Up to 20% off select tools
iPad Pro 12.9" 6th Gen Front Camera Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
14
Past 30 Days:
77
All Time:
279
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the front camera in your iPad Pro 12.9" 6th Gen.
You will lose Face ID if you replace the front camera. The front camera assembly and the logic board are paired, so if you replace either, then you'll lose Face ID.
LTE and mmWave iPads: This guide is written with a previous iPad Pro model. Your device may look a little different, but the procedure is identical.
Wi-Fi only iPads: Use this guide as a general reference, but you may need to perform extra disassembly not covered in this guide.
Battery note: In some photos, you'll see two card strips blocking the battery connector. That's an optional technique—it's better to fully discharge the battery instead. Ignore this visual discrepancy as you work through the guide.
This guide is written with an A2379 model iPad Pro.
    1. iPad Pro 12.9" 6th Gen Front Camera Replacement, Prepare your iPad for disassembly: step 1, image 1 of 1
      • Allow your iPad's battery to fully drain (shuts off by itself) before starting this repair. A charged battery may catch fire if damaged during the repair.
      • If your battery is swollen, take appropriate precautions.
      • Unplug any cables and fully shut down your iPad.
      Ask FixBot
    1. iPad Pro 12.9" 6th Gen Front Camera Replacement, Heat the right edge: step 2, image 1 of 1
      • Apply a heated iOpener to the right edge of the screen for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the iPad—the screen and internal battery are susceptible to heat damage.
      Ask FixBot
    2. iPad Pro 12.9" 6th Gen Front Camera Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      Ask FixBot
    3. iPad Pro 12.9" 6th Gen Front Camera Replacement: step 4, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement: step 4, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement: step 4, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    4. iPad Pro 12.9" 6th Gen Front Camera Replacement: step 5, image 1 of 2 iPad Pro 12.9" 6th Gen Front Camera Replacement: step 5, image 2 of 2
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next step.
      Ask FixBot
    5. iPad Pro 12.9" 6th Gen Front Camera Replacement, Insert an opening pick: step 6, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Insert an opening pick: step 6, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Insert an opening pick: step 6, image 3 of 3
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken display.
      • Apply a suction handle to the screen as close to the center of the right edge as possible.
      • Pull up on the suction handle with a strong, steady force to create a small gap between the frame and screen.
      • The large screen is very fragile. Only create a gap big enough to insert an opening pick.
      • If you're having trouble making a gap, reapply a heated iOpener to the right edge for two minutes.
      • Insert an opening pick into the gap.
      • Don't insert the pick more than 5 mm to avoid damaging the screen.
      Ask FixBot
    6. iPad Pro 12.9" 6th Gen Front Camera Replacement, Right edge information: step 7, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Right edge information: step 7, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Right edge information: step 7, image 3 of 3
      • There are two 2.3 cm-long magnets along the right edge of the screen. Don't insert your opening pick more than 2 mm to avoid damaging the screen in these locations:
      • The first magnet begins 1.9 cm from the top of the iPad.
      • The second magnet begins 2.9 cm from the bottom of the iPad.
      • Everywhere else, don't insert your opening pick more than 5 mm.
      Ask FixBot
    7. iPad Pro 12.9" 6th Gen Front Camera Replacement, Separate the right adhesive: step 8, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Separate the right adhesive: step 8, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Separate the right adhesive: step 8, image 3 of 3
      • Slide your opening pick along the right edge of the screen to separate the adhesive.
      • Angle your pick downward and insert up to a 2 mm depth near the magnet cutouts and 5 mm everywhere else.
      • Leave the pick inserted in the bottom right corner before continuing.
      Ask FixBot
    8. iPad Pro 12.9" 6th Gen Front Camera Replacement, Separate the corner adhesive: step 9, image 1 of 2 iPad Pro 12.9" 6th Gen Front Camera Replacement, Separate the corner adhesive: step 9, image 2 of 2
      • Slide your opening pick around the bottom right corner of the screen to separate the adhesive.
      • Leave your pick in the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    9. iPad Pro 12.9" 6th Gen Front Camera Replacement, Heat the bottom edge: step 10, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the screen for two minutes.
      Ask FixBot
    10. iPad Pro 12.9" 6th Gen Front Camera Replacement, Separate the bottom adhesive: step 11, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Separate the bottom adhesive: step 11, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Separate the bottom adhesive: step 11, image 3 of 3
      • Insert a second opening pick under the bottom right corner of the screen.
      • Don't insert your opening pick more than 5 mm.
      • Slide your pick to the bottom left corner to separate the bottom adhesive.
      Ask FixBot
    11. iPad Pro 12.9" 6th Gen Front Camera Replacement, Slice the corner adhesive: step 12, image 1 of 2 iPad Pro 12.9" 6th Gen Front Camera Replacement, Slice the corner adhesive: step 12, image 2 of 2
      • Rotate your opening pick around the bottom left corner of the screen.
      • Leave your pick in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    12. iPad Pro 12.9" 6th Gen Front Camera Replacement, Heat the left edge: step 13, image 1 of 1
      • Apply a heated iOpener to the left edge of the screen for two minutes.
      Ask FixBot
    13. iPad Pro 12.9" 6th Gen Front Camera Replacement, Left edge information: step 14, image 1 of 2 iPad Pro 12.9" 6th Gen Front Camera Replacement, Left edge information: step 14, image 2 of 2
      • There are four cutouts for flex cables along the left edge of the screen where the adhesive is very thin. Don’t insert your opening pick more than 2 mm in these locations to avoid damaging the display:
      • The 2.1-cm outer cutouts begin at 6.1 cm from the top and bottom of the frame.
      • The 2.8-cm inner cutouts begin at 10.1 cm from the top and bottom of the frame.
      Ask FixBot
    14. iPad Pro 12.9" 6th Gen Front Camera Replacement, Slice the left adhesive: step 15, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Slice the left adhesive: step 15, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Slice the left adhesive: step 15, image 3 of 3
      • Insert a third opening pick under the bottom left corner of the screen.
      • Slide your pick to the top left corner to slice the left adhesive, making sure to avoid the cutouts shown in the previous step.
      • Leave the pick inserted in the top left corner before continuing.
      Ask FixBot
    15. iPad Pro 12.9" 6th Gen Front Camera Replacement, Slice the corner adhesive: step 16, image 1 of 2 iPad Pro 12.9" 6th Gen Front Camera Replacement, Slice the corner adhesive: step 16, image 2 of 2
      • Slide your opening pick around the top left corner of the screen.
      • Leave your pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    16. iPad Pro 12.9" 6th Gen Front Camera Replacement, Heat the top edge: step 17, image 1 of 1
      • Apply a heated iOpener to the top edge of the screen for two minutes.
      Ask FixBot
    17. iPad Pro 12.9" 6th Gen Front Camera Replacement, Top edge information: step 18, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Top edge information: step 18, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Top edge information: step 18, image 3 of 3
      • While the top edge adhesive softens, note the following:
      • There are 0.7-cm cutouts for the ambient light sensors starting 4.1 cm from each of the side edges. Don't insert your pick more than 1 mm here.
      • The front-facing camera and additional sensors are in the center of the top edge. Don't insert your pick here—there is less than 1 mm of adhesive and you may damage the components.
      • For everywhere else, don't insert your pick more than 5 mm to avoid damaging the screen.
      Ask FixBot
    18. iPad Pro 12.9" 6th Gen Front Camera Replacement, Separate the top adhesive: step 19, image 1 of 2 iPad Pro 12.9" 6th Gen Front Camera Replacement, Separate the top adhesive: step 19, image 2 of 2
      • Slide your opening pick toward the top right edge, stopping just before the camera assembly.
      • If you slide any farther, you risk damaging the camera's sensors.
      • Leave your pick inserted before continuing.
      Ask FixBot
    19. iPad Pro 12.9" 6th Gen Front Camera Replacement: step 20, image 1 of 2 iPad Pro 12.9" 6th Gen Front Camera Replacement: step 20, image 2 of 2
      • Insert a new opening pick on the other side of the camera assembly, about 4 cm from the previous pick.
      • Slide your pick to the top right corner to slice the remaining adhesive.
      Ask FixBot
    20. iPad Pro 12.9" 6th Gen Front Camera Replacement, Reposition the screen: step 21, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Reposition the screen: step 21, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Reposition the screen: step 21, image 3 of 3
      • Don't fully remove the screen, as it's attached by several cables.
      • Grab two opposing corners of the screen and lift up to separate it from the frame.
      • If the screen feels stuck, slide your opening picks around the perimeter to separate any remaining adhesive. Pay attention to sensitive areas shown in previous steps.
      • Shift the screen towards the bottom right corner of the frame until the ribbon cable near the top edge is uncovered.
      Ask FixBot
    21. iPad Pro 12.9" 6th Gen Front Camera Replacement, Unfasten the upper cable shield: step 22, image 1 of 1
      FixMat
      $31.41
      Buy
      • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
      • Use a Phillips screwdriver to remove the two screws securing the upper cable shield:
      • One 1.8 mm-long screw
      • One 1.4 mm-long screw
      • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
      Ask FixBot
    22. iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the upper cable shield: step 23, image 1 of 2 iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the upper cable shield: step 23, image 2 of 2
      Buy
      • Use tweezers or your fingers to grab and remove the upper cable shield.
      Ask FixBot
    23. iPad Pro 12.9" 6th Gen Front Camera Replacement, Disconnect the upper sensors: step 24, image 1 of 2 iPad Pro 12.9" 6th Gen Front Camera Replacement, Disconnect the upper sensors: step 24, image 2 of 2
      • Use the tip of a spudger to pry up and disconnect the upper sensors press connector.
      • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    24. iPad Pro 12.9" 6th Gen Front Camera Replacement, Reposition the screen: step 25, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Reposition the screen: step 25, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Reposition the screen: step 25, image 3 of 3
      • Grip the right edge of the screen and open it like a book.
      • Don't pull up on the screen—the screen cables are still attached.
      • Lay the screen down over the left edge of the iPad.
      • Be careful not to strain the screen cables.
      Ask FixBot
    1. iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the logic board cover: step 26, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the logic board cover: step 26, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the logic board cover: step 26, image 3 of 3
      • The logic board cover is lightly adhered to the logic board.
      • Peel the cover off of the logic board to remove it.
      Ask FixBot
    1. iPad Pro 12.9" 6th Gen Front Camera Replacement, Unfasten the display brackets: step 27, image 1 of 1
      • Use a Phillips screwdriver to remove the seven screws securing the top and bottom display brackets:
      • Four 1.1 mm-long screws
      • Two 2.0 mm-long screws
      • One 1.0 mm-long screw
      Ask FixBot
    2. iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the display brackets: step 28, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the display brackets: step 28, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the display brackets: step 28, image 3 of 3
      Buy
      • Use tweezers, or your fingers, to remove the top and bottom display brackets.
      Ask FixBot
    3. iPad Pro 12.9" 6th Gen Front Camera Replacement, Disconnect the bottom display cables: step 29, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Disconnect the bottom display cables: step 29, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Disconnect the bottom display cables: step 29, image 3 of 3
      • Use a spudger to pry up and disconnect the two bottom display cable press connectors.
      Ask FixBot
    4. iPad Pro 12.9" 6th Gen Front Camera Replacement, Disconnect the top display cables: step 30, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Disconnect the top display cables: step 30, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Disconnect the top display cables: step 30, image 3 of 3
      • Use a spudger to pry up and disconnect the two top display cable press connectors.
      Ask FixBot
    5. iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the screen: step 31, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the screen: step 31, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the screen: step 31, image 3 of 3
      • Remove the screen.
      Ask FixBot
    1. iPad Pro 12.9" 6th Gen Front Camera Replacement, Unfasten the front camera bracket: step 32, image 1 of 1
      • Use a Phillips screwdriver to remove the three screws securing the front camera bracket to the logic board:
      • Two 1.1 mm-long screws
      Ask FixBot
    2. iPad Pro 12.9" 6th Gen Front Camera Replacement, Heat the front camera bracket: step 33, image 1 of 1
      • The front camera bracket is adhered to the logic board.
      • Heat an iOpener and apply it to the front camera bracket for two minutes.
      Ask FixBot
    3. iPad Pro 12.9" 6th Gen Front Camera Replacement, Separate the bracket adhesive: step 34, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Separate the bracket adhesive: step 34, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Separate the bracket adhesive: step 34, image 3 of 3
      • Insert an opening pick between the front camera bracket and the logic board.
      • Slide the pick toward the top of the iPad to separate the adhesive.
      Ask FixBot
    4. iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the front camera bracket: step 35, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the front camera bracket: step 35, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the front camera bracket: step 35, image 3 of 3
      • Slide the front camera bracket toward the right edge of the iPad to release its metal clip.
      • Remove the front camera bracket.
      • During reassembly, make sure the metal clip is secured under the logic board before continuing.
      Ask FixBot
    5. iPad Pro 12.9" 6th Gen Front Camera Replacement, Disconnect the front camera: step 36, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Disconnect the front camera: step 36, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Disconnect the front camera: step 36, image 3 of 3
      • Use a spudger to pry up and disconnect the three front camera cable press connectors.
      Ask FixBot
    6. iPad Pro 12.9" 6th Gen Front Camera Replacement: step 37, image 1 of 2 iPad Pro 12.9" 6th Gen Front Camera Replacement: step 37, image 2 of 2
      Buy
      • The left-most front camera cable is lightly adhered to the frame.
      • Use tweezers, or your fingers, to peel the left-most cable off of the logic board.
      Ask FixBot
    7. iPad Pro 12.9" 6th Gen Front Camera Replacement, Unfasten the front camera: step 38, image 1 of 1
      • Use a T3 Torx screwdriver to remove the two 2.2 mm-long screws securing the front camera.
      Ask FixBot
    8. iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the front camera: step 39, image 1 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the front camera: step 39, image 2 of 3 iPad Pro 12.9" 6th Gen Front Camera Replacement, Remove the front camera: step 39, image 3 of 3
      • The front camera is strongly adhered to the frame with heat-resistant epoxy. Work slowly to avoid damaging surrounding components.
      • Insert a spudger underneath the front camera, between the middle and right cables.
      • Twist the spudger to separate the epoxy securing the front camera.
      • This may require significant force.
      • Remove the front camera.
      • During reassembly, use a spudger to scrape off any remaining epoxy before reinstalling the front camera.
      Ask FixBot
Arthur Shi
354,431 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 14
Past 30 Days: 77
All Time: 279
