iPhone 11 Lightning Connector Assembly Replacement
Video Instructions
73 other people completed this guide.
Arty
34,253 Reputation
110 Guides authored
23 Guide Comments
I would rather have a picture and written step by step, he doesn’t say some parts what is called
Dulce Vidal - Reply Share
Me too. I would appreciate knowing the size and type of all screws and standoffs and where they go.
I most likely mixed up a few of them and now the screen stays black.
Kim Mace - Reply Share
First, DISCONNECT the battery before ANY connections, and the battery should be the last thing you re-connect. And you DO NOT need to remove the logic board.
Gregg Stanley - Reply Share
Just completed this repair. Wow it’s tricky but as echoed above, I would try and disconnect battery first although design of the iPhone 11 makes it very difficult to do this. Also, definitely don’t remove logic board and you don’t have to remove the battery either. Removing battery possibly makes it very slightly easier but if you take your time it’s not necessary. Good luck
richarddillon - Reply Share
IS not there a problem with at chip on the charging flex, that causes warnings and or re-boots I have been reading about somewhere?I mean, fitting it is easy enough, but APPPPle keeps annoying customers trying to stop them going to independent shops or doing repairs themselves!
JoeBlog - Reply Share
Past 24 Hours: 76
Past 7 Days: 397
Past 30 Days: 1,845
All Time: 101,456
