Up to 20% off select tools
iPhone 14 Screen Replacement
Views: 155K
View statistics:
Past 24 Hours:
139
Past 7 Days:
938
Past 30 Days:
4,234
All Time:
154,986
Comments: 60
43 comments on steps, 17 guide comments.
Go to guide comments
Completed: 68
68 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
  • iPhone 14 Screen
    4.7
Parts
Tools
Introduction
Go to step 1 ↓
If your iPhone 14 screen is cracked, not responding to touch, or not showing a picture when your phone is powered on, use this guide to restore your iPhone to working order with a new screen, a.k.a. display assembly.
This guide was created using the A2882 (international) model. If you're fixing a different iPhone 14 model, there may be some visual discrepancies, but the procedure should be the same.
Note: On iOS 17.6 and earlier, True Tone and auto brightness functionality is disabled after a screen replacement, even when using an original Apple screen. Face ID is also disabled, unless the iPhone is running iOS 15.2 or newer. On the latest iOS version, you can calibrate your new screen using Apple's Repair Assistant to restore True Tone functionality. This may happen automatically.
You’ll need replacement adhesive to reattach the screen when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
    1. iPhone 14 Screen Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone 14 Screen Replacement, Remove the pentalobe screws: step 1, image 2 of 2
      • Power off your iPhone before beginning disassembly.
      • Use a P2 pentalobe screwdriver to remove the two 6.8 mm‑long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 14 Screen Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 14 Screen Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 14 Screen Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 14 Screen Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone 14 Screen Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone 14 Screen Replacement, Tape over any cracks: step 3, image 3 of 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Ask FixBot
    2. iPhone 14 Screen Replacement, Screen information: step 4, image 1 of 3 iPhone 14 Screen Replacement, Screen information: step 4, image 2 of 3 iPhone 14 Screen Replacement, Screen information: step 4, image 3 of 3
      • For easier screen removal in the next steps, note the following:
      • There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll separate the two.
      • Sometimes the display panel separates from the bezel before you even get a chance to insert a pick. This may be unavoidable depending on the condition of the adhesive.
      Ask FixBot
    3. iPhone 14 Screen Replacement, Heat the bottom edge: step 5, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom half of the screen until it’s slightly too hot to touch. This softens the adhesive securing it.
      • Improper use of a heat gun can destroy the display and/or battery—review this guide for instructions. To prevent screen damage, keep your heat source moving rather than focused on one spot.
      • For tips on using a hair dryer to soften adhesive, check out this guide.
      Ask FixBot
    4. iPhone 14 Screen Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone 14 Screen Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone 14 Screen Replacement, Insert an opening pick: step 6, image 3 of 3
      • Apply a suction handle near the bottom edge of the screen.
      • Pull up on the suction handle with firm, constant pressure to create a slight gap under the screen.
      • The adhesive holding the screen in place is very strong. If you're having a hard time, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • Insert an opening pick beneath the screen and its plastic bezel.
      • Make sure to insert the opening pick under the thick plastic bezel to avoid damaging your screen. You should see a visual gap, and the pick shouldn't catch on anything. If you can't see the gap, you'll need to pull the screen up more.
      • If you can't create a gap, apply more heat to the edge and try again.
      Ask FixBot
    5. iPhone 14 Screen Replacement, Separate the bottom edge adhesive: step 7, image 1 of 3 iPhone 14 Screen Replacement, Separate the bottom edge adhesive: step 7, image 2 of 3 iPhone 14 Screen Replacement, Separate the bottom edge adhesive: step 7, image 3 of 3
      • Don't insert your opening pick deeper than 3 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    6. iPhone 14 Screen Replacement, Heat the right edge: step 8, image 1 of 2 iPhone 14 Screen Replacement, Heat the right edge: step 8, image 2 of 2
      • Heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
      Ask FixBot
    7. iPhone 14 Screen Replacement, Separate the right adhesive: step 9, image 1 of 3 iPhone 14 Screen Replacement, Separate the right adhesive: step 9, image 2 of 3 iPhone 14 Screen Replacement, Separate the right adhesive: step 9, image 3 of 3
      • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
      • Continue sliding up the right edge of the iPhone until you reach the top right corner.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      • Leave the pick in the top right corner before continuing.
      Ask FixBot
    8. iPhone 14 Screen Replacement, Heat the top edge: step 10, image 1 of 1
      • Heat the top edge of the iPhone until the screen is slightly too hot to touch.
      Ask FixBot
    9. iPhone 14 Screen Replacement, Separate the top adhesive: step 11, image 1 of 3 iPhone 14 Screen Replacement, Separate the top adhesive: step 11, image 2 of 3 iPhone 14 Screen Replacement, Separate the top adhesive: step 11, image 3 of 3
      • Don't insert your pick deeper than 3 mm along the top edge.
      • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
      Ask FixBot
    10. iPhone 14 Screen Replacement, Heat the left edge: step 12, image 1 of 2 iPhone 14 Screen Replacement, Heat the left edge: step 12, image 2 of 2
      • Heat the left edge of the iPhone until the screen is slightly too hot to touch.
      Ask FixBot
    11. iPhone 14 Screen Replacement, Separate the left adhesive: step 13, image 1 of 3 iPhone 14 Screen Replacement, Separate the left adhesive: step 13, image 2 of 3 iPhone 14 Screen Replacement, Separate the left adhesive: step 13, image 3 of 3
      • There are delicate cables along the left edge of your iPhone. Don't insert your pick deeper than 2 mm here, as you may damage the cables.
      • Rotate your pick around the top left corner of the screen.
      • Slide your pick to the bottom left corner of the screen to separate the adhesive.
      • If you're having trouble separating the adhesive, reheat the left edge.
      Ask FixBot
    12. iPhone 14 Screen Replacement, Open the iPhone: step 14, image 1 of 3 iPhone 14 Screen Replacement, Open the iPhone: step 14, image 2 of 3 iPhone 14 Screen Replacement, Open the iPhone: step 14, image 3 of 3
      • Remove your suction handle from the screen.
      • Rotate your iPhone so the right edge faces you.
      • Open your iPhone by swinging the screen up from the right side, like the front cover of a book.
      • Lean the screen against something to keep it propped up while you're working on the phone.
      • If you don't have anything at hand to lean the screen against, your suction handle can do the trick.
      • During reassembly, lay the screen in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the screen down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the screen and make sure they aren't bent.
      Ask FixBot
    13. iPhone 14 Screen Replacement, Unfasten the display connector bracket screw: step 15, image 1 of 2 iPhone 14 Screen Replacement, Unfasten the display connector bracket screw: step 15, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Use a Y000 screwdriver to remove the 0.9 mm-long screw securing the display connector bracket.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the screen in place. Be sure to power your iPhone back down completely before you continue working.
      Ask FixBot
    14. iPhone 14 Screen Replacement, Remove the display connector bracket: step 16, image 1 of 3 iPhone 14 Screen Replacement, Remove the display connector bracket: step 16, image 2 of 3 iPhone 14 Screen Replacement, Remove the display connector bracket: step 16, image 3 of 3
      Buy
      • Grasp the screw hole end of the connector bracket with a pair of tweezers.
      • Lift the bracket slightly to loosen the latch on the other edge.
      • Remove the display connector bracket.
      • During reassembly, make sure the bracket latches properly.
      Ask FixBot
    15. iPhone 14 Screen Replacement, Disconnect the display connector: step 17, image 1 of 2 iPhone 14 Screen Replacement, Disconnect the display connector: step 17, image 2 of 2
      • Use the pointed end of a spudger to disconnect the display cable by prying the connector straight up from its socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    16. iPhone 14 Screen Replacement, Unfasten the front sensor connector bracket: step 18, image 1 of 2 iPhone 14 Screen Replacement, Unfasten the front sensor connector bracket: step 18, image 2 of 2
      • Use a Y000 screwdriver to remove the 0.9 mm-long screw securing the front sensor connector bracket.
      Ask FixBot
    17. iPhone 14 Screen Replacement, Remove the front sensor connector bracket: step 19, image 1 of 3 iPhone 14 Screen Replacement, Remove the front sensor connector bracket: step 19, image 2 of 3 iPhone 14 Screen Replacement, Remove the front sensor connector bracket: step 19, image 3 of 3
      • Remove the front sensor connector bracket.
      Ask FixBot
    18. iPhone 14 Screen Replacement, Disconnect the front sensor cable: step 20, image 1 of 2 iPhone 14 Screen Replacement, Disconnect the front sensor cable: step 20, image 2 of 2
      • Use the pointed end of a spudger to disconnect the front sensor cable by prying the connector straight up from its socket.
      Ask FixBot
    19. iPhone 14 Screen Replacement, Remove the screen: step 21, image 1 of 2 iPhone 14 Screen Replacement, Remove the screen: step 21, image 2 of 2
      • Remove the screen.
      • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • During reassembly, pause here if you wish to replace the screen adhesives.
      Ask FixBot
    1. Careful: step 22 is sourced from a guide that's marked as in-progress.
      iPhone 14 Screen Replacement, Front sensors information: step 22, image 1 of 1
      • The front sensor assembly is located behind the screen, directly beneath the cut‑out for the Face ID sensors.
      • Check if the replacement screen comes with one installed. If it does, skip the rest of these steps.
      Ask FixBot
    1. iPhone 14 Screen Replacement, Unfasten the front sensor bracket: step 23, image 1 of 1
      • Use a Y000 screwdriver to remove the two 1.4 mm-long screws securing the sensor assembly bracket.
      Ask FixBot
    2. iPhone 14 Screen Replacement, Remove the front sensor bracket: step 24, image 1 of 2 iPhone 14 Screen Replacement, Remove the front sensor bracket: step 24, image 2 of 2
      Buy
      • Use tweezers, or your fingers, to remove the front sensor assembly bracket.
      Ask FixBot
    3. iPhone 14 Screen Replacement, Heat the front sensor assembly: step 25, image 1 of 2 iPhone 14 Screen Replacement, Heat the front sensor assembly: step 25, image 2 of 2
      • Heat an iOpener and apply it to the top edge of the screen for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
      Ask FixBot
    4. iPhone 14 Screen Replacement, Disconnect the ambient light sensor: step 26, image 1 of 2 iPhone 14 Screen Replacement, Disconnect the ambient light sensor: step 26, image 2 of 2
      • Insert an opening pick between the ambient light sensor and its recess in the screen.
      • Pry up with the pick to separate the ambient light sensor from the screen.
      Ask FixBot
    5. iPhone 14 Screen Replacement, Disconnect the proximity sensor: step 27, image 1 of 2 iPhone 14 Screen Replacement, Disconnect the proximity sensor: step 27, image 2 of 2
      • Insert an opening pick between the proximity sensor and its recess on the screen.
      • Pry up with the pick to separate the proximity sensor from the screen.
      Ask FixBot
    6. iPhone 14 Screen Replacement, Reposition the proximity sensor: step 28, image 1 of 2 iPhone 14 Screen Replacement, Reposition the proximity sensor: step 28, image 2 of 2
      • Use tweezers, or your fingers, to move the proximity sensor cable away from the screen.
      Ask FixBot
    7. iPhone 14 Screen Replacement, Disconnect the microphone: step 29, image 1 of 3 iPhone 14 Screen Replacement, Disconnect the microphone: step 29, image 2 of 3 iPhone 14 Screen Replacement, Disconnect the microphone: step 29, image 3 of 3
      • Insert an opening pick under the microphone cable, close to the microphone (the metal rectangle).
      • Slide the opening pick around the perimeter of the microphone to separate its adhesive.
      Ask FixBot
    8. iPhone 14 Screen Replacement, Remove the front sensor assembly: step 30, image 1 of 3 iPhone 14 Screen Replacement, Remove the front sensor assembly: step 30, image 2 of 3 iPhone 14 Screen Replacement, Remove the front sensor assembly: step 30, image 3 of 3
      • At this point, the adhesive may have cooled down. If so, apply a heated iOpener to the assembly for one minute before continuing.
      • Insert an opening pick under the left side of the front sensor assembly.
      • Slide the pick under the assembly to separate it from the frame.
      Ask FixBot
    9. iPhone 14 Screen Replacement: step 31, image 1 of 2 iPhone 14 Screen Replacement: step 31, image 2 of 2
      • Remove the front sensor assembly.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings → General →About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the frame and place the screen back in its original position.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
68 other people completed this guide.
Author
with
Tobias Isakeit
136,836 Reputation
189 Guides authored
17 Guide Comments
great and good job
kungsholmens mobil - Reply Share
Is there still a software lock that disables face id / auto brightness?
Yung Bruh - Reply Share
Your proximity cable was probably damaged while being moved. You would need to replace it and recalibrate the face ID to fix it
Travis - Reply Share
What about the battery isnt it a risk to connect it like this. Feels like half of the repair job,
atlas Tanko - Reply Share
Hi atlas Tanko, you're right, normally we recommend disconnecting the battery before replacing the screen. Due to the design of the iPhone 14 and 14 Plus (separate entry methods for screen and battery replacements), we consider it safe in this case. For the iPhone 14 Pro and Pro Max, we still include steps for disconnecting the battery during screen replacements.
Manuel Haeussermann - Reply Share
Past 24 Hours: 139
Past 7 Days: 938
Past 30 Days: 4,234
All Time: 154,986
