iPhone 13 WiFi Chip Replacement
Video Overview
iPhone WiFi Chip Repair Solution
    1. iPhone 13 WiFi Chip Replacement, Disassemble the iPhone 13: step 1, image 1 of 3 iPhone 13 WiFi Chip Replacement, Disassemble the iPhone 13: step 1, image 2 of 3 iPhone 13 WiFi Chip Replacement, Disassemble the iPhone 13: step 1, image 3 of 3
      • Cover the cameras with protection stickers.
      • Remove the motherboard and split it.
      Ask FixBot
    2. iPhone 13 WiFi Chip Replacement, Test the Wi-Fi Circuits: step 2, image 1 of 2 iPhone 13 WiFi Chip Replacement, Test the Wi-Fi Circuits: step 2, image 2 of 2
      • Test the circuits related to the Wi-Fi module to verify that they are normal.
      Ask FixBot
    3. iPhone 13 WiFi Chip Replacement, Remove the NAND Chip: step 3, image 1 of 3 iPhone 13 WiFi Chip Replacement, Remove the NAND Chip: step 3, image 2 of 3 iPhone 13 WiFi Chip Replacement, Remove the NAND Chip: step 3, image 3 of 3
      • It is not possible to read the Wi-Fi serial number (SN) simply by connecting the iPhone to the programming software. Therefore, we will remove the NAND chip.
      • Heat the NAND chip evenly with a hot air gun at 420°C and airflow 80.
      • Pry the NAND chip up.
      • Apply some flux to the soldering pad of the NAND chip.
      • Remove the tins from the soldering pad using braid and a soldering iron.
      Ask FixBot
    4. iPhone 13 WiFi Chip Replacement, Use the Luban Programmer: step 4, image 1 of 3 iPhone 13 WiFi Chip Replacement, Use the Luban Programmer: step 4, image 2 of 3 iPhone 13 WiFi Chip Replacement, Use the Luban Programmer: step 4, image 3 of 3
      • Place the NAND chip in a Luban programmer.
      • Connect the programmer to a PC and open the programming software.
      • Click "Check Factory Data" to read the EcID of the iPhone.
      • Read the EcID from the NAND chip.
      Ask FixBot
    5. iPhone 13 WiFi Chip Replacement, Write New Wi-Fi SN Data: step 5, image 1 of 3 iPhone 13 WiFi Chip Replacement, Write New Wi-Fi SN Data: step 5, image 2 of 3 iPhone 13 WiFi Chip Replacement, Write New Wi-Fi SN Data: step 5, image 3 of 3
      • Place a new Wi-Fi module into the Luban programmer to write in the Wi-Fi SN.
      • Copy the EcID and select WiFi Operations on the navigation menu.
      • Paste the EcID and click "Check now."
      • Then click "Write now."
      • The Wi-Fi SN has been written into the new Wi-Fi module.
      Ask FixBot
    6. iPhone 13 WiFi Chip Replacement, Replace the Wi-Fi Module: step 6, image 1 of 3 iPhone 13 WiFi Chip Replacement, Replace the Wi-Fi Module: step 6, image 2 of 3 iPhone 13 WiFi Chip Replacement, Replace the Wi-Fi Module: step 6, image 3 of 3
      • Place the signal board onto a fixture.
      • Cover some other components with Kapton tape for protection.
      • Heat the Wi-Fi module with a hot air gun and use a pry knife to remove the edge adhesives.
      • Pry up the Wi-Fi module.
      • Apply some flux to the soldering pad of the Wi-Fi module.
      Ask FixBot
    7. iPhone 13 WiFi Chip Replacement, Solder the New Wi-Fi Module: step 7, image 1 of 3 iPhone 13 WiFi Chip Replacement, Solder the New Wi-Fi Module: step 7, image 2 of 3 iPhone 13 WiFi Chip Replacement, Solder the New Wi-Fi Module: step 7, image 3 of 3
      • Remove the tins from the soldering joints of the signal board.
      • Remove the tins from the soldering joints of the logic board.
      • Align the new Wi-Fi module carrying the SN to the soldering pad.
      • Solder the new Wi-Fi module with a hot air gun at 380°C and airflow 60.
      Ask FixBot
    8. iPhone 13 WiFi Chip Replacement, Solder the NAND Chip: step 8, image 1 of 1
      • Solder the NAND chip with a hot air gun at 380°C and airflow 60.
      Ask FixBot
    9. iPhone 13 WiFi Chip Replacement, Testing: step 9, image 1 of 3 iPhone 13 WiFi Chip Replacement, Testing: step 9, image 2 of 3 iPhone 13 WiFi Chip Replacement, Testing: step 9, image 3 of 3
      • Put the logic board and the signal board into a motherboard-layered test fixture.
      • Connect the iPhone 13 screen cable and the power cable.
      • Use a pair of tweezers to trigger the power-on.
      • The iPhone 13 should power on properly.
      • Go to settings to check if the Wi-Fi function toggle is resumed.
      Ask FixBot
    10. iPhone 13 WiFi Chip Replacement, Reassemble and Done: step 10, image 1 of 3 iPhone 13 WiFi Chip Replacement, Reassemble and Done: step 10, image 2 of 3 iPhone 13 WiFi Chip Replacement, Reassemble and Done: step 10, image 3 of 3
      • Solder the signal board with the logic board.
      • Assemble the iPhone 13 and test the Wi-Fi function.
      • Test and Wi-Fi should be restored and connected properly.
      Ask FixBot
Finish Line
REWA
19,573 Reputation
55 Guides authored
0 Guide Comments
Past 24 Hours: 21
Past 7 Days: 168
Past 30 Days: 782
All Time: 11,081
