Up to 20% off select tools
iPhone 16 Screen Replacement
Views: 59K
View statistics:
Past 24 Hours:
107
Past 7 Days:
787
Past 30 Days:
3,518
All Time:
58,763
Comments: 34
31 comments on steps, 3 guide comments.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
  • iPhone 16 Screen
    4.6
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a broken, cracked, or non‑responsive screen in your iPhone 16.
You'll need replacement screen adhesive to complete this repair.
Note: Since you can't disconnect the battery during this repair, be especially careful not to use metal prying tools or touch exposed contacts in your iPhone.
After your repair, calibrate an original Apple display using Repair Assistant.
    1. iPhone 16 Screen Replacement, Before you begin: step 1, image 1 of 2 iPhone 16 Screen Replacement, Before you begin: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Ask FixBot
    2. iPhone 16 Screen Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 16 Screen Replacement, Tape over any cracks: step 2, image 2 of 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    3. iPhone 16 Screen Replacement, Remove the pentalobe screws: step 3, image 1 of 2 iPhone 16 Screen Replacement, Remove the pentalobe screws: step 3, image 2 of 2
      • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 16 Screen Replacement, Mark your opening picks: step 4, image 1 of 3 iPhone 16 Screen Replacement, Mark your opening picks: step 4, image 2 of 3 iPhone 16 Screen Replacement, Mark your opening picks: step 4, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 16 Screen Replacement, Screen information: step 5, image 1 of 2 iPhone 16 Screen Replacement, Screen information: step 5, image 2 of 2
      • To avoid damaging your screen in the next steps, note the following:
      • There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll separate the two.
      • Sometimes the display panel separates from the bezel before you even get a chance to insert a pick. This may be unavoidable depending on the condition of the adhesive.
      Ask FixBot
    2. iPhone 16 Screen Replacement, Heat the bottom edge: step 6, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
      Ask FixBot
    3. iPhone 16 Screen Replacement, Insert an opening pick: step 7, image 1 of 3 iPhone 16 Screen Replacement, Insert an opening pick: step 7, image 2 of 3 iPhone 16 Screen Replacement, Insert an opening pick: step 7, image 3 of 3
      • Apply a suction handle to the bottom edge of the screen.
      • While supporting the frame with one hand, pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    4. iPhone 16 Screen Replacement, Screen information: step 8, image 1 of 2 iPhone 16 Screen Replacement, Screen information: step 8, image 2 of 2
      • As you slice the adhesive securing the screen in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
      • Two delicate cables connecting the screen to the phone—one just above the Action button and the other about halfway between the volume down button and the bottom of the phone.
      • Multiple spring contacts around the perimeter of the phone.
      Ask FixBot
    5. iPhone 16 Screen Replacement, Heat the right edge: step 9, image 1 of 1
      • Use a hair dryer or heat gun to heat the right edge of the screen until it's hot to the touch.
      Ask FixBot
    6. iPhone 16 Screen Replacement, Separate the right adhesive: step 10, image 1 of 3 iPhone 16 Screen Replacement, Separate the right adhesive: step 10, image 2 of 3 iPhone 16 Screen Replacement, Separate the right adhesive: step 10, image 3 of 3
      • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
      • Slide your opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive and release the metal clip.
      • You'll hear and feel the metal clip release as you pass it.
      Ask FixBot
    7. iPhone 16 Screen Replacement, Heat the top edge: step 11, image 1 of 1
      • Use a hair dryer or heat gun to heat the top edge of the screen until it's hot to the touch.
      Ask FixBot
    8. iPhone 16 Screen Replacement, Separate the top adhesive: step 12, image 1 of 2 iPhone 16 Screen Replacement, Separate the top adhesive: step 12, image 2 of 2
      • Continue sliding your pick around the top right corner and across the top edge to separate the adhesive and release the two metal clips.
      Ask FixBot
    9. iPhone 16 Screen Replacement, Heat the left edge: step 13, image 1 of 1
      • Use a hair dryer or heat gun to heat the left edge of the screen until it's hot to the touch.
      Ask FixBot
    10. iPhone 16 Screen Replacement, Separate the left adhesive: step 14, image 1 of 2 iPhone 16 Screen Replacement, Separate the left adhesive: step 14, image 2 of 2
      • Don't insert your pick deeper than 3 mm to avoid damaging the screen cables and the spring contacts.
      • Slide the opening pick down the left edge of the screen to separate the remaining adhesive and release the last two metal clips.
      Ask FixBot
    11. iPhone 16 Screen Replacement, Prop up the screen: step 15, image 1 of 3 iPhone 16 Screen Replacement, Prop up the screen: step 15, image 2 of 3 iPhone 16 Screen Replacement, Prop up the screen: step 15, image 3 of 3
      • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
      • Swing open the screen over the left edge of the phone and support it with a clean, sturdy object.
      Ask FixBot
    12. iPhone 16 Screen Replacement, Remove the connector covers: step 16, image 1 of 2 iPhone 16 Screen Replacement, Remove the connector covers: step 16, image 2 of 2
      • Use a tri-point Y000 driver to remove the two 0.9 mm‑long screws securing the front sensor and screen connector covers.
      Ask FixBot
    13. iPhone 16 Screen Replacement: step 17, image 1 of 2 iPhone 16 Screen Replacement: step 17, image 2 of 2
      • Use tweezers, or your fingers, to lift the front sensor cover to a 90-degree angle and unhook it from its slot in the logic board.
      • Lift the cover out of its slot and remove it.
      Ask FixBot
    14. iPhone 16 Screen Replacement: step 18, image 1 of 2 iPhone 16 Screen Replacement: step 18, image 2 of 2
      • Use tweezers, or your fingers, to lift the screen connector cover at a slight angle to unhook it from its slot in the logic board.
      Ask FixBot
    15. iPhone 16 Screen Replacement, Disconnect the screen: step 19, image 1 of 3 iPhone 16 Screen Replacement, Disconnect the screen: step 19, image 2 of 3 iPhone 16 Screen Replacement, Disconnect the screen: step 19, image 3 of 3
      • Use the tip of a spudger to pry up and disconnect the screen press connector.
      • Repeat for the front sensor press connector.
      Ask FixBot
    16. iPhone 16 Screen Replacement, Remove the screen: step 20, image 1 of 1
      • Lift the screen off the frame and remove it.
      Ask FixBot
    17. iPhone 16 Screen Replacement, Remove the ambient light sensor bracket: step 21, image 1 of 3 iPhone 16 Screen Replacement, Remove the ambient light sensor bracket: step 21, image 2 of 3 iPhone 16 Screen Replacement, Remove the ambient light sensor bracket: step 21, image 3 of 3
      • Use a Phillips screwdriver to remove the 1.3 mm‑long screw securing the ambient light sensor bracket.
      • Use a pair of tweezers or your fingers to lift and remove the ambient light sensor bracket.
      Ask FixBot
    18. iPhone 16 Screen Replacement, Pry up the ambient light sensor: step 22, image 1 of 3 iPhone 16 Screen Replacement, Pry up the ambient light sensor: step 22, image 2 of 3 iPhone 16 Screen Replacement, Pry up the ambient light sensor: step 22, image 3 of 3
      • Use a hair dryer, heat gun, or heated iOpener to soften the adhesive under the ambient light sensor and ambient light sensor cable.
      • Use an opening pick to pry up the ambient light sensor.
      Ask FixBot
    19. iPhone 16 Screen Replacement, Reposition the ambient light sensor cable: step 23, image 1 of 2 iPhone 16 Screen Replacement, Reposition the ambient light sensor cable: step 23, image 2 of 2
      • Use your finger to push the ambient light sensor away from its recess.
      Ask FixBot
    20. iPhone 16 Screen Replacement, Peel up the ambient light sensor cable: step 24, image 1 of 2 iPhone 16 Screen Replacement, Peel up the ambient light sensor cable: step 24, image 2 of 2
      • Gently slide an opening pick under the ambient light sensor cable, starting near the sensor and moving to the opposite corner.
      • If the adhesive doesn't peel up easily, apply more heat.
      Ask FixBot
    21. iPhone 16 Screen Replacement, Remove the ambient light sensor: step 25, image 1 of 3 iPhone 16 Screen Replacement, Remove the ambient light sensor: step 25, image 2 of 3 iPhone 16 Screen Replacement, Remove the ambient light sensor: step 25, image 3 of 3
      • Continue slowly sliding the opening pick under the ambient light sensor cable until the cable is free from the screen.
      • Use a pair of tweezers to lift the ambient light sensor off of the screen.
      Ask FixBot
    1. iPhone 16 Screen Replacement, End of disassembly: step 26, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
      • When reconnecting press connectors, align the connector carefully over its socket and press down with your fingertip or spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    1. iPhone 16 Screen Replacement, Place the ambient light sensor: step 27, image 1 of 3 iPhone 16 Screen Replacement, Place the ambient light sensor: step 27, image 2 of 3 iPhone 16 Screen Replacement, Place the ambient light sensor: step 27, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • Without letting the ambient light sensor adhesive touch the screen, use a pair of tweezers to hold the sensor above the back of the new screen.
      • Align the ambient light sensor with its recess in the back of the screen.
      • Use a spudger or your finger to press the ambient light sensor into its recess.
      • Lay the ambient light sensor cable down on the back of the screen.
      • If the ambient light sensor cable isn't sticking, apply a few small pieces of double‑sided tape, like Tesa tape, to the back of the sensor cable.
      Ask FixBot
    2. iPhone 16 Screen Replacement, Press the ambient light sensor: step 28, image 1 of 3 iPhone 16 Screen Replacement, Press the ambient light sensor: step 28, image 2 of 3 iPhone 16 Screen Replacement, Press the ambient light sensor: step 28, image 3 of 3
      • Use your finger to press down the ambient light sensor cable.
      Ask FixBot
    3. iPhone 16 Screen Replacement, Install the ambient light sensor bracket: step 29, image 1 of 3 iPhone 16 Screen Replacement, Install the ambient light sensor bracket: step 29, image 2 of 3 iPhone 16 Screen Replacement, Install the ambient light sensor bracket: step 29, image 3 of 3
      • Use tweezers or your fingers to place the ambient light sensor bracket over the back of the sensor.
      • Use a Phillips screwdriver to install the 1.3 mm‑long screw securing the ambient light sensor bracket.
      Ask FixBot
    4. iPhone 16 Screen Replacement, Remove the screen adhesive: step 30, image 1 of 3 iPhone 16 Screen Replacement, Remove the screen adhesive: step 30, image 2 of 3 iPhone 16 Screen Replacement, Remove the screen adhesive: step 30, image 3 of 3
      • Be careful not to damage any of the spring contacts as you clean the frame.
      • This is a good point to test your repair before sealing up the phone. Connect the screen, power on the phone, and make sure it works as expected. Power it back down, disconnect the screen, and continue reassembly.
      • The adhesive remaining on the phone's frame can be difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
      • Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
      • Use a pair of tweezers to remove the adhesive around the entire perimeter of the phone.
      Ask FixBot
    5. iPhone 16 Screen Replacement: step 31, image 1 of 3 iPhone 16 Screen Replacement: step 31, image 2 of 3 iPhone 16 Screen Replacement: step 31, image 3 of 3
      • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
      • Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
      • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
      • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
      Ask FixBot
    6. iPhone 16 Screen Replacement, Orient the adhesive: step 32, image 1 of 2 iPhone 16 Screen Replacement, Orient the adhesive: step 32, image 2 of 2
      • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to make sure the adhesive is oriented correctly.
      • Your adhesive may look slightly different.
      Ask FixBot
    7. iPhone 16 Screen Replacement, Expose the bottom edge of the adhesive: step 33, image 1 of 2 iPhone 16 Screen Replacement, Expose the bottom edge of the adhesive: step 33, image 2 of 2
      • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
      Ask FixBot
    8. iPhone 16 Screen Replacement, Apply the adhesive: step 34, image 1 of 3 iPhone 16 Screen Replacement, Apply the adhesive: step 34, image 2 of 3 iPhone 16 Screen Replacement, Apply the adhesive: step 34, image 3 of 3
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
      • When the adhesive is aligned, use your finger to press it down firmly along the bottom edge.
      Ask FixBot
    9. iPhone 16 Screen Replacement: step 35, image 1 of 3 iPhone 16 Screen Replacement: step 35, image 2 of 3 iPhone 16 Screen Replacement: step 35, image 3 of 3
      • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
      • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
      • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
      Ask FixBot
    10. iPhone 16 Screen Replacement, Press the adhesive into place: step 36, image 1 of 3 iPhone 16 Screen Replacement, Press the adhesive into place: step 36, image 2 of 3 iPhone 16 Screen Replacement, Press the adhesive into place: step 36, image 3 of 3
      • Make sure the liner is aligned properly by checking that all spring contacts and the front-facing camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
      • Use the flat end of a spudger to press the adhesive firmly into place all around the iPhone.
      • Be careful not to press on the camera, spring contacts, or other internal components.
      Ask FixBot
    11. iPhone 16 Screen Replacement, Remove the top liner: step 37, image 1 of 3 iPhone 16 Screen Replacement, Remove the top liner: step 37, image 2 of 3 iPhone 16 Screen Replacement, Remove the top liner: step 37, image 3 of 3
      • Use the point of a spudger to lift the pull tab in the top‑right corner of the frame until you can grab it with your fingers.
      • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners under it.
      • Peel back the top liner and remove it.
      Ask FixBot
    12. iPhone 16 Screen Replacement: step 38, image 1 of 2 iPhone 16 Screen Replacement: step 38, image 2 of 2
      • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
      • Your pull tabs may be in different positions.
      • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. If the adhesive is clean and properly aligned, you may proceed, just be careful not to touch anything to the exposed adhesive until you are ready to install the screen.
      Ask FixBot
    13. iPhone 16 Screen Replacement, Prop up the screen: step 39, image 1 of 1
      • Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
      Ask FixBot
    14. iPhone 16 Screen Replacement, Connect the screen and front sensor: step 40, image 1 of 3 iPhone 16 Screen Replacement, Connect the screen and front sensor: step 40, image 2 of 3 iPhone 16 Screen Replacement, Connect the screen and front sensor: step 40, image 3 of 3
      • Use the flat end of a spudger or your finger to connect the screen and front sensor press connectors.
      Ask FixBot
    15. iPhone 16 Screen Replacement, Cover the connectors: step 41, image 1 of 2 iPhone 16 Screen Replacement, Cover the connectors: step 41, image 2 of 2
      • Use a pair of tweezers or your fingers to place the screen connector cover over the screen connector by inserting it at a slight downward angle to engage the hook, then laying the cover flat over the connector.
      Ask FixBot
    16. iPhone 16 Screen Replacement: step 42, image 1 of 2 iPhone 16 Screen Replacement: step 42, image 2 of 2
      • Use a pair of tweezers or your fingers to place the front sensor connector cover over the front sensor connector by inserting it at a 90‑degree angle to engage the hook, then laying the cover flat over the connector.
      Ask FixBot
    17. iPhone 16 Screen Replacement, Install the cover screws: step 43, image 1 of 2 iPhone 16 Screen Replacement, Install the cover screws: step 43, image 2 of 2
      • Use a tri-point Y000 driver to install the two 0.9 mm‑long screws securing the front sensor connector and screen connector covers.
      Ask FixBot
    18. iPhone 16 Screen Replacement, Remove the final adhesive liners: step 44, image 1 of 3 iPhone 16 Screen Replacement, Remove the final adhesive liners: step 44, image 2 of 3 iPhone 16 Screen Replacement, Remove the final adhesive liners: step 44, image 3 of 3
      • As you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing touches the exposed adhesive.
      • Use a pair of tweezers or your fingers to remove the two narrow liners covering the adhesive along the right, top, and bottom edges of the iPhone.
      Ask FixBot
    19. iPhone 16 Screen Replacement: step 45, image 1 of 3 iPhone 16 Screen Replacement: step 45, image 2 of 3 iPhone 16 Screen Replacement: step 45, image 3 of 3
      • Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the phone.
      • Use a pair of tweezers or your fingers to remove the final liner along the left edge of the phone.
      Ask FixBot
    20. iPhone 16 Screen Replacement, Place the screen: step 46, image 1 of 2 iPhone 16 Screen Replacement, Place the screen: step 46, image 2 of 2
      • Align the screen over the frame, then lower it into place.
      Ask FixBot
    21. iPhone 16 Screen Replacement: step 47, image 1 of 2 iPhone 16 Screen Replacement: step 47, image 2 of 2
      • Firmly press the top edge of the screen into the adhesive, then the bottom edge, until the screen is fully seated in the frame.
      Ask FixBot
    22. iPhone 16 Screen Replacement, Heat the screen: step 48, image 1 of 2 iPhone 16 Screen Replacement, Heat the screen: step 48, image 2 of 2
      • To help the adhesive bond, apply heat to the edges of the screen using an iOpener, hair dryer, or heat gun until it's hot to the touch.
      • Firmly press around the perimeter of the screen.
      • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the screen.
      Ask FixBot
    23. iPhone 16 Screen Replacement, Press the back glass: step 49, image 1 of 3 iPhone 16 Screen Replacement, Press the back glass: step 49, image 2 of 3 iPhone 16 Screen Replacement, Press the back glass: step 49, image 3 of 3
      • To evenly compress your iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
      • If you have the box your iPhone came in, take the lid and place it on a flat surface.
      • If you don't have your original box, skip this step for an alternate method.
      • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
      • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
      • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
      Ask FixBot
    24. iPhone 16 Screen Replacement: step 50, image 1 of 2 iPhone 16 Screen Replacement: step 50, image 2 of 2
      • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the screen.
      • Place the iPhone screen-side-down on a soft, flat surface.
      • Apply tape to the back glass to protect its finish.
      Ask FixBot
    25. iPhone 16 Screen Replacement: step 51, image 1 of 3 iPhone 16 Screen Replacement: step 51, image 2 of 3 iPhone 16 Screen Replacement: step 51, image 3 of 3
      • Place two layers of coins or similarly thick objects on the tape along the edges of the back glass.
      • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
      Ask FixBot
    26. iPhone 16 Screen Replacement: step 52, image 1 of 1
      • Stack multiple books or other heavy objects on your iPhone.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      Ask FixBot
    1. iPhone 16 Screen Replacement, Install the pentalobe screws: step 53, image 1 of 2 iPhone 16 Screen Replacement, Install the pentalobe screws: step 53, image 2 of 2
      • Use a P2 pentalobe driver to install the two 7.7 mm-long screws on either side of the charging port.
      Ask FixBot
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant. Navigate to Settings → General → About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Answers Community for help.
13 other people completed this guide.
Author
with
Alex Diaz-Kokaisl
253,191 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
3 Guide Comments
i am impressed that apple FINALLY caved for better repair support on right-to-repair and RCS. worked great on my iphone 16 for much cheaper than the appple store was offering. also first comment.
renny putansu - Reply Share
My Apple Store claims they don’t have permission to replace screens on iphone16 yet? Do you know when this will be resolved?
TJT - Reply Share
If it is not an original iPhone 16 display, does Repair Assistant work without any problems?
Hans - Reply Share
Past 24 Hours: 107
Past 7 Days: 787
Past 30 Days: 3,518
All Time: 58,763
