Up to 20% off select tools
iPhone 12 Loudspeaker Replacement
Views: 46K
View statistics:
Past 24 Hours:
13
Past 7 Days:
141
Past 30 Days:
710
All Time:
46,061
Comments: 86
85 comments on steps, 1 guide comment.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove and replace the loudspeaker in an iPhone 12. The loudspeaker is the speaker at the bottom of an iPhone.
    1. iPhone 12 Loudspeaker Replacement, Remove the pentalobe screws: step 1, image 1 of 1
      • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.75 mm long pentalobe P2 screws at the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
    1. iPhone 12 Loudspeaker Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 12 Loudspeaker Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 12 Loudspeaker Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 12 Loudspeaker Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone 12 Loudspeaker Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone 12 Loudspeaker Replacement, Tape over any cracks: step 3, image 3 of 3
      • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow this step.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • Apply strips of packing tape to the cracked glass until the whole screen is covered—this will help keep the glass contained and allow the suction cup to stick to the screen.
      • Make sure there's a single strip (not overlapping) of tape across the bottom edge, big enough for a suction cup to fit on.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Ask FixBot
    2. iPhone 12 Loudspeaker Replacement, Screen damage warning: step 4, image 1 of 3 iPhone 12 Loudspeaker Replacement, Screen damage warning: step 4, image 2 of 3 iPhone 12 Loudspeaker Replacement, Screen damage warning: step 4, image 3 of 3
      • To avoid damaging your screen in the next steps, note the following:
      • There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll damage the screen.
      • Sometimes the display panel separates from the bezel before you even get a chance to insert a pick. This may be unavoidable depending on the condition of the adhesive. In this case, you’ll most likely need to replace your entire screen.
      Ask FixBot
    3. iPhone 12 Loudspeaker Replacement, Anti-Clamp instructions: step 5, image 1 of 3 iPhone 12 Loudspeaker Replacement, Anti-Clamp instructions: step 5, image 2 of 3 iPhone 12 Loudspeaker Replacement, Anti-Clamp instructions: step 5, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    4. iPhone 12 Loudspeaker Replacement: step 6, image 1 of 3 iPhone 12 Loudspeaker Replacement: step 6, image 2 of 3 iPhone 12 Loudspeaker Replacement: step 6, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    5. iPhone 12 Loudspeaker Replacement: step 7, image 1 of 3 iPhone 12 Loudspeaker Replacement: step 7, image 2 of 3 iPhone 12 Loudspeaker Replacement: step 7, image 3 of 3
      • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
      • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    6. iPhone 12 Loudspeaker Replacement, Heat the bottom edge: step 8, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom half of the screen until it’s slightly too hot to touch. This softens the adhesive securing it.
      • Improper use of a heat gun can destroy the display and/or battery—review this guide for instructions. To prevent screen damage, keep your heat source moving rather than focused on one spot.
      • For tips on using a hair dryer to soften adhesive, check out this guide.
      Ask FixBot
    7. iPhone 12 Loudspeaker Replacement, Apply a suction cup: step 9, image 1 of 2 iPhone 12 Loudspeaker Replacement, Apply a suction cup: step 9, image 2 of 2
      • Apply a suction handle to the bottom edge of the screen.
      Ask FixBot
    8. iPhone 12 Loudspeaker Replacement, Screen information: step 10, image 1 of 1
      • To avoid damaging your screen in the next step, note the following:
      Ask FixBot
    9. iPhone 12 Loudspeaker Replacement, Lift the screen slightly: step 11, image 1 of 3 iPhone 12 Loudspeaker Replacement, Lift the screen slightly: step 11, image 2 of 3 iPhone 12 Loudspeaker Replacement, Lift the screen slightly: step 11, image 3 of 3
      • Pull up on the suction handle with firm, constant pressure to create a slight gap under the screen’s plastic bezel.
      • The adhesive holding the screen in place is very strong. If you're having a hard time, be patient, apply more heat, and try again.
      • Insert an opening pick into the gap.
      • Remember to insert the opening pick under the thick plastic bezel to avoid damaging your screen.
      Ask FixBot
    10. iPhone 12 Loudspeaker Replacement, Separate the bottom edge adhesive: step 12, image 1 of 3 iPhone 12 Loudspeaker Replacement, Separate the bottom edge adhesive: step 12, image 2 of 3 iPhone 12 Loudspeaker Replacement, Separate the bottom edge adhesive: step 12, image 3 of 3
      • Don't insert your opening pick deeper than 3 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    11. iPhone 12 Loudspeaker Replacement, Heat the right edge: step 13, image 1 of 2 iPhone 12 Loudspeaker Replacement, Heat the right edge: step 13, image 2 of 2
      • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
      Ask FixBot
    12. iPhone 12 Loudspeaker Replacement, Separate the right adhesive: step 14, image 1 of 3 iPhone 12 Loudspeaker Replacement, Separate the right adhesive: step 14, image 2 of 3 iPhone 12 Loudspeaker Replacement, Separate the right adhesive: step 14, image 3 of 3
      • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
      • Continue sliding up the right edge of the iPhone until you reach the top right corner.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      • Leave the pick in the top right corner before continuing.
      Ask FixBot
    13. iPhone 12 Loudspeaker Replacement, Heat the top edge: step 15, image 1 of 1
      • Use a hair dryer to heat the top edge of the iPhone until the screen is slightly too hot to touch.
      Ask FixBot
    14. iPhone 12 Loudspeaker Replacement, Separate the top adhesive: step 16, image 1 of 3 iPhone 12 Loudspeaker Replacement, Separate the top adhesive: step 16, image 2 of 3 iPhone 12 Loudspeaker Replacement, Separate the top adhesive: step 16, image 3 of 3
      • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the top sensors.
      • Leave the pick in the top left corner before continuing.
      Ask FixBot
    15. iPhone 12 Loudspeaker Replacement, Heat the left edge: step 17, image 1 of 2 iPhone 12 Loudspeaker Replacement, Heat the left edge: step 17, image 2 of 2
      • Use a hair dryer to heat the left edge of the iPhone until the screen is slightly too hot to touch.
      Ask FixBot
    16. iPhone 12 Loudspeaker Replacement, Separate the left adhesive: step 18, image 1 of 3 iPhone 12 Loudspeaker Replacement, Separate the left adhesive: step 18, image 2 of 3 iPhone 12 Loudspeaker Replacement, Separate the left adhesive: step 18, image 3 of 3
      • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
      • Rotate your pick around the top left corner of the screen.
      • Slide your pick down the left edge of the screen to separate the adhesive.
      • If you're having trouble separating the adhesive, reheat the left edge.
      Ask FixBot
    17. iPhone 12 Loudspeaker Replacement, Open the iPhone: step 19, image 1 of 3 iPhone 12 Loudspeaker Replacement, Open the iPhone: step 19, image 2 of 3 iPhone 12 Loudspeaker Replacement, Open the iPhone: step 19, image 3 of 3
      • Rotate your iPhone so the right edge faces you.
      • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
      Ask FixBot
    18. iPhone 12 Loudspeaker Replacement, Unscrew the battery and display connector cover: step 20, image 1 of 1
      Magnetic Project Mat
      $16.96
      Buy
      • Remove two 1.1 mm long Y000 screws securing the battery and display connector cover.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      Ask FixBot
    19. iPhone 12 Loudspeaker Replacement, Remove the battery and display connector cover: step 21, image 1 of 1
      • Remove the cover.
      Ask FixBot
    20. iPhone 12 Loudspeaker Replacement, Disconnect the battery: step 22, image 1 of 2 iPhone 12 Loudspeaker Replacement, Disconnect the battery: step 22, image 2 of 2
      • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Ask FixBot
    21. iPhone 12 Loudspeaker Replacement, Disconnect the display cable: step 23, image 1 of 2 iPhone 12 Loudspeaker Replacement, Disconnect the display cable: step 23, image 2 of 2
      • Use a spudger or a fingernail to disconnect the display cable connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    22. iPhone 12 Loudspeaker Replacement, Disconnect the digitizer cable: step 24, image 1 of 2 iPhone 12 Loudspeaker Replacement, Disconnect the digitizer cable: step 24, image 2 of 2
      • Use a spudger or a fingernail to disconnect the digitizer cable connector.
      • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
      Ask FixBot
    23. iPhone 12 Loudspeaker Replacement, Unscrew the front sensor connector cover: step 25, image 1 of 1
      • Use a Y000 driver to remove four screws securing the front sensor connector cover.
      • Three 1.1 mm long screws
      • One 1.4 mm long screw
      Ask FixBot
    24. iPhone 12 Loudspeaker Replacement, Remove the front sensor connector cover: step 26, image 1 of 3 iPhone 12 Loudspeaker Replacement, Remove the front sensor connector cover: step 26, image 2 of 3 iPhone 12 Loudspeaker Replacement, Remove the front sensor connector cover: step 26, image 3 of 3
      • Swing the cover up from the left until the small clip on the right unhooks.
      • Remove the cover.
      • During reassembly, insert the clip on the right edge into its slot first, then hinge the rest of the cover into place.
      Ask FixBot
    25. iPhone 12 Loudspeaker Replacement, Disconnect the front sensors: step 27, image 1 of 2 iPhone 12 Loudspeaker Replacement, Disconnect the front sensors: step 27, image 2 of 2
      • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
      Ask FixBot
    26. iPhone 12 Loudspeaker Replacement, Remove the display assembly: step 28, image 1 of 1
      Ask FixBot
    1. iPhone 12 Loudspeaker Replacement, Unscrew the loudspeaker: step 29, image 1 of 1
      • Use a Phillips driver to remove the four 1.6 mm screws securing the loudspeaker.
      Ask FixBot
    2. iPhone 12 Loudspeaker Replacement, Remove the loudspeaker: step 30, image 1 of 1
      • Remove the loudspeaker.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 Answers community for help.
14 other people completed this guide.
Author
with
Adam O'Camb
226,699 Reputation
415 Guides authored
1 Guide Comment
Every guide that I've seen has you remove the screen completely before replacing the speaker. This seems to be the hardest and riskiest part of the repair. The screen ribbon cables don't seem to obstruct access to the speaker. Is there a reason that you can't leave the ribbon cables alone and just prop the screen up at a right angle to the phone body and then replace the speaker? I can see the logic behind disconnecting the battery but what about the other cables?
Keith Silver - Reply Share
Past 24 Hours: 13
Past 7 Days: 141
Past 30 Days: 710
All Time: 46,061
