Up to 20% off select tools
iPhone 12 Pro SIM Card Replacement
Views: 24K
View statistics:
Past 24 Hours:
11
Past 7 Days:
52
Past 30 Days:
239
All Time:
23,903
Comments: 2
2 comments on steps.
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove or replace the SIM card in your iPhone 12 Pro. This guide is for the physical SIM card only; the embedded SIM (eSIM) is silicon-based and cannot be removed.
    1. iPhone 12 Pro SIM Card Replacement, Eject the SIM card tray: step 1, image 1 of 2 iPhone 12 Pro SIM Card Replacement, Eject the SIM card tray: step 1, image 2 of 2
      • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the volume button edge of the iPhone.
      • Press firmly to eject the tray.
      Ask FixBot
    2. iPhone 12 Pro SIM Card Replacement, Remove the SIM card tray: step 2, image 1 of 3 iPhone 12 Pro SIM Card Replacement, Remove the SIM card tray: step 2, image 2 of 3 iPhone 12 Pro SIM Card Replacement, Remove the SIM card tray: step 2, image 3 of 3
      • Remove the SIM card tray from the iPhone.
      • The SIM card will fall out of the tray easily.
      • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
      • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your iPhone's internal components.
      Ask FixBot
6 other people completed this guide.
Author
with
Adam O'Camb
226,699 Reputation
415 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 52
Past 30 Days: 239
All Time: 23,903
