Introduction
Go to step 1 ↓Follow this guide to replace the Taptic Engine in your iPhone 16 Pro.
You might need to replace the Taptic Engine if you're getting weak or no vibrations from your iPhone.
You'll need replacement back glass adhesive to complete this repair.
Before you begin:
Unplug any cables, and remove all cases, covers, and accessories (like portable chargers).
Hold the power and either volume button and slide to power off your phone.
Apply packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
On all edges, keep the opening pick at least 2 mm deep to avoid putting pressure on the glass itself.
Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
Apply a heated iOpener to the bottom edge of the back glass for two minutes.
Apply a suction handle to the bottom edge of the back glass, above the USB-C port.
Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
Insert the pick just far enough to sit fully beneath the glass.
There's a delicate cable connecting the back glass to the phone, right next to the volume up button.
There are multiple spring contacts around the perimeter of the phone.
Slide your pick back and forth along the bottom edge to separate the adhesive.
Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
Slide your pick around the bottom right corner and halfway up the right edge, or until you feel a hard stop at a clip securing the back glass.
Leave this pick inserted to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge.
Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
Heat the top edge of the back glass, including the area around the volume buttons, until it's hot to the touch.
Slide your opening pick across the top edge and around the top right corner to the volume up button to separate the adhesive.
Gently swing open the back glass towards the volume buttons.
Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
Remove the opening picks.
Use a tri-point Y000 screwdriver to remove the three screws securing the lower connector cover:
Two 1.2 mm‑long screws
One 1.0 mm‑long screw
Use the point of a spudger to pry up and disconnect the battery press connector.
Use a tri-point Y000 screwdriver to remove the four screws securing the upper connector cover:
Two 1.0 mm‑long screws
One 1.2 mm‑long screw
One 1.6 mm‑long screw
Use the point of a spudger to pry up and disconnect the back glass press connector.
Use a Phillips screwdriver to remove the three screws securing the Taptic Engine cover:
One 3.0 mm‑long screw
Two 1.7 mm‑long screws
Use the point of a spudger to pry up and disconnect the lower assembly cable press connector from the logic board.
Use a Phillips screwdriver to remove the 1.9 mm‑long screw securing the Taptic Engine.
Use blunt-nose tweezers or your fingers to align the Taptic Engine with its screw posts and place it in the frame.
Use your finger or a spudger to connect the two lower assembly press connectors.
Use your finger or a spudger to connect the lower assembly cable press connector, located in the bottom-right corner of the logic board.
Use tweezers or your fingers to install the Taptic Engine cover.
Tool used on this step:Tweezers$4.99
Use blunt nose tweezers or your fingers to remove large pieces of adhesive from the frame perimeter.
Use a spudger to scrape the adhesive residue off of the frame.
Tool used on this step:Microfiber Cleaning Cloths$3.99
If you're reusing your back glass, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
Wrap a lint-free cloth or a coffee filter over the point of a spudger and apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to it.
Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
Lay the adhesive sheet over the frame to determine its proper orientation.
Use your finger or a spudger to press and connect the battery press connector onto the logic board.
Align the back glass connector cover by its screw holes and lay it in place.
Use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
Check the frame and back glass for any stray liners and remove them. There should be no liners remaining.
Lower the back glass onto the frame, beginning with the top edge.
Press along the edges of the iPhone until the back glass sits flush against the frame.
Use a hair dryer, heat gun, or an iOpener to heat the back glass perimeter until it's slightly too hot to touch.
Use your fingers to firmly squeeze around the perimeter of the iPhone.
Use a P2 pentalobe screwdriver to install the two 7.4 mm‑long screws on either side of the USB-C port.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
