Up to 20% off select tools
iPhone 3G Front Panel Assembly Replacement
Views: 255K
View statistics:
Past 24 Hours:
9
Past 7 Days:
28
Past 30 Days:
121
All Time:
254,736
Comments: 117
116 comments on steps, 1 guide comment.
Go to guide comments
Completed: 185
185 people have marked this guide "completed." Will you be next?
Favorites: 114
114 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 2 hours
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
The front panel assembly, including the digitizer, ear speaker, and home button, can be replaced on the iPhone 3G.
Video Overview
    1. iPhone 3G Front Panel Assembly Replacement, Broken Glass: step 1, image 1 of 3 iPhone 3G Front Panel Assembly Replacement, Broken Glass: step 1, image 2 of 3 iPhone 3G Front Panel Assembly Replacement, Broken Glass: step 1, image 3 of 3
      • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    1. iPhone 3G Front Panel Assembly Replacement, Display: step 2, image 1 of 1
      • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
      • Make sure to keep all the screws organized as you are taking the phone apart. They are different sizes.
      Ask FixBot
    2. iPhone 3G Front Panel Assembly Replacement: step 3, image 1 of 1
      • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
      • Be very careful when opening the iPhone so that the cables under the display are not severed.
      • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
      • Use a small suction cup near the Home button to gently pull up the lower portion of the iPhone's display assembly.
      • If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape may be used.
      Ask FixBot
    3. iPhone 3G Front Panel Assembly Replacement: step 4, image 1 of 1
      • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
      • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
      Ask FixBot
    4. iPhone 3G Front Panel Assembly Replacement: step 5, image 1 of 1
      • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
      • Ribbon cable "1" is connected with a plug style connector. The block at the end of the cable is the plug which is simply pushed into a socket on the circuit board. No other locking mechanism is used.
      Ask FixBot
    5. iPhone 3G Front Panel Assembly Replacement: step 6, image 1 of 1
      • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
      • Use a spudger to disconnect the black ribbon cable labeled "2."
      Ask FixBot
    6. iPhone 3G Front Panel Assembly Replacement: step 7, image 1 of 2 iPhone 3G Front Panel Assembly Replacement: step 7, image 2 of 2
      • Ribbon cable "3" is held in place by a FPC style connector. You must unlock this connector before sliding the ribbon cable out. The locking mechanism is on the opposite side of where the cable is inserted - it swivels upwards 90 degrees. Use a plastic spudger to lift the locking mechanism.
      • The FPC locking latch is very delicate and is typically a different color than the body of the connector. (see the detail image of FPC connector open and closed)
      • Slide the ribbon cable out of the connector, and remove the display assembly from the iPhone.
      • It's impossible to properly reinsert a ribbon into an FPC connector unless the lock is disengaged. Make sure the locking latch is open when attaching/detaching the cable.
      Ask FixBot
    7. iPhone 3G Front Panel Assembly Replacement: step 8, image 1 of 1
      • Remove the single Phillips #00 screw from the corner of the display assembly.
      Ask FixBot
    8. iPhone 3G Front Panel Assembly Replacement: step 9, image 1 of 1
      • Remove the two Phillips #00 screws from the right side of the display assembly.
      Ask FixBot
    9. iPhone 3G Front Panel Assembly Replacement: step 10, image 1 of 1
      • Turn the display around, and if there is a thin strip of black tape on the edge of the display assembly, carefully peel it up.
      • Keeping the tape from sticking to itself can be tricky. We recommend placing the tape on a wax-coated piece of paper (any sticker backing will do).
      Ask FixBot
    10. iPhone 3G Front Panel Assembly Replacement: step 11, image 1 of 1
      • Remove the three Phillips #00 screws from the left side of the display assembly.
      Ask FixBot
    11. iPhone 3G Front Panel Assembly Replacement: step 12, image 1 of 1
      • Turn the display assembly over and again carefully insert a metal spudger between the two metal rails along the edge of the display assembly. Gently rotate the spudger to lift the LCD up from the glass.
      Ask FixBot
    12. iPhone 3G Front Panel Assembly Replacement: step 13, image 1 of 1
      • Separate the LCD and glass by sliding the LCD panel away from the ribbon cables on the glass.
      Ask FixBot
    1. iPhone 3G Front Panel Assembly Replacement, Front Panel Assembly: step 14, image 1 of 1
      • Front Panel Assembly remains.
      Ask FixBot
Finish Line
185 other people completed this guide.
Author
with
1 Guide Comment
Be very careful opening the display. On my phone, connector #4 was stuck to the inside surface of the display. The display was difficult to open and released suddenly. Although the display didn't open as far as shown in picture #2, and certainly less than shown in picture #3, when it released, it tore connector #4 completely away from the dock connector assembly. So, in addition to needing a new display assembly to fix a broken home button, I now need to replace the dock connector as well.
Randall Roman - Reply Share
Past 24 Hours: 9
Past 7 Days: 28
Past 30 Days: 121
All Time: 254,736
