Up to 20% off select tools
iPhone 1st Generation Battery Replacement
Views: 405K
View statistics:
Past 24 Hours:
23
Past 7 Days:
115
Past 30 Days:
686
All Time:
405,222
Comments: 63
60 comments on steps, 3 guide comments.
Go to guide comments
Completed: 152
152 people have marked this guide "completed." Will you be next?
Favorites: 104
104 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 55 minutes - 1 hour
Difficulty: Very difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Battery not lasting long? Swap it out (requires soldering).
    1. iPhone 1st Generation Battery Replacement, SIM Card: step 1, image 1 of 1
      • Insert a SIM card eject tool or paper clip into the hole next to the headphone jack.
      • Press down on the paper clip until the SIM card tray pops out.
      Ask FixBot
    2. iPhone 1st Generation Battery Replacement: step 2, image 1 of 1
      • Grasp the SIM card tray and slide it out of the iPhone.
      Ask FixBot
    1. iPhone 1st Generation Battery Replacement, Antenna Cover: step 3, image 1 of 1
      • This image shows the two tabs and two catches located on the underside of the antenna cover. The two tabs at the top of the image must be pushed towards the black cover to release them.
      Ask FixBot
    2. iPhone 1st Generation Battery Replacement: step 4, image 1 of 1
      • Be sure to slide the metal spudger between the dock connector and the antenna cover, and not into the dock connector itself.
      • Insert a metal spudger into the slot between the dock connector and the antenna cover. Gently pry up near the two tabs to create a small gap between the antenna cover and the silver front bezel.
      Ask FixBot
    3. iPhone 1st Generation Battery Replacement: step 5, image 1 of 1
      • Insert an iPod opening tool in the gap between the antenna cover and the front bezel. The wedge of the tool should be pointing towards the antenna cover. Slide the tool around the corner and up until you reach the metal backing.
      • Repeat the same procedure on the other side of the dock connector.
      Ask FixBot
    4. iPhone 1st Generation Battery Replacement: step 6, image 1 of 1
      • Grasp the antenna cover on either side and slide it up and away from the iPhone. This requires some force. If it does not come free, ensure that the antenna cover is lifted up enough to free the catches.
      Ask FixBot
    1. iPhone 1st Generation Battery Replacement, Case: step 7, image 1 of 1
      • Remove the three Phillips #00 screws securing the rear panel to the iPhone.
      Ask FixBot
    2. iPhone 1st Generation Battery Replacement: step 8, image 1 of 1
      • Getting the iPhone open is a challenging feat, so don't get discouraged. Take a deep breath and make sure you have plenty of time to get the job done.
      • The small square hole is the location to insert the dental pick in the next step.
      Ask FixBot
    3. iPhone 1st Generation Battery Replacement: step 9, image 1 of 1
      • Start removing the rear panel on the side with the buttons.
      • Slide the dental pick completely into the square hole. You may need to wiggle the tool and apply a good amount of force to get it to go all the way.
      Ask FixBot
    4. iPhone 1st Generation Battery Replacement: step 10, image 1 of 1
      • Pry up the rear panel by pulling the dental pick counterclockwise in a quick motion. Apply force perpendicular to the plane of the display assembly. You may be afraid to go fast, but going slowly is more likely to bend the case.
      Ask FixBot
    5. iPhone 1st Generation Battery Replacement: step 11, image 1 of 1
      • Use a spudger to free the rear panel from the iPhone along the corner and top.
      Ask FixBot
    6. iPhone 1st Generation Battery Replacement: step 12, image 1 of 1
      • Repeat the same procedure on the other side of the iPhone. Slide the dental pick completely into the square hole. You may need to wiggle the tool and apply a good amount of force to get it to go all the way.
      Ask FixBot
    7. iPhone 1st Generation Battery Replacement: step 13, image 1 of 1
      • Pry up the rear panel by pulling the dental pick clockwise in a quick motion. Apply force perpendicular to the plane of the display assembly. You may be afraid to go fast, but going slowly is more likely to bend the case.
      • The rear panel is still attached to the iPhone by the headphone jack cable, so don't entirely remove the rear panel from the iPhone just yet.
      Ask FixBot
    8. iPhone 1st Generation Battery Replacement: step 14, image 1 of 1
      • Make sure the phone is off before disconnecting the headphone jack cable.
      • Use a spudger to disconnect the headphone jack cable from the logic board.
      Ask FixBot
    1. iPhone 1st Generation Battery Replacement, Battery: step 15, image 1 of 1
      • Use the tip of a spudger to remove the cloudy white glue covering the battery contacts.
      • To reduce the risk of shorting the red battery lead to the metal shield, you can first remove the glue from the black and white battery leads. After desoldering the black and white leads, then remove the glue and desolder the red lead.
      Ask FixBot
    2. iPhone 1st Generation Battery Replacement: step 16, image 1 of 1
      • Working from the edge opposite the battery connectors, insert a spudger between the battery and the plastic frame and pry up. The battery is attached to the casing with an adhesive, but should slowly come free.
      • If the battery isn't coming free, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery.
      • Wait about one minute for the alcohol solution to weaken the adhesive.
      • Use the flat end of a spudger to gently lift the battery.
      • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
      • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before continuing.
      Ask FixBot
    3. iPhone 1st Generation Battery Replacement: step 17, image 1 of 1
      • If you have never soldered before, we have a guide that makes it easy to learn. We suggest brushing up before proceeding.
      • We're now ready to begin the soldering process. You'll need a soldering iron, solder, and desoldering wick. You should be able to find these items at a Radio Shack if you don't already have them.
      • Clean the solding iron by melting a small amount of solder directly onto the soldering iron's tip and then wiping the tip of the soldering iron on a damp sponge.
      Ask FixBot
    4. iPhone 1st Generation Battery Replacement: step 18, image 1 of 1
      • Place the desoldering wick on top of the existing solder ball.
      • Place the soldering iron on top of wick above the existing solder ball.
      • Hold the soldering iron in place until the solder melts into the wick.
      • Repeat the same procedure on the remaining two connectors.
      • Lift the old battery out of the iPhone. Be sure that all the solder has been removed before pulling the wires away from the board. The wires should come free with little to no resistance.
      Ask FixBot
    5. iPhone 1st Generation Battery Replacement: step 19, image 1 of 1
      • We recommend that you clean the exposed surface of the board with a soft cloth or sponge and a small amount of rubbing alcohol.
      • Melt a small solder bead directly onto the metal connector on the board by placing the soldering iron onto the metal connector and then pressing solder against the tip and the board.
      • Once a small amount of solder has melted onto the board, lift the solder away first and then the soldering iron.
      Ask FixBot
    6. iPhone 1st Generation Battery Replacement: step 20, image 1 of 1
      • The solder bead should look like a small dome or hemisphere. If it is flat or jagged, simply place the soldering iron back on the solder to re-melt it and then pull the soldering iron away. It may require a little more solder if this does not work.
      Ask FixBot
    7. iPhone 1st Generation Battery Replacement: step 21, image 1 of 1
      • Attach the red lead first, followed by the white lead, and finish with the black lead.
      • Place the wire from the new battery onto the new solder bead.
      • Press the tip of the soldering iron onto the solder bead until it melts.
      • Slide the wire lead into the liquid solder until it is in the center of the bead, then remove the soldering iron.
      • Continue with the other two connections the same way, taking special care not to solder two of the connectors together.
      Ask FixBot
152 other people completed this guide.
Author
with
iRobot
1 Reputation
632 Guides authored
3 Guide Comments
Where can I source an iPhone 2g battery in 2018?
Adrian Ledesma - Reply Share
Click on the button on the top of this page that says, “iPhone Gen 1 Replacement Battery available for sale on eBay”
Anthony Guerrero - Reply Share
Right, I’ll go do that real quick /s
Furbland Channel 2 - Reply Share
Past 24 Hours: 23
Past 7 Days: 115
Past 30 Days: 686
All Time: 405,222
