Introduction
Go to step 1 ↓The iPhone 12 mini is more difficult to repair than the average iPhone. Opening it risks damaging the screen even if you follow all instructions correctly. Pay attention to all warnings and proceed with care.
The Taptic Engine produces your iPhone's vibration and haptic feedback functions. This guide shows how to remove and/or replace the Taptic Engine in an iPhone 12 mini.
You’ll need replacement adhesive to reattach components when reassembling the device.
Power off your iPhone before beginning disassembly.
Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
Measure 3Â mm from the tip and mark the opening pick with a permanent marker.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
To avoid damaging your screen in the next steps, note the following:
There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll damage the screen.
Tool used on this step:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
Skip the next three steps.
Use a hair dryer or a heat gun to heat the bottom half of the iPhone until the screen is slightly too hot to touch.
If you're using a single suction handle, apply it to the bottom edge of the phone, as close to the edge as possible.
If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the metal frame.
Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
Slide your pick back and forth along the bottom edge to separate the adhesive.
Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
Slide the opening pick around the bottom right corner and along the right edge of the iPhone, slicing through the adhesive holding the display in place.
Use a hair dryer to heat the top half of the iPhone until the screen is slightly too hot to touch.
Use a hair dryer to heat the left edge of the iPhone until the screen is slightly too hot to touch.
Rotate your pick around the top left corner of the screen.
Slide your pick down the left edge of the screen to separate the adhesive.
Rotate your iPhone so the right edge faces you.
Open the iPhone by swinging the display up from the right side, like the front cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
Tool used on this step:Magnetic Project Mat$16.96
Remove the 1.25 mm-long Y000 screw securing the battery & display connector cover bracket.
Tool used on this step:Tweezers$4.99
Use a pair of tweezers to remove the battery & display connector bracket.
Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Use a spudger or a clean fingernail to pry the OLED panel cable connector up from its socket on the logic board.
Remove the five 1 mm-long Y000 screws securing the front sensor assembly cover bracket.
Use a spudger or a clean fingernail to disconnect the front sensor assembly cable connector.
Remove the 1.3Â mm-long Phillips #000 screw.
Remove the 2.1Â mm-long Phillips #000 screw.
Remove the 1.6Â mm-long Y000 screw.
Use a pair of tweezers to remove the Taptic engine connector cover bracket.
Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
To reassemble your device, follow the above steps in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 mini Answers community for help.
8 other people completed this guide.
2 Guide Comments
Well, I'm actually looking to replace the Lightning Connector Assy. It looks like the phone needs to be completely gutted to do this?
Hi mastertape,
sadly that's the case. In order to replace the lightning connector assembly you need to remove the screen assembly, speaker, rear facing camera, Taptic engine and the whole logic board. If you're lucky your lightning connector is just dirty. That's quite often the case. Before disassembling your whole phone try to clean the connector carefully with a wooden toothpick or similar. I hope that solves the problem for you.
