Up to 20% off select tools
iPhone 5s Screen Replacement
Views: 1M
View statistics:
Past 24 Hours:
37
Past 7 Days:
214
Past 30 Days:
994
All Time:
1,027,320
Comments: 597
516 comments on steps, 81 guide comments.
Go to guide comments
Completed: 1376
1376 people have marked this guide "completed." Will you be next?
Favorites: 544
544 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Learn how to replace your iPhone 5s screen. This part comes with the front-facing camera, earpiece speaker and sensor cable already installed, making for an easier repair.
All you need to do is remove the old screen and transfer the home button to the new screen in order for Touch ID (fingerprint scanning) to function.
Video Overview
    1. iPhone 5s Screen Replacement, Removing the Pentalobe screws: step 1, image 1 of 1
      • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.9 mm Pentalobe screws from either side of Lightning connector.
      Ask FixBot
    2. iPhone 5s Screen Replacement, Taping the display glass: step 2, image 1 of 3 iPhone 5s Screen Replacement, Taping the display glass: step 2, image 2 of 3 iPhone 5s Screen Replacement, Taping the display glass: step 2, image 3 of 3
      • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    3. iPhone 5s Screen Replacement, Display separation prevention: step 3, image 1 of 3 iPhone 5s Screen Replacement, Display separation prevention: step 3, image 2 of 3 iPhone 5s Screen Replacement, Display separation prevention: step 3, image 3 of 3
      • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
      • Regardless of the tool you use, you need to be sure you pull up the entire display.
      • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
      • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
      Ask FixBot
    4. iPhone 5s Screen Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPhone 5s Screen Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPhone 5s Screen Replacement, Anti-Clamp instructions: step 4, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use the included tape pad to create a grippier surface.
      Ask FixBot
    5. iPhone 5s Screen Replacement: step 5, image 1 of 3 iPhone 5s Screen Replacement: step 5, image 2 of 3 iPhone 5s Screen Replacement: step 5, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next two steps.
      Ask FixBot
    6. iPhone 5s Screen Replacement, Manual Opening Procedure: step 6, image 1 of 1
      • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
      • Press a suction cup onto the screen, just above the home button.
      • Be sure the cup is completely on the screen to get a tight seal.
      Ask FixBot
    7. iPhone 5s Screen Replacement, Start lifting the front panel assembly: step 7, image 1 of 1
      • The front panel is attached with clips, and there are several ribbon cables connecting it to the rest of the phone. Your goal here is to release the clips and open the phone only enough to disconnect the cables. Go slowly and carefully to avoid damage.
      • Make sure the suction cup is firmly attached to the front panel assembly near the home button.
      • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the home button end of the front panel from the rear case.
      • With a plastic opening tool, gently pry the edges of the rear case down, away from the front panel assembly, while you pull up with the suction cup.
      • Take your time and apply firm, constant force. The front panel assembly is a much tighter fit than on most other devices.
      Ask FixBot
    8. iPhone 5s Screen Replacement: step 8, image 1 of 2 iPhone 5s Screen Replacement: step 8, image 2 of 2
      • Do not try to completely remove the front panel assembly from the rear case, as there are several delicate ribbon cables connecting them.
      • Pull the plastic nub to release the vacuum seal on the suction cup.
      • Remove the suction cup from the screen.
      Ask FixBot
    9. iPhone 5s Screen Replacement, Removing the Touch ID cable bracket: step 9, image 1 of 3 iPhone 5s Screen Replacement, Removing the Touch ID cable bracket: step 9, image 2 of 3 iPhone 5s Screen Replacement, Removing the Touch ID cable bracket: step 9, image 3 of 3
      Buy
      • Open the phone just enough to reveal the metal bracket covering the home button cable.
      • Do not open the phone too far or you risk damaging the home button cable, or the socket it plugs into. Keep the cable loose—if it is stretched out, that's too far.
      • Only the phone's original home button assembly will be capable of using the Touch ID functionality. If you rip the cable, installing a new home button will only restore ordinary home button functions, not the Touch ID features.
      • Use the tip of a spudger to push the bracket free and remove it with tweezers.
      • The next two steps apply to reassembly. Skip them and continue to Step 12 until reassembly.
      Ask FixBot
    10. iPhone 5s Screen Replacement: step 10, image 1 of 2 iPhone 5s Screen Replacement: step 10, image 2 of 2
      • During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, in front of the metal tab. The bottom must latch down over the connector.
      • Slide the top of the bracket over the Touch ID cable connector from left to right.
      • Alternatively, lay the bracket directly over the connector. The edge with the "leg" will prop the bracket up at a slight angle, and the opposite edge must be between the cable connector and the metal tab near the battery. With the edge of a spudger flat against the bracket, apply gentle downward pressure to snap in the back and front clasps.
      Ask FixBot
    11. iPhone 5s Screen Replacement: step 11, image 1 of 2 iPhone 5s Screen Replacement: step 11, image 2 of 2
      • During reassembly, use the flat end of a spudger to snap the front portion of the Touch ID cable bracket down over the cable connector.
      • If the bracket does not snap down flush, you may need to remove the bracket and slide it over the cable connector again for a better fit.
      Ask FixBot
    12. iPhone 5s Screen Replacement, Disconnecting the home button cable connector: step 12, image 1 of 2 iPhone 5s Screen Replacement, Disconnecting the home button cable connector: step 12, image 2 of 2
      • Use the tip of a spudger to pry the home button cable connector up out of its socket.
      • Be sure you're separating the cable connector from its socket, and not prying the entire socket up. The socket is on its own glued-down cable that can be pried up if you aren't careful.
      Ask FixBot
    13. iPhone 5s Screen Replacement, Opening up the phone: step 13, image 1 of 3 iPhone 5s Screen Replacement, Opening up the phone: step 13, image 2 of 3 iPhone 5s Screen Replacement, Opening up the phone: step 13, image 3 of 3
      • Once the connector has been released, pull the home button end of the assembly away from the rear case, using the top of the phone as a hinge.
      • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
      • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
      • In a pinch, you can use an unopened canned beverage to hold the display.
      Ask FixBot
    14. iPhone 5s Screen Replacement: step 14, image 1 of 1
      • Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
      Ask FixBot
    15. iPhone 5s Screen Replacement: step 15, image 1 of 1
      • Remove the metal battery connector bracket from the iPhone.
      Ask FixBot
    16. iPhone 5s Screen Replacement: step 16, image 1 of 2 iPhone 5s Screen Replacement: step 16, image 2 of 2
      • Use the flat end of a spudger to gently pry the battery connector up from its socket on the logic board.
      • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
      Ask FixBot
    17. iPhone 5s Screen Replacement: step 17, image 1 of 1
      • Remove the following screws securing the front panel assembly cable bracket to the logic board:
      • One 1.7 mm Phillips #000 screw
      • One 1.2 mm Phillips #000 screw
      • One 1.3 mm Phillips #000 screw
      • One more 1.7 mm Phillips #000 screw
      • This 1.7 mm screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing.
      • It is especially important to keep track of your screws in this step for reassembly. Accidentally using the 1.3 mm screw or one of the 1.7 mm screws in the bottom right hole will result in significant damage to the logic board causing the phone to no longer boot properly.
      • Be careful not to over-tighten the screws, and don't force them. If they don't fit easily when you are securing them, they may be the wrong size.
      Ask FixBot
    18. iPhone 5s Screen Replacement: step 18, image 1 of 1
      • Remove the front panel assembly cable bracket from the logic board.
      Ask FixBot
    19. iPhone 5s Screen Replacement: step 19, image 1 of 2 iPhone 5s Screen Replacement: step 19, image 2 of 2
      • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable.
      Ask FixBot
    20. iPhone 5s Screen Replacement: step 20, image 1 of 2 iPhone 5s Screen Replacement: step 20, image 2 of 2
      • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
      • Disconnect the LCD cable connector.
      • When reassembling your phone, the LCD cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
      Ask FixBot
    21. iPhone 5s Screen Replacement: step 21, image 1 of 2 iPhone 5s Screen Replacement: step 21, image 2 of 2
      • Finally, disconnect the digitizer cable connector.
      Ask FixBot
    22. iPhone 5s Screen Replacement: step 22, image 1 of 1
      • Remove the front panel assembly from the rear case.
      Ask FixBot
    1. iPhone 5s Screen Replacement, Home Button Assembly: step 23, image 1 of 2 iPhone 5s Screen Replacement, Home Button Assembly: step 23, image 2 of 2
      • Unscrew the single captive Phillips #000 screw securing the home button cable.
      • The captive screw is fastened to the home button cable by a spring contact backing. During reassembly, ensure the contact is in the correct orientation—on the side of the screw nearest the LCD.
      • If your replacement part does not have this captive screw and spring contact, you will need to transfer them to the new cable.
      Ask FixBot
    2. iPhone 5s Screen Replacement: step 24, image 1 of 2 iPhone 5s Screen Replacement: step 24, image 2 of 2
      • Fold the home button cable down, out of the way of the home button bracket.
      Ask FixBot
    3. iPhone 5s Screen Replacement: step 25, image 1 of 1
      • Remove the two 1.4 mm Phillips #000 screws from the home button bracket.
      Ask FixBot
    4. iPhone 5s Screen Replacement: step 26, image 1 of 1
      • Remove the home button bracket from the display assembly.
      Ask FixBot
    5. iPhone 5s Screen Replacement: step 27, image 1 of 2 iPhone 5s Screen Replacement: step 27, image 2 of 2
      • Wedge the the tip of a spudger underneath the home button cable assembly.
      • The home button cable is affixed by mild adhesive.
      • Gently work the spudger underneath the cable to separate the home button cable from the front panel assembly.
      • Do not remove the home button yet, as it is still attached to the front panel assembly.
      Ask FixBot
    6. iPhone 5s Screen Replacement: step 28, image 1 of 2 iPhone 5s Screen Replacement: step 28, image 2 of 2
      • If necessary, remove the tape over the home button on the front side of your cracked front panel assembly.
      • Gently push the top left corner of the home button up away from the front panel.
      • Do not push the home button all the way through—you only need to get a corner free, so that you can pry it free with a spudger.
      • This membrane is very thin. If you feel like you're going to tear the button, apply heat and try again.
      Ask FixBot
    7. iPhone 5s Screen Replacement: step 29, image 1 of 2 iPhone 5s Screen Replacement: step 29, image 2 of 2
      • Peel the home button the rest of the way off of the display by prying gently with a spudger.
      Ask FixBot
    8. iPhone 5s Screen Replacement: step 30, image 1 of 1
      • Remove the home button assembly from the front panel.
      Ask FixBot
    1. iPhone 5s Screen Replacement, Screen: step 31, image 1 of 1
      • The screen remains.
      • If your replacement screen is missing any components that are still on the assembly you just removed, follow this guide to transfer them to the new part.
      • If your replacement screen came with any protective plastic films that you don't see on the original display, be sure to peel them off before beginning reassembly.
      Ask FixBot
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing. Take your e-waste to an R2 or e-Stewards certified recycler. Repair didn't go as planned? Check out our Answers community for troubleshooting help.
1376 other people completed this guide.
Author
with
Walter Galan
712,028 Reputation
1,203 Guides authored
81 Guide Comments
Excellent guide, many thanks to the author and commenters. I replaced the rear facing camera at the same time and had no issues with parts or tools.
Agree with the comment from Nathan for Step 17 to be careful not to displace the captive spring, it would have slipped away from me if I had not read the comment. Tricky to manouvere that part.
Get the magnetic mat, makes things a lot easier. Thanks again.
Matt - Reply Share
It would be helpful if the guide used tools that were listed as required when purchasing the replacement screen. When I ordered the screen, the site suggested the iopener, which i purchased. It was not involved in the repair though the iclack tool was referenced.
lkboak - Reply Share
Hi, i have problem with my earpiece speaker after i reassemble my screen, it doesn't work and i should talk with the speaker, why it happen and what should i do???
Tanks.
Ali Sakhtianchi - Reply Share
This same thing happened to me. I had to take the front camera/sensor assembly out of my old device and use it with the new display assembly. Thankfully that part wasn't damaged or I would have been screwed.
Jorden - Reply Share
I think ifixit have miss-drawn the screws for the LCD Plate. I believe the two motherboard (lower/bottom) screws should be the short ones, and the "red screws" should go at the top. Only the bottom 2 go into the PCB, the others go into pillars. Please can someone check this. As putting the 1.7mm in the Bottom Left Corner is a bad idea. it should be the 1.3mmm
russ - Reply Share
Past 24 Hours: 37
Past 7 Days: 214
Past 30 Days: 994
All Time: 1,027,320
