Introduction
Go to step 1 ↓Want to replace or take out the camera? Here's how.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Ribbon cable "3" is held in place by an FPC style connector. Unlocking this connector is a must before removing the ribbon cable: use a plastic spudger to flip up the white plastic tab holding the remaining ribbon cable in place. The white tab will rotate up 90 degrees, releasing the ribbon cable.
Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone.
65 other people completed this guide.
1 Guide Comment
Thanks for an awesome guide. On mine after getting it reassembled the camera had a green screen. The cable for the camera got slightly disconnected while putting things back together. I'm thinking because the one I got the ribbon was kinda stiff and straight when it had to fold to go back in properly it came slightly unplugged. I just squashed around the camera corner of the case pinching it, of course not to hard, and it came up and works perfectly now. Thanks again, my friend sold me this iphone cheap cause the camera was broke. Thanks to you its good as new.
