iPhone 16 Pro LiDAR Sensor Replacement
    1. iPhone 16 Pro LiDAR Sensor Replacement, Prepare the phone for disassembly: step 1, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Prepare the phone for disassembly: step 1, image 2 of 2
      • Allow the phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from the phone.
      • Hold the power and either volume buttons and slide to power off the phone.
      Ask FixBot
    2. iPhone 16 Pro LiDAR Sensor Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Tape over any cracks: step 2, image 2 of 2
      • If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    3. iPhone 16 Pro LiDAR Sensor Replacement, Mark your opening picks: step 3, image 1 of 3 iPhone 16 Pro LiDAR Sensor Replacement, Mark your opening picks: step 3, image 2 of 3 iPhone 16 Pro LiDAR Sensor Replacement, Mark your opening picks: step 3, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    4. iPhone 16 Pro LiDAR Sensor Replacement, Remove the pentalobe screws: step 4, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Remove the pentalobe screws: step 4, image 2 of 2
      • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
      Ask FixBot
    1. iPhone 16 Pro LiDAR Sensor Replacement, Heat the bottom edge: step 5, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Heat the bottom edge: step 5, image 2 of 2
      • Apply a heated iOpener to the bottom edge of the back glass for two minutes.
      • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Ask FixBot
    2. iPhone 16 Pro LiDAR Sensor Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone 16 Pro LiDAR Sensor Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone 16 Pro LiDAR Sensor Replacement, Insert an opening pick: step 6, image 3 of 3
      • Apply a suction handle to the bottom edge of the back glass, above the USB-C port.
      • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    3. iPhone 16 Pro LiDAR Sensor Replacement, Back glass information: step 7, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Back glass information: step 7, image 2 of 2
      • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
      • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
      • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
      • If you damage the spring contacts, gently bend them back with a spudger or opening pick so they align with their gold contact pads on the back glass.
      Ask FixBot
    4. iPhone 16 Pro LiDAR Sensor Replacement, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 16 Pro LiDAR Sensor Replacement, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 16 Pro LiDAR Sensor Replacement, Separate the bottom edge adhesive: step 8, image 3 of 3
      • Don't insert your pick deeper than 5 mm on the bottom edge to avoid damaging the spring contact.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    5. iPhone 16 Pro LiDAR Sensor Replacement, Heat the right edge: step 9, image 1 of 1
      • Heat the right edge of the back glass until it's hot to the touch.
      Ask FixBot
    6. iPhone 16 Pro LiDAR Sensor Replacement, Separate the bottom right corner adhesive: step 10, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Separate the bottom right corner adhesive: step 10, image 2 of 2
      • Slide your pick around the bottom right corner and halfway up the right edge, or until you feel a hard stop at a clip securing the back glass.
      • Don't slice near the volume buttons to avoid damaging the wireless charging/flash cable.
      • Leave this pick inserted to prevent the adhesive from resealing.
      Ask FixBot
    7. iPhone 16 Pro LiDAR Sensor Replacement, Heat the left edge: step 11, image 1 of 1
      • Heat the left edge of the back glass until it's hot to the touch.
      Ask FixBot
    8. iPhone 16 Pro LiDAR Sensor Replacement, Separate the left edge adhesive: step 12, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Separate the left edge adhesive: step 12, image 2 of 2
      • Insert a second opening pick at the bottom edge.
      • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
      • You'll hear and feel the metal clips release as you pass them.
      • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    9. iPhone 16 Pro LiDAR Sensor Replacement, Heat the top edge: step 13, image 1 of 1
      • Heat the top edge of the back glass, including the area around the volume buttons, until it's hot to the touch.
      Ask FixBot
    10. iPhone 16 Pro LiDAR Sensor Replacement, Separate the top edge adhesive: step 14, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Separate the top edge adhesive: step 14, image 2 of 2
      • Don't insert your pick deeper than 3 mm along the top edge to avoid damaging the spring contacts.
      • Slide your opening pick across the top edge and around the top right corner to the volume up button to separate the adhesive.
      • You'll hear and feel clicks as the top two clips release.
      Ask FixBot
    11. iPhone 16 Pro LiDAR Sensor Replacement, Swing open the back glass: step 15, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Swing open the back glass: step 15, image 2 of 2
      • Don't try to fully remove the back glass just yet—it's still attached with a delicate ribbon cable. Follow the next few steps to remove it safely.
      • If the back glass doesn't swing open easily, don't force it—go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
      • You may need to lift the back glass up slightly before swinging it open to fully disengage the clips.
      • Gently swing open the back glass towards the volume buttons.
      • Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
      • Remove the opening picks.
      • Consider using polyimide tape to protect the rear camera lenses while you're working inside the phone. Don't push against the lenses to avoid damaging the delicate stabilizers.
      Ask FixBot
    12. iPhone 16 Pro LiDAR Sensor Replacement, Disconnect the battery: step 16, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Disconnect the battery: step 16, image 2 of 2
      • Use a tri-point Y000 screwdriver to remove the three screws securing the lower connector cover:
      • Two 1.2 mm‑long screws
      • One 1.0 mm‑long screw
      Ask FixBot
    13. iPhone 16 Pro LiDAR Sensor Replacement: step 17, image 1 of 3 iPhone 16 Pro LiDAR Sensor Replacement: step 17, image 2 of 3 iPhone 16 Pro LiDAR Sensor Replacement: step 17, image 3 of 3
      • Use tweezers or your fingers to pick up and remove the lower connector cover.
      Ask FixBot
    14. iPhone 16 Pro LiDAR Sensor Replacement: step 18, image 1 of 3 iPhone 16 Pro LiDAR Sensor Replacement: step 18, image 2 of 3 iPhone 16 Pro LiDAR Sensor Replacement: step 18, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    15. iPhone 16 Pro LiDAR Sensor Replacement, Disconnect the back glass: step 19, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Disconnect the back glass: step 19, image 2 of 2
      • Use a tri-point Y000 screwdriver to remove the four screws securing the upper connector cover:
      • Two 1.0 mm‑long screws
      • One 1.2 mm‑long screw
      • One 1.6 mm‑long screw
      Ask FixBot
    16. iPhone 16 Pro LiDAR Sensor Replacement: step 20, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement: step 20, image 2 of 2
      • Use tweezers or your fingers to pick up and remove the upper connector cover.
      Ask FixBot
    17. iPhone 16 Pro LiDAR Sensor Replacement: step 21, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement: step 21, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the back glass press connector.
      Ask FixBot
    18. iPhone 16 Pro LiDAR Sensor Replacement, Remove the back glass: step 22, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Remove the back glass: step 22, image 2 of 2
      • Lift the back glass off the frame and remove it.
      Ask FixBot
    1. iPhone 16 Pro LiDAR Sensor Replacement, Disconnect the LiDAR sensor: step 23, image 1 of 3 iPhone 16 Pro LiDAR Sensor Replacement, Disconnect the LiDAR sensor: step 23, image 2 of 3 iPhone 16 Pro LiDAR Sensor Replacement, Disconnect the LiDAR sensor: step 23, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the LiDAR sensor press connector.
      Ask FixBot
    2. iPhone 16 Pro LiDAR Sensor Replacement, Remove the LiDAR Sensor: step 24, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Remove the LiDAR Sensor: step 24, image 2 of 2
      • Use a Phillips screwdriver to remove the two screws securing the LiDAR sensor:
      • One 1.7 mm‑long screw
      • One 3.0 mm‑long screw
      Ask FixBot
    3. iPhone 16 Pro LiDAR Sensor Replacement: step 25, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement: step 25, image 2 of 2
      • Use your fingers or tweezers to lift and remove the LiDAR sensor.
      Ask FixBot
    1. iPhone 16 Pro LiDAR Sensor Replacement, Disassembly complete: step 26, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your iPhone. Some of the reassembly photos show the Pro Max model, but the procedure is correct for the Pro.
      Ask FixBot
    1. iPhone 16 Pro LiDAR Sensor Replacement, Install the LiDAR Sensor: step 27, image 1 of 3 iPhone 16 Pro LiDAR Sensor Replacement, Install the LiDAR Sensor: step 27, image 2 of 3 iPhone 16 Pro LiDAR Sensor Replacement, Install the LiDAR Sensor: step 27, image 3 of 3
      • Set the LiDAR sensor in the phone aligned with its screw holes.
      • Make sure the LiDAR sensor's cable sits flush between the battery and logic board.
      Ask FixBot
    2. iPhone 16 Pro LiDAR Sensor Replacement: step 28, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement: step 28, image 2 of 2
      • Use a Phillips screwdriver to install the two screws securing the LiDAR sensor:
      Ask FixBot
    3. iPhone 16 Pro LiDAR Sensor Replacement, Connect the LiDAR sensor: step 29, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Connect the LiDAR sensor: step 29, image 2 of 2
      Ask FixBot
    1. iPhone 16 Pro LiDAR Sensor Replacement, Remove the leftover adhesive: step 30, image 1 of 3 iPhone 16 Pro LiDAR Sensor Replacement, Remove the leftover adhesive: step 30, image 2 of 3 iPhone 16 Pro LiDAR Sensor Replacement, Remove the leftover adhesive: step 30, image 3 of 3
      Tool used on this step:
      Buy
      • Work around the fragile grounding clips as you're cleaning the frame. If you bend one out of place, gently bend it back with your fingers or tweezers.
      • Use blunt nose tweezers or your fingers to remove large pieces of adhesive from the frame perimeter.
      • Use a spudger to scrape the adhesive residue off of the frame.
      • If the adhesive feels stubborn, apply some heat using a hair dryer or heat gun and try again.
      Ask FixBot
    2. iPhone 16 Pro LiDAR Sensor Replacement, Clean the back glass: step 31, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Clean the back glass: step 31, image 2 of 2
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • If you're reusing your back glass, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
      Ask FixBot
    3. iPhone 16 Pro LiDAR Sensor Replacement, Clean the frame: step 32, image 1 of 1
      • Wrap a lint-free cloth or a coffee filter over the point of a spudger and apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to it.
      • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
      • Take your time doing this. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
      Ask FixBot
    4. iPhone 16 Pro LiDAR Sensor Replacement, Apply the replacement adhesive: step 33, image 1 of 1
      • Lay the adhesive sheet over the frame to determine its proper orientation.
      • Use features such as the camera cutout and notches along the top and bottom edges to visualize how the adhesive will lay in the frame.
      Ask FixBot
    5. iPhone 16 Pro LiDAR Sensor Replacement: step 34, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement: step 34, image 2 of 2
      • Grab the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
      • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
      • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
      Ask FixBot
    6. iPhone 16 Pro LiDAR Sensor Replacement: step 35, image 1 of 3 iPhone 16 Pro LiDAR Sensor Replacement: step 35, image 2 of 3 iPhone 16 Pro LiDAR Sensor Replacement: step 35, image 3 of 3
      • Carefully align the exposed edge of the adhesive strip with the corresponding edge of the iPhone's frame.
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • When it's correctly aligned, gently press the exposed adhesive strip onto the frame.
      Ask FixBot
    7. iPhone 16 Pro LiDAR Sensor Replacement: step 36, image 1 of 3 iPhone 16 Pro LiDAR Sensor Replacement: step 36, image 2 of 3 iPhone 16 Pro LiDAR Sensor Replacement: step 36, image 3 of 3
      • Continue peeling away the liner from the adhesive, gently pressing the adhesive into place.
      • If you've correctly aligned the adhesive, the edges will fall perfectly into place.
      • If your adhesive is slightly misaligned, gently pull the long edges into alignment with the frame.
      • If the adhesive begins to crease or wrinkle, remove it and start over with fresh adhesive.
      • If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
      Ask FixBot
    8. iPhone 16 Pro LiDAR Sensor Replacement: step 37, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement: step 37, image 2 of 2
      • Use a spudger to press the adhesive around the entire perimeter of your iPhone.
      • Work around the fragile grounding clips. If you bend one out of place, gently bend it back with your fingers or tweezers.
      • Don't press too hard, or you'll stretch and deform the adhesive.
      Ask FixBot
    9. iPhone 16 Pro LiDAR Sensor Replacement: step 38, image 1 of 3 iPhone 16 Pro LiDAR Sensor Replacement: step 38, image 2 of 3 iPhone 16 Pro LiDAR Sensor Replacement: step 38, image 3 of 3
      • Use a spudger or your fingers to lift the pull tab connected to the large front liner. The pull tab is often in a corner of the liner.
      • Use the pull tab to peel off the large front liner from the adhesive.
      • At this point, you may still have a liner covering the perimeter, which prevents the adhesive from accidentally sticking to anything while you're reassembling your iPhone. Don't remove these small release liners just yet.
      Ask FixBot
    10. iPhone 16 Pro LiDAR Sensor Replacement, Connect the back glass: step 39, image 1 of 1
      • Prop up the back glass along the right edge of your iPhone.
      Ask FixBot
    11. iPhone 16 Pro LiDAR Sensor Replacement: step 40, image 1 of 1
      • Use your finger or the flat end of a spudger to press and connect the back glass connector onto the logic board.
      Ask FixBot
    12. iPhone 16 Pro LiDAR Sensor Replacement, Connect the battery: step 41, image 1 of 1
      • Use your finger or a spudger to press and connect the battery press connector onto the logic board.
      • This is a good point to test your repair before sealing up your iPhone. Power on your iPhone and make sure it works as expected. Power it back down and continue reassembly.
      • If your iPhone doesn't turn on, connect it to a power source and try again.
      • If you've replaced the logic board and the screen fails to turn on, you'll need to follow the screen guide to manually connect the display connector.
      Ask FixBot
    13. iPhone 16 Pro LiDAR Sensor Replacement, Install the connector covers: step 42, image 1 of 1
      • Align the back glass connector cover by its screw holes and lay it in place.
      Ask FixBot
    14. iPhone 16 Pro LiDAR Sensor Replacement: step 43, image 1 of 1
      • Use a tri-point Y000 screwdriver to install the four screws securing the upper connector cover:
      Ask FixBot
    15. iPhone 16 Pro LiDAR Sensor Replacement: step 44, image 1 of 1
      • Align the battery connector cover by its screw holes and lay it in place.
      Ask FixBot
    16. iPhone 16 Pro LiDAR Sensor Replacement: step 45, image 1 of 1
      • Use a tri-point Y000 driver to install the three screws securing the battery connector cover:
      • Two 1.3 mm‑long screws
      Ask FixBot
    17. iPhone 16 Pro LiDAR Sensor Replacement, Remove the final adhesive liners: step 46, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Remove the final adhesive liners: step 46, image 2 of 2
      • Use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
      • As you remove the liners, make sure nothing touches the exposed adhesive.
      • Check the frame and back glass for any stray liners and remove them. There should be no liners remaining.
      Ask FixBot
    18. iPhone 16 Pro LiDAR Sensor Replacement, Install the back glass: step 47, image 1 of 3 iPhone 16 Pro LiDAR Sensor Replacement, Install the back glass: step 47, image 2 of 3 iPhone 16 Pro LiDAR Sensor Replacement, Install the back glass: step 47, image 3 of 3
      • Lower the back glass onto the frame, beginning with the top edge.
      • If you feel resistance, a perimeter clip may have bent out of place and is being crushed by the frame. Look at the point of resistance and gently straighten any bent clips.
      • Press along the edges of the iPhone until the back glass sits flush against the frame.
      Ask FixBot
    19. iPhone 16 Pro LiDAR Sensor Replacement, Apply heat to the perimeter: step 48, image 1 of 1
      • Use a hair dryer, heat gun, or an iOpener to heat the back glass perimeter until it's slightly too hot to touch.
      • The heat softens the adhesive and helps create a better bond.
      Ask FixBot
    1. iPhone 16 Pro LiDAR Sensor Replacement, Apply pressure to the perimeter: step 49, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Apply pressure to the perimeter: step 49, image 2 of 2
      • Use your fingers to firmly squeeze around the perimeter of the iPhone.
      Ask FixBot
    2. iPhone 16 Pro LiDAR Sensor Replacement: step 50, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement: step 50, image 2 of 2
      • Place your iPhone screen-side down on a clean, flat work surface.
      • Lay a strip of tape around the perimeter of the back glass to protect the finish.
      • Stack coins around the perimeter of the back glass until you create a wall that's as tall as the rear camera protrusions.
      • Alternatively, you can use vise clamps around the perimeter of your device to set the new adhesive.
      Ask FixBot
    3. iPhone 16 Pro LiDAR Sensor Replacement: step 51, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement: step 51, image 2 of 2
      • Place 3-4 heavy books squarely on top of your iPhone.
      • The coins may leave a slight impression on the bottom book cover, so don't use anything valuable.
      • Leave the books in place for about 30 minutes.
      • The pressure will help activate the adhesive.
      Ask FixBot
    1. iPhone 16 Pro LiDAR Sensor Replacement, Install the pentalobe screws: step 52, image 1 of 2 iPhone 16 Pro LiDAR Sensor Replacement, Install the pentalobe screws: step 52, image 2 of 2
      • Use a P2 pentalobe screwdriver to install the two 7.4 mm‑long screws on either side of the USB-C port.
      Ask FixBot
After your repair, calibrate a genuine replacement LiDAR sensor using Apple's Repair Assistant. Navigate to Settings → General → About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
Nick Schultz
65,794 Reputation
343 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 52
Past 30 Days: 169
All Time: 1,569
