iPhone 11 Pro Max Back Glass Replacement
    1. iPhone 11 Pro Max Back Glass Replacement, Positioning and Adjust the Distance: step 1, image 1 of 3 iPhone 11 Pro Max Back Glass Replacement, Positioning and Adjust the Distance: step 1, image 2 of 3 iPhone 11 Pro Max Back Glass Replacement, Positioning and Adjust the Distance: step 1, image 3 of 3
      • First, place the iPhone 11 Pro Max back glass into the centered positioning mold.
      • Then, use a focal length rod to adjust the distance between the laser head and the back glass.
      Ask FixBot
    2. iPhone 11 Pro Max Back Glass Replacement, Scan The Back Glass With Laser: step 2, image 1 of 3 iPhone 11 Pro Max Back Glass Replacement, Scan The Back Glass With Laser: step 2, image 2 of 3 iPhone 11 Pro Max Back Glass Replacement, Scan The Back Glass With Laser: step 2, image 3 of 3
      • Close the door. Select the iPhone 11 Pro Max’s back cover drawing from the model list, then click the “Figures” key - the machine will laser the back glass automatically.
      • Here we can see that the machine is an enclosed structure with a window door and the laser is not exposed. You can observe the laser process at any time and it’s 100% safe and reliable during the operation.
      • What’s more, while the laser machine is working, you can release your hands to do other repair jobs. It’s very convenient.
      Ask FixBot
    3. iPhone 11 Pro Max Back Glass Replacement, Separate The Back Glass - Part 1: step 3, image 1 of 3 iPhone 11 Pro Max Back Glass Replacement, Separate The Back Glass - Part 1: step 3, image 2 of 3 iPhone 11 Pro Max Back Glass Replacement, Separate The Back Glass - Part 1: step 3, image 3 of 3
      • Once the laser is finished, take out the phone and give the back glass a little tap with a focal length rob. The back glass would appear with some cracks, it would be easier to separate.
      • No need for too much force.
      Ask FixBot
    4. iPhone 11 Pro Max Back Glass Replacement, Separate The Back Glass - Part 2: step 4, image 1 of 3 iPhone 11 Pro Max Back Glass Replacement, Separate The Back Glass - Part 2: step 4, image 2 of 3 iPhone 11 Pro Max Back Glass Replacement, Separate The Back Glass - Part 2: step 4, image 3 of 3
      • At this time, you can use a blade and a playing card to remove the back glass.
      • You can see a wireless charging sensor in the middle of the phone after you remove the back glass.
      • Be careful of sharp glass that could cause injury. Wear gloves to avoid cutting your hands.
      Ask FixBot
    5. iPhone 11 Pro Max Back Glass Replacement, Separate the Glass Around the Triple-Lens Camera: step 5, image 1 of 3 iPhone 11 Pro Max Back Glass Replacement, Separate the Glass Around the Triple-Lens Camera: step 5, image 2 of 3 iPhone 11 Pro Max Back Glass Replacement, Separate the Glass Around the Triple-Lens Camera: step 5, image 3 of 3
      • The glass around the triple-lens camera is relatively thick and the glass in this area is harder to remove. No matter how hard it is, you still can find a way to overcome it.
      • If you are not able to tear down the glass in this area, you can laser the glass in this area one more time.
      • Here, the engineer is using a blade, a grinding tool, a sculpture knife to remove the glass in this area.
      • You should be more patient in this step. Finally, you can take out the glass in this area successfully.
      Ask FixBot
    6. iPhone 11 Pro Max Back Glass Replacement, Clean up the Residual Glue and Black Dust: step 6, image 1 of 3 iPhone 11 Pro Max Back Glass Replacement, Clean up the Residual Glue and Black Dust: step 6, image 2 of 3 iPhone 11 Pro Max Back Glass Replacement, Clean up the Residual Glue and Black Dust: step 6, image 3 of 3
      • After finishing the last step, clean up the residual glue and black dust with alcohol and a dustless cloth.
      • Now you can see the back stainless steel plate is very clean in the picture. The next step is to install the new back glass.
      Ask FixBot
    7. iPhone 11 Pro Max Back Glass Replacement, Change a New Back Glass: step 7, image 1 of 3 iPhone 11 Pro Max Back Glass Replacement, Change a New Back Glass: step 7, image 2 of 3 iPhone 11 Pro Max Back Glass Replacement, Change a New Back Glass: step 7, image 3 of 3
      • Before installing the new back glass, you have to put the dustproof net back to the microphone area.
      • Then, add new glue onto the back stainless steel plate and laminate the new back glass to it.
      Ask FixBot
    8. iPhone 11 Pro Max Back Glass Replacement: step 8, image 1 of 3 iPhone 11 Pro Max Back Glass Replacement: step 8, image 2 of 3 iPhone 11 Pro Max Back Glass Replacement: step 8, image 3 of 3
      • Finally, clamp it for 30 minutes.
      • You can see the final effect in the below picture, that is so great.
      • Test the camera. Perfect.
      • That’s all today. If you want to know more cell phone repair information, you can reply to this post.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Save time and money with good tools.
12 other people completed this guide.
RAotom Kim
1,017 Reputation
4 Guides authored
5 Guide Comments
Did you guys experienced any restart problems ? i fixed 2 iphone 11 pro max this way and now customer’s phones keep restarting. i dont know what to do at this point. Is there something i need to watch out for ?
ceyhun ustabas - Reply Share
I m facing same restart issue on 11 pro max after back glass repair plz help me someone
VIPUL parmar - Reply Share
it’s because you cut microphone or damaged it ,power button comes with the back microphone ,it’s need to replaced .imo
CellDoc Livingston - Reply Share
Hello same problem What is the microphone to replace? thank you
nordine hamida - Reply Share
Comment je peux faire pour acheter cette machine?
Merci !
Techniphone12 - Reply Share
Past 24 Hours: 6
Past 7 Days: 88
Past 30 Days: 336
All Time: 42,797
