Up to 20% off select tools
iPhone 16 Front Camera Assembly Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
10
Past 7 Days:
105
Past 30 Days:
410
All Time:
4,664
Comments: 31
31 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the front camera assembly in your iPhone 16.
This assembly includes the front-facing camera and Face ID hardware.
If your front-facing photos come out fuzzy, noisy, or your camera has trouble focusing, it might need to be replaced.
You'll need replacement back glass adhesive to complete this repair.
After your repair, calibrate authentic Apple front cameras using Repair Assistant.
    1. iPhone 16 Front Camera Assembly Replacement, Before you begin: step 1, image 1 of 2 iPhone 16 Front Camera Assembly Replacement, Before you begin: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Ask FixBot
    2. iPhone 16 Front Camera Assembly Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 16 Front Camera Assembly Replacement, Tape over any cracks: step 2, image 2 of 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    3. iPhone 16 Front Camera Assembly Replacement, Remove the pentalobe screws: step 3, image 1 of 2 iPhone 16 Front Camera Assembly Replacement, Remove the pentalobe screws: step 3, image 2 of 2
      • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 16 Front Camera Assembly Replacement, Mark your opening picks: step 4, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Mark your opening picks: step 4, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Mark your opening picks: step 4, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 16 Front Camera Assembly Replacement, Heat the bottom edge: step 5, image 1 of 1
      Tool used on this step:
      iOpener
      $14.95
      Buy
      • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
      • You can also use an iOpener to heat the back glass. Follow these instructions to heat and apply the iOpener properly.
      Ask FixBot
    2. iPhone 16 Front Camera Assembly Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Insert an opening pick: step 6, image 3 of 3
      • Apply a suction handle to the bottom edge of the back glass.
      • While supporting the frame with one hand, pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    3. iPhone 16 Front Camera Assembly Replacement, Back glass information: step 7, image 1 of 1
      • As you slice the adhesive securing the back glass in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
      • A delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
      • Multiple spring contacts around the perimeter of the phone.
      Ask FixBot
    4. iPhone 16 Front Camera Assembly Replacement, Heat the right edge: step 8, image 1 of 1
      • Use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
      Ask FixBot
    5. iPhone 16 Front Camera Assembly Replacement, Separate the bottom right adhesive: step 9, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Separate the bottom right adhesive: step 9, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Separate the bottom right adhesive: step 9, image 3 of 3
      • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
      • Slide your pick around the bottom right corner and to the volume down button to separate the adhesive and release the metal clip.
      • Don't slide past the volume buttons to avoid damaging the wireless charging cable.
      • You'll hear and feel the metal clip release as you pass it.
      • Leave this pick inserted to prevent the adhesive from resealing.
      Ask FixBot
    6. iPhone 16 Front Camera Assembly Replacement, Heat the left edge: step 10, image 1 of 1
      • Use a hair dryer or heat gun to heat the left edge of the back glass until it's hot to the touch.
      Ask FixBot
    7. iPhone 16 Front Camera Assembly Replacement, Separate the left adhesive: step 11, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Separate the left adhesive: step 11, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Separate the left adhesive: step 11, image 3 of 3
      • Insert a second opening pick at the bottom edge.
      • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
      • You'll hear and feel the metal clips release as you pass them.
      • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    8. iPhone 16 Front Camera Assembly Replacement, Heat the top edge: step 12, image 1 of 1
      • Use a hair dryer or heat gun to heat the top edge of the back glass until it's hot to the touch.
      Ask FixBot
    9. iPhone 16 Front Camera Assembly Replacement, Separate the top right adhesive: step 13, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Separate the top right adhesive: step 13, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Separate the top right adhesive: step 13, image 3 of 3
      • Slide your second opening pick around the top left corner and along the top edge to separate the adhesive and release the metal clips.
      • Continue sliding your pick around the top right corner until you reach the Action button.
      Ask FixBot
    10. iPhone 16 Front Camera Assembly Replacement, Reposition the back glass: step 14, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Reposition the back glass: step 14, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Reposition the back glass: step 14, image 3 of 3
      • At this point, the back glass should be free from the frame. If the back glass feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
      • Swing open the back glass to the right of the phone to separate the remaining adhesive.
      • Support the back glass with a clean, sturdy object.
      • Remove the opening picks before continuing.
      Ask FixBot
    11. iPhone 16 Front Camera Assembly Replacement, Remove the middle connector cover screws: step 15, image 1 of 2 iPhone 16 Front Camera Assembly Replacement, Remove the middle connector cover screws: step 15, image 2 of 2
      • Use a tri-point Y000 driver to remove the two 1 mm‑long screws securing the middle connector cover.
      Ask FixBot
    12. iPhone 16 Front Camera Assembly Replacement, Remove the middle connector cover: step 16, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Remove the middle connector cover: step 16, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Remove the middle connector cover: step 16, image 3 of 3
      • Insert the point of a spudger in either cutout on the middle connector cover.
      • Slide the cover towards the left edge of the phone and release its hook from its slot on the logic board.
      • Remove the cover.
      Ask FixBot
    13. iPhone 16 Front Camera Assembly Replacement, Disconnect the battery: step 17, image 1 of 2 iPhone 16 Front Camera Assembly Replacement, Disconnect the battery: step 17, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    14. iPhone 16 Front Camera Assembly Replacement, Disconnect the wireless charging coil: step 18, image 1 of 2 iPhone 16 Front Camera Assembly Replacement, Disconnect the wireless charging coil: step 18, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
      Ask FixBot
    15. iPhone 16 Front Camera Assembly Replacement, Remove the back glass: step 19, image 1 of 1
      • Lift the back glass off the frame and remove it.
      Ask FixBot
    1. iPhone 16 Front Camera Assembly Replacement, Remove the top bracket screws: step 20, image 1 of 2 iPhone 16 Front Camera Assembly Replacement, Remove the top bracket screws: step 20, image 2 of 2
      • Use a screwdriver to remove the four screws securing the top bracket:
      • One 3.5 mm-long Phillips screw
      • Two 1.4 mm-long Phillips screws
      • One 1.0 mm-long tri-point Y000 screw
      Ask FixBot
    2. iPhone 16 Front Camera Assembly Replacement, Remove the top bracket: step 21, image 1 of 2 iPhone 16 Front Camera Assembly Replacement, Remove the top bracket: step 21, image 2 of 2
      • Use tweezers, or your fingers, to remove the top bracket.
      Ask FixBot
    1. iPhone 16 Front Camera Assembly Replacement, Disconnect the front camera: step 22, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Disconnect the front camera: step 22, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Disconnect the front camera: step 22, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the two front camera press connectors.
      • The second press connector is underneath the first.
      Ask FixBot
    2. iPhone 16 Front Camera Assembly Replacement, Remove the front camera: step 23, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Remove the front camera: step 23, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Remove the front camera: step 23, image 3 of 3
      • Insert the point of a spudger between the top edge of the front camera and the frame.
      • Lift the front camera out of the frame and remove it.
      Ask FixBot
    1. iPhone 16 Front Camera Assembly Replacement, End of disassembly: step 24, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
      • When reconnecting press connectors, align the connector carefully over its socket and press down with your fingertip or spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    1. iPhone 16 Front Camera Assembly Replacement, Place the front camera assembly: step 25, image 1 of 2 iPhone 16 Front Camera Assembly Replacement, Place the front camera assembly: step 25, image 2 of 2
      • Place the front camera assembly into its recess in the frame.
      Ask FixBot
    2. iPhone 16 Front Camera Assembly Replacement, Connect the front camera assembly: step 26, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Connect the front camera assembly: step 26, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Connect the front camera assembly: step 26, image 3 of 3
      • Use the flat end of a spudger or your finger to connect the front camera's bottom press connector, then the top press connector.
      Ask FixBot
    1. iPhone 16 Front Camera Assembly Replacement, Reinstall the top bracket: step 27, image 1 of 2 iPhone 16 Front Camera Assembly Replacement, Reinstall the top bracket: step 27, image 2 of 2
      • Use tweezers, or your fingers, to reinstall the top bracket.
      Ask FixBot
    2. iPhone 16 Front Camera Assembly Replacement, Install the top bracket screws: step 28, image 1 of 2 iPhone 16 Front Camera Assembly Replacement, Install the top bracket screws: step 28, image 2 of 2
      • Use a screwdriver to install the four screws securing the top bracket:
      Ask FixBot
    1. iPhone 16 Front Camera Assembly Replacement, Remove the back glass adhesive: step 29, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Remove the back glass adhesive: step 29, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Remove the back glass adhesive: step 29, image 3 of 3
      • Be careful not to damage any of the spring contacts as you clean the frame.
      • This is a good point to test your repair before sealing up your phone. Connect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down, disconnect the battery and back glass, and continue reassembly.
      • The adhesive remaining on your phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
      • Use the pointed end of a spudger to press and roll the adhesive until you can grip it with a pair of tweezers.
      Ask FixBot
    2. iPhone 16 Front Camera Assembly Replacement: step 30, image 1 of 2 iPhone 16 Front Camera Assembly Replacement: step 30, image 2 of 2
      • Use the tweezers to pull the adhesive off of the phone.
      • Repeat the previous step and this step until all of the adhesive is removed.
      Ask FixBot
    3. iPhone 16 Front Camera Assembly Replacement, Clean the frame: step 31, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Clean the frame: step 31, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Clean the frame: step 31, image 3 of 3
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
      • Wrap a microfiber or lint-free cloth over the point of a spudger and apply a few drops of high-concentration isopropyl alcohol (over 90%) to the cloth.
      • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
      • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
      Ask FixBot
    4. iPhone 16 Front Camera Assembly Replacement, Clean the back glass: step 32, image 1 of 2 iPhone 16 Front Camera Assembly Replacement, Clean the back glass: step 32, image 2 of 2
      • If you're not reusing your back glass, skip this step.
      • Apply a few drops of high-concentration isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter of the back glass to prepare the surface for new adhesive.
      • If any clips on the back glass are bent, gently straighten them with your fingers.
      Ask FixBot
    5. iPhone 16 Front Camera Assembly Replacement, Orient the adhesive: step 33, image 1 of 2 iPhone 16 Front Camera Assembly Replacement, Orient the adhesive: step 33, image 2 of 2
      • Orient your replacement adhesive over the frame with the larger blue liner on the underside and its pull tab in the bottom-right corner.
      • The color of your liner and the pull tab locations may be different on your adhesive.
      • Use features such as the camera cutout and notches along the edges to ensure the adhesive is oriented correctly.
      Ask FixBot
    6. iPhone 16 Front Camera Assembly Replacement, Expose the bottom edge of the adhesive: step 34, image 1 of 1
      • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
      Ask FixBot
    7. iPhone 16 Front Camera Assembly Replacement, Apply the adhesive: step 35, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Apply the adhesive: step 35, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Apply the adhesive: step 35, image 3 of 3
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • Hold the blue liner out of the way and align the adhesive with the bottom edge of the iPhone.
      • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
      Ask FixBot
    8. iPhone 16 Front Camera Assembly Replacement: step 36, image 1 of 3 iPhone 16 Front Camera Assembly Replacement: step 36, image 2 of 3 iPhone 16 Front Camera Assembly Replacement: step 36, image 3 of 3
      • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
      • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
      • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
      Ask FixBot
    9. iPhone 16 Front Camera Assembly Replacement, Press the adhesive into place: step 37, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Press the adhesive into place: step 37, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Press the adhesive into place: step 37, image 3 of 3
      • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
      • Be careful not to touch the spring contacts sticking through the pink liner.
      Ask FixBot
    10. iPhone 16 Front Camera Assembly Replacement, Remove the pink liner: step 38, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Remove the pink liner: step 38, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Remove the pink liner: step 38, image 3 of 3
      • Use the small pull tab in the top-right corner to remove the pink adhesive liner.
      Ask FixBot
    11. iPhone 16 Front Camera Assembly Replacement: step 39, image 1 of 2 iPhone 16 Front Camera Assembly Replacement: step 39, image 2 of 2
      • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
      • Your pull tabs may be in different positions.
      • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. If the adhesive is clean and properly aligned, you may proceed, just be careful not to touch anything to the exposed adhesive until you are ready to install the back glass.
      Ask FixBot
    12. iPhone 16 Front Camera Assembly Replacement, Connect the charging coil: step 40, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Connect the charging coil: step 40, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Connect the charging coil: step 40, image 3 of 3
      • Prop up the back glass along the right edge of your iPhone, using a box or similar sturdy object to support the screen.
      • Use the flat end of a spudger or your finger to connect the charging coil press connector.
      Ask FixBot
    13. iPhone 16 Front Camera Assembly Replacement, Connect the battery: step 41, image 1 of 2 iPhone 16 Front Camera Assembly Replacement, Connect the battery: step 41, image 2 of 2
      • Use the flat end of a spudger or your finger to connect the battery.
      Ask FixBot
    14. iPhone 16 Front Camera Assembly Replacement, Install the cover: step 42, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Install the cover: step 42, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Install the cover: step 42, image 3 of 3
      • The connector cover has two hooks that slide into slots on the logic board.
      • Lay the connector cover on the phone so the hooks are slightly to the left of their slots in the logic board.
      • Use your finger to press the connector cover down and to the right until both hooks slide into their slots.
      Ask FixBot
    15. iPhone 16 Front Camera Assembly Replacement, Install the cover screws: step 43, image 1 of 2 iPhone 16 Front Camera Assembly Replacement, Install the cover screws: step 43, image 2 of 2
      • Use a tri-point Y000 driver to install the two 1 mm‑long screws securing the middle connector cover.
      Ask FixBot
    16. iPhone 16 Front Camera Assembly Replacement, Remove the final adhesive liners: step 44, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Remove the final adhesive liners: step 44, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Remove the final adhesive liners: step 44, image 3 of 3
      • As you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing touches the exposed adhesive.
      • Use the blue tabs to remove the liners from the bottom, left, and top edges of your iPhone. Wait to remove the liner along the right edge.
      Ask FixBot
    17. iPhone 16 Front Camera Assembly Replacement: step 45, image 1 of 2 iPhone 16 Front Camera Assembly Replacement: step 45, image 2 of 2
      • Without letting the back glass touch the adhesive, hold the back glass over the phone so you can access the final liner along the right edge of the phone.
      • Use a pair of tweezers or your fingers to remove the final liner along the right edge of the phone.
      Ask FixBot
    18. iPhone 16 Front Camera Assembly Replacement, Place the back glass: step 46, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Place the back glass: step 46, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Place the back glass: step 46, image 3 of 3
      • Hold the back glass above the phone and align it with the frame.
      • Lay the glass straight down onto the frame and press until the clips engage.
      • Press around the perimeter of the back glass to engage all clips.
      Ask FixBot
    19. iPhone 16 Front Camera Assembly Replacement, Heat the back glass: step 47, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Heat the back glass: step 47, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Heat the back glass: step 47, image 3 of 3
      • To help the adhesive bond, apply heat to the edges of the back glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
      • Firmly press around the perimeter of the back glass.
      • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the back glass.
      Ask FixBot
    20. iPhone 16 Front Camera Assembly Replacement, Press the back glass: step 48, image 1 of 3 iPhone 16 Front Camera Assembly Replacement, Press the back glass: step 48, image 2 of 3 iPhone 16 Front Camera Assembly Replacement, Press the back glass: step 48, image 3 of 3
      • To evenly compress your iPhone and strengthen the bond of the back glass to the frame, you need to account for the camera bump.
      • If you have the box your iPhone came in, take the lid and place it on a flat surface.
      • If you don't have your original box, skip this step for an alternate method.
      • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
      • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
      • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
      Ask FixBot
    21. iPhone 16 Front Camera Assembly Replacement: step 49, image 1 of 2 iPhone 16 Front Camera Assembly Replacement: step 49, image 2 of 2
      • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the back glass.
      • Place the iPhone screen-side-down on a soft, flat surface.
      • Apply tape to the back glass to protect its finish.
      Ask FixBot
    22. iPhone 16 Front Camera Assembly Replacement: step 50, image 1 of 3 iPhone 16 Front Camera Assembly Replacement: step 50, image 2 of 3 iPhone 16 Front Camera Assembly Replacement: step 50, image 3 of 3
      • Place two layers of coins or similarly thick objects on the tape along the edges of the back glass.
      • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
      Ask FixBot
    23. iPhone 16 Front Camera Assembly Replacement: step 51, image 1 of 1
      • Stack multiple books or other heavy objects on your iPhone.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      Ask FixBot
    1. iPhone 16 Front Camera Assembly Replacement, Install the pentalobe screws: step 52, image 1 of 2 iPhone 16 Front Camera Assembly Replacement, Install the pentalobe screws: step 52, image 2 of 2
      • Use a P2 pentalobe driver to install the two 7.7 mm-long screws on either side of the charging port.
      Ask FixBot
After your repair, calibrate a genuine replacement front camera and Face ID using Apple's Repair Assistant. Navigate to Settings → General → About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Answers Community for help.
Author
with
Alex Diaz-Kokaisl
253,203 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 105
Past 30 Days: 410
All Time: 4,664
