Parts
Tools
Introduction
Go to step 1 ↓Use this guide to replace the metallic outer power button on your iPhone.
Power off your iPhone before beginning disassembly.
Your phone's rear cover may have two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws. Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
Remove the single 1.5 mm Phillips screw securing the battery connector to the logic board (if present).
Pull up on the exposed clear plastic tab to peel the battery off the adhesive securing it to the iPhone.
If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
Remove the battery.
Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
Remove the two 1.8 mm Phillips screws securing the dock connector cable to the logic board.
Remove the thin metal dock connector cable cover.
Remove the following five screws:
Three 1.3 mm Phillips screws
One 1.5 mm Phillips screw
One 2.4 mm Phillips screw
Disconnect the five cables near the top of the logic board in the following order:
Headphone jack/volume button cable
Power button cable
Front facing camera cable
Digitizer cable
Display data cable
To disconnect the cables, use the edge of a plastic opening tool to gently lift their connectors up and out of the sockets on the logic board.
Remove the two 2.0 mm Phillips screws securing the power button bracket to the outer case.
Slightly pull the power button bracket away from the outer case.
74 other people completed this guide.
6 Guide Comments
Hello! New to this comment section and love it compared to the YouTube videos that always seem to have the wrong phone... I have a Verizon CDMA iPhone 4 (not 4s). I'm having a problem with the power button. I have changed the ribbon and the button still won't click. I have checked the ribbon button with a pointed screwdriver and it clicks like it should. For example, if I did not put the metal/physical button back into the phone, it would see that I could just poke something inside to turn on and off. Is there a "spring" to the physical button? Do I have something missing? The button seems as it is in the diagrams and I wonder if the wire on the bottom of the button is supposed to provide a springing of some sort...to allow for it to "stay tall" and away from the bubble button on the ribbon. Then when the physical button is pushed it will go down and activate or push the ribbon button, and then click or spring back up. Am I missing something here? Tks GANDL2123@gmail.com
"the outward edges should be on top"... what? I have the iphone 4 Verizon and I've followed the instructions to the letter. I have installed the power button with the metal wire thing down towards the screen...the button slides in nicely and I have replaced the new ribbon cable with the copper button on it new and when I test the copper button on the cable itself it does click...but when installed I can't get the button to spring in and out and click like it is supposed to. What am I doing wrong...? Tks to gandL2123@gmail.com. Augusta, GA
