable Replacement: step 36, image 1 of 2 iPhone 6 Antenna Flex Cable Replacement: step 36, image 2 of 2
      • Use the flat end of a spudger to lift the battery connector end of the logic board up slightly, just enough to grab with your fingers.
      • Insert the spudger near the metal shields below the SIM card tray to avoid damaging any chips or sockets.
      Ask FixBot
    17. iPhone 6 Antenna Flex Cable Replacement: step 37, image 1 of 3 iPhone 6 Antenna Flex Cable Replacement: step 37, image 2 of 3 iPhone 6 Antenna Flex Cable Replacement: step 37, image 3 of 3
      • Lift the battery connector end of the logic board and pull it up and out of the rear case.
      • Be careful not to snag the logic board on any cables.
      Ask FixBot
    1. iPhone 6 Antenna Flex Cable Replacement, Antenna Flex Cable: step 38, image 1 of 2 iPhone 6 Antenna Flex Cable Replacement, Antenna Flex Cable: step 38, image 2 of 2
      Buy
      • Flip the logic board over to expose the antenna on the back side.
      • Disconnect the four coaxial connectors from the logic board and remove the antenna cable from the logic board.
      Ask FixBot
416 other people completed this guide.
Sam Goldheart
478,450 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
147 Guide Comments
Great tutorial. Gps, bluetooth and wifi working again 100% for less than 2 quid. Thanks
Andres - Reply Share
Great Guide, GPS Antenna and WIFI antenna replaced!!! a little sweat... but i did it
Miguel Cartagenova - Reply Share
Hi,
Where are the GPS antenna and the GPS chip please ?
Thks
ccTEST - Reply Share
This part and replacement guide saved my iPhone. I thought the phone was just getting old and on its way out since the bluetooth and gps were incredibly awful. Bluetooth only worked within direct line of sight within one foot, and gps had stopped working almost completely. It took some time to perform this repair, but I following the guide carefully and patiently fixed the problem completely. This part and guide worked perfectly. Thank you very much ifixit!
Joseph Engbert - Reply Share
EXCELLENT Instructions! 1:15 first time. Worked great, saved me the cost of a new phone. The "genius bar" said it couldn't be fixed, talk about self serving "you will have to buy a new phone!"
KEY GUIDANCE
0) Be careful when taking the front off, I snapped off one of two pieces near the lightening connector!
1) Print out the instructions (yes its a lot of pages, but trust me)
2) As you take off screws and pieces tape them to the instructions where they go
3) YOU will thank me later.
If I had not done this I think it would have been twice as long, and likely made mistakes and perhaps damaged something with the wrong length screw. I kept like screws together under one piece of tape, next to each color indicator.
rtotah67 - Reply Share
Past 24 Hours: 5
Past 7 Days: 47
Past 30 Days: 237
All Time: 366,467
