Up to 20% off select tools
iPhone 13 mini Screen Replacement
Views: 120K
View statistics:
Past 24 Hours:
74
Past 7 Days:
629
Past 30 Days:
2,875
All Time:
120,278
Comments: 89
77 comments on steps, 12 guide comments.
Go to guide comments
Completed: 37
37 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
If your iPhone 13 mini screen is cracked, not responding to touch, or not showing a picture when your phone is powered on, use this guide to restore your iPhone to working order with a new screen, a.k.a. display assembly.
Note: On iOS 17.6 and earlier, True Tone and auto brightness functionality is disabled after a screen replacement, even when using an original Apple screen. Face ID is also disabled, unless the iPhone is running iOS 15.2 or newer. On iOS 18 and newer, you can calibrate your new screen using Apple's Repair Assistant to restore True Tone functionality on genuine screens purchased from Apple.
You’ll need replacement adhesive to reattach components when reassembling the device.
    1. iPhone 13 mini Screen Replacement, Remove the screws: step 1, image 1 of 2 iPhone 13 mini Screen Replacement, Remove the screws: step 1, image 2 of 2
      • For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
    1. iPhone 13 mini Screen Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 13 mini Screen Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 13 mini Screen Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 13 mini Screen Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone 13 mini Screen Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone 13 mini Screen Replacement, Tape over any cracks: step 3, image 3 of 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screenuntil the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Ask FixBot
    2. iPhone 13 mini Screen Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPhone 13 mini Screen Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPhone 13 mini Screen Replacement, Anti-Clamp instructions: step 4, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    3. iPhone 13 mini Screen Replacement: step 5, image 1 of 3 iPhone 13 mini Screen Replacement: step 5, image 2 of 3 iPhone 13 mini Screen Replacement: step 5, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    4. iPhone 13 mini Screen Replacement: step 6, image 1 of 3 iPhone 13 mini Screen Replacement: step 6, image 2 of 3 iPhone 13 mini Screen Replacement: step 6, image 3 of 3
      • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
      • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    5. iPhone 13 mini Screen Replacement, Heat the bottom edge: step 7, image 1 of 1
      • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone until the screen is slightly too hot to touch.
      • Never leave your hair dryer in one spot for an extended period of time.
      Ask FixBot
    6. iPhone 13 mini Screen Replacement, Apply a suction handle: step 8, image 1 of 1
      • If you're using a single suction handle, apply it to the bottom edge of the phone, as close to the edge as possible.
      Ask FixBot
    7. iPhone 13 mini Screen Replacement, Screen information: step 9, image 1 of 3 iPhone 13 mini Screen Replacement, Screen information: step 9, image 2 of 3 iPhone 13 mini Screen Replacement, Screen information: step 9, image 3 of 3
      • To avoid damaging your screen in the next step, note the following:
      • There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll damage the screen.
      • Sometimes the display panel separates from the bezel before you even get a chance to insert a pick. This may be unavoidable depending on the condition of the adhesive. In this case, you’ll most likely need to replace your entire screen.
      Ask FixBot
    8. iPhone 13 mini Screen Replacement, Insert an opening pick: step 10, image 1 of 3 iPhone 13 mini Screen Replacement, Insert an opening pick: step 10, image 2 of 3 iPhone 13 mini Screen Replacement, Insert an opening pick: step 10, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • Insert an opening pick into the gap under the screen's plastic bezel.
      • Make sure to insert the pick between the plastic bezel and the metal frame. If you insert the pick between the glass screen and the plastic bezel, you'll damage your screen.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    9. iPhone 13 mini Screen Replacement, Separate the bottom adhesive: step 11, image 1 of 3 iPhone 13 mini Screen Replacement, Separate the bottom adhesive: step 11, image 2 of 3 iPhone 13 mini Screen Replacement, Separate the bottom adhesive: step 11, image 3 of 3
      • Don't insert your opening pick deeper than 3 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    10. iPhone 13 mini Screen Replacement, Heat the right edge: step 12, image 1 of 2 iPhone 13 mini Screen Replacement, Heat the right edge: step 12, image 2 of 2
      • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
      Ask FixBot
    11. iPhone 13 mini Screen Replacement, Separate the right adhesive: step 13, image 1 of 3 iPhone 13 mini Screen Replacement, Separate the right adhesive: step 13, image 2 of 3 iPhone 13 mini Screen Replacement, Separate the right adhesive: step 13, image 3 of 3
      • Slide the opening pick around the bottom right corner and along the right edge of the iPhone, slicing through the adhesive holding the display in place.
      • Don't insert your pick more than 3 mm, and don't force it through unheated sections of adhesive, or it may slip and damage internal components.
      • Leave the pick in the top right corner before continuing.
      Ask FixBot
    12. iPhone 13 mini Screen Replacement, Heat the top edge: step 14, image 1 of 1
      • Use a hair dryer to heat the top edge of the iPhone until the screen is slightly too hot to touch.
      Ask FixBot
    13. iPhone 13 mini Screen Replacement, Separate the top adhesive: step 15, image 1 of 3 iPhone 13 mini Screen Replacement, Separate the top adhesive: step 15, image 2 of 3 iPhone 13 mini Screen Replacement, Separate the top adhesive: step 15, image 3 of 3
      • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the top sensors.
      • Leave the pick in the top left corner before continuing.
      Ask FixBot
    14. iPhone 13 mini Screen Replacement, Heat the left edge: step 16, image 1 of 2 iPhone 13 mini Screen Replacement, Heat the left edge: step 16, image 2 of 2
      • Use a hair dryer to heat the left edge of the iPhone until the screen is slightly too hot to touch.
      Ask FixBot
    15. iPhone 13 mini Screen Replacement, Separate the left adhesive: step 17, image 1 of 3 iPhone 13 mini Screen Replacement, Separate the left adhesive: step 17, image 2 of 3 iPhone 13 mini Screen Replacement, Separate the left adhesive: step 17, image 3 of 3
      • There are delicate cables along the left edge of your iPhone. Don't insert your pick deeper than 2 mm here, as you may damage the cables.
      • Rotate your pick around the top left corner of the screen.
      • Slide your pick to the bottom left corner of the screen to separate the adhesive.
      • If you're having trouble separating the adhesive, reheat the left edge.
      Ask FixBot
    16. iPhone 13 mini Screen Replacement, Remove the suction cup(s): step 18, image 1 of 1
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Ask FixBot
    17. iPhone 13 mini Screen Replacement, Open the iPhone mini: step 19, image 1 of 2 iPhone 13 mini Screen Replacement, Open the iPhone mini: step 19, image 2 of 2
      • Rotate your iPhone so the right edge faces you.
      • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
      Ask FixBot
    1. iPhone 13 mini Screen Replacement, Unscrew the battery and display connector cover: step 20, image 1 of 1
      Magnetic Project Mat
      $16.96
      Buy
      • Remove the 1.2 mm-long Y000 screw securing the battery and display connector cover.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      Ask FixBot
    2. iPhone 13 mini Screen Replacement, Remove the cover: step 21, image 1 of 2 iPhone 13 mini Screen Replacement, Remove the cover: step 21, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the battery and display connector cover.
      Ask FixBot
    3. iPhone 13 mini Screen Replacement, Disconnect the battery and the OLED display cable: step 22, image 1 of 3 iPhone 13 mini Screen Replacement, Disconnect the battery and the OLED display cable: step 22, image 2 of 3 iPhone 13 mini Screen Replacement, Disconnect the battery and the OLED display cable: step 22, image 3 of 3
      • Use a spudger to pry the battery and OLED panel cable connectors up from their sockets on the logic board.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    4. iPhone 13 mini Screen Replacement, Unscrew the front sensor connector cover: step 23, image 1 of 1
      • Remove the three screws securing the front sensor assembly cover:
      • One 1.4 mm-long Phillips screw
      • This screw may strip easily. Use a driver that fits the screw head snugly, apply firm downward pressure, and turn slowly to avoid stripping it.
      • One 1.8 mm-long Y000 screw
      • One 1.2 mm-long Y000 screw
      Ask FixBot
    5. iPhone 13 mini Screen Replacement, Remove the cover: step 24, image 1 of 2 iPhone 13 mini Screen Replacement, Remove the cover: step 24, image 2 of 2
      • Use a pair of tweezers to remove the front sensor assembly connector cover.
      Ask FixBot
    6. iPhone 13 mini Screen Replacement, Disconnect the front sensors: step 25, image 1 of 2 iPhone 13 mini Screen Replacement, Disconnect the front sensors: step 25, image 2 of 2
      • Use a spudger to disconnect the front sensor assembly cable connector.
      Ask FixBot
    7. iPhone 13 mini Screen Replacement, Remove the display assembly: step 26, image 1 of 1
      Ask FixBot
    1. iPhone 13 mini Screen Replacement, Unscrew the metal cover: step 27, image 1 of 1
      • Remove the three 1.4 mm-long tri-point Y000 screws securing the sensor assembly cover.
      Ask FixBot
    2. iPhone 13 mini Screen Replacement, Remove the cover: step 28, image 1 of 2 iPhone 13 mini Screen Replacement, Remove the cover: step 28, image 2 of 2
      Buy
      • Use a pair of blunt nose tweezers to remove the metal cover.
      Ask FixBot
    3. iPhone 13 mini Screen Replacement, Heat up the top edge of the display: step 29, image 1 of 1
      • Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
      Ask FixBot
    4. iPhone 13 mini Screen Replacement, Separate the ambient light sensor: step 30, image 1 of 2 iPhone 13 mini Screen Replacement, Separate the ambient light sensor: step 30, image 2 of 2
      • Use the pointed end of a spudger to pry the ambient light sensor out of its recess.
      • Take care not to damage the light sensor ribbon cables while prying.
      Ask FixBot
    5. iPhone 13 mini Screen Replacement: step 31, image 1 of 3 iPhone 13 mini Screen Replacement: step 31, image 2 of 3 iPhone 13 mini Screen Replacement: step 31, image 3 of 3
      • Use the pointed end of a spudger to pry the proximity sensor and the microphone out of their recesses.
      Ask FixBot
    6. iPhone 13 mini Screen Replacement: step 32, image 1 of 1
      • Use a hairdryer or heat gun or prepare an iOpener and apply it again to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
      Ask FixBot
    7. iPhone 13 mini Screen Replacement: step 33, image 1 of 2 iPhone 13 mini Screen Replacement: step 33, image 2 of 2
      • Carefully slide an opening pick underneath the front sensor assembly cable to loosen the adhesive.
      Ask FixBot
    8. iPhone 13 mini Screen Replacement: step 34, image 1 of 1
      • Remove the front sensor assembly.
      • During reassembly, check the position of the sensors and the microphone. Avoid obstructing them with any adhesive.
      Ask FixBot
To reassemble your device, follow the above steps in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings → General →About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Check out our iPhone 13 mini Answers community for troubleshooting help.
37 other people completed this guide.
Author
with
Adriana Zwink
69,920 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
12 Guide Comments
is the 'The iPhone 13 disables the Face ID function when you replace the screen' issue still happening since IOS 15.2? all the other pages for iPhone 13's mention its been fixed since then, does this apply to the mini as well?
Nick - Reply Share
I was scared about this one too, but Face ID seems fine after yesterday's screen replacement.
Artemiy - Reply Share
Also ich repariere als Hobby häufiger Handys aber das 13er in dem Fall das Mini heute das erste mal und ich muss sagen ich hatte noch nie solche Probleme wie bei dem Gerät. Dazu muss allerdings gesagt sein es war recht stark gesplittert am unteren rand Saugnäpfe und Kleber hat alles sehr schlecht gehaftet. Anfangs klebte der Kleber, vom Display, noch so stark das ich das DisplayGLAS auseinander genommen habe ohne den Rahmen was ich anfangs nicht bemerkte, danach sah das "Display" so aus. Ebenso die schrauben ich habe sonst nie Probleme mit den Y000 schrauben hier habe ich gleich zwei kaputt gemacht und musste diese Aufbohren! Kaputte Schraube / Aufbohren
Am Ende war man erstmal erleichtert das alles funktioniert :)
Jonas Borgers - Reply Share
Hi Jonas, das klingt wirklich nach einem komplizierten Displaytausch und die Bilder sprechen für sich. Danke fürs Teilen deiner Erfahrung und schön, dass die Reparatur am Ende doch noch geklappt hat!
Adriana Zwink - Reply Share
I’ve been told by an Apple repair technician that to keep True Tone and Face ID working, you have to turn off find my.
Aspect22 - Reply Share
Past 24 Hours: 74
Past 7 Days: 629
Past 30 Days: 2,875
All Time: 120,278
