iPhone 14 Rear-Facing Cameras Replacement
  1. iPhone 14 Rear-Facing Cameras Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone 14 Rear-Facing Cameras Replacement, Remove the pentalobe screws: step 1, image 2 of 2
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
  2. iPhone 14 Rear-Facing Cameras Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 14 Rear-Facing Cameras Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 14 Rear-Facing Cameras Replacement, Mark your opening picks: step 2, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 14 Rear-Facing Cameras Replacement, Tape over any cracks: step 3, image 1 of 2 iPhone 14 Rear-Facing Cameras Replacement, Tape over any cracks: step 3, image 2 of 2
    • If your iPhone has a cracked rear glass, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's rear glass until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the rear glass with that instead.
    • If all else fails, you can superglue the suction cup to the rear glass.
  4. iPhone 14 Rear-Facing Cameras Replacement, Heat the bottom edge: step 4, image 1 of 1
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone until the rear glass is slightly too hot to touch.
    • Never leave your heat gun in one spot for an extended period of time.
  5. iPhone 14 Rear-Facing Cameras Replacement, Insert an opening pick: step 5, image 1 of 3 iPhone 14 Rear-Facing Cameras Replacement, Insert an opening pick: step 5, image 2 of 3 iPhone 14 Rear-Facing Cameras Replacement, Insert an opening pick: step 5, image 3 of 3
    • Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
    • Insert an opening pick into the gap.
    • The adhesive holding the rear glass in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the rear glass up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
  6. iPhone 14 Rear-Facing Cameras Replacement, Heat the left edge: step 6, image 1 of 1
    • Heat the left edge of the iPhone until the rear glass is slightly too hot to touch.
  7. iPhone 14 Rear-Facing Cameras Replacement, Slice the left edge adhesive: step 7, image 1 of 3 iPhone 14 Rear-Facing Cameras Replacement, Slice the left edge adhesive: step 7, image 2 of 3 iPhone 14 Rear-Facing Cameras Replacement, Slice the left edge adhesive: step 7, image 3 of 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  8. iPhone 14 Rear-Facing Cameras Replacement, Rear glass information: step 8, image 1 of 1
    • There's a delicate cable along the right edge, next to the volume up button. Don't insert your pick here, as you may damage the cable.
  9. iPhone 14 Rear-Facing Cameras Replacement, Heat the right edge: step 9, image 1 of 1
    • Heat the right edge of the iPhone (the edge with the volume buttons) until the rear glass is slightly too hot to touch.
  10. iPhone 14 Rear-Facing Cameras Replacement, Slice the right edge adhesive: step 10, image 1 of 3 iPhone 14 Rear-Facing Cameras Replacement, Slice the right edge adhesive: step 10, image 2 of 3 iPhone 14 Rear-Facing Cameras Replacement, Slice the right edge adhesive: step 10, image 3 of 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the charging coil cable.
  11. iPhone 14 Rear-Facing Cameras Replacement, Heat the top edge: step 11, image 1 of 1
    • Heat the top edge of the iPhone until the rear glass is slightly too hot to touch.
  12. iPhone 14 Rear-Facing Cameras Replacement, Slice the top edge adhesive: step 12, image 1 of 3 iPhone 14 Rear-Facing Cameras Replacement, Slice the top edge adhesive: step 12, image 2 of 3 iPhone 14 Rear-Facing Cameras Replacement, Slice the top edge adhesive: step 12, image 3 of 3
    • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
  13. iPhone 14 Rear-Facing Cameras Replacement: step 13, image 1 of 3 iPhone 14 Rear-Facing Cameras Replacement: step 13, image 2 of 3 iPhone 14 Rear-Facing Cameras Replacement: step 13, image 3 of 3
    • Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and halfway across the top edge.
    • Don't insert the pick more than 3 mm, as you may damage or smear the camera array.
    • Don't try to fully separate the rear glass yet, as a fragile ribbon cable still connects it to the iPhone's logic board.
  14. iPhone 14 Rear-Facing Cameras Replacement, Open the iPhone: step 14, image 1 of 3 iPhone 14 Rear-Facing Cameras Replacement, Open the iPhone: step 14, image 2 of 3 iPhone 14 Rear-Facing Cameras Replacement, Open the iPhone: step 14, image 3 of 3
    • Remove your suction handle from the rear glass.
    • Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
    • Be careful not to strain the short charging coil flex cable.
    • Lean the rear glass against something to keep it propped up while you're working on the phone.
    • If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
    • During reassembly, lay the rear glass in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the rear glass and make sure they aren't bent.
  15. iPhone 14 Rear-Facing Cameras Replacement, Unfasten the battery connector cover screws: step 15, image 1 of 2 iPhone 14 Rear-Facing Cameras Replacement, Unfasten the battery connector cover screws: step 15, image 2 of 2
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  16. iPhone 14 Rear-Facing Cameras Replacement, Remove the battery connector cover: step 16, image 1 of 3 iPhone 14 Rear-Facing Cameras Replacement, Remove the battery connector cover: step 16, image 2 of 3 iPhone 14 Rear-Facing Cameras Replacement, Remove the battery connector cover: step 16, image 3 of 3
    Buy
    • Grasp the battery connector cover with a pair of tweezers and slide it upwards (towards the A15 print) to unlatch the top hook.
    • Remove the battery connector cover.
  17. iPhone 14 Rear-Facing Cameras Replacement, Disconnect the battery: step 17, image 1 of 2 iPhone 14 Rear-Facing Cameras Replacement, Disconnect the battery: step 17, image 2 of 2
    • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  18. iPhone 14 Rear-Facing Cameras Replacement, Unfasten the charging coil connector cover screw: step 18, image 1 of 2 iPhone 14 Rear-Facing Cameras Replacement, Unfasten the charging coil connector cover screw: step 18, image 2 of 2
    • Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
  19. iPhone 14 Rear-Facing Cameras Replacement, Remove the charging coil connector bracket: step 19, image 1 of 2 iPhone 14 Rear-Facing Cameras Replacement, Remove the charging coil connector bracket: step 19, image 2 of 2
    • Use a pair of tweezers to remove the charging coil connector cover.
  20. iPhone 14 Rear-Facing Cameras Replacement, Disconnect the charging coil: step 20, image 1 of 2 iPhone 14 Rear-Facing Cameras Replacement, Disconnect the charging coil: step 20, image 2 of 2
    • Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
  21. iPhone 14 Rear-Facing Cameras Replacement, Remove the rear glass assembly: step 21, image 1 of 2 iPhone 14 Rear-Facing Cameras Replacement, Remove the rear glass assembly: step 21, image 2 of 2
    • Remove the rear glass assembly.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, pause here if you wish to replace the rear glass adhesives.
  22. iPhone 14 Rear-Facing Cameras Replacement, Disconnect the rear-facing camera assembly: step 22, image 1 of 3 iPhone 14 Rear-Facing Cameras Replacement, Disconnect the rear-facing camera assembly: step 22, image 2 of 3 iPhone 14 Rear-Facing Cameras Replacement, Disconnect the rear-facing camera assembly: step 22, image 3 of 3
    • Use a spudger to disconnect the two rear facing camera cables by prying the connectors straight up from their sockets.
  23. iPhone 14 Rear-Facing Cameras Replacement, Remove the rear-facing camera assembly screws: step 23, image 1 of 1
    • Use a Phillips screwdriver to remove the three 2.1 mm-long screws securing the rear camera assembly.
  24. iPhone 14 Rear-Facing Cameras Replacement, Pry up the rear-facing camera assembly: step 24, image 1 of 2 iPhone 14 Rear-Facing Cameras Replacement, Pry up the rear-facing camera assembly: step 24, image 2 of 2
    • Insert the pointed end of a spudger underneath the top edge of the rear-facing camera assembly.
    • Pry up with the spudger to loosen the rear-facing camera assembly.
  25. iPhone 14 Rear-Facing Cameras Replacement, Remove the rear-facing camera assembly: step 25, image 1 of 3 iPhone 14 Rear-Facing Cameras Replacement, Remove the rear-facing camera assembly: step 25, image 2 of 3 iPhone 14 Rear-Facing Cameras Replacement, Remove the rear-facing camera assembly: step 25, image 3 of 3
    Buy
    • Use a pair of tweezers or your fingers to remove the rear-facing camera assembly.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
6 other people completed this guide.
Dominik Schnabelrauch
258,048 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
25,685 Guides authored
4 Guide Comments
Be Careful!! In certain models you also have to unplug the cable that goes over the camera cables, and lift it slightly out of the way. (this cable plugs in just below where the wireless coil plugs in) failure to do so will rip this cable.
Phone Doctors Ohio - Reply Share
I need your help.
iPhone 14 backcamera not working.
Opened the iPhone, disconnected battery and camera, reconnected everything and closed the phone.
Camera is working for a few hours and then it went black again.
iPhone didn’t drop, no water or anything. Just using it. Took a bunch of photos and next photo didn’t work anymore.
Any ideas? I already cleaned the connectors with alcohol. Nothing changed. Closed the phone and camera is working only for a few hours.
A new camera is so %#*@ expensive and even I don’t know if it is really a hardware problem of the cam.
Pättes - Reply Share
Hey Pättes,
Do the other cameras work when you use the camera app? If you can, try a third-party camera app to see if it can display anything. If nothing displays, there's a high chance it's a hardware issue.
When you start the camera app and it shows only black, does the camera area around the back cover get very hot after a minute—almost too hot to the touch? If so, it's likely a hardware malfunction.
Arthur Shi - Reply Share
Die Anleitung ist sehr gut. Beim Zusammenbau ist mir leider das Kabel zur Ladespule auf der Rückseite gerissen. Ich habe dann eine neue Ladespule (iPhone 14 Wireless Charging Antenna) bestellt und mithilfe der iFixit-Anleitung (https://de.ifixit.com/Anleitung/iPhone+1...) den Austausch durchgeführt. Das hat super funktioniert und ist vielleicht auch ein Tipp für diejenigen, denen es auch passiert.
Manuel Beer - Reply Share
Past 24 Hours: 36
Past 7 Days: 281
Past 30 Days: 1,298
All Time: 35,176
