Up to 20% off select tools
iPhone 4S Rear Panel Replacement
Views: 267K
View statistics:
Past 24 Hours:
13
Past 7 Days:
56
Past 30 Days:
309
All Time:
267,130
Comments: 58
43 comments on steps, 15 guide comments.
Go to guide comments
Completed: 814
814 people have marked this guide "completed." Will you be next?
Favorites: 312
312 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Remove the rear panel to access the internal components of your iPhone.
    1. iPhone 4S Rear Panel Replacement, Rear Panel: step 1, image 1 of 1
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.6 mm Pentalobe P2 screws next to the dock connector.
      • Be sure the driver is well-seated when removing Pentalobe screws—they are easy to strip.
      Ask FixBot
    2. iPhone 4S Rear Panel Replacement: step 2, image 1 of 2 iPhone 4S Rear Panel Replacement: step 2, image 2 of 2
      • Push the rear panel toward the top edge of the iPhone.
      • The panel will move about 2 mm.
      Ask FixBot
    3. iPhone 4S Rear Panel Replacement: step 3, image 1 of 1
      • Pull the rear panel away from the back of the iPhone, being careful not to damage the plastic clips attached to the rear panel.
      • Remove the rear panel from the iPhone.
      Ask FixBot
814 other people completed this guide.
Author
with
Walter Galan
712,028 Reputation
1,203 Guides authored
15 Guide Comments
If you have trouble removing the back after sliding it, do not force or pry it. You didn't push it far enough. Gently push it further and it will come off easily!
Stephen Foskett - Reply Share
On the iPhone 4S Mirrored Rear Panel there was a clear plastic covering on the INSIDE side of the Panel that covers a jagged black area. There is also a small plastic covering over the camera lens, also on the inside side of the Panel. The iFixIt step-by-step instructions do not include any information about whether to remove these or leave them. I chose to peel them off and it appears everything works okay. But there probably should have been a mention about what to do with these "stickers."
jlinder1 - Reply Share
Thanks! I didn't notice the scuff covers until we noticed the poor quality of the photos. After I took the back off and removed the film covers, the photos are back to the original quality. Thanks again for your comment. The covers should have an obvious tab on them for easy removal
David Bergum - Reply Share
www.partoflaptop.com/iphone-4s-repair-parts_iphone-4s-rear-panel-replacement.html
li ma - Reply Share
there are many kinds of iphone 4s rear panel from this site:
li ma - Reply Share
Past 24 Hours: 13
Past 7 Days: 56
Past 30 Days: 309
All Time: 267,130
