Up to 20% off select tools
iPhone 12 mini Screen Replacement
Views: 187K
View statistics:
Past 24 Hours:
61
Past 7 Days:
493
Past 30 Days:
2,457
All Time:
187,014
Comments: 100
85 comments on steps, 15 guide comments.
Go to guide comments
Completed: 67
67 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 3 hours
Difficulty: Difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
The iPhone 12 mini is more difficult to repair than the average iPhone. Pay attention to all warnings and proceed with care.
If your iPhone 12 mini screen is cracked, not responding to touch, or not showing a picture when your phone is powered on, use this guide to restore your iPhone to working order with a new screen, a.k.a. display assembly.
The combined earpiece speaker + sensor assembly affixed to the back of the display is paired to your individual iPhone from the factory, so you must transfer it from your old display to your new one during any display replacement. It contains the flood illuminator, which is part of the biometric Face ID security feature. If it is damaged or replaced, Face ID will cease to function, so take extra care not to damage any of these components during this procedure. If damaged, only Apple or an Apple-authorized technician can restore Face ID function.
Note: On iOS 17.6 and earlier, True Tone functionality is disabled after a screen replacement, even when using an original Apple screen. On iOS 18 and newer, you can calibrate your new screen using Apple's Repair Assistant to restore True Tone functionality on genuine screens purchased from Apple.
You’ll need replacement adhesive to reattach components when reassembling the device.
    1. iPhone 12 mini Screen Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone 12 mini Screen Replacement, Remove the pentalobe screws: step 1, image 2 of 2
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
      Ask FixBot
    1. iPhone 12 mini Screen Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 12 mini Screen Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 12 mini Screen Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 12 mini Screen Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone 12 mini Screen Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone 12 mini Screen Replacement, Tape over any cracks: step 3, image 3 of 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Ask FixBot
    2. iPhone 12 mini Screen Replacement, Screen damage warning: step 4, image 1 of 3 iPhone 12 mini Screen Replacement, Screen damage warning: step 4, image 2 of 3 iPhone 12 mini Screen Replacement, Screen damage warning: step 4, image 3 of 3
      • To avoid damaging your screen in the next steps, note the following:
      • There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll damage the screen.
      • Sometimes the display panel separates from the bezel before you even get a chance to insert a pick. This may be unavoidable depending on the condition of the adhesive. In this case, you’ll most likely need to replace your entire screen.
      Ask FixBot
    3. iPhone 12 mini Screen Replacement, Anti-Clamp instructions: step 5, image 1 of 3 iPhone 12 mini Screen Replacement, Anti-Clamp instructions: step 5, image 2 of 3 iPhone 12 mini Screen Replacement, Anti-Clamp instructions: step 5, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    4. iPhone 12 mini Screen Replacement: step 6, image 1 of 3 iPhone 12 mini Screen Replacement: step 6, image 2 of 3 iPhone 12 mini Screen Replacement: step 6, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    5. iPhone 12 mini Screen Replacement: step 7, image 1 of 3 iPhone 12 mini Screen Replacement: step 7, image 2 of 3 iPhone 12 mini Screen Replacement: step 7, image 3 of 3
      • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
      • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
      • Make sure the opening pick is placed properly between the plastic bezel and the frame to avoid damaging your screen.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    6. iPhone 12 mini Screen Replacement, Heat the bottom half of the phone: step 8, image 1 of 1
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      • Heating the bottom half of the iPhone helps soften the adhesive securing the display, making it easier to open.
      • Use a hair dryer or a heat gun to heat the bottom half of the iPhone until the screen is slightly too hot to touch.
      • For best practices on using a hair dryer to soften adhesive, check out this guide. For warnings on heat gun use, check out this guide.
      • To prevent screen damage, keep your heat source moving rather than focused on one spot.
      • If you have trouble during the opening procedure, the adhesive most likely cooled down. Apply more heat to further soften the adhesive.
      Ask FixBot
    7. iPhone 12 mini Screen Replacement, Apply a suction handle: step 9, image 1 of 2 iPhone 12 mini Screen Replacement, Apply a suction handle: step 9, image 2 of 2
      • If you're using a single suction handle, apply it to the bottom edge of the phone, as close to the edge as possible.
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      Ask FixBot
    8. iPhone 12 mini Screen Replacement, Lift the screen slightly: step 10, image 1 of 3 iPhone 12 mini Screen Replacement, Lift the screen slightly: step 10, image 2 of 3 iPhone 12 mini Screen Replacement, Lift the screen slightly: step 10, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the metal frame.
      • A plastic bezel is secured to the underside of the display, and needs to lift up with the display. Inserting a pick between the bezel and the display will damage the panel.
      • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
      • Make sure to insert the opening pick under the thick plastic bezel to avoid damaging your screen. You should see a visual gap, and the pick shouldn't catch on anything. If you can't see the gap, you'll need to pull the screen up more.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    9. iPhone 12 mini Screen Replacement, Separate the bottom edge adhesive: step 11, image 1 of 3 iPhone 12 mini Screen Replacement, Separate the bottom edge adhesive: step 11, image 2 of 3 iPhone 12 mini Screen Replacement, Separate the bottom edge adhesive: step 11, image 3 of 3
      • Don't insert your opening pick deeper than 3 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    10. iPhone 12 mini Screen Replacement, Heat the right edge: step 12, image 1 of 2 iPhone 12 mini Screen Replacement, Heat the right edge: step 12, image 2 of 2
      • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
      Ask FixBot
    11. iPhone 12 mini Screen Replacement, Separate the screen adhesive: step 13, image 1 of 3 iPhone 12 mini Screen Replacement, Separate the screen adhesive: step 13, image 2 of 3 iPhone 12 mini Screen Replacement, Separate the screen adhesive: step 13, image 3 of 3
      • Slide the opening pick around the bottom right corner and along the right edge of the iPhone, slicing through the adhesive holding the display in place.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      Ask FixBot
    12. iPhone 12 mini Screen Replacement, Heat the top half: step 14, image 1 of 1
      • Use a hair dryer to heat the top half of the iPhone until the screen is slightly too hot to touch.
      Ask FixBot
    13. iPhone 12 mini Screen Replacement: step 15, image 1 of 3 iPhone 12 mini Screen Replacement: step 15, image 2 of 3 iPhone 12 mini Screen Replacement: step 15, image 3 of 3
      • The top edge of the display is secured with both glue and clips.
      • Insert your pick underneath the top-right corner of the display panel.
      • Slide the pick around the top right corner. Because of the clips you might encounter some resistance.
      • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
      • Gently pulling the front panel assembly towards the bottom edge of the phone simplifies this step a little.
      • Slide the pick along the top edge and cut any remaining adhesive securing the display.
      Ask FixBot
    14. iPhone 12 mini Screen Replacement, Heat the left edge: step 16, image 1 of 2 iPhone 12 mini Screen Replacement, Heat the left edge: step 16, image 2 of 2
      • Use a hair dryer to heat the left edge of the iPhone until the screen is slightly too hot to touch.
      Ask FixBot
    15. iPhone 12 mini Screen Replacement, Separate the left edge adhesive: step 17, image 1 of 3 iPhone 12 mini Screen Replacement, Separate the left edge adhesive: step 17, image 2 of 3 iPhone 12 mini Screen Replacement, Separate the left edge adhesive: step 17, image 3 of 3
      • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
      • Rotate your pick around the top left corner of the screen.
      • Slide your pick down the left edge of the screen to separate the adhesive.
      • If you're having trouble separating the adhesive, reheat the left edge.
      Ask FixBot
    16. iPhone 12 mini Screen Replacement, Open the iPhone: step 18, image 1 of 3 iPhone 12 mini Screen Replacement, Open the iPhone: step 18, image 2 of 3 iPhone 12 mini Screen Replacement, Open the iPhone: step 18, image 3 of 3
      • Rotate your iPhone so the right edge faces you.
      • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
      Ask FixBot
    1. iPhone 12 mini Screen Replacement, Unscrew the battery and display connector cover: step 19, image 1 of 2 iPhone 12 mini Screen Replacement, Unscrew the battery and display connector cover: step 19, image 2 of 2
      Magnetic Project Mat
      $16.96
      Buy
      • Remove the 1.25 mm-long Y000 screw securing the battery & display connector cover bracket.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      Ask FixBot
    2. iPhone 12 mini Screen Replacement, Remove the battery and display connector cover: step 20, image 1 of 2 iPhone 12 mini Screen Replacement, Remove the battery and display connector cover: step 20, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the battery & display connector bracket.
      • There are two little hinges on the right edge of the connector bracket. Make sure to align them with their counterparts during reassembly.
      Ask FixBot
    3. iPhone 12 mini Screen Replacement, Disconnect the battery: step 21, image 1 of 2 iPhone 12 mini Screen Replacement, Disconnect the battery: step 21, image 2 of 2
      • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Ask FixBot
    4. iPhone 12 mini Screen Replacement, Disconnect the OLED display cable: step 22, image 1 of 2 iPhone 12 mini Screen Replacement, Disconnect the OLED display cable: step 22, image 2 of 2
      • Use a spudger or a clean fingernail to pry the OLED panel cable connector up from its socket on the logic board.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    5. iPhone 12 mini Screen Replacement, Unscrew the front sensor assembly cover: step 23, image 1 of 2 iPhone 12 mini Screen Replacement, Unscrew the front sensor assembly cover: step 23, image 2 of 2
      • Remove the five 1 mm-long Y000 screws securing the front sensor assembly cover bracket.
      Ask FixBot
    6. iPhone 12 mini Screen Replacement: step 24, image 1 of 2 iPhone 12 mini Screen Replacement: step 24, image 2 of 2
      • Use a pair of tweezers to remove the front sensor assembly bracket.
      Ask FixBot
    7. iPhone 12 mini Screen Replacement, Disconnect the front sensors: step 25, image 1 of 2 iPhone 12 mini Screen Replacement, Disconnect the front sensors: step 25, image 2 of 2
      • Use a spudger or a clean fingernail to disconnect the front sensor assembly cable connector.
      Ask FixBot
    8. iPhone 12 mini Screen Replacement, Remove the display assembly: step 26, image 1 of 1
      Ask FixBot
    1. iPhone 12 mini Screen Replacement, Unscrew the front sensor and speaker assembly: step 27, image 1 of 2 iPhone 12 mini Screen Replacement, Unscrew the front sensor and speaker assembly: step 27, image 2 of 2
      • Remove the 1.1 mm-long tri-point Y000 screw.
      • Remove the 1.8 mm-long tri-point Y000 screw.
      • Remove the two 1.6 mm-long Phillips #00 screws.
      • Don't try to remove the front sensor and speaker assembly yet. It's still glued to the rear side of the display panel.
      Ask FixBot
    2. iPhone 12 mini Screen Replacement: step 28, image 1 of 2 iPhone 12 mini Screen Replacement: step 28, image 2 of 2
      • Slide the flat end of a spudger underneath the top right corner of the earpiece speaker and fold it to the back.
      Ask FixBot
    3. iPhone 12 mini Screen Replacement, Heat up the top edge of the display: step 29, image 1 of 1
      • Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
      Ask FixBot
    4. iPhone 12 mini Screen Replacement, Pry up the proximity sensor: step 30, image 1 of 2 iPhone 12 mini Screen Replacement, Pry up the proximity sensor: step 30, image 2 of 2
      • Use the pointed end of a spudger to carefully pry the proximity sensor out of its recess.
      Ask FixBot
    5. iPhone 12 mini Screen Replacement: step 31, image 1 of 2 iPhone 12 mini Screen Replacement: step 31, image 2 of 2
      • Slide a spudger underneath the wide sensor assembly flex cable to separate it from the screen.
      • Avoid tensioning any of the sensor flex cables during this procedure.
      Ask FixBot
    6. iPhone 12 mini Screen Replacement, Pry up the flood illuminator: step 32, image 1 of 2 iPhone 12 mini Screen Replacement, Pry up the flood illuminator: step 32, image 2 of 2
      Buy
      • Use a spudger or a pair of tweezers to pry the flood illuminator out of its recess.
      Ask FixBot
    7. iPhone 12 mini Screen Replacement, Remove the earpiece speaker and front sensor assembly: step 33, image 1 of 3 iPhone 12 mini Screen Replacement, Remove the earpiece speaker and front sensor assembly: step 33, image 2 of 3 iPhone 12 mini Screen Replacement, Remove the earpiece speaker and front sensor assembly: step 33, image 3 of 3
      • Remove the earpiece speaker and front sensor assembly.
      • During reassembly, check the position of the sensors and the microphone. Avoid obstructing them with any adhesive.
      • Flood illuminiator
      • Proximity sensor
      • Microphone
      Ask FixBot
To reassemble your device, follow the above steps in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings → General →About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Check out our iPhone 12 mini Answers community for troubleshooting help.
67 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,200 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
15 Guide Comments
so does apple have to pair it?
Roman - Reply Share
The only way to pair the new sceen to the phone to retain Tue Tone is to buy a dedicated board that copy the data from the original screen to the new.
Daniele Carminati - Reply Share
This guide was impeccable! The hardest part is definitely getting the screen glue off. Ended up separating the frame of the screen from the display itself. All worked out in the end though!
Thomas Hubbell - Reply Share
same! I was wondering why the inside of my phone looked different than the pictures before realizing the screen assembly has two layers and I accidentally removed only the top one instead of both.
Likewise, worked out for me anyhow.
macro - Reply Share
The same thing happened to me. So a simple battery replacement turned into a display replacement :D
Roman Fialka - Reply Share
Past 24 Hours: 61
Past 7 Days: 493
Past 30 Days: 2,457
All Time: 187,014
