Up to 20% off select tools
iPhone 4 Contact Clip Replacement
Views: 87K
View statistics:
Past 24 Hours:
3
Past 7 Days:
32
Past 30 Days:
153
All Time:
86,864
Comments: 23
21 comments on steps, 2 guide comments.
Go to guide comments
Completed: 93
93 people have marked this guide "completed." Will you be next?
Favorites: 201
201 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
    1. iPhone 4 Contact Clip Replacement, Rear Panel: step 1, image 1 of 2 iPhone 4 Contact Clip Replacement, Rear Panel: step 1, image 2 of 2
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
      • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
      • Be sure the driver is well seated when removing Pentalobe screws, they are very easy to strip.
      Ask FixBot
    2. iPhone 4 Contact Clip Replacement: step 2, image 1 of 2 iPhone 4 Contact Clip Replacement: step 2, image 2 of 2
      • Push the rear panel toward the top edge of the iPhone.
      • The panel will move about 2 mm.
      Ask FixBot
    3. iPhone 4 Contact Clip Replacement: step 3, image 1 of 1
      • Pinch the rear panel with your fingers and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
      • Be careful not to damage the plastic clips attached to the rear panel.
      • If you are installing a new rear panel, be sure to remove the plastic protective sticker from the inside of the camera lens and the sticker from the large black area near the lens.
      Ask FixBot
    1. iPhone 4 Contact Clip Replacement, Contact Clip: step 4, image 1 of 1
      • Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board.
      Ask FixBot
    2. iPhone 4 Contact Clip Replacement: step 5, image 1 of 3 iPhone 4 Contact Clip Replacement: step 5, image 2 of 3 iPhone 4 Contact Clip Replacement: step 5, image 3 of 3
      • Use an iPod opening tool to carefully pry the battery connector up from the ends closest to the top and bottom edges of the iPhone.
      • Do not pry against the contact clip.
      • Remove the contact clip from the iPhone.
      • Before reconnecting the battery connector, be sure the pressure contact (shown in red) is properly positioned next to the battery connector.
      • Before reassembly, be sure to clean all metal-to-metal contact points on the pressure contact as well as its contact point on the rear panel with a de-greaser such as windex. The oils on your fingers have the potential to cause wireless interference issues.
      Ask FixBot
93 other people completed this guide.
Attached Documents
Author
with
Scott Head
53,724 Reputation
7 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
2 Guide Comments
need a job as assistant with the author ...i am a 16 year old kid who loved being with iphones ..i can do a all kind of software problems in iphones and ipads....please reply.sir
mac - Reply Share
Mwea ko battery ka connector chayan
Lalita Kumar - Reply Share
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 153
All Time: 86,864
