Introduction
Use this guide to replace the earpiece speaker in your iPhone 15 Pro.
If phone calls sound like static or crackling, it may be time to replace the earpiece speaker.
You'll need replacement screen adhesive to complete this repair.
Unplug all cables from your phone.
Hold the power and either volume button and slide to power off your phone.
If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
Apply a suction handle to the bottom edge of the screen.
Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
Insert the tip of an opening pick into the gap.
There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
Slide your pick back and forth along the bottom edge to separate the adhesive.
Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
Rotate your pick so the flat edge is under the screen.
Twist the pick to increase the gap between the screen and the frame until the right clip releases.
Insert a second opening pick to the right of the first pick.
Slide the first pick back to the bottom right corner of the screen.
Slide the second pick to the top right corner of the screen to separate the adhesive.
Leave these picks inserted to prevent the adhesive from resealing.
Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
Rotate your pick around the top left corner of the screen.
Slide your pick to the bottom left corner of the screen to separate the adhesive.
Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cables.
Swing up the right edge of the screen like the front cover of a book.
Prop up the screen so you can access its cables without straining them.
Use a Y000 screwdriver to remove the six screws securing the logic board cover:
Four 1.6 mm‑long screws
Two 1.3 mm‑long screws
Rotate the bottom of the logic board cover counterclockwise and slide the top left corner out from under the ambient light sensor cable to remove it.
Use the tip of an opening pick to pry up and disconnect the battery press connector from the bottom right corner of the logic board.
Use the tip of an opening pick to pry up and disconnect the screen cable from the center of the logic board.
Gently slide the tip of an opening pick under the ambient light sensor cable near the top left corner of the logic board.
Lift the cable to disconnect it.
Use the tip of an opening pick to pry up and disconnect the three rear camera press connectors from the top right of the logic board.
Use a Phillips #000 screwdriver to remove the three screws securing the rear cameras:
One 3.8 mm‑long screw
One 3.2 mm‑long screw
One 2.8 mm‑long screw
Insert the point of a spudger between the top right corner of the rear cameras and frame.
Pry up until you can grab the rear cameras with your fingers.
Remove the rear cameras.
Tool used on this step:Standoff Screwdriver for iPhones$5.49
Use a Phillips #000 screwdriver to remove the 2 mm‑long screw securing the top of the earpiece speaker.
Use a standoff screwdriver to remove the remaining screw securing the bottom left corner of the earpiece speaker.
Congratulations on completing disassembly! The remaining steps show how to reassemble the iPhone.
Align the gasket on the top right corner of the earpiece speaker with its recess in the frame.
Press the gasket into its recess, then lower the earpiece speaker into place.
Use a Phillips #000 screwdriver to install the 2 mm‑long screw securing the top of the earpiece speaker.
Use a standoff screwdriver to install the remaining screw securing the bottom left corner of the earpiece speaker.
Align the rear camera assembly with its recess in the frame and set it into place.
Use a Phillips #000 screwdriver to install the three screws securing the rear cameras:
Use the flat end of a spudger to connect the three rear camera press connectors—starting with the black one—to their respective sockets on the logic board.
Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
Use a pair of tweezers, or your fingers, to remove the adhesive around the entire perimeter of the iPhone.
Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to orient it correctly.
Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but don't remove it all the way.
While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
When the adhesive is aligned, set it down along the bottom edge.
Use the flat end of a spudger to press the adhesive into place all around the iPhone.
Lift the pull tab in the top‑right corner of the frame to peel off the top liner and remove it.
Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
Use your finger or the flat end of a spudger to connect the screen and ambient light sensor press connectors.
Use your finger or the flat end of a spudger to connect the battery press connector.
Slide the top left corner of the logic board cover under the ambient light sensor cable and set it into place, aligned with its screw holes.
Use a Y000 screwdriver to install the six screws securing the logic board cover:
Use tweezers to remove the two narrow liners covering the adhesive along the right, top, and bottom edges of the frame.
Firmly press along the edges of the screen to engage the clips and compress the adhesive.
Use a P2 pentalobe screwdriver to install the two 7 mm‑long screws on either side of the charging port.
To help the adhesive bond, apply heat to the edges of the screen using a hair dryer or heat gun until it's hot to the touch.
If you have screen vise clamps, use them to strengthen the bond of the new adhesive. If not, keep reading for more ways to secure the screen.
If you have the iPhone's original box, take the lid and place it on a flat surface.
If you don't have the original box, skip this step for an alternate method.
Place the iPhone screen-side-up in the lid of the box with the camera bump in its recess.
Find something close to the size of the iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
Leave the objects in place for at least thirty minutes, ideally overnight.
Place the iPhone screen-side-down on a soft, flat surface.
Apply tape to the back glass to protect its finish.
Place three layers of coins or similarly thick objects on the tape along the edges of the back glass.
Evenly distribute the coins and make sure they are at least as thick as the camera bump.
Congratulations on replacing the earpiece speaker!
3 other people completed this guide.
