iPhone 12 Pentalobe Screws Replacement
    1. iPhone 12 Pentalobe Screws Replacement, Remove the pentalobe screws: step 1, image 1 of 1
      • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.75 mm long pentalobe P2 screws at the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
13 other people completed this guide.
Adam O'Camb
225,558 Reputation
415 Guides authored
5 Guide Comments
why is this a thing
Repairify Scotland - Reply Share
This is perfect, thank you! I wasn’t sure I’d be able to do this repair, but with this expert guidance I have succeeded. I’m ready for level 3.
Chris Phelan - Reply Share
well done - would you like medal
someone just pointed out the fact it says to discharge the battery -
‘Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. ‘
you are removing the 2 pentalobes, not anything ‘internal’
Hello kindle explain what you mean by discharging of battery Thanks
Kelvin Esosa - Reply Share
Past 24 Hours: 15
Past 7 Days: 68
Past 30 Days: 328
All Time: 18,590
