Up to 20% off select tools
iPhone 11 Pro Max Screen Replacement
Views: 257K
View statistics:
Past 24 Hours:
49
Past 7 Days:
348
Past 30 Days:
1,820
All Time:
257,202
Comments: 70
49 comments on steps, 21 guide comments.
Go to guide comments
Completed: 121
121 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
  • iPhone 11 Pro Max Screen
    4.7
Parts
Tools
Introduction
Go to step 1 ↓
If your iPhone 11 Pro Max screen is cracked, not responding to touch, or not showing a picture when your phone is powered on, use this guide to restore your iPhone to working order with a new screen, a.k.a. display assembly.
The combined earpiece speaker + sensor assembly affixed to the back of the display is paired to your individual iPhone from the factory, so you must transfer it from your old display to your new one during any display replacement. It contains the flood illuminator, which is part of the biometric Face ID security feature. If it is damaged or replaced, Face ID will cease to function, so take extra care not to damage any of these components during this procedure. If damaged, only Apple or an Apple-authorized technician can restore Face ID function.
Note: True Tone functionality is disabled after a screen replacement, even when using an original Apple screen. Additionally, your iPhone may temporarily show a warning about the “genuineness” of the display.
    1. iPhone 11 Pro Max Screen Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone 11 Pro Max Screen Replacement, Remove the pentalobe screws: step 1, image 2 of 2
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
    1. iPhone 11 Pro Max Screen Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 11 Pro Max Screen Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 11 Pro Max Screen Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 11 Pro Max Screen Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone 11 Pro Max Screen Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone 11 Pro Max Screen Replacement, Tape over any cracks: step 3, image 3 of 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Ask FixBot
    2. iPhone 11 Pro Max Screen Replacement, Screen information: step 4, image 1 of 3 iPhone 11 Pro Max Screen Replacement, Screen information: step 4, image 2 of 3 iPhone 11 Pro Max Screen Replacement, Screen information: step 4, image 3 of 3
      • To avoid damaging your screen in the next steps, note the following:
      • There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll damage the screen.
      • Sometimes the display panel separates from the bezel before you even get a chance to insert a pick. This may be unavoidable depending on the condition of the adhesive. In this case, you’ll most likely need to replace your entire screen.
      Ask FixBot
    3. iPhone 11 Pro Max Screen Replacement, Anti-Clamp instructions: step 5, image 1 of 3 iPhone 11 Pro Max Screen Replacement, Anti-Clamp instructions: step 5, image 2 of 3 iPhone 11 Pro Max Screen Replacement, Anti-Clamp instructions: step 5, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    4. iPhone 11 Pro Max Screen Replacement: step 6, image 1 of 3 iPhone 11 Pro Max Screen Replacement: step 6, image 2 of 3 iPhone 11 Pro Max Screen Replacement: step 6, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    5. iPhone 11 Pro Max Screen Replacement: step 7, image 1 of 3 iPhone 11 Pro Max Screen Replacement: step 7, image 2 of 3 iPhone 11 Pro Max Screen Replacement: step 7, image 3 of 3
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    6. iPhone 11 Pro Max Screen Replacement, Heat the lower edge of the phone: step 8, image 1 of 1
      • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
      • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
      Ask FixBot
    7. iPhone 11 Pro Max Screen Replacement: step 9, image 1 of 2 iPhone 11 Pro Max Screen Replacement: step 9, image 2 of 2
      • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
      Ask FixBot
    8. iPhone 11 Pro Max Screen Replacement, Lift the display slightly: step 10, image 1 of 3 iPhone 11 Pro Max Screen Replacement, Lift the display slightly: step 10, image 2 of 3 iPhone 11 Pro Max Screen Replacement, Lift the display slightly: step 10, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
      • Insert an opening pick into the gap.
      • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    9. iPhone 11 Pro Max Screen Replacement, Separate the screen adhesive: step 11, image 1 of 3 iPhone 11 Pro Max Screen Replacement, Separate the screen adhesive: step 11, image 2 of 3 iPhone 11 Pro Max Screen Replacement, Separate the screen adhesive: step 11, image 3 of 3
      • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      Ask FixBot
    10. iPhone 11 Pro Max Screen Replacement, Screen information: step 12, image 1 of 1
      • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
      Ask FixBot
    11. iPhone 11 Pro Max Screen Replacement: step 13, image 1 of 3 iPhone 11 Pro Max Screen Replacement: step 13, image 2 of 3 iPhone 11 Pro Max Screen Replacement: step 13, image 3 of 3
      • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Ask FixBot
    12. iPhone 11 Pro Max Screen Replacement: step 14, image 1 of 3 iPhone 11 Pro Max Screen Replacement: step 14, image 2 of 3 iPhone 11 Pro Max Screen Replacement: step 14, image 3 of 3
      • The top edge of the display is secured with both glue and clips.
      • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
      • Insert your pick into the top-right corner of the phone.
      Ask FixBot
    13. iPhone 11 Pro Max Screen Replacement: step 15, image 1 of 2 iPhone 11 Pro Max Screen Replacement: step 15, image 2 of 2
      • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
      • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
      • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
      Ask FixBot
    14. iPhone 11 Pro Max Screen Replacement, Remove the suction cup: step 16, image 1 of 1
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Ask FixBot
    15. iPhone 11 Pro Max Screen Replacement, Open the iPhone: step 17, image 1 of 3 iPhone 11 Pro Max Screen Replacement, Open the iPhone: step 17, image 2 of 3 iPhone 11 Pro Max Screen Replacement, Open the iPhone: step 17, image 3 of 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
      Ask FixBot
    1. iPhone 11 Pro Max Screen Replacement, Unscrew the battery connector cover: step 18, image 1 of 2 iPhone 11 Pro Max Screen Replacement, Unscrew the battery connector cover: step 18, image 2 of 2
      Magnetic Project Mat
      $16.96
      Buy
      • Remove two 1.3 mm long Y000 screws securing the battery cover bracket.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      Ask FixBot
    2. iPhone 11 Pro Max Screen Replacement, Remove the battery connector cover: step 19, image 1 of 1
      • Remove the bracket.
      Ask FixBot
    3. iPhone 11 Pro Max Screen Replacement, Disconnect the battery: step 20, image 1 of 2 iPhone 11 Pro Max Screen Replacement, Disconnect the battery: step 20, image 2 of 2
      • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Ask FixBot
    4. iPhone 11 Pro Max Screen Replacement, Unscrew the logic board cover screws: step 21, image 1 of 2 iPhone 11 Pro Max Screen Replacement, Unscrew the logic board cover screws: step 21, image 2 of 2
      • Use a Y000 driver to remove six 1.3 mm screws securing the logic board cover bracket.
      Ask FixBot
    5. iPhone 11 Pro Max Screen Replacement, Remove the logic board cover bracket: step 22, image 1 of 1
      Ask FixBot
    6. iPhone 11 Pro Max Screen Replacement, Disconnect the OLED display cable: step 23, image 1 of 2 iPhone 11 Pro Max Screen Replacement, Disconnect the OLED display cable: step 23, image 2 of 2
      • Use a spudger or a fingernail to disconnect the OLED panel cable connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    7. iPhone 11 Pro Max Screen Replacement, Disconnect the front sensors + digitizer: step 24, image 1 of 3 iPhone 11 Pro Max Screen Replacement, Disconnect the front sensors + digitizer: step 24, image 2 of 3 iPhone 11 Pro Max Screen Replacement, Disconnect the front sensors + digitizer: step 24, image 3 of 3
      • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
      • Use a spudger or a fingernail to disconnect the digitizer cable connector.
      • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
      Ask FixBot
    8. iPhone 11 Pro Max Screen Replacement, Remove the display assembly: step 25, image 1 of 1
      Ask FixBot
    1. iPhone 11 Pro Max Screen Replacement, Unscrew the front assembly: step 26, image 1 of 2 iPhone 11 Pro Max Screen Replacement, Unscrew the front assembly: step 26, image 2 of 2
      • Remove the three screws securing the speaker/sensor assembly to the back of the display:
      • Two 1.6 mm Phillips screws
      • One 1.4 mm Y000 screw
      Ask FixBot
    2. iPhone 11 Pro Max Screen Replacement, Flip the speaker assembly over: step 27, image 1 of 3 iPhone 11 Pro Max Screen Replacement, Flip the speaker assembly over: step 27, image 2 of 3 iPhone 11 Pro Max Screen Replacement, Flip the speaker assembly over: step 27, image 3 of 3
      • The earpiece speaker is lightly adhered in place.
      • Use the point of a spudger to gently pry up the top edge of the speaker.
      • Flip the speaker assembly over—down and away from the top edge of the display.
      • The speaker remains attached via a very thin ribbon cable. Be careful not to strain or damage the cable.
      Ask FixBot
    3. iPhone 11 Pro Max Screen Replacement, Heat up the top edge of the display: step 28, image 1 of 1
      • Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
      Ask FixBot
    4. iPhone 11 Pro Max Screen Replacement, Pry up the microphone: step 29, image 1 of 3 iPhone 11 Pro Max Screen Replacement, Pry up the microphone: step 29, image 2 of 3 iPhone 11 Pro Max Screen Replacement, Pry up the microphone: step 29, image 3 of 3
      • Use the point of a spudger to lift and separate the microphone from its notch in the front panel.
      Ask FixBot
    5. iPhone 11 Pro Max Screen Replacement, Separate the ambient light sensor: step 30, image 1 of 2 iPhone 11 Pro Max Screen Replacement, Separate the ambient light sensor: step 30, image 2 of 2
      Buy
      • Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display.
      • If the sensor does not wiggle free after a few seconds, apply more heat and try again.
      • The sensor remains attached to the rest of the sensor assembly via a very thin flex cable. Be careful not to strain or damage the cable.
      Ask FixBot
    6. iPhone 11 Pro Max Screen Replacement: step 31, image 1 of 3 iPhone 11 Pro Max Screen Replacement: step 31, image 2 of 3 iPhone 11 Pro Max Screen Replacement: step 31, image 3 of 3
      • If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below.
      • If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier.
      • During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
      • Then, set the ambient light sensor on top of the diffuser. You will need to hold the sensor in position while installing the screws securing the earpiece/sensor assembly. Once the screws are tightened, the sensor will stay in place and work normally.
      Ask FixBot
    7. iPhone 11 Pro Max Screen Replacement: step 32, image 1 of 3 iPhone 11 Pro Max Screen Replacement: step 32, image 2 of 3 iPhone 11 Pro Max Screen Replacement: step 32, image 3 of 3
      • Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module.
      • Gently wiggle and lift to separate the module from its notch in the front panel.
      • It's helpful to lift and hold the speaker out of the way for access. Just be careful not to pull on the thin flex cable while you work.
      Ask FixBot
    8. iPhone 11 Pro Max Screen Replacement, Remove the speaker + front sensor assembly: step 33, image 1 of 3 iPhone 11 Pro Max Screen Replacement, Remove the speaker + front sensor assembly: step 33, image 2 of 3 iPhone 11 Pro Max Screen Replacement, Remove the speaker + front sensor assembly: step 33, image 3 of 3
      • Remove the earpiece speaker and front sensor assembly.
      • During reassembly, check the position of the black plastic module containing these components:
      • Proximity sensor
      • Flood illuminator
      • The module must be positioned so that these components are not obstructed by any adhesive.
      Ask FixBot
Repair didn’t go as planned? Check out our iPhone 11 Pro Max Answers community for troubleshooting help.
121 other people completed this guide.
Author
with
Jeff Suovanen
455,892 Reputation
259 Guides authored
21 Guide Comments
There is no programmer yet for the 11 Pro as far as I can see, the YT clip is about older models. Anyone have a solution?
Fixandinstall - Reply Share
So far the newest iPhone I have repaired is an iPhone 7 - should I give the 11 pro a go?
TheRe - Reply Share
Yes. It's very simple
Cheyenne Reed - Reply Share
I just finished this repair and this guide was very easy and clear to follow. I had no issues with the parts from ifixit and my phone is back to fully operational. I just wish that OLED screen wasn’t so much money, but oh well…
Scott Hyder - Reply Share
how do i return it back there is no how to put it back
ps_fan_1 - Reply Share
Past 24 Hours: 49
Past 7 Days: 348
Past 30 Days: 1,820
All Time: 257,202
