Up to 20% off select tools
iPhone 13 Pro Max SIM Card Replacement
Views: 10K
View statistics:
Past 24 Hours:
6
Past 7 Days:
54
Past 30 Days:
285
All Time:
10,377
Comments: 2
2 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 seconds - 1 minute
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove or replace the SIM card in your iPhone 13 Pro Max. This guide is for the physical SIM card only; the embedded SIM (eSIM) is silicon-based and cannot be removed.
    1. iPhone 13 Pro Max SIM Card Replacement, Eject the SIM card tray: step 1, image 1 of 3 iPhone 13 Pro Max SIM Card Replacement, Eject the SIM card tray: step 1, image 2 of 3 iPhone 13 Pro Max SIM Card Replacement, Eject the SIM card tray: step 1, image 3 of 3
      • Insert a SIM card eject tool into the small hole in the SIM card tray, located on the volume button edge of the iPhone.
      • Press firmly to eject the tray.
      Ask FixBot
    2. iPhone 13 Pro Max SIM Card Replacement, Remove the SIM card tray: step 2, image 1 of 3 iPhone 13 Pro Max SIM Card Replacement, Remove the SIM card tray: step 2, image 2 of 3 iPhone 13 Pro Max SIM Card Replacement, Remove the SIM card tray: step 2, image 3 of 3
      • Remove the SIM card tray from the iPhone.
      • The SIM card will fall out of the tray easily.
      • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
      • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your iPhone's internal components.
      Ask FixBot
9 other people completed this guide.
Author
with
Sam Omiotek
101,895 Reputation
289 Guides authored
2 Guide Comments
Merci enormément pour ce tutoriel très utile, depuis le temps que je cherchais la procédure !
iBryan Phones - Reply Share
يطلع لي في خلوي هناك تحديث مطلوب لاستخدام البيانات الخلوية على. هذا الايفون وش حل المشكلة
Shahad - Reply Share
Past 24 Hours: 6
Past 7 Days: 54
Past 30 Days: 285
All Time: 10,377
