iPhone 11 Pro Max Face ID Not Working Repair
    1. iPhone 11 Pro Max Face ID Not Working Repair, iPhone 11 Pro Max Face ID Not Working Repair: step 1, image 1 of 3 iPhone 11 Pro Max Face ID Not Working Repair, iPhone 11 Pro Max Face ID Not Working Repair: step 1, image 2 of 3 iPhone 11 Pro Max Face ID Not Working Repair, iPhone 11 Pro Max Face ID Not Working Repair: step 1, image 3 of 3
      • Go to Settings > Face ID & Passcode > Set Up Face ID. When trying to set up Face ID, “Move iPhone a little lower/higher” pops up. Face ID cannot be normally set up. It can be judged that the dot projector of the Face ID has malfunctioned.
      • Remove the display and then detach the Face ID module. We can see a red mark, which indicates that the phone has water damage.
      Ask FixBot
    2. iPhone 11 Pro Max Face ID Not Working Repair: step 2, image 1 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 2, image 2 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 2, image 3 of 3
      • Connect the dot projector flex cable with the I2C Repair Programmer. The test shows that the dot projector flex cable has malfunctioned.
      • Press “Read” and read the data from the dot projector flex cable.
      • Connect a new I2C iPhone 11 Pro Max flex cable to the programmer. Press “Write” and write the data that has been read on the new flex cable.
      Ask FixBot
    3. iPhone 11 Pro Max Face ID Not Working Repair: step 3, image 1 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 3, image 2 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 3, image 3 of 3
      • Dip a small amount of UV Adhesive on the crystal of the dot projector flex cable and solidify it with the UV Lamp. This step is aimed at fixing the crystal.
      • Remove the foam on the back of the dot projector.
      Ask FixBot
    4. iPhone 11 Pro Max Face ID Not Working Repair: step 4, image 1 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 4, image 2 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 4, image 3 of 3
      • To make positioning easier during assembly, mark the module with the Sculpture Knife.
      • Since the dot projector flex cable is under the metal plate, lift the metal plate to remove the flex cable.
      Ask FixBot
    5. iPhone 11 Pro Max Face ID Not Working Repair: step 5, image 1 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 5, image 2 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 5, image 3 of 3
      • Attach the Face ID module to the Holding Fixture and grind the welding position of the metal plate.
      • Insert the pry knife into the gap between the dot projector module and the crystal.
      Ask FixBot
    6. iPhone 11 Pro Max Face ID Not Working Repair: step 6, image 1 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 6, image 2 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 6, image 3 of 3
      • Heat with a hot air gun at 150℃ and remove the dot projector flex cable.
      • Heat with a hot air gun at 320℃ and detach the dot projector module.
      Ask FixBot
    7. iPhone 11 Pro Max Face ID Not Working Repair: step 7, image 1 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 7, image 2 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 7, image 3 of 3
      • Attach the dot projector module to the Holding Fixture. Heat with the Hot Air Gun at 320℃ and take out the MOSFET.
      • Apply a small amount of Solder Paste to the bonding pad with the Soldering Iron at 365℃. Jump wire between pin 2 and pin 3 of the MOSFET with 0.02mm copper wire.
      Ask FixBot
    8. iPhone 11 Pro Max Face ID Not Working Repair: step 8, image 1 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 8, image 2 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Attach the dot projector module to the holder. To clean the tin on the dot projector module, smear rosin with the Soldering Iron at 365℃ and solder-wick.
      • Clean the module with PCB Cleaner afterward. Heat with Hot Air Gun at 240℃ and remove residual adhesive with tweezers.
      Ask FixBot
    9. iPhone 11 Pro Max Face ID Not Working Repair: step 9, image 1 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 9, image 2 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 9, image 3 of 3
      • Get the new flex cable. Put the Reballing Stencil in the right position and apply some medium-temperature Solder Paste evenly.
      • Heat with the Hot Air Gun at 320℃ and remove the Reballing Stencil after the flex cable has cooled.
      Ask FixBot
    10. iPhone 11 Pro Max Face ID Not Working Repair: step 10, image 1 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 10, image 2 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 10, image 3 of 3
      • Heat with the Hot Air Gun at 320℃ again and apply a small amount of Paste Flux to the flex cable.
      • Fix the flex cable to the holder and align the dot projector module.
      Ask FixBot
    11. iPhone 11 Pro Max Face ID Not Working Repair: step 11, image 1 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 11, image 2 of 3 iPhone 11 Pro Max Face ID Not Working Repair: step 11, image 3 of 3
      • Solder with Hot Air Gun at 320℃.
      • Connect the flex cable that has been soldered to the I2C programmer. Press “Test” and the screen shows “Pass,” which indicates that the flex cable is normal.
      • Attach the flex cable to the Holding Fixture and put the dot projector flex cable in position.
      Ask FixBot
    12. iPhone 11 Pro Max Face ID Not Working Repair: step 12, image 1 of 2 iPhone 11 Pro Max Face ID Not Working Repair: step 12, image 2 of 2
      • Apply a small amount of 460 Adhesive between the dot projector module and the crystal.
      • Once the adhesive has set, arrange the flex cable.
      Ask FixBot
    13. iPhone 11 Pro Max Face ID Not Working Repair: step 13, image 1 of 2 iPhone 11 Pro Max Face ID Not Working Repair: step 13, image 2 of 2
      • Install the flex cable on the phone. Boot up the phone, and go to Face ID settings. Face ID is set up normally and unlocks normally. The fault is cleared.
      Ask FixBot
Please stay tuned for more content.
4 other people completed this guide.
REWA
19,573 Reputation
55 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 70
Past 30 Days: 289
All Time: 3,626
