iPhone 15 Plus Rear Cameras Replacement
    1. iPhone 15 Plus Rear Cameras Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 iPhone 15 Plus Rear Cameras Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Ask FixBot
    2. iPhone 15 Plus Rear Cameras Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 15 Plus Rear Cameras Replacement, Tape over any cracks: step 2, image 2 of 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    1. iPhone 15 Plus Rear Cameras Replacement, Mark your opening picks: step 3, image 1 of 3 iPhone 15 Plus Rear Cameras Replacement, Mark your opening picks: step 3, image 2 of 3 iPhone 15 Plus Rear Cameras Replacement, Mark your opening picks: step 3, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 15 Plus Rear Cameras Replacement, Remove the pentalobe screws: step 4, image 1 of 1
      • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 15 Plus Rear Cameras Replacement, Heat the bottom edge: step 5, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Ask FixBot
    2. iPhone 15 Plus Rear Cameras Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone 15 Plus Rear Cameras Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone 15 Plus Rear Cameras Replacement, Insert an opening pick: step 6, image 3 of 3
      • Apply a suction handle to the bottom edge of the back glass.
      • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    3. iPhone 15 Plus Rear Cameras Replacement, Back glass information: step 7, image 1 of 1
      • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
      • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
      • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
      Ask FixBot
    4. iPhone 15 Plus Rear Cameras Replacement, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 15 Plus Rear Cameras Replacement, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 15 Plus Rear Cameras Replacement, Separate the bottom edge adhesive: step 8, image 3 of 3
      • Don't insert your opening pick deeper than 5 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    5. iPhone 15 Plus Rear Cameras Replacement, Heat the right edge: step 9, image 1 of 1
      • Heat the right edge of the back glass until it's hot to the touch.
      Ask FixBot
    6. iPhone 15 Plus Rear Cameras Replacement, Separate the bottom right corner adhesive: step 10, image 1 of 3 iPhone 15 Plus Rear Cameras Replacement, Separate the bottom right corner adhesive: step 10, image 2 of 3 iPhone 15 Plus Rear Cameras Replacement, Separate the bottom right corner adhesive: step 10, image 3 of 3
      • Don't insert your pick deeper than 7 mm along the right edge.
      • Rotate your pick around the bottom right corner and slide it halfway up the right edge or until you feel a hard stop at a clip securing the back glass.
      • Don't slice near the volume buttons to avoid damaging the wireless charging cable.
      • Leave this pick inserted to prevent the adhesive from resealing.
      Ask FixBot
    7. iPhone 15 Plus Rear Cameras Replacement, Heat the left edge: step 11, image 1 of 1
      • Heat the left edge of the back glass until it's hot to the touch.
      Ask FixBot
    8. iPhone 15 Plus Rear Cameras Replacement, Separate the left edge adhesive: step 12, image 1 of 3 iPhone 15 Plus Rear Cameras Replacement, Separate the left edge adhesive: step 12, image 2 of 3 iPhone 15 Plus Rear Cameras Replacement, Separate the left edge adhesive: step 12, image 3 of 3
      • Don't insert your pick deeper than 5 mm along the left edge.
      • Insert a second opening pick at the bottom edge.
      • Rotate the second pick around the bottom left corner.
      • Slide this pick up to the top left corner to separate the adhesive.
      Ask FixBot
    9. iPhone 15 Plus Rear Cameras Replacement, Heat the top edge: step 13, image 1 of 1
      • Heat the top edge of the back glass until it's hot to the touch.
      Ask FixBot
    10. iPhone 15 Plus Rear Cameras Replacement, Separate the top edge adhesive: step 14, image 1 of 3 iPhone 15 Plus Rear Cameras Replacement, Separate the top edge adhesive: step 14, image 2 of 3 iPhone 15 Plus Rear Cameras Replacement, Separate the top edge adhesive: step 14, image 3 of 3
      • Don't insert your pick deeper than 3 mm along the top edge.
      • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
      • You might hear and feel clicks as the top two clips release.
      • Leave this pick in place to prevent the adhesive from resealing.
      Ask FixBot
    11. iPhone 15 Plus Rear Cameras Replacement, Heat the top right corner: step 15, image 1 of 1
      • Heat the top right corner of the back glass until it's hot to the touch.
      Ask FixBot
    12. iPhone 15 Plus Rear Cameras Replacement, Separate the top right corner adhesive: step 16, image 1 of 3 iPhone 15 Plus Rear Cameras Replacement, Separate the top right corner adhesive: step 16, image 2 of 3 iPhone 15 Plus Rear Cameras Replacement, Separate the top right corner adhesive: step 16, image 3 of 3
      • Don't insert your pick deeper than 4 mm along the right edge.
      • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
      Ask FixBot
    13. iPhone 15 Plus Rear Cameras Replacement, Swing open the back glass: step 17, image 1 of 2 iPhone 15 Plus Rear Cameras Replacement, Swing open the back glass: step 17, image 2 of 2
      • Gently swing open the back glass to the right of the phone.
      • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
      • Rest the back glass against a raised surface so it doesn't strain the cable.
      Ask FixBot
    1. iPhone 15 Plus Rear Cameras Replacement, Unfasten the lower connector cover: step 18, image 1 of 2 iPhone 15 Plus Rear Cameras Replacement, Unfasten the lower connector cover: step 18, image 2 of 2
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
      Ask FixBot
    2. iPhone 15 Plus Rear Cameras Replacement, Remove the lower connector cover: step 19, image 1 of 3 iPhone 15 Plus Rear Cameras Replacement, Remove the lower connector cover: step 19, image 2 of 3 iPhone 15 Plus Rear Cameras Replacement, Remove the lower connector cover: step 19, image 3 of 3
      Buy
      • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
      • Remove the cover.
      Ask FixBot
    3. iPhone 15 Plus Rear Cameras Replacement: step 20, image 1 of 3 iPhone 15 Plus Rear Cameras Replacement: step 20, image 2 of 3 iPhone 15 Plus Rear Cameras Replacement: step 20, image 3 of 3
      • Hold the back glass upright with one hand and rotate the bottom edge to the left to reveal the battery press connector just below the volume buttons.
      • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
      • A plus and minus sign is printed on the head of this connector.
      • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
      Ask FixBot
    1. iPhone 15 Plus Rear Cameras Replacement, Disconnect the rear cameras and antenna: step 21, image 1 of 3 iPhone 15 Plus Rear Cameras Replacement, Disconnect the rear cameras and antenna: step 21, image 2 of 3 iPhone 15 Plus Rear Cameras Replacement, Disconnect the rear cameras and antenna: step 21, image 3 of 3
      • Use the tip of an opening pick to pry up and disconnect the two rear camera press connectors and the antenna press connector located to the top right of the battery.
      Ask FixBot
    2. iPhone 15 Plus Rear Cameras Replacement, Unfasten the rear cameras: step 22, image 1 of 1
      • Use a Phillips #00 driver to remove the three 2.2 mm‑long screws securing the rear cameras.
      Ask FixBot
    3. iPhone 15 Plus Rear Cameras Replacement, Free the camera cables: step 23, image 1 of 3 iPhone 15 Plus Rear Cameras Replacement, Free the camera cables: step 23, image 2 of 3 iPhone 15 Plus Rear Cameras Replacement, Free the camera cables: step 23, image 3 of 3
      • The two rear camera cables route underneath the antenna cable, making rear camera removal tricky. Follow the next two steps to free the camera cables.
      • Use your fingers to grab the top and bottom press connectors and lift their cables out from their channels along the edge of the battery.
      • This leaves just the middle of the three press connectors in place.
      Ask FixBot
    4. iPhone 15 Plus Rear Cameras Replacement, Separate the antenna cable adhesive: step 24, image 1 of 3 iPhone 15 Plus Rear Cameras Replacement, Separate the antenna cable adhesive: step 24, image 2 of 3 iPhone 15 Plus Rear Cameras Replacement, Separate the antenna cable adhesive: step 24, image 3 of 3
      • The cable for the middle press connector is adhered to an adjacent cable along the top edge of the battery. In this step, you'll separate this adhesive.
      • Hold the two cables you just freed out of the way of the middle press connector cable.
      • Insert the tip of an opening pick between the middle press connector cable and its adjacent cable to separate the adhesive.
      Ask FixBot
    5. iPhone 15 Plus Rear Cameras Replacement, Pry up the rear cameras: step 25, image 1 of 2 iPhone 15 Plus Rear Cameras Replacement, Pry up the rear cameras: step 25, image 2 of 2
      • Use the point of your spudger to pry up the top edge of the rear cameras until you can grab them with your fingers.
      Ask FixBot
    6. iPhone 15 Plus Rear Cameras Replacement, Remove the rear cameras: step 26, image 1 of 3 iPhone 15 Plus Rear Cameras Replacement, Remove the rear cameras: step 26, image 2 of 3 iPhone 15 Plus Rear Cameras Replacement, Remove the rear cameras: step 26, image 3 of 3
      • Pull the rear cameras toward the top of the phone and let their cables slide underneath the antenna cable.
      • Remove the rear cameras.
      • During reassembly, make sure the camera cables route underneath the antenna cable. Use this picture for reference to order the cables correctly.
      Ask FixBot
To reassemble your phone, follow these instructions in reverse order.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings → General →About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
3 other people completed this guide.
Clay Eickemeyer
107,902 Reputation
472 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,630 Guides authored
1 Guide Comment
Hallo, wo kann ich die Reparatur machen lassen, meine Finger sind nicht mehr ruhig genug???
Wilma Werning - Reply Share
Past 24 Hours: 16
Past 7 Days: 99
Past 30 Days: 345
All Time: 5,267
