Up to 20% off select tools
iPhone 16 Pro Screen Refurbishment
Views: 9.6K
View statistics:
Past 24 Hours:
6
Past 7 Days:
58
Past 30 Days:
304
All Time:
9,565
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 30 minutes
Difficulty: Very difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
Refurbishing the iPhone 16 Pro screen is not just a cost-effective solution; it's often necessary when dealing with a cracked or damaged display. While many technicians find this task challenging, with the right tools and techniques, you can achieve a professional finish without cutting wires. In this guide, we'll walk you through the step-by-step process of refurbishing your iPhone 16 Pro screen, from start to finish.
Video Overview
Refurbish iPhone 16 Pro Screen Without Cutting Wire
    1. iPhone 16 Pro Screen Refurbishment, Precautions: step 1, image 1 of 3 iPhone 16 Pro Screen Refurbishment, Precautions: step 1, image 2 of 3 iPhone 16 Pro Screen Refurbishment, Precautions: step 1, image 3 of 3
      • Remove the charger from your phone and check that it has enough charge.
      • Verify the iPhone 16 Pro's touch and display functions.
      • If everything checks out, proceed to disassemble the screen.
      Ask FixBot
    2. iPhone 16 Pro Screen Refurbishment, Add Camera Sticker: step 2, image 1 of 3 iPhone 16 Pro Screen Refurbishment, Add Camera Sticker: step 2, image 2 of 3 iPhone 16 Pro Screen Refurbishment, Add Camera Sticker: step 2, image 3 of 3
      • Make sure the phone is turned off before disassembling it.
      • Use a Pentalobe Screwdriver to unscrew the bottom screws.
      • We use the REFOX RF40 iSeparator to separate the screen quickly.
      • Cover the front camera with a sticker to protect it from the laser machine.
      • This step simply applies a sticker to protect the camera, and step 4 will enable proper disassembly.
      Ask FixBot
    3. iPhone 16 Pro Screen Refurbishment, Screen Treatment: step 3, image 1 of 3 iPhone 16 Pro Screen Refurbishment, Screen Treatment: step 3, image 2 of 3 iPhone 16 Pro Screen Refurbishment, Screen Treatment: step 3, image 3 of 3
      • Use a UV laser machine, such as the DALI K300, for treating the screen.
      • Select the appropriate diagram or pattern on the UV laser machine to ensure the entire screen is treated evenly.
      • After the treatment, inspect the screen to confirm it is functioning correctly.
      Ask FixBot
    4. iPhone 16 Pro Screen Refurbishment, Disassemble the Phone: step 4, image 1 of 3 iPhone 16 Pro Screen Refurbishment, Disassemble the Phone: step 4, image 2 of 3 iPhone 16 Pro Screen Refurbishment, Disassemble the Phone: step 4, image 3 of 3
      • Flip the screen and detach it from the iPhone 16 Pro.
      • Remove the cover from the camera.
      • Remove the front sensor assembly.
      • The iPhone 15 and 16 series utilize injection molding to bond the frame bezel, making traditional removal methods risky due to potential flex damage. Laser treatment makes frame removal safer and easier.
      Ask FixBot
    5. iPhone 16 Pro Screen Refurbishment, Remove the Frame: step 5, image 1 of 3 iPhone 16 Pro Screen Refurbishment, Remove the Frame: step 5, image 2 of 3 iPhone 16 Pro Screen Refurbishment, Remove the Frame: step 5, image 3 of 3
      • Ensure that the screen is aligned with the glass separating machine and push downward suction.
      • Make sure the below and upper temperatures are set correctly.
      • Using a soft pry knife, guide your way around the frame bezel with some alcohol.
      • The frame was removed to prevent screen bubbles.
      • Once the frame is removed, clean the adhesive residue thoroughly.
      Ask FixBot
    6. iPhone 16 Pro Screen Refurbishment, Separate Front Glass: step 6, image 1 of 2 iPhone 16 Pro Screen Refurbishment, Separate Front Glass: step 6, image 2 of 2
      • Use a protective film instead of cutting a wire, as it is easier and safer.
      • Use alcohol throughout the process.
      • Remove glue/OCA residue using an electric glue remover or other methods.
      Ask FixBot
    7. iPhone 16 Pro Screen Refurbishment, Install New Front Glass: step 7, image 1 of 3 iPhone 16 Pro Screen Refurbishment, Install New Front Glass: step 7, image 2 of 3 iPhone 16 Pro Screen Refurbishment, Install New Front Glass: step 7, image 3 of 3
      • Install the new front glass using a dust-free hood to ensure a clean, particle-free environment.
      • Use alignment mold for precise alignment and to reduce the risk of air bubbles caused by operational errors.
      • Place the screen into a laminating machine to laminate it.
      • Transfer the screen to a debubbling chamber to remove any air bubbles that may have formed during the process.
      Ask FixBot
    8. iPhone 16 Pro Screen Refurbishment, Install New Frame: step 8, image 1 of 3 iPhone 16 Pro Screen Refurbishment, Install New Frame: step 8, image 2 of 3 iPhone 16 Pro Screen Refurbishment, Install New Frame: step 8, image 3 of 3
      • Use an automatic glue dispenser to apply adhesive precisely and evenly. This ensures consistent bonding and reduces manual errors. Alternatively, you can apply glue manually.
      • Use a heat press machine to press and secure the frame.
      • Once the frame installation has been completed and the frame has been pressed, check to ensure that it has been properly secured.
      Ask FixBot
    9. iPhone 16 Pro Screen Refurbishment, Final Result: step 9, image 1 of 2 iPhone 16 Pro Screen Refurbishment, Final Result: step 9, image 2 of 2
      • Connect the screen with the phone and remove the sticker.
      • Check the screen to ensure it is working properly.
      • Now assemble the iPhone 16 Pro, as you have successfully refurbished it.
      Ask FixBot
Finish Line
2 other people completed this guide.
Author
with
REWA
19,811 Reputation
55 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 58
Past 30 Days: 304
All Time: 9,565
