Up to 20% off select tools
iPhone 16 Pro Battery Replacement
Views: 61K
View statistics:
Past 24 Hours:
168
Past 7 Days:
1,136
Past 30 Days:
5,287
All Time:
60,796
Comments: 10
9 comments on steps, 1 guide comment.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 3 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace the battery in your iPhone 16 Pro.
iPhone batteries are rated to hold 80% of their capacity for up to 500 charge cycles, or roughly 18–24 months. If your iPhone needs to be charged more often or runs slower, it might be time to replace the battery.
If your battery is swollen, take appropriate precautions.
You'll need replacement battery and back glass adhesive to complete this repair.
As of iOS 18.1, battery health should work with both genuine and aftermarket replacement batteries. If you're running an older version of iOS, you'll need a genuine Apple battery to retain battery health functionality.
After your repair, run Repair Assistant to reset the battery metrics.
    1. iPhone 16 Pro Battery Replacement, Prepare the phone for disassembly: step 1, image 1 of 2 iPhone 16 Pro Battery Replacement, Prepare the phone for disassembly: step 1, image 2 of 2
      • Before you begin:
      • Back up your data.
      • Discharge the phone's battery drain below 25%. A charged lithium‑ion battery can catch fire if accidentally damaged.
      • Unplug any cables, and remove all cases, covers, and accessories (like portable chargers).
      • Hold the power and either volume button and slide to power off your phone.
      Ask FixBot
    2. iPhone 16 Pro Battery Replacement, Cracked glass preparation: step 2, image 1 of 2 iPhone 16 Pro Battery Replacement, Cracked glass preparation: step 2, image 2 of 2
      • Glass shards can complicate disassembly—or worse, cause injury. If your phone's back glass is cracked, follow this step.
      • Apply packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
      • Make sure there's a single strip (not overlapping) of tape on the bottom edge, big enough for a suction cup to fit on.
      • Only cover the glass itself—don't stick any tape to the frame.
      • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    3. iPhone 16 Pro Battery Replacement, Mark your opening picks: step 3, image 1 of 3 iPhone 16 Pro Battery Replacement, Mark your opening picks: step 3, image 2 of 3 iPhone 16 Pro Battery Replacement, Mark your opening picks: step 3, image 3 of 3
      • If inserted too deep, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      • On all edges, keep the opening pick at least 2 mm deep to avoid putting pressure on the glass itself.
      Ask FixBot
    4. iPhone 16 Pro Battery Replacement, Remove the pentalobe screws: step 4, image 1 of 2 iPhone 16 Pro Battery Replacement, Remove the pentalobe screws: step 4, image 2 of 2
      • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
      Ask FixBot
    1. iPhone 16 Pro Battery Replacement, Heat the bottom edge: step 5, image 1 of 2 iPhone 16 Pro Battery Replacement, Heat the bottom edge: step 5, image 2 of 2
      • Apply a heated iOpener to the bottom edge of the back glass for two minutes.
      • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's slightly too hot to touch.
      • Improper use of a heat gun can destroy the display and/or battery—follow the linked instructions carefully.
      Ask FixBot
    2. iPhone 16 Pro Battery Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone 16 Pro Battery Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone 16 Pro Battery Replacement, Insert an opening pick: step 6, image 3 of 3
      • Apply a suction handle to the bottom edge of the back glass, above the USB-C port.
      • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
      • If the back glass doesn't budge, reheat it and try again.
      • Insert the pick just far enough to sit fully beneath the glass.
      Ask FixBot
    3. iPhone 16 Pro Battery Replacement, Back glass information: step 7, image 1 of 2 iPhone 16 Pro Battery Replacement, Back glass information: step 7, image 2 of 2
      • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
      • There's a delicate cable connecting the back glass to the phone, right next to the volume up button.
      • There are multiple spring contacts around the perimeter of the phone.
      • If you damage the spring contacts, gently bend them back with a spudger or opening pick so they align with their gold contact pads on the back glass.
      Ask FixBot
    4. iPhone 16 Pro Battery Replacement, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 16 Pro Battery Replacement, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 16 Pro Battery Replacement, Separate the bottom edge adhesive: step 8, image 3 of 3
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    5. iPhone 16 Pro Battery Replacement, Heat the right edge: step 9, image 1 of 1
      • Heat the right edge of the back glass until it's hot to the touch.
      Ask FixBot
    6. iPhone 16 Pro Battery Replacement, Separate the bottom right corner adhesive: step 10, image 1 of 2 iPhone 16 Pro Battery Replacement, Separate the bottom right corner adhesive: step 10, image 2 of 2
      • Slide your pick around the bottom right corner and halfway up the right edge, or until you feel a hard stop at a clip securing the back glass.
      • Don't insert the pick deeper than 3 mm near the volume buttons to avoid damaging the wireless charging/flash cable.
      • Leave this pick inserted to prevent the adhesive from resealing.
      Ask FixBot
    7. iPhone 16 Pro Battery Replacement, Heat the left edge: step 11, image 1 of 1
      • Heat the left edge of the back glass until it's hot to the touch.
      Ask FixBot
    8. iPhone 16 Pro Battery Replacement, Separate the left edge adhesive: step 12, image 1 of 2 iPhone 16 Pro Battery Replacement, Separate the left edge adhesive: step 12, image 2 of 2
      • Insert a second opening pick at the bottom edge.
      • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
      • You'll hear and feel the metal clips release as you pass them.
      • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    9. iPhone 16 Pro Battery Replacement, Heat the top edge: step 13, image 1 of 1
      • Heat the top edge of the back glass, including the area around the volume buttons, until it's hot to the touch.
      Ask FixBot
    10. iPhone 16 Pro Battery Replacement, Separate the top edge adhesive: step 14, image 1 of 2 iPhone 16 Pro Battery Replacement, Separate the top edge adhesive: step 14, image 2 of 2
      • Don't insert your pick deeper than 3 mm along the top edge to avoid damaging the spring contacts.
      • Slide your opening pick across the top edge and around the top right corner to the volume up button to separate the adhesive.
      • You'll hear and feel clicks as the top two clips release.
      Ask FixBot
    11. iPhone 16 Pro Battery Replacement, Swing open the back glass: step 15, image 1 of 2 iPhone 16 Pro Battery Replacement, Swing open the back glass: step 15, image 2 of 2
      • Don't try to fully remove the back glass just yet—it's still attached with a delicate ribbon cable. Follow the next few steps to remove it safely.
      • If the back glass doesn't swing open easily, don't force it—go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
      • You may need to lift the back glass up slightly before swinging it open to fully disengage the clips.
      • Gently swing open the back glass towards the volume buttons.
      • Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
      • Remove the opening picks.
      • Consider using polyimide tape to protect the rear camera lenses while you're working inside the phone. Don't push against the lenses to avoid damaging the delicate stabilizers.
      Ask FixBot
    12. iPhone 16 Pro Battery Replacement, Remove the lower connector cover: step 16, image 1 of 2 iPhone 16 Pro Battery Replacement, Remove the lower connector cover: step 16, image 2 of 2
      • Use a tri-point Y000 screwdriver to remove the three screws securing the lower connector cover:
      • Two 1.2 mm‑long screws
      • One 1.0 mm‑long screw
      • Small iFixit Phillips bits are designed to work with JIS screws, so you can use an iFixit PH 00 driver. You can try Phillips drivers from other manufacturers, but you risk stripping the screw.
      Ask FixBot
    13. iPhone 16 Pro Battery Replacement: step 17, image 1 of 3 iPhone 16 Pro Battery Replacement: step 17, image 2 of 3 iPhone 16 Pro Battery Replacement: step 17, image 3 of 3
      • Use tweezers or your fingers to pick up and remove the lower connector cover.
      Ask FixBot
    14. iPhone 16 Pro Battery Replacement, Disconnect the battery: step 18, image 1 of 3 iPhone 16 Pro Battery Replacement, Disconnect the battery: step 18, image 2 of 3 iPhone 16 Pro Battery Replacement, Disconnect the battery: step 18, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    15. iPhone 16 Pro Battery Replacement, Remove the upper connector cover: step 19, image 1 of 2 iPhone 16 Pro Battery Replacement, Remove the upper connector cover: step 19, image 2 of 2
      • Use a tri-point Y000 screwdriver to remove the four screws securing the upper connector cover:
      • Two 1.0 mm‑long screws
      • One 1.2 mm‑long screw
      • One 1.6 mm‑long screw
      Ask FixBot
    16. iPhone 16 Pro Battery Replacement: step 20, image 1 of 2 iPhone 16 Pro Battery Replacement: step 20, image 2 of 2
      • Use tweezers or your fingers to pick up and remove the upper connector cover.
      Ask FixBot
    17. iPhone 16 Pro Battery Replacement, Disconnect the back glass: step 21, image 1 of 2 iPhone 16 Pro Battery Replacement, Disconnect the back glass: step 21, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the back glass press connector.
      Ask FixBot
    18. iPhone 16 Pro Battery Replacement, Remove the back glass: step 22, image 1 of 2 iPhone 16 Pro Battery Replacement, Remove the back glass: step 22, image 2 of 2
      • Lift the back glass off the frame and remove it.
      Ask FixBot
    1. iPhone 16 Pro Battery Replacement, Remove the Taptic Engine cover: step 23, image 1 of 2 iPhone 16 Pro Battery Replacement, Remove the Taptic Engine cover: step 23, image 2 of 2
      • Use a Phillips screwdriver to remove the three screws securing the Taptic Engine cover:
      • One 3.0 mm‑long screw
      • Two 1.7 mm‑long screws
      Ask FixBot
    2. iPhone 16 Pro Battery Replacement: step 24, image 1 of 3 iPhone 16 Pro Battery Replacement: step 24, image 2 of 3 iPhone 16 Pro Battery Replacement: step 24, image 3 of 3
      • Use tweezers or your fingers to lift the top edge of the Taptic Engine cover.
      • Once the bottom edge unlatches from the frame, remove the Taptic Engine cover.
      Ask FixBot
    3. iPhone 16 Pro Battery Replacement, Disconnect the lower assembly cable: step 25, image 1 of 2 iPhone 16 Pro Battery Replacement, Disconnect the lower assembly cable: step 25, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the lower assembly cable press connector from the logic board.
      Ask FixBot
    4. iPhone 16 Pro Battery Replacement: step 26, image 1 of 3 iPhone 16 Pro Battery Replacement: step 26, image 2 of 3 iPhone 16 Pro Battery Replacement: step 26, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the two press connectors near the bottom right edge of the frame.
      Ask FixBot
    5. iPhone 16 Pro Battery Replacement: step 27, image 1 of 2 iPhone 16 Pro Battery Replacement: step 27, image 2 of 2
      • Use a tri-point Y000 screwdriver to remove the 1.0 mm‑long screw securing the lower assembly cable.
      Ask FixBot
    6. iPhone 16 Pro Battery Replacement: step 28, image 1 of 2 iPhone 16 Pro Battery Replacement: step 28, image 2 of 2
      • Use an iOpener or hair dryer to heat up the lower assembly cable section on top of the Taptic Engine until it's hot to the touch.
      Ask FixBot
    7. iPhone 16 Pro Battery Replacement: step 29, image 1 of 2 iPhone 16 Pro Battery Replacement: step 29, image 2 of 2
      • Slide an opening pick under the lower assembly cable to separate it from the Taptic Engine.
      • Carefully bend the cable out of the way so you can access the Taptic Engine.
      Ask FixBot
    8. iPhone 16 Pro Battery Replacement, Remove the Taptic Engine: step 30, image 1 of 2 iPhone 16 Pro Battery Replacement, Remove the Taptic Engine: step 30, image 2 of 2
      • Use a Phillips screwdriver to remove the 1.9 mm‑long screw securing the Taptic Engine.
      Ask FixBot
    9. iPhone 16 Pro Battery Replacement: step 31, image 1 of 2 iPhone 16 Pro Battery Replacement: step 31, image 2 of 2
      • Slide the tip of an opening pick along the top edge of the Taptic Engine to separate the plastic buffer strip adhered to it.
      Ask FixBot
    10. iPhone 16 Pro Battery Replacement: step 32, image 1 of 3 iPhone 16 Pro Battery Replacement: step 32, image 2 of 3 iPhone 16 Pro Battery Replacement: step 32, image 3 of 3
      • Use the point of a spudger to pry up the Taptic Engine from its top-right corner.
      • Be careful not to pry against the battery.
      • Remove the Taptic Engine.
      Ask FixBot
    1. iPhone 16 Pro Battery Replacement, Remove the loudspeaker: step 33, image 1 of 2 iPhone 16 Pro Battery Replacement, Remove the loudspeaker: step 33, image 2 of 2
      • Remove the four screws securing the loudspeaker:
      • Two 1.6 mm‑long Phillips screws
      • One 2.0 mm‑long Phillips screw
      • One 1.3 mm‑long tri-point Y000 screw
      Ask FixBot
    2. iPhone 16 Pro Battery Replacement: step 34, image 1 of 3 iPhone 16 Pro Battery Replacement: step 34, image 2 of 3 iPhone 16 Pro Battery Replacement: step 34, image 3 of 3
      • Insert the point of a spudger underneath the loudspeaker's bottom-right screw hole.
      • Pry up and remove the loudspeaker.
      Ask FixBot
    1. iPhone 16 Pro Battery Replacement, Battery adhesive information: step 35, image 1 of 1
      • The battery is secured with three stretch release adhesive strips. The next four steps show how to remove them and free the battery.
      • Be careful not to dent or puncture the battery. Even with its metal enclosure, the battery can catch fire if damaged.
      Ask FixBot
    2. iPhone 16 Pro Battery Replacement, Remove the battery: step 36, image 1 of 2 iPhone 16 Pro Battery Replacement, Remove the battery: step 36, image 2 of 2
      • Insert the tip of angled tweezers under one of the black pull tabs.
      Ask FixBot
    3. iPhone 16 Pro Battery Replacement: step 37, image 1 of 3 iPhone 16 Pro Battery Replacement: step 37, image 2 of 3 iPhone 16 Pro Battery Replacement: step 37, image 3 of 3
      • Use your tweezers to slice through the black tab and peel the tab off the top of the battery.
      • Don't try to pull the tab out from under the battery just yet.
      Ask FixBot
    4. iPhone 16 Pro Battery Replacement: step 38, image 1 of 3 iPhone 16 Pro Battery Replacement: step 38, image 2 of 3 iPhone 16 Pro Battery Replacement: step 38, image 3 of 3
      • Use tweezers or your fingers to grab the pull tab and pull it down so it's flat against the frame.
      • Slowly pull the adhesive out from under the battery at as low of an angle as possible.
      • Give the strip plenty of time to stretch and re-grip it as necessary. When the strip becomes too long, wrap it around your tweezers and continue pulling.
      • If the strip breaks off, try to retrieve it from under the battery. If you can't retrieve it, move onto the next strip.
      Ask FixBot
    5. iPhone 16 Pro Battery Replacement: step 39, image 1 of 2 iPhone 16 Pro Battery Replacement: step 39, image 2 of 2
      • Repeat the procedure with the two remaining adhesive strips.
      • Carefully bend the lower assembly cable out of the way as needed to access the adhesive strips.
      Ask FixBot
    6. iPhone 16 Pro Battery Replacement: step 40, image 1 of 2 iPhone 16 Pro Battery Replacement: step 40, image 2 of 2
      • If you removed all three stretch release adhesive strips, congratulations! Lift and remove the battery.
      • If one or more adhesive strips broke, skip to the next step to remove them with isopropyl alcohol.
      Ask FixBot
    7. iPhone 16 Pro Battery Replacement, Alternate method to remove the battery: step 41, image 1 of 1
      • The next two steps show how to remove the battery if the adhesive strips broke.
      • Lift the bottom edge of the frame to tilt the phone.
      • Use a pipette or a syringe to apply 2–3 drops of high concentration (>90%) isopropyl alcohol along the bottom edge of the battery, close to where each broken adhesive strip came out.
      • Wait one minute for the isopropyl alcohol to flow under the battery and soften the adhesive.
      Ask FixBot
    8. iPhone 16 Pro Battery Replacement: step 42, image 1 of 3 iPhone 16 Pro Battery Replacement: step 42, image 2 of 3 iPhone 16 Pro Battery Replacement: step 42, image 3 of 3
      • Insert the tip of an opening pick between the bottom of the battery and the frame.
      • Insert a second opening pick between the left edge of the battery and the frame. Use this pick to pry the battery upwards slowly with steady force. Work your way up the edge of the battery, giving the adhesive time to release.
      • Don't bend or crease the battery. If it feels stubborn, apply a few more drops of isopropyl alcohol and try again.
      • Once the adhesive loosens, grab and remove the battery.
      Ask FixBot
    1. iPhone 16 Pro Battery Replacement, Disassembly complete: step 43, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your iPhone. Some of the reassembly photos show the Pro Max model, but the procedure is correct for the Pro.
      Ask FixBot
    1. iPhone 16 Pro Battery Replacement, Clean the frame: step 44, image 1 of 2 iPhone 16 Pro Battery Replacement, Clean the frame: step 44, image 2 of 2
      • Remove any remaining adhesive from the battery recess.
      • Wipe the frame surface with a lint-free cloth and a few drops of isopropyl alcohol. Wait for the alcohol to fully evaporate before installing the new battery.
      • Before removing any liners on the adhesive, place the battery in its recess to check that it fits and that its cable reaches its socket on the logic board. Don't connect the battery yet!
      Ask FixBot
    2. iPhone 16 Pro Battery Replacement, Install new adhesive: step 45, image 1 of 3 iPhone 16 Pro Battery Replacement, Install new adhesive: step 45, image 2 of 3 iPhone 16 Pro Battery Replacement, Install new adhesive: step 45, image 3 of 3
      Tool used on this step:
      Stretch Release Battery Adhesive
      $3.99
      Buy
      • The next four steps show how to apply custom-cut adhesive to the battery. If your battery comes with adhesive pre-installed, skip the next four steps.
      • If needed, follow this guide to apply generic stretch release adhesive strips instead. Ensure the position of these strips lines up with the adhesive wells in the phone's frame. Use this photo as a reference.
      • Align the new adhesive with your battery to see how it needs to be applied. Set all strips fully on the battery, and align the top edges of the black pull tabs with the bottom edge of the battery.
      • Your adhesive may look slightly different or have different liners.
      • If the battery‑side of your adhesive has two liners, remove the top liner.
      • If the battery‑side of your adhesive has one liner, remove it.
      Ask FixBot
    3. iPhone 16 Pro Battery Replacement: step 46, image 1 of 2 iPhone 16 Pro Battery Replacement: step 46, image 2 of 2
      • Lay the adhesive onto the battery and press each strip firmly into place.
      Ask FixBot
    4. iPhone 16 Pro Battery Replacement: step 47, image 1 of 3 iPhone 16 Pro Battery Replacement: step 47, image 2 of 3 iPhone 16 Pro Battery Replacement: step 47, image 3 of 3
      • If the battery‑side of your adhesive still has a bottom liner on it, remove it now, and press each strip firmly into place.
      Ask FixBot
    5. iPhone 16 Pro Battery Replacement: step 48, image 1 of 1
      • Use your finger to fold each black pull tab around the bottom edge of the battery and press it into place.
      Ask FixBot
    6. iPhone 16 Pro Battery Replacement, Remove the adhesive film: step 49, image 1 of 3 iPhone 16 Pro Battery Replacement, Remove the adhesive film: step 49, image 2 of 3 iPhone 16 Pro Battery Replacement, Remove the adhesive film: step 49, image 3 of 3
      • Remove the iPhone‑side liner off of the battery adhesive.
      Ask FixBot
    7. iPhone 16 Pro Battery Replacement, Align the battery: step 50, image 1 of 3 iPhone 16 Pro Battery Replacement, Align the battery: step 50, image 2 of 3 iPhone 16 Pro Battery Replacement, Align the battery: step 50, image 3 of 3
      • The battery adhesive is very sticky! Be careful as you align the battery in its recess—once it sticks, you won't be able to realign it.
      • Lower the battery partially into its recess, making sure the adhesive doesn't touch the frame.
      • Use a spudger or your finger to connect the battery cable's press connector to ensure that the cable reaches.
      Ask FixBot
    8. iPhone 16 Pro Battery Replacement, Install the battery: step 51, image 1 of 3 iPhone 16 Pro Battery Replacement, Install the battery: step 51, image 2 of 3 iPhone 16 Pro Battery Replacement, Install the battery: step 51, image 3 of 3
      • Push the battery towards the top of the iPhone, and lay it in its recess.
      • Use your fingers to press firmly against the battery for ten seconds to bond it to the frame.
      • Use a spudger or your finger to disconnect the battery from the logic board.
      Ask FixBot
    1. iPhone 16 Pro Battery Replacement, Transfer the battery shim: step 52, image 1 of 3 iPhone 16 Pro Battery Replacement, Transfer the battery shim: step 52, image 2 of 3 iPhone 16 Pro Battery Replacement, Transfer the battery shim: step 52, image 3 of 3
      • If the black plastic shim beneath the battery didn't come out with the loudspeaker, skip this step.
      • Align the battery shim so it's flush with the new loudspeaker's left edge and underside. Press it onto the loudspeaker to adhere it.
      • If the shim isn't sticky, set it into the phone alongside the loudspeaker in the next step.
      Ask FixBot
    2. iPhone 16 Pro Battery Replacement, Install the loudspeaker: step 53, image 1 of 3 iPhone 16 Pro Battery Replacement, Install the loudspeaker: step 53, image 2 of 3 iPhone 16 Pro Battery Replacement, Install the loudspeaker: step 53, image 3 of 3
      • Align the bottom edge of the loudspeaker with the frame.
      • Set the loudspeaker into its recess.
      Ask FixBot
    3. iPhone 16 Pro Battery Replacement: step 54, image 1 of 2 iPhone 16 Pro Battery Replacement: step 54, image 2 of 2
      • Install the four screws securing the loudspeaker:
      Ask FixBot
    1. iPhone 16 Pro Battery Replacement, Install the Taptic Engine: step 55, image 1 of 2 iPhone 16 Pro Battery Replacement, Install the Taptic Engine: step 55, image 2 of 2
      • Use blunt-nose tweezers or your fingers to align the Taptic Engine with its screw posts and place it in the frame.
      Ask FixBot
    2. iPhone 16 Pro Battery Replacement: step 56, image 1 of 2 iPhone 16 Pro Battery Replacement: step 56, image 2 of 2
      • Use a Phillips screwdriver to install the 1.9 mm‑long screw securing the Taptic Engine, located on its right edge.
      Ask FixBot
    3. iPhone 16 Pro Battery Replacement, Connect the lower assembly cable: step 57, image 1 of 3 iPhone 16 Pro Battery Replacement, Connect the lower assembly cable: step 57, image 2 of 3 iPhone 16 Pro Battery Replacement, Connect the lower assembly cable: step 57, image 3 of 3
      • Use your finger or a spudger to connect the two lower assembly press connectors.
      • These press connectors can be tricky. Align each connector over its socket and press down—first on one side, then the other—until it clicks into place. Don't try to force them. If you're having trouble, reposition them and try again.
      Ask FixBot
    4. iPhone 16 Pro Battery Replacement: step 58, image 1 of 2 iPhone 16 Pro Battery Replacement: step 58, image 2 of 2
      • Use a tri-point Y000 screwdriver to install the 1.0 mm‑long screw securing the lower assembly cable.
      Ask FixBot
    5. iPhone 16 Pro Battery Replacement: step 59, image 1 of 2 iPhone 16 Pro Battery Replacement: step 59, image 2 of 2
      • Use your finger or a spudger to connect the lower assembly cable press connector, located in the bottom-right corner of the logic board.
      Ask FixBot
    6. iPhone 16 Pro Battery Replacement, Install the Taptic Engine cover: step 60, image 1 of 3 iPhone 16 Pro Battery Replacement, Install the Taptic Engine cover: step 60, image 2 of 3 iPhone 16 Pro Battery Replacement, Install the Taptic Engine cover: step 60, image 3 of 3
      Ask FixBot
    7. iPhone 16 Pro Battery Replacement: step 61, image 1 of 2 iPhone 16 Pro Battery Replacement: step 61, image 2 of 2
      • Use a Phillips screwdriver to install the three screws securing the Taptic Engine cover:
      Ask FixBot
    1. iPhone 16 Pro Battery Replacement, Remove the leftover adhesive: step 62, image 1 of 3 iPhone 16 Pro Battery Replacement, Remove the leftover adhesive: step 62, image 2 of 3 iPhone 16 Pro Battery Replacement, Remove the leftover adhesive: step 62, image 3 of 3
      Buy
      • Work around the fragile grounding clips as you're cleaning the frame. If you bend one out of place, gently bend it back with your fingers or tweezers.
      • Use blunt nose tweezers or your fingers to remove large pieces of adhesive from the frame perimeter.
      • Use a spudger to scrape the adhesive residue off of the frame.
      • If the adhesive feels stubborn, apply some heat using a hair dryer or heat gun and try again.
      Ask FixBot
    2. iPhone 16 Pro Battery Replacement, Clean the back glass: step 63, image 1 of 2 iPhone 16 Pro Battery Replacement, Clean the back glass: step 63, image 2 of 2
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • If you're reusing your back glass, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
      Ask FixBot
    3. iPhone 16 Pro Battery Replacement, Clean the frame: step 64, image 1 of 1
      • Wrap a lint-free cloth or a coffee filter over the point of a spudger and apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to it.
      • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
      • Take your time doing this. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
      Ask FixBot
    4. iPhone 16 Pro Battery Replacement, Apply the replacement adhesive: step 65, image 1 of 1
      • Lay the adhesive sheet over the frame to determine its proper orientation.
      • Use features such as the camera cutout and notches along the top and bottom edges to visualize how the adhesive will lay in the frame.
      Ask FixBot
    5. iPhone 16 Pro Battery Replacement: step 66, image 1 of 2 iPhone 16 Pro Battery Replacement: step 66, image 2 of 2
      • Grab the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
      • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
      • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
      Ask FixBot
    6. iPhone 16 Pro Battery Replacement: step 67, image 1 of 3 iPhone 16 Pro Battery Replacement: step 67, image 2 of 3 iPhone 16 Pro Battery Replacement: step 67, image 3 of 3
      • Carefully align the exposed edge of the adhesive strip with the corresponding edge of the iPhone's frame.
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • When it's correctly aligned, gently press the exposed adhesive strip onto the frame.
      Ask FixBot
    7. iPhone 16 Pro Battery Replacement: step 68, image 1 of 3 iPhone 16 Pro Battery Replacement: step 68, image 2 of 3 iPhone 16 Pro Battery Replacement: step 68, image 3 of 3
      • Continue peeling away the liner from the adhesive, gently pressing the adhesive into place.
      • If you've correctly aligned the adhesive, the edges will fall perfectly into place.
      • If your adhesive is slightly misaligned, gently pull the long edges into alignment with the frame.
      • If the adhesive begins to crease or wrinkle, remove it and start over with fresh adhesive.
      • If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
      Ask FixBot
    8. iPhone 16 Pro Battery Replacement: step 69, image 1 of 2 iPhone 16 Pro Battery Replacement: step 69, image 2 of 2
      • Use a spudger to press the adhesive around the entire perimeter of your iPhone.
      • Work around the fragile grounding clips. If you bend one out of place, gently bend it back with your fingers or tweezers.
      • Don't press too hard, or you'll stretch and deform the adhesive.
      Ask FixBot
    9. iPhone 16 Pro Battery Replacement: step 70, image 1 of 3 iPhone 16 Pro Battery Replacement: step 70, image 2 of 3 iPhone 16 Pro Battery Replacement: step 70, image 3 of 3
      • Use a spudger or your fingers to lift the pull tab connected to the large front liner. The pull tab is often in a corner of the liner.
      • Use the pull tab to peel off the large front liner from the adhesive.
      • At this point, you may still have a liner covering the perimeter, which prevents the adhesive from accidentally sticking to anything while you're reassembling your iPhone. Don't remove these small release liners just yet.
      Ask FixBot
    10. iPhone 16 Pro Battery Replacement, Connect the back glass: step 71, image 1 of 1
      • Prop up the back glass along the right edge of your iPhone.
      Ask FixBot
    11. iPhone 16 Pro Battery Replacement: step 72, image 1 of 1
      • Use your finger or the flat end of a spudger to press and connect the back glass connector onto the logic board.
      Ask FixBot
    12. iPhone 16 Pro Battery Replacement, Connect the battery: step 73, image 1 of 1
      • Use your finger or a spudger to press and connect the battery press connector onto the logic board.
      • This is a good point to test your repair before sealing up your iPhone. Power on your iPhone and make sure it works as expected. Power it back down and continue reassembly.
      • If your iPhone doesn't turn on, connect it to a power source and try again.
      • If you've replaced the logic board and the screen fails to turn on, you'll need to follow the screen guide to manually connect the display connector.
      Ask FixBot
    13. iPhone 16 Pro Battery Replacement, Install the connector covers: step 74, image 1 of 1
      • Align the back glass connector cover by its screw holes and lay it in place.
      Ask FixBot
    14. iPhone 16 Pro Battery Replacement: step 75, image 1 of 1
      • Use a tri-point Y000 screwdriver to install the four screws securing the upper connector cover:
      Ask FixBot
    15. iPhone 16 Pro Battery Replacement: step 76, image 1 of 1
      • Align the battery connector cover by its screw holes and lay it in place.
      Ask FixBot
    16. iPhone 16 Pro Battery Replacement: step 77, image 1 of 1
      • Use a tri-point Y000 driver to install the three screws securing the battery connector cover:
      • Two 1.3 mm‑long screws
      Ask FixBot
    17. iPhone 16 Pro Battery Replacement, Remove the final adhesive liners: step 78, image 1 of 2 iPhone 16 Pro Battery Replacement, Remove the final adhesive liners: step 78, image 2 of 2
      • Use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
      • As you remove the liners, make sure nothing touches the exposed adhesive.
      • Check the frame and back glass for any stray liners and remove them. There should be no liners remaining.
      Ask FixBot
    18. iPhone 16 Pro Battery Replacement, Install the back glass: step 79, image 1 of 3 iPhone 16 Pro Battery Replacement, Install the back glass: step 79, image 2 of 3 iPhone 16 Pro Battery Replacement, Install the back glass: step 79, image 3 of 3
      • Lower the back glass onto the frame, beginning with the top edge.
      • If you feel resistance, a perimeter clip may have bent out of place and is being crushed by the frame. Look at the point of resistance and gently straighten any bent clips.
      • Press along the edges of the iPhone until the back glass sits flush against the frame.
      Ask FixBot
    19. iPhone 16 Pro Battery Replacement, Apply heat to the perimeter: step 80, image 1 of 1
      • Use a hair dryer, heat gun, or an iOpener to heat the back glass perimeter until it's slightly too hot to touch.
      • The heat softens the adhesive and helps create a better bond.
      Ask FixBot
    1. iPhone 16 Pro Battery Replacement, Apply pressure to the perimeter: step 81, image 1 of 2 iPhone 16 Pro Battery Replacement, Apply pressure to the perimeter: step 81, image 2 of 2
      • Use your fingers to firmly squeeze around the perimeter of the iPhone.
      Ask FixBot
    2. iPhone 16 Pro Battery Replacement: step 82, image 1 of 2 iPhone 16 Pro Battery Replacement: step 82, image 2 of 2
      • Place your iPhone screen-side down on a clean, flat work surface.
      • Lay a strip of tape around the perimeter of the back glass to protect the finish.
      • Stack coins around the perimeter of the back glass until you create a wall that's as tall as the rear camera protrusions.
      • Alternatively, you can use vise clamps around the perimeter of your device to set the new adhesive.
      Ask FixBot
    3. iPhone 16 Pro Battery Replacement: step 83, image 1 of 2 iPhone 16 Pro Battery Replacement: step 83, image 2 of 2
      • Place 3-4 heavy books squarely on top of your iPhone.
      • The coins may leave a slight impression on the bottom book cover, so don't use anything valuable.
      • Leave the books in place for about 30 minutes.
      • The pressure will help activate the adhesive.
      Ask FixBot
    1. iPhone 16 Pro Battery Replacement, Install the pentalobe screws: step 84, image 1 of 2 iPhone 16 Pro Battery Replacement, Install the pentalobe screws: step 84, image 2 of 2
      • Use a P2 pentalobe screwdriver to install the two 7.4 mm‑long screws on either side of the USB-C port.
      Ask FixBot
After your repair, run Apple's Repair Assistant. Navigate to Settings → General → About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
12 other people completed this guide.
Nick Schultz
71,397 Reputation
363 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
1 Guide Comment
Considering how easy screen repairs have become on the 16 and 17 series, it's a bit odd to see the battery repair become this tedious.
Steven Durham - Reply Share
Past 24 Hours: 168
Past 7 Days: 1,136
Past 30 Days: 5,287
All Time: 60,796
