iPhone 14 Loudspeaker Replacement
    1. iPhone 14 Loudspeaker Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone 14 Loudspeaker Replacement, Remove the pentalobe screws: step 1, image 2 of 2
      • Power off your iPhone before beginning disassembly.
      • Use a P2 pentalobe screwdriver to remove the two 6.8 mm‑long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 14 Loudspeaker Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 14 Loudspeaker Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 14 Loudspeaker Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 14 Loudspeaker Replacement, Tape over any cracks: step 3, image 1 of 2 iPhone 14 Loudspeaker Replacement, Tape over any cracks: step 3, image 2 of 2
      • If your iPhone has a cracked rear glass, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's rear glass until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the rear glass with that instead.
      • If all else fails, you can superglue the suction cup to the rear glass.
      Ask FixBot
    2. iPhone 14 Loudspeaker Replacement, Heat the bottom edge: step 4, image 1 of 1
      • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone until the rear glass is slightly too hot to touch.
      • Never leave your heat gun in one spot for an extended period of time.
      Ask FixBot
    3. iPhone 14 Loudspeaker Replacement, Insert an opening pick: step 5, image 1 of 3 iPhone 14 Loudspeaker Replacement, Insert an opening pick: step 5, image 2 of 3 iPhone 14 Loudspeaker Replacement, Insert an opening pick: step 5, image 3 of 3
      • Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
      • Insert an opening pick into the gap.
      • The adhesive holding the rear glass in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the rear glass up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
      Ask FixBot
    4. iPhone 14 Loudspeaker Replacement, Heat the left edge: step 6, image 1 of 1
      • Heat the left edge of the iPhone until the rear glass is slightly too hot to touch.
      Ask FixBot
    5. iPhone 14 Loudspeaker Replacement, Slice the left edge adhesive: step 7, image 1 of 3 iPhone 14 Loudspeaker Replacement, Slice the left edge adhesive: step 7, image 2 of 3 iPhone 14 Loudspeaker Replacement, Slice the left edge adhesive: step 7, image 3 of 3
      • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      Ask FixBot
    6. iPhone 14 Loudspeaker Replacement, Rear glass information: step 8, image 1 of 1
      • There's a delicate cable along the right edge, next to the volume up button. Don't insert your pick here, as you may damage the cable.
      Ask FixBot
    7. iPhone 14 Loudspeaker Replacement, Heat the right edge: step 9, image 1 of 1
      • Heat the right edge of the iPhone (the edge with the volume buttons) until the rear glass is slightly too hot to touch.
      Ask FixBot
    8. iPhone 14 Loudspeaker Replacement, Slice the right edge adhesive: step 10, image 1 of 3 iPhone 14 Loudspeaker Replacement, Slice the right edge adhesive: step 10, image 2 of 3 iPhone 14 Loudspeaker Replacement, Slice the right edge adhesive: step 10, image 3 of 3
      • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the charging coil cable.
      Ask FixBot
    9. iPhone 14 Loudspeaker Replacement, Heat the top edge: step 11, image 1 of 1
      • Heat the top edge of the iPhone until the rear glass is slightly too hot to touch.
      Ask FixBot
    10. iPhone 14 Loudspeaker Replacement, Slice the top edge adhesive: step 12, image 1 of 3 iPhone 14 Loudspeaker Replacement, Slice the top edge adhesive: step 12, image 2 of 3 iPhone 14 Loudspeaker Replacement, Slice the top edge adhesive: step 12, image 3 of 3
      • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
      Ask FixBot
    11. iPhone 14 Loudspeaker Replacement: step 13, image 1 of 3 iPhone 14 Loudspeaker Replacement: step 13, image 2 of 3 iPhone 14 Loudspeaker Replacement: step 13, image 3 of 3
      • Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and halfway across the top edge.
      • Don't insert the pick more than 3 mm, as you may damage or smear the camera array.
      • Don't try to fully separate the rear glass yet, as a fragile ribbon cable still connects it to the iPhone's logic board.
      Ask FixBot
    12. iPhone 14 Loudspeaker Replacement, Open the iPhone: step 14, image 1 of 3 iPhone 14 Loudspeaker Replacement, Open the iPhone: step 14, image 2 of 3 iPhone 14 Loudspeaker Replacement, Open the iPhone: step 14, image 3 of 3
      • Remove your suction handle from the rear glass.
      • Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
      • Be careful not to strain the short charging coil flex cable.
      • Lean the rear glass against something to keep it propped up while you're working on the phone.
      • If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
      • During reassembly, lay the rear glass in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the rear glass and make sure they aren't bent.
      Ask FixBot
    13. iPhone 14 Loudspeaker Replacement, Unfasten the battery connector cover screws: step 15, image 1 of 2 iPhone 14 Loudspeaker Replacement, Unfasten the battery connector cover screws: step 15, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      Ask FixBot
    14. iPhone 14 Loudspeaker Replacement, Remove the battery connector cover: step 16, image 1 of 3 iPhone 14 Loudspeaker Replacement, Remove the battery connector cover: step 16, image 2 of 3 iPhone 14 Loudspeaker Replacement, Remove the battery connector cover: step 16, image 3 of 3
      Buy
      • Grasp the battery connector cover with a pair of tweezers and slide it upwards (towards the A15 print) to unlatch the top hook.
      • Remove the battery connector cover.
      Ask FixBot
    15. iPhone 14 Loudspeaker Replacement, Disconnect the battery: step 17, image 1 of 2 iPhone 14 Loudspeaker Replacement, Disconnect the battery: step 17, image 2 of 2
      • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Ask FixBot
    16. iPhone 14 Loudspeaker Replacement, Unfasten the charging coil connector cover screw: step 18, image 1 of 2 iPhone 14 Loudspeaker Replacement, Unfasten the charging coil connector cover screw: step 18, image 2 of 2
      • Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
      Ask FixBot
    17. iPhone 14 Loudspeaker Replacement, Remove the charging coil connector bracket: step 19, image 1 of 2 iPhone 14 Loudspeaker Replacement, Remove the charging coil connector bracket: step 19, image 2 of 2
      • Use a pair of tweezers to remove the charging coil connector cover.
      Ask FixBot
    18. iPhone 14 Loudspeaker Replacement, Disconnect the charging coil: step 20, image 1 of 2 iPhone 14 Loudspeaker Replacement, Disconnect the charging coil: step 20, image 2 of 2
      • Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
      Ask FixBot
    19. iPhone 14 Loudspeaker Replacement, Remove the rear glass assembly: step 21, image 1 of 2 iPhone 14 Loudspeaker Replacement, Remove the rear glass assembly: step 21, image 2 of 2
      • Remove the rear glass assembly.
      • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • During reassembly, pause here if you wish to replace the rear glass adhesives.
      Ask FixBot
    1. iPhone 14 Loudspeaker Replacement, Remove the Taptic Engine screws: step 22, image 1 of 1
      • Use a Phillips screwdriver to remove the three 2.1 mm-long screws securing the Taptic Engine.
      Ask FixBot
    2. iPhone 14 Loudspeaker Replacement, Remove the Taptic Engine Connector Bracket: step 23, image 1 of 2 iPhone 14 Loudspeaker Replacement, Remove the Taptic Engine Connector Bracket: step 23, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the Taptic Engine connector bracket.
      Ask FixBot
    3. iPhone 14 Loudspeaker Replacement, Disconnect the Taptic Engine: step 24, image 1 of 2 iPhone 14 Loudspeaker Replacement, Disconnect the Taptic Engine: step 24, image 2 of 2
      • Use the pointed end of a spudger to disconnect the Taptic Engine by prying the connector straight up from its socket.
      Ask FixBot
    4. iPhone 14 Loudspeaker Replacement, Remove the Taptic Engine: step 25, image 1 of 2 iPhone 14 Loudspeaker Replacement, Remove the Taptic Engine: step 25, image 2 of 2
      • Use a pair of tweezers or your fingers to remove the Taptic Engine.
      Ask FixBot
    1. iPhone 14 Loudspeaker Replacement, Remove the metal bracket screw: step 26, image 1 of 1
      • Use a Phillips screwdriver to remove the 1.5 mm-long screw securing the metal bracket on the right side of the charging port.
      Ask FixBot
    2. iPhone 14 Loudspeaker Replacement, Remove the metal bracket: step 27, image 1 of 3 iPhone 14 Loudspeaker Replacement, Remove the metal bracket: step 27, image 2 of 3 iPhone 14 Loudspeaker Replacement, Remove the metal bracket: step 27, image 3 of 3
      Buy
      • Use a pair of tweezers to carefully fold the metal bracket in an upright position to unhinge it from its plastic hook.
      • During reassembly make sure to align the bracket correctly with the plastic hook.
      • Remove the metal bracket.
      Ask FixBot
    3. iPhone 14 Loudspeaker Replacement, Remove the loudspeaker screws: step 28, image 1 of 1
      • Use a screwdriver to remove the five screws securing the loudspeaker:
      • Three 1.4 mm-long Phillips screws
      • One 1.6 mm-long Phillips screw
      • One 1.2 mm-long Y000 screw
      Ask FixBot
    4. iPhone 14 Loudspeaker Replacement, Free the loudspeaker: step 29, image 1 of 2 iPhone 14 Loudspeaker Replacement, Free the loudspeaker: step 29, image 2 of 2
      • Use the pointed end of a spudger to carefully fold the grounding cable at the right edge of the loudspeaker to the side.
      Ask FixBot
    5. iPhone 14 Loudspeaker Replacement, Remove the loudspeaker: step 30, image 1 of 3 iPhone 14 Loudspeaker Replacement, Remove the loudspeaker: step 30, image 2 of 3 iPhone 14 Loudspeaker Replacement, Remove the loudspeaker: step 30, image 3 of 3
      • Remove the loudspeaker.
      Ask FixBot
12 other people completed this guide.
Tobias Isakeit
135,839 Reputation
189 Guides authored
1 Guide Comment
The flex cable ground in step #32 tore in my repairs. Any idea the proper name for it so I can maybe find it here or on aliexpress etc?
justaine reid - Reply Share
Past 24 Hours: 29
Past 7 Days: 178
Past 30 Days: 800
All Time: 18,916
