Up to 20% off select tools
iPhone 3G Logic Board Replacement
Views: 205K
View statistics:
Past 24 Hours:
10
Past 7 Days:
31
Past 30 Days:
159
All Time:
205,183
Comments: 13
8 comments on steps, 5 guide comments.
Go to guide comments
Completed: 102
102 people have marked this guide "completed." Will you be next?
Favorites: 93
93 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The logic board of your iPhone controls everything in the iPhone.
    1. iPhone 3G Logic Board Replacement, Broken Glass: step 1, image 1 of 3 iPhone 3G Logic Board Replacement, Broken Glass: step 1, image 2 of 3 iPhone 3G Logic Board Replacement, Broken Glass: step 1, image 3 of 3
      • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    1. iPhone 3G Logic Board Replacement, Logic Board: step 2, image 1 of 1
      • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
      Ask FixBot
    2. iPhone 3G Logic Board Replacement: step 3, image 1 of 1
      • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
      • Be very careful when opening the iPhone so that the cables under the display are not severed.
      • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
      • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
      • If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape, or thick, clear packing tape may be used.
      Ask FixBot
    3. iPhone 3G Logic Board Replacement: step 4, image 1 of 1
      • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
      • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
      Ask FixBot
    4. iPhone 3G Logic Board Replacement: step 5, image 1 of 1
      • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
      Ask FixBot
    5. iPhone 3G Logic Board Replacement: step 6, image 1 of 1
      • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
      • Use a spudger to disconnect the black ribbon cable labeled "2."
      Ask FixBot
    6. iPhone 3G Logic Board Replacement: step 7, image 1 of 1
      • Use a spudger to flip up the white plastic tab holding the remaining ribbon cable in place. The white tab will rotate up 90 degrees, releasing the ribbon cable.
      • Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone.
      Ask FixBot
    7. iPhone 3G Logic Board Replacement: step 8, image 1 of 1
      • Insert your SIM eject tool or a paper clip into the hole next to the headphone jack.
      • Press down on the tool until the SIM card tray pops out.
      • Grasp the SIM card tray and slide it out of the iPhone.
      Ask FixBot
    8. iPhone 3G Logic Board Replacement: step 9, image 1 of 1
      • Use a spudger to disconnect the ribbon cable labeled "4."
      Ask FixBot
    9. iPhone 3G Logic Board Replacement: step 10, image 1 of 1
      • Use a spudger to disconnect the ribbon cable labeled "5."
      Ask FixBot
    10. iPhone 3G Logic Board Replacement: step 11, image 1 of 2 iPhone 3G Logic Board Replacement: step 11, image 2 of 2
      • Use a spudger to disconnect the ribbon cable labeled "6."
      • If you have an iPhone 3GS, refer to picture 2 and use a spudger to disconnect the ribbon cable labeled "7."
      Ask FixBot
    11. iPhone 3G Logic Board Replacement: step 12, image 1 of 1
      • Carefully peel up the small sticker labeled "Do not remove."
      Ask FixBot
    12. iPhone 3G Logic Board Replacement: step 13, image 1 of 1
      • Remove the following 8 screws:
      • Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear panel.
      • Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
      • One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
      Ask FixBot
    13. iPhone 3G Logic Board Replacement: step 14, image 1 of 1
      • Use a spudger to gently remove the camera retaining clip, (formerly secured by the removed screw) and gently pry the camera up and out of its housing in the rear panel. The camera cannot be removed entirely yet because it's connected to the bottom of the logic board.
      Ask FixBot
    14. iPhone 3G Logic Board Replacement: step 15, image 1 of 1
      • Use a spudger to gently pry up the end of the logic board closest to the dock connector.
      • If the board won't lift up, double check to make sure all the screws securing the logic board have been removed.
      Ask FixBot
    15. iPhone 3G Logic Board Replacement: step 16, image 1 of 1
      • Slide the logic board towards the dock connector and out of the iPhone.
      Ask FixBot
    16. iPhone 3G Logic Board Replacement: step 17, image 1 of 1
      • Use a spudger to disconnect the camera from the logic board.
      Ask FixBot
102 other people completed this guide.
Author
with
iRobot
1 Reputation
632 Guides authored
5 Guide Comments
Step 6: When I attempted to 'rotate the white connector 90 degrees' my white connector broke into 4 pieces... my phone is now beyond my repair. I feel soo dumb. I should have used a pair of eyebrow tweezers (two flat blades that press together) to wiggle the #3 ribbon cable in/out of the connector instead of trying to pivot it.
Anyone know how to repair this? Drop me a line at quathiaski(at)gmail.com
Dayna - Reply Share
I have found out why I broke my connector all to heck... I attacked the wrong end with my plastic prodder. Work on the BLACK end... it moves...not the white end.
Dayna - Reply Share
Hi Dayna, How are you today.
You are not dumb, you is learning.
Have a nice day :)
Jose - Reply Share
Where Can I buy a Iphone 3g replacement Logic Board?
Akomedias - Reply Share
Wow… I don't know!!
You have to search for used parts in marketplace like eBay and so on.
It's the only way I know, I'm sorry.
Mauro Macniaco - Reply Share
Past 24 Hours: 10
Past 7 Days: 31
Past 30 Days: 159
All Time: 205,183
