Introduction
Follow this guide to replace the logic board in your iPhone 16 Pro.
The logic board has connectors on top and below itself. As a result, you may need to remove the screen to re-connect it.
You'll need replacement back glass adhesive to complete this repair.
After you complete this guide, calibrate authentic Apple replacement components using Repair Assistant.
Unplug any cables from the phone.
Hold the power and either volume buttons and slide to power off the phone.
If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
Apply a heated iOpener to the bottom edge of the back glass for two minutes.
Apply a suction handle to the bottom edge of the back glass, above the USB-C port.
Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
Insert the tip of an opening pick into the gap.
There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
Slide your pick back and forth along the bottom edge to separate the adhesive.
Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
Slide your pick around the bottom right corner and halfway up the right edge, or until you feel a hard stop at a clip securing the back glass.
Leave this pick inserted to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge.
Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
Heat the top edge of the back glass, including the area around the volume buttons, until it's hot to the touch.
Slide your opening pick across the top edge and around the top right corner to the volume up button to separate the adhesive.
Gently swing open the back glass towards the volume buttons.
Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
Remove the opening picks.
Use a tri-point Y000 screwdriver to remove the three screws securing the lower connector cover:
Two 1.2 mm‑long screws
One 1.0 mm‑long screw
Use a tri-point Y000 screwdriver to remove the four screws securing the upper connector cover:
Two 1.0 mm‑long screws
One 1.2 mm‑long screw
One 1.6 mm‑long screw
Use the point of a spudger to pry up and disconnect the earpiece speaker and 5G mmWave antenna press connectors, located on the top right corner of the logic board.
Use a Phillips screwdriver to remove the six screws securing the earpiece speaker:
Three 1.2 mm‑long screws
Two 1.8 mm‑long screws
One 1.7 mm‑long screw
Use a spudger to pry up and disconnect the press connectors from the top of the logic board:
Seven silver connectors
Three black connectors
Tool used on this step:Standoff Screwdriver for iPhones$5.49
Use a standoff screwdriver to remove the four screws securing the logic board:
Two 4.5 mm‑long screws
One 3.4 mm‑long screw
One 4.2 mm‑long screw
This image shows the display connector underneath the logic board with the board removed. The next two steps show how to disconnect this connector from the logic board.
Insert the flat edge of an opening pick between the battery and the logic board. Hold the pick in place with your fingers.
Hold the logic board above the phone so the socket on the underside of the board is close to the front sensor cable.
Use your finger or a spudger to press the front sensor cable connector into its socket on the logic board until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
Use your fingers or a spudger to gently hold all the loose press connectors out of the way so you can lay the logic board in place.
Lay the logic board in its recess.
Make sure the logic board rests in place against its screw posts. The posts will properly align the board to the display connector underneath it.
Insert the top edge of the earpiece speaker into its cutout at a downward angle before pressing it flat to the frame.
Use your finger or a spudger to connect the earpiece speaker and 5G mmWave antenna (US only) press connectors, located on the top right corner of the logic board.
Tool used on this step:Tweezers$4.99
Use blunt nose tweezers or your fingers to remove large pieces of adhesive from the frame perimeter.
Use a spudger to scrape the adhesive residue off of the frame.
Tool used on this step:Microfiber Cleaning Cloths$3.99
If you're reusing your back glass, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
Wrap a lint-free cloth or a coffee filter over the point of a spudger and apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to it.
Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
Lay the adhesive sheet over the frame to determine its proper orientation.
Use your finger or a spudger to press and connect the battery press connector onto the logic board.
Align the back glass connector cover by its screw holes and lay it in place.
Use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
Check the frame and back glass for any stray liners and remove them. There should be no liners remaining.
Lower the back glass onto the frame, beginning with the top edge.
Press along the edges of the iPhone until the back glass sits flush against the frame.
Use a hair dryer, heat gun, or an iOpener to heat the back glass perimeter until it's slightly too hot to touch.
Use your fingers to firmly squeeze around the perimeter of the iPhone.
Use a P2 pentalobe screwdriver to install the two 7.4 mm‑long screws on either side of the USB-C port.
After your repair, calibrate genuine replacement parts using Apple's Repair Assistant. Navigate to Settings → General → About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
4 other people completed this guide.
