Up to 20% off select tools
iPhone 4S Battery Replacement
Views: 27K
View statistics:
Past 24 Hours:
13
Past 7 Days:
40
Past 30 Days:
227
All Time:
26,991
Comments: 8
7 comments on steps, 1 guide comment.
Go to guide comments
Completed: 64
64 people have marked this guide "completed." Will you be next?
Favorites: 17
17 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Request Guide Deletion
This guide will be reviewed by admins for deletion.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Community-Contributed Guide
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
This guide consists of instructions on how to replace the battery in an iPhone 4S.
    1. iPhone 4S Battery Replacement, Pentalobe Screws: step 1, image 1 of 1
      • Remove the two bottom Pentalobe screws next to the 30-Pin connector.
      • It is recommended that you use a small 5-Point screwdriver for this process.
      • Remember to make sure your iPhone is fully turned off before commencing this process, to prevent serious injury to the phone.
      Ask FixBot
    2. iPhone 4S Battery Replacement, Back Panel Removal: step 2, image 1 of 2 iPhone 4S Battery Replacement, Back Panel Removal: step 2, image 2 of 2
      • Push the back panel towards the top of the iPhone. Doing this should allow the back panel to slide off safely.
      • Do not apply too much pressure to the back. Especially if your phone has a cracked back panel.
      • Do not rush it! Time is key.
      Ask FixBot
    3. iPhone 4S Battery Replacement, Battery Screws: step 3, image 1 of 1
      • Remove these two screws that are securing the battery connector to the Logic Board.
      • Beware of unscrewing the battery connector, as your screwdriver does have the possibility to slip and pierce the battery.
      • For the bottom screws, it is recommended that you use a 1.5 mm screw bit, and a 1.7 mm for the top screw.
      Ask FixBot
    4. iPhone 4S Battery Replacement, Battery Strip: step 4, image 1 of 1
      • Locate and pull the plastic tab to pull out the battery. Make sure to pry up on the outside of the battery on all sides.
      • Do not pull on the plastic tab too hard, as it can easily rip, making the battery removal process harder.
      Ask FixBot
    5. iPhone 4S Battery Replacement, Battery Removal: step 5, image 1 of 1
      • Carefully remove the battery.
      • Remember, if you are replacing your battery, remember to preform a hard reset on your iPhone by holding on both the home and power button for a few seconds once the repair is all finished.
      Ask FixBot
64 other people completed this guide.
Author
with
Cole Anello
2,070 Reputation
1 Guide authored
1 Guide Comment
la olum bunu benim 1 yaşında kızım da biliyo
ahmetceylanbm - Reply Share
Past 24 Hours: 13
Past 7 Days: 40
Past 30 Days: 227
All Time: 26,991
