Parts
Tools
Introduction
Go to step 1 ↓This guide is for replacing the metal portion of the volume buttons, not the electronic switches.
Power off your iPhone before beginning disassembly.
Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board.
Use the clear plastic pull tab to gently lift the battery out of the iPhone.
If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
Before reconnecting the battery connector, be sure the contact clip (shown in red) is properly positioned next to the battery connector.
Tool used on this step:Tweezers$4.99
Use a pair of tweezers to remove the small strip of tape covering the back of the volume buttons.
87 other people completed this guide.
Attached Documents
1 Guide Comment
The attached PDF document for the screw is very well thought out. Thank you for your hard work,
