iPhone 5s Front Facing Camera and Sensor Cable Replacement
    1. iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Removing the Pentalobe screws: step 1, image 1 of 1
      • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.9 mm Pentalobe screws from either side of Lightning connector.
      Ask FixBot
    2. iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Taping the display glass: step 2, image 1 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Taping the display glass: step 2, image 2 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Taping the display glass: step 2, image 3 of 3
      • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    3. iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Display separation prevention: step 3, image 1 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Display separation prevention: step 3, image 2 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Display separation prevention: step 3, image 3 of 3
      • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
      • Regardless of the tool you use, you need to be sure you pull up the entire display.
      • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
      • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
      Ask FixBot
    4. iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Anti-Clamp instructions: step 4, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use the included tape pad to create a grippier surface.
      Ask FixBot
    5. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 5, image 1 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 5, image 2 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 5, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next two steps.
      Ask FixBot
    6. iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Manual Opening Procedure: step 6, image 1 of 1
      • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
      • Press a suction cup onto the screen, just above the home button.
      • Be sure the cup is completely on the screen to get a tight seal.
      Ask FixBot
    7. iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Start lifting the front panel assembly: step 7, image 1 of 1
      • The front panel is attached with clips, and there are several ribbon cables connecting it to the rest of the phone. Your goal here is to release the clips and open the phone only enough to disconnect the cables. Go slowly and carefully to avoid damage.
      • Make sure the suction cup is firmly attached to the front panel assembly near the home button.
      • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the home button end of the front panel from the rear case.
      • With a plastic opening tool, gently pry the edges of the rear case down, away from the front panel assembly, while you pull up with the suction cup.
      • Take your time and apply firm, constant force. The front panel assembly is a much tighter fit than on most other devices.
      Ask FixBot
    8. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 8, image 1 of 2 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 8, image 2 of 2
      • Do not try to completely remove the front panel assembly from the rear case, as there are several delicate ribbon cables connecting them.
      • Pull the plastic nub to release the vacuum seal on the suction cup.
      • Remove the suction cup from the screen.
      Ask FixBot
    9. iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Removing the Touch ID cable bracket: step 9, image 1 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Removing the Touch ID cable bracket: step 9, image 2 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Removing the Touch ID cable bracket: step 9, image 3 of 3
      Buy
      • Open the phone just enough to reveal the metal bracket covering the home button cable.
      • Do not open the phone too far or you risk damaging the home button cable, or the socket it plugs into. Keep the cable loose—if it is stretched out, that's too far.
      • Only the phone's original home button assembly will be capable of using the Touch ID functionality. If you rip the cable, installing a new home button will only restore ordinary home button functions, not the Touch ID features.
      • Use the tip of a spudger to push the bracket free and remove it with tweezers.
      • The next two steps apply to reassembly. Skip them and continue to Step 12 until reassembly.
      Ask FixBot
    10. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 10, image 1 of 2 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 10, image 2 of 2
      • During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, in front of the metal tab. The bottom must latch down over the connector.
      • Slide the top of the bracket over the Touch ID cable connector from left to right.
      • Alternatively, lay the bracket directly over the connector. The edge with the "leg" will prop the bracket up at a slight angle, and the opposite edge must be between the cable connector and the metal tab near the battery. With the edge of a spudger flat against the bracket, apply gentle downward pressure to snap in the back and front clasps.
      Ask FixBot
    11. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 11, image 1 of 2 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 11, image 2 of 2
      • During reassembly, use the flat end of a spudger to snap the front portion of the Touch ID cable bracket down over the cable connector.
      • If the bracket does not snap down flush, you may need to remove the bracket and slide it over the cable connector again for a better fit.
      Ask FixBot
    12. iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Disconnecting the home button cable connector: step 12, image 1 of 2 iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Disconnecting the home button cable connector: step 12, image 2 of 2
      • Use the tip of a spudger to pry the home button cable connector up out of its socket.
      • Be sure you're separating the cable connector from its socket, and not prying the entire socket up. The socket is on its own glued-down cable that can be pried up if you aren't careful.
      Ask FixBot
    13. iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Opening up the phone: step 13, image 1 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Opening up the phone: step 13, image 2 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Opening up the phone: step 13, image 3 of 3
      • Once the connector has been released, pull the home button end of the assembly away from the rear case, using the top of the phone as a hinge.
      • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
      • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
      • In a pinch, you can use an unopened canned beverage to hold the display.
      Ask FixBot
    14. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 14, image 1 of 1
      • Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
      Ask FixBot
    15. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 15, image 1 of 1
      • Remove the metal battery connector bracket from the iPhone.
      Ask FixBot
    16. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 16, image 1 of 2 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 16, image 2 of 2
      • Use the flat end of a spudger to gently pry the battery connector up from its socket on the logic board.
      • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
      Ask FixBot
    17. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 17, image 1 of 1
      • Remove the following screws securing the front panel assembly cable bracket to the logic board:
      • One 1.7 mm Phillips #000 screw
      • One 1.2 mm Phillips #000 screw
      • One 1.3 mm Phillips #000 screw
      • One more 1.7 mm Phillips #000 screw
      • This 1.7 mm screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing.
      • It is especially important to keep track of your screws in this step for reassembly. Accidentally using the 1.3 mm screw or one of the 1.7 mm screws in the bottom right hole will result in significant damage to the logic board causing the phone to no longer boot properly.
      • Be careful not to over-tighten the screws, and don't force them. If they don't fit easily when you are securing them, they may be the wrong size.
      Ask FixBot
    18. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 18, image 1 of 1
      • Remove the front panel assembly cable bracket from the logic board.
      Ask FixBot
    19. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 19, image 1 of 2 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 19, image 2 of 2
      • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable.
      Ask FixBot
    20. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 20, image 1 of 2 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 20, image 2 of 2
      • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
      • Disconnect the LCD cable connector.
      • When reassembling your phone, the LCD cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
      Ask FixBot
    21. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 21, image 1 of 2 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 21, image 2 of 2
      • Finally, disconnect the digitizer cable connector.
      Ask FixBot
    22. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 22, image 1 of 1
      • Remove the front panel assembly from the rear case.
      Ask FixBot
    1. iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Earpiece Speaker: step 23, image 1 of 1
      • Remove the two screws securing the upper component bracket:
      • 4.0 mm Phillips #000
      • 2.3 mm Phillips #000
      • It is imperative that the right screws are inserted into their respective holes. Otherwise it may cause severe damage to the LCD during reassembly.
      Ask FixBot
    2. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 24, image 1 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 24, image 2 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 24, image 3 of 3
      Buy
      • Orient the phone as shown, with the home button on top and the earpiece speaker on bottom.
      • Gently dislodge the clip, near the bottom left corner of the earpiece speaker bracket, outwards from its recess on the front panel assembly.
      • Do not pry with excessive force, as the earpiece speaker bracket is fragile and malleable.
      • With a set of tweezers, shift the bracket to the left to unclip it.
      Ask FixBot
    3. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 25, image 1 of 1
      • Remove the bracket from the display.
      Ask FixBot
    4. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 26, image 1 of 2 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 26, image 2 of 2
      • Remove the earpiece speaker with a set of tweezers.
      • If you use your fingers, be very careful not to touch the gold contacts on the front panel. Finger oil can prevent good contact.
      Ask FixBot
    5. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 27, image 1 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 27, image 2 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 27, image 3 of 3
      • To replace the earpiece speaker, it is easiest to install the speaker and bracket together:
      • Place the earpiece speaker bracket over the speaker so that it fits snugly in its housing.
      • Slide the left hook of the bracket into the notch above the top left corner of the front facing camera.
      • Rotate the bracket so it lays flat on the rear case, aligning the two screw holes. Press the bracket into place, ensuring the hook on the right side of the metal bracket latches onto the display.
      Ask FixBot
    1. iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Front Facing Camera and Sensor Cable Assembly: step 28, image 1 of 1
      iOpener
      $24.95
      Buy
      • This step requires removing the front facing camera and sensor cable from your front panel assembly.
      • The front facing camera and sensor cable is adhered to the display assembly with mild adhesive.
      • Using an iOpener to soften the adhesive will help safely remove it. Follow our iOpener instructions to use it.
      Ask FixBot
    2. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 29, image 1 of 2 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 29, image 2 of 2
      Buy
      • Using the edge of a set of tweezers or a metal spudger, gently pry the earpiece speaker contact cable up, to separate this portion of the camera and sensor cable from the adhesive below.
      • Only pry directly under the earpiece speaker contacts—there are sensors and microchips that can be damaged by prying elsewhere.
      Ask FixBot
    3. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 30, image 1 of 2 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 30, image 2 of 2
      • Use the point of a spudger to lift the ambient light sensor and proximity sensor out of their recess in the display assembly.
      • There is a small, square plastic and metal holder for the proximity sensor. This holder is essential for the proximity sensor to function correctly.
      • If replacing the proximity sensor make sure that the holder remains adhered to the back of the display. If it comes off with the old proximity sensor, remove it from the old sensor and use a tiny bit of adhesive to re-attach it to the back of the display.
      Ask FixBot
    4. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 31, image 1 of 2 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 31, image 2 of 2
      • Use the flat end of a spudger to gently peel the front-facing camera portion of the cable away from the display assembly.
      Ask FixBot
    5. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 32, image 1 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 32, image 2 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 32, image 3 of 3
      • If you are reattaching the same shield plate to a new display, there is no need to peel the cable assembly off the LCD shield plate. Skip this step.
      • Carefully peel the cable assembly off of the LCD shield plate to remove it from the display.
      • Be careful not to grab the digitizer cable while peeling up the front facing camera and sensor assembly cable.
      Ask FixBot
    1. iPhone 5s Front Facing Camera and Sensor Cable  Replacement, Front Facing Camera and Sensor Cable: step 33, image 1 of 1
      • Remove any plastic coverings from the microphone on the sensor cable assembly.
      Ask FixBot
    2. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 34, image 1 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 34, image 2 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 34, image 3 of 3
      • Remove any clear backing strips from the light sensor, cable and front-facing camera.
      Ask FixBot
    3. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 35, image 1 of 2 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 35, image 2 of 2
      Buy
      • In order to ensure a good fit and proper placement of components, make sure your new cable assembly matches the one that came out of your iPhone.
      • You may need to use a set of tweezers to fold the microphone portion of the cable so that the gold portion is inside the cable, and the silver unit is on top.
      Ask FixBot
    4. iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 36, image 1 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 36, image 2 of 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: step 36, image 3 of 3
      • If your replacement sensor cable has an extra tab, you'll need to carefully cut it off. You won't need this tab—it's used for parts testing.
      • Use scissors to cut the cable right below the yellow plastic tabs.
      Ask FixBot
157 other people completed this guide.
Sam Goldheart
478,447 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
21 Guide Comments
I'm confused as to what you attach the top part in the last picture, the part with yellow or orange on it? Does that connect to the grounding sticker portion? And how is that removed originally, just by pulling it off?
Machek Koziol - Reply Share
How do you attached the copper grounding shield to the new proximity flex ribbon?
I can't find a video showing that anywhere
jlh - Reply Share
I have to second Machek Kozoil's question. What do you do with the yellow contacts? I can get the proximity sensor to work but not the camera. I assume it has to do with these yellow contacts. Any ideas? If anyone knows I will make a youtube video explaining this for others as I haven'y found one yet. In the link below I have included a picture of the factory part on top and replacement part on bottom.
http://i.imgur.com/qAfmnls.jpg
lanekrarup - Reply Share
As someone has suggested, it is probably a part used in manufacturing process. The original part doesn't have it, and it seems to be cut off. And that is exactly what I did, and everything works. There is nowhere to attach it anyway so instead of folding it and trying to fit it in, you might as well just cut it off.
Stifmeister - Reply Share
This is not a good guide. iFixit have been very lazy on the final, critical points regarding the EMI shielding. Without correct shielding the screen will wobble or the camera/proximity sensors will fail.
Ryan Richardson - Reply Share
Past 24 Hours: 6
Past 7 Days: 56
Past 30 Days: 251
All Time: 241,700
