Up to 20% off select tools
iPad Pro 12.9" 6th Gen Battery Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
15
Past 7 Days:
107
Past 30 Days:
549
All Time:
1,944
Comments: 10
10 comments on steps.
Completed: 0
Favorites: 0
Time Required: 2 - 3 hours
Difficulty: Difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the battery in your iPad Pro 12.9" 6th Gen.
LTE and mmWave iPads: This guide is written with a previous iPad Pro model. Your device may look a little different, but the procedure is identical.
Wi-Fi only iPads: Use this guide as a general reference, but you may need to perform extra disassembly not covered in this guide.
Battery note: In some photos, you'll see two card strips blocking the battery connector. That's an optional technique—it's better to fully discharge the battery instead. Ignore this visual discrepancy as you work through the guide.
This guide is written with an A2379 model iPad Pro.
    1. iPad Pro 12.9" 6th Gen Battery Replacement, Prepare your iPad for disassembly: step 1, image 1 of 1
      • Allow your iPad's battery to fully drain (shuts off by itself) before starting this repair. A charged battery may catch fire if damaged during the repair.
      • If your battery is swollen, take appropriate precautions.
      • Unplug any cables and fully shut down your iPad.
      Ask FixBot
    1. iPad Pro 12.9" 6th Gen Battery Replacement, Heat the right edge: step 2, image 1 of 1
      • Apply a heated iOpener to the right edge of the screen for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the iPad—the screen and internal battery are susceptible to heat damage.
      Ask FixBot
    2. iPad Pro 12.9" 6th Gen Battery Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      Ask FixBot
    3. iPad Pro 12.9" 6th Gen Battery Replacement: step 4, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 4, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 4, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    4. iPad Pro 12.9" 6th Gen Battery Replacement: step 5, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement: step 5, image 2 of 2
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next step.
      Ask FixBot
    5. iPad Pro 12.9" 6th Gen Battery Replacement, Insert an opening pick: step 6, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Insert an opening pick: step 6, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Insert an opening pick: step 6, image 3 of 3
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken display.
      • Apply a suction handle to the screen as close to the center of the right edge as possible.
      • Pull up on the suction handle with a strong, steady force to create a small gap between the frame and screen.
      • The large screen is very fragile. Only create a gap big enough to insert an opening pick.
      • If you're having trouble making a gap, reapply a heated iOpener to the right edge for two minutes.
      • Insert an opening pick into the gap.
      • Don't insert the pick more than 5 mm to avoid damaging the screen.
      Ask FixBot
    6. iPad Pro 12.9" 6th Gen Battery Replacement, Right edge information: step 7, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Right edge information: step 7, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Right edge information: step 7, image 3 of 3
      • There are two 2.3 cm-long magnets along the right edge of the screen. Don't insert your opening pick more than 2 mm to avoid damaging the screen in these locations:
      • The first magnet begins 1.9 cm from the top of the iPad.
      • The second magnet begins 2.9 cm from the bottom of the iPad.
      • Everywhere else, don't insert your opening pick more than 5 mm.
      Ask FixBot
    7. iPad Pro 12.9" 6th Gen Battery Replacement, Separate the right adhesive: step 8, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the right adhesive: step 8, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the right adhesive: step 8, image 3 of 3
      • Slide your opening pick along the right edge of the screen to separate the adhesive.
      • Angle your pick downward and insert up to a 2 mm depth near the magnet cutouts and 5 mm everywhere else.
      • Leave the pick inserted in the bottom right corner before continuing.
      Ask FixBot
    8. iPad Pro 12.9" 6th Gen Battery Replacement, Separate the corner adhesive: step 9, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the corner adhesive: step 9, image 2 of 2
      • Slide your opening pick around the bottom right corner of the screen to separate the adhesive.
      • Leave your pick in the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    9. iPad Pro 12.9" 6th Gen Battery Replacement, Heat the bottom edge: step 10, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the screen for two minutes.
      Ask FixBot
    10. iPad Pro 12.9" 6th Gen Battery Replacement, Separate the bottom adhesive: step 11, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the bottom adhesive: step 11, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the bottom adhesive: step 11, image 3 of 3
      • Insert a second opening pick under the bottom right corner of the screen.
      • Don't insert your opening pick more than 5 mm.
      • Slide your pick to the bottom left corner to separate the bottom adhesive.
      Ask FixBot
    11. iPad Pro 12.9" 6th Gen Battery Replacement, Slice the corner adhesive: step 12, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Slice the corner adhesive: step 12, image 2 of 2
      • Rotate your opening pick around the bottom left corner of the screen.
      • Leave your pick in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    12. iPad Pro 12.9" 6th Gen Battery Replacement, Heat the left edge: step 13, image 1 of 1
      • Apply a heated iOpener to the left edge of the screen for two minutes.
      Ask FixBot
    13. iPad Pro 12.9" 6th Gen Battery Replacement, Left edge information: step 14, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Left edge information: step 14, image 2 of 2
      • There are four cutouts for flex cables along the left edge of the screen where the adhesive is very thin. Don’t insert your opening pick more than 2 mm in these locations to avoid damaging the display:
      • The 2.1-cm outer cutouts begin at 6.1 cm from the top and bottom of the frame.
      • The 2.8-cm inner cutouts begin at 10.1 cm from the top and bottom of the frame.
      Ask FixBot
    14. iPad Pro 12.9" 6th Gen Battery Replacement, Slice the left adhesive: step 15, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Slice the left adhesive: step 15, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Slice the left adhesive: step 15, image 3 of 3
      • Insert a third opening pick under the bottom left corner of the screen.
      • Slide your pick to the top left corner to slice the left adhesive, making sure to avoid the cutouts shown in the previous step.
      • Leave the pick inserted in the top left corner before continuing.
      Ask FixBot
    15. iPad Pro 12.9" 6th Gen Battery Replacement, Slice the corner adhesive: step 16, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Slice the corner adhesive: step 16, image 2 of 2
      • Slide your opening pick around the top left corner of the screen.
      • Leave your pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    16. iPad Pro 12.9" 6th Gen Battery Replacement, Heat the top edge: step 17, image 1 of 1
      • Apply a heated iOpener to the top edge of the screen for two minutes.
      Ask FixBot
    17. iPad Pro 12.9" 6th Gen Battery Replacement, Top edge information: step 18, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Top edge information: step 18, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Top edge information: step 18, image 3 of 3
      • While the top edge adhesive softens, note the following:
      • There are 0.7-cm cutouts for the ambient light sensors starting 4.1 cm from each of the side edges. Don't insert your pick more than 1 mm here.
      • The front-facing camera and additional sensors are in the center of the top edge. Don't insert your pick here—there is less than 1 mm of adhesive and you may damage the components.
      • For everywhere else, don't insert your pick more than 5 mm to avoid damaging the screen.
      Ask FixBot
    18. iPad Pro 12.9" 6th Gen Battery Replacement, Separate the top adhesive: step 19, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the top adhesive: step 19, image 2 of 2
      • Slide your opening pick toward the top right edge, stopping just before the camera assembly.
      • If you slide any farther, you risk damaging the camera's sensors.
      • Leave your pick inserted before continuing.
      Ask FixBot
    19. iPad Pro 12.9" 6th Gen Battery Replacement: step 20, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement: step 20, image 2 of 2
      • Insert a new opening pick on the other side of the camera assembly, about 4 cm from the previous pick.
      • Slide your pick to the top right corner to slice the remaining adhesive.
      Ask FixBot
    20. iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the screen: step 21, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the screen: step 21, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the screen: step 21, image 3 of 3
      • Don't fully remove the screen, as it's attached by several cables.
      • Grab two opposing corners of the screen and lift up to separate it from the frame.
      • If the screen feels stuck, slide your opening picks around the perimeter to separate any remaining adhesive. Pay attention to sensitive areas shown in previous steps.
      • Shift the screen towards the bottom right corner of the frame until the ribbon cable near the top edge is uncovered.
      Ask FixBot
    21. iPad Pro 12.9" 6th Gen Battery Replacement, Unfasten the upper cable shield: step 22, image 1 of 1
      FixMat
      $31.41
      Buy
      • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
      • Use a Phillips screwdriver to remove the two screws securing the upper cable shield:
      • One 1.8 mm-long screw
      • One 1.4 mm-long screw
      • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
      Ask FixBot
    22. iPad Pro 12.9" 6th Gen Battery Replacement, Remove the upper cable shield: step 23, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the upper cable shield: step 23, image 2 of 2
      Buy
      • Use tweezers or your fingers to grab and remove the upper cable shield.
      Ask FixBot
    23. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the upper sensors: step 24, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the upper sensors: step 24, image 2 of 2
      • Use the tip of a spudger to pry up and disconnect the upper sensors press connector.
      • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    24. iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the screen: step 25, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the screen: step 25, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the screen: step 25, image 3 of 3
      • Grip the right edge of the screen and open it like a book.
      • Don't pull up on the screen—the screen cables are still attached.
      • Lay the screen down over the left edge of the iPad.
      • Be careful not to strain the screen cables.
      Ask FixBot
    1. iPad Pro 12.9" 6th Gen Battery Replacement, Remove the logic board cover: step 26, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the logic board cover: step 26, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the logic board cover: step 26, image 3 of 3
      • The logic board cover is lightly adhered to the logic board.
      • Peel the cover off of the logic board to remove it.
      Ask FixBot
    2. iPad Pro 12.9" 6th Gen Battery Replacement, Unfasten the battery connector: step 27, image 1 of 1
      • Use a Phillips screwdriver to remove the 1.7 mm-long screw securing the battery connector to the logic board.
      Ask FixBot
    1. iPad Pro 12.9" 6th Gen Battery Replacement, Unfasten the display brackets: step 28, image 1 of 1
      • Use a Phillips screwdriver to remove the seven screws securing the top and bottom display brackets:
      • Four 1.1 mm-long screws
      • Two 2.0 mm-long screws
      • One 1.0 mm-long screw
      Ask FixBot
    2. iPad Pro 12.9" 6th Gen Battery Replacement, Remove the display brackets: step 29, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the display brackets: step 29, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the display brackets: step 29, image 3 of 3
      Buy
      • Use tweezers, or your fingers, to remove the top and bottom display brackets.
      Ask FixBot
    3. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the bottom display cables: step 30, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the bottom display cables: step 30, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the bottom display cables: step 30, image 3 of 3
      • Use a spudger to pry up and disconnect the two bottom display cable press connectors.
      Ask FixBot
    4. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the top display cables: step 31, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the top display cables: step 31, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the top display cables: step 31, image 3 of 3
      • Use a spudger to pry up and disconnect the two top display cable press connectors.
      Ask FixBot
    5. iPad Pro 12.9" 6th Gen Battery Replacement, Remove the screen: step 32, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the screen: step 32, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the screen: step 32, image 3 of 3
      • Remove the screen.
      Ask FixBot
    1. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the charging port: step 33, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the charging port: step 33, image 2 of 2
      • Use a spudger to pry up and disconnect the charging port cable press connector.
      Ask FixBot
    2. iPad Pro 12.9" 6th Gen Battery Replacement, Separate the charging port adhesive: step 34, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the charging port adhesive: step 34, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the charging port adhesive: step 34, image 3 of 3
      • The charging port cable is lightly adhered to the logic board.
      • Insert an opening pick between the charging port cable and the logic board.
      • Slide the pick toward the charging port to separate the adhesive.
      Ask FixBot
    3. iPad Pro 12.9" 6th Gen Battery Replacement, Unfasten the charging port: step 35, image 1 of 1
      • Use a Phillips screwdriver to remove the two 1.8 mm-long screws securing the charging port.
      Ask FixBot
    4. iPad Pro 12.9" 6th Gen Battery Replacement, Remove the grounding clips: step 36, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the grounding clips: step 36, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the grounding clips: step 36, image 3 of 3
      Buy
      • Use tweezers to remove the two small grounding clips next to the charging port.
      Ask FixBot
    5. iPad Pro 12.9" 6th Gen Battery Replacement, Remove the charging port: step 37, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the charging port: step 37, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the charging port: step 37, image 3 of 3
      • Use your fingers to pull the charging port out of its slot in the frame.
      • Remove the charging port.
      Ask FixBot
    1. iPad Pro 12.9" 6th Gen Battery Replacement, Unfasten the front camera bracket: step 38, image 1 of 1
      • Use a Phillips screwdriver to remove the three screws securing the front camera bracket to the logic board:
      • Two 1.1 mm-long screws
      Ask FixBot
    2. iPad Pro 12.9" 6th Gen Battery Replacement, Heat the front camera bracket: step 39, image 1 of 1
      • The front camera bracket is adhered to the logic board.
      • Heat an iOpener and apply it to the front camera bracket for two minutes.
      Ask FixBot
    3. iPad Pro 12.9" 6th Gen Battery Replacement, Separate the bracket adhesive: step 40, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the bracket adhesive: step 40, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the bracket adhesive: step 40, image 3 of 3
      • Insert an opening pick between the front camera bracket and the logic board.
      • Slide the pick toward the top of the iPad to separate the adhesive.
      Ask FixBot
    4. iPad Pro 12.9" 6th Gen Battery Replacement, Remove the front camera bracket: step 41, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the front camera bracket: step 41, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the front camera bracket: step 41, image 3 of 3
      • Slide the front camera bracket toward the right edge of the iPad to release its metal clip.
      • Remove the front camera bracket.
      • During reassembly, make sure the metal clip is secured under the logic board before continuing.
      Ask FixBot
    5. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the front camera: step 42, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the front camera: step 42, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the front camera: step 42, image 3 of 3
      • Use a spudger to pry up and disconnect the three front camera cable press connectors.
      Ask FixBot
    6. iPad Pro 12.9" 6th Gen Battery Replacement: step 43, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement: step 43, image 2 of 2
      Buy
      • The left-most front camera cable is lightly adhered to the frame.
      • Use tweezers, or your fingers, to peel the left-most cable off of the logic board.
      Ask FixBot
    7. iPad Pro 12.9" 6th Gen Battery Replacement, Unfasten the front camera: step 44, image 1 of 1
      • Use a T3 Torx screwdriver to remove the two 2.2 mm-long screws securing the front camera.
      Ask FixBot
    8. iPad Pro 12.9" 6th Gen Battery Replacement, Remove the front camera: step 45, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the front camera: step 45, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the front camera: step 45, image 3 of 3
      • The front camera is strongly adhered to the frame with heat-resistant epoxy. Work slowly to avoid damaging surrounding components.
      • Insert a spudger underneath the front camera, between the middle and right cables.
      • Twist the spudger to separate the epoxy securing the front camera.
      • This may require significant force.
      • Remove the front camera.
      • During reassembly, use a spudger to scrape off any remaining epoxy before reinstalling the front camera.
      Ask FixBot
    1. iPad Pro 12.9" 6th Gen Battery Replacement, Unfasten the rear camera bracket: step 46, image 1 of 1
      • Use a Phillips screwdriver to remove the five screws securing the rear camera bracket to the frame:
      • Two 1.2 mm-long screws
      • One 2.7 mm-long screw
      • One 2.6 mm-long screw
      Ask FixBot
    2. iPad Pro 12.9" 6th Gen Battery Replacement, Remove the rear camera bracket: step 47, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the rear camera bracket: step 47, image 2 of 2
      Buy
      • Use tweezers, or your fingers, to remove the rear camera bracket.
      Ask FixBot
    3. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the rear cameras: step 48, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the rear cameras: step 48, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the rear cameras: step 48, image 3 of 3
      • Use a spudger to pry up and disconnect the wide-angle camera cable press connector.
      • Disconnect the bottom power button cable press connector.
      Ask FixBot
    4. iPad Pro 12.9" 6th Gen Battery Replacement: step 49, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 49, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 49, image 3 of 3
      • Use a spudger to pry up and disconnect the LiDAR sensor cable press connector.
      • Disconnect the ultrawide camera cable press connector.
      Ask FixBot
    5. iPad Pro 12.9" 6th Gen Battery Replacement: step 50, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement: step 50, image 2 of 2
      • Use a spudger to pry up and disconnect the top power button cable press connector.
      Ask FixBot
    6. iPad Pro 12.9" 6th Gen Battery Replacement, Remove the rear camera assembly: step 51, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the rear camera assembly: step 51, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the rear camera assembly: step 51, image 3 of 3
      • Insert a spudger between the right edge of the rear camera assembly and the frame.
      • Pry up to separate the rear camera from the frame.
      • Remove the rear camera assembly.
      Ask FixBot
    1. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the coaxial cables: step 52, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the coaxial cables: step 52, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the coaxial cables: step 52, image 3 of 3
      • Use the pointed end of a spudger to disconnect the six coaxial cables near the top of the iPad by prying up as close to their connectors as possible.
      • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
      Ask FixBot
    2. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the top microphones: step 53, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the top microphones: step 53, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the top microphones: step 53, image 3 of 3
      • Use a spudger to pry up and disconnect the two top microphone press connectors.
      Ask FixBot
    3. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the top speakers: step 54, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the top speakers: step 54, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the top speakers: step 54, image 3 of 3
      • Use the tip of a spudger to pry up and disconnect the four top speaker connectors.
      • Insert the spudger under the middle of the connectors. Alternatively, you can pry under the cables.
      Ask FixBot
    4. iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the speaker cables: step 55, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the speaker cables: step 55, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the speaker cables: step 55, image 3 of 3
      Buy
      • Three of the speaker cables are lightly adhered to the logic board.
      • Use tweezers, or your fingers, to peel the three speaker cables off of the logic board.
      • Grip the cables by the black foam tubes, not the wires themselves.
      Ask FixBot
    5. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the 5G mmWave antenna: step 56, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the 5G mmWave antenna: step 56, image 2 of 2
      • Use a spudger to pry up and disconnect the 5G mmWave antenna press connector.
      Ask FixBot
    6. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the top right microphone: step 57, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the top right microphone: step 57, image 2 of 2
      • Use a spudger to pry up and disconnect the top right microphone press connector.
      Ask FixBot
    7. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the bottom speakers: step 58, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the bottom speakers: step 58, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the bottom speakers: step 58, image 3 of 3
      • Use the tip of a spudger to pry up and disconnect the four bottom speaker connectors.
      Ask FixBot
    8. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the Smart Connector: step 59, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the Smart Connector: step 59, image 2 of 2
      • Use a spudger to pry up and disconnect the Smart Connector press connector.
      Ask FixBot
    9. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the SIM card reader: step 60, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the SIM card reader: step 60, image 2 of 2
      • Use a spudger to pry up and disconnect the SIM card reader press connector.
      Ask FixBot
    10. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the top antenna: step 61, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the top antenna: step 61, image 2 of 2
      • Use a spudger to pry up and disconnect the top antenna press connector.
      Ask FixBot
    11. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the Wi-Fi antenna: step 62, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the Wi-Fi antenna: step 62, image 2 of 2
      • Use the pointed end of a spudger to disconnect the Wi-Fi antenna coaxial cable by prying up as close to its connector as possible.
      Ask FixBot
    12. iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the Wi-Fi cable: step 63, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the Wi-Fi cable: step 63, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the Wi-Fi cable: step 63, image 3 of 3
      • Peel the Wi-Fi cable towards the right edge of the iPad to separate it from the logic board.
      Ask FixBot
    13. iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the antenna cable: step 64, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the antenna cable: step 64, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the antenna cable: step 64, image 3 of 3
      • Begin to peel the antenna cable along the right edge of the logic board.
      Ask FixBot
    14. iPad Pro 12.9" 6th Gen Battery Replacement: step 65, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 65, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 65, image 3 of 3
      • Continue peeling the antenna cable until it completely separates from the right edge of the logic board.
      Ask FixBot
    15. iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the 5G mmWave antenna: step 66, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the 5G mmWave antenna: step 66, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Reposition the 5G mmWave antenna: step 66, image 3 of 3
      • Peel the 5G mmWave cable toward the right edge of the iPad to separate it from the logic board.
      Ask FixBot
    16. iPad Pro 12.9" 6th Gen Battery Replacement, Unfasten the logic board brackets: step 67, image 1 of 1
      • Use a Phillips screwdriver to remove the two screws securing the logic board brackets:
      • One 1.1 mm-long screw
      Ask FixBot
    17. iPad Pro 12.9" 6th Gen Battery Replacement, Remove the logic board brackets: step 68, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the logic board brackets: step 68, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the logic board brackets: step 68, image 3 of 3
      • Slide the right bracket away from the logic board to release its metal locking clip.
      • Remove the right bracket.
      • During reassembly, make sure the metal clips are secured under the logic board before continuing.
      Ask FixBot
    18. iPad Pro 12.9" 6th Gen Battery Replacement: step 69, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 69, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 69, image 3 of 3
      • Slide the left bracket away from the logic board to release its metal locking clip.
      • Remove the left bracket.
      Ask FixBot
    19. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the antenna: step 70, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the antenna: step 70, image 2 of 2
      • Use a spudger to pry up and disconnect the bottom left antenna press connector.
      Ask FixBot
    20. iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the Apple Pencil charger: step 71, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the Apple Pencil charger: step 71, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Disconnect the Apple Pencil charger: step 71, image 3 of 3
      • Use a spudger to pry up and disconnect the left microphone and Apple Pencil charger cable press connectors.
      Ask FixBot
    21. iPad Pro 12.9" 6th Gen Battery Replacement, Apply isopropyl alcohol: step 72, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Apply isopropyl alcohol: step 72, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Apply isopropyl alcohol: step 72, image 3 of 3
      • Apply high concentration (over 90%) isopropyl alcohol to the right edge of the logic board.
      • Tilt the right edge of the iPad upward to allow the isopropyl alcohol to work its way underneath the logic board.
      • Hold for one minute to allow the isopropyl alcohol to weaken the adhesive.
      Ask FixBot
    22. iPad Pro 12.9" 6th Gen Battery Replacement, Separate the bottom adhesive: step 73, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the bottom adhesive: step 73, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the bottom adhesive: step 73, image 3 of 3
      • Slide an opening pick under the bottom edge of the logic board, near the charging port, to separate the bottom adhesive.
      • Leave the opening pick inserted to prevent the adhesive from resealing.
      Ask FixBot
    23. iPad Pro 12.9" 6th Gen Battery Replacement, Separate the right adhesive: step 74, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the right adhesive: step 74, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the right adhesive: step 74, image 3 of 3
      • Insert an opening pick under the right edge of the logic board.
      • Slide the opening pick toward the battery connector to separate the right adhesive.
      • Leave the opening pick inserted next to the battery connector to prevent the adhesive from resealing.
      Ask FixBot
    24. iPad Pro 12.9" 6th Gen Battery Replacement: step 75, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 75, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 75, image 3 of 3
      • Insert a third opening pick under the logic board on the other side of the battery connector.
      • Slide the opening pick toward the top of the iPad to separate the remaining right adhesive.
      Ask FixBot
    25. iPad Pro 12.9" 6th Gen Battery Replacement, Separate the left adhesive: step 76, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the left adhesive: step 76, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the left adhesive: step 76, image 3 of 3
      • Insert an opening pick under the left edge of the logic board.
      • Slide the opening pick along the left edge to separate its adhesive.
      Ask FixBot
    26. iPad Pro 12.9" 6th Gen Battery Replacement, Separate the top adhesive: step 77, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the top adhesive: step 77, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the top adhesive: step 77, image 3 of 3
      • Slide a fifth opening pick under the top edge of the logic board, near the front camera, to separate the top adhesive.
      Ask FixBot
    27. iPad Pro 12.9" 6th Gen Battery Replacement, Apply isopropyl alcohol: step 78, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Apply isopropyl alcohol: step 78, image 2 of 2
      • The logic board has a small "branch" that runs along the top right battery cell.
      • Apply high concentration (over 90%) isopropyl alcohol to the branch of the logic board.
      Ask FixBot
    28. iPad Pro 12.9" 6th Gen Battery Replacement, Separate the remaining adhesive: step 79, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the remaining adhesive: step 79, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the remaining adhesive: step 79, image 3 of 3
      • Slide the top right opening pick along the top branch of the logic board to separate the remaining adhesive.
      • At this point, the logic board should be fully separated from the frame. If the logic board still feels stuck, slide an opening pick around its perimeter to slice any remaining adhesive.
      Ask FixBot
    29. iPad Pro 12.9" 6th Gen Battery Replacement, Remove the logic board: step 80, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the logic board: step 80, image 2 of 2
      • Remove the logic board.
      • During reassembly, make sure all of the connectors are above the logic board before securing it back into the fame.
      Ask FixBot
    1. iPad Pro 12.9" 6th Gen Battery Replacement, Battery removal information: step 81, image 1 of 2 iPad Pro 12.9" 6th Gen Battery Replacement, Battery removal information: step 81, image 2 of 2
      • Before you continue, note the following:
      • There are nine stretch-release adhesive pull tabs that have to be removed to separate the adhesive underneath the battery.
      • The corners of some of the battery cells have a small amount of extra adhesive that needs to be separated.
      • The remainder of the adhesive is located between the battery cells, underneath their battery boards.
      Ask FixBot
    2. iPad Pro 12.9" 6th Gen Battery Replacement, Remove the stretch-release adhesive: step 82, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the stretch-release adhesive: step 82, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Remove the stretch-release adhesive: step 82, image 3 of 3
      Buy
      • The next two steps will demonstrate how to remove the nine stretch-release adhesives.
      • Use tweezers, or your fingers, to separate the pull tab from the battery enough so you can grab it with your fingers.
      • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      Ask FixBot
    3. iPad Pro 12.9" 6th Gen Battery Replacement: step 83, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 83, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 83, image 3 of 3
      • Pull the strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the battery.
      • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
      • Repeat the process on all nine stretch-release adhesive strips.
      • If you removed all of the stretch-release adhesive, skip to this step. Otherwise, follow the next two steps for each battery cell with remaining adhesive.
      Ask FixBot
    4. iPad Pro 12.9" 6th Gen Battery Replacement, Alternate removal instructions: step 84, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Alternate removal instructions: step 84, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Alternate removal instructions: step 84, image 3 of 3
      • The next two steps will demonstrate how to separate the stretch-release adhesive if one of the tabs breaks.
      • Apply high-strength (>90%) isopropyl alcohol along the edge of the battery.
      • Tilt the iPad to allow the isopropyl alcohol to work its way underneath the battery.
      Ask FixBot
    5. iPad Pro 12.9" 6th Gen Battery Replacement, Separate the adhesive: step 85, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the adhesive: step 85, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the adhesive: step 85, image 3 of 3
      Plastic Cards
      $2.99
      Buy
      • Insert a plastic card into the gap between the battery and the frame.
      • Use the plastic card to slice the adhesive underneath the battery.
      • Repeat for each battery cell with remaining stretch-release adhesive.
      Ask FixBot
    6. iPad Pro 12.9" 6th Gen Battery Replacement, Separate the battery adhesive: step 86, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the battery adhesive: step 86, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the battery adhesive: step 86, image 3 of 3
      • The next three steps will demonstrate how to remove the extra battery adhesive.
      • Insert a plastic card into the gap between the top right battery cell and the frame.
      Ask FixBot
    7. iPad Pro 12.9" 6th Gen Battery Replacement: step 87, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 87, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 87, image 3 of 3
      • Insert a plastic card into the gap between the top left battery cell and the frame.
      Ask FixBot
    8. iPad Pro 12.9" 6th Gen Battery Replacement: step 88, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 88, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 88, image 3 of 3
      • Insert a plastic card into the gap between the bottom left battery cell and the frame.
      Ask FixBot
    9. iPad Pro 12.9" 6th Gen Battery Replacement, Apply isopropyl alcohol: step 89, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Apply isopropyl alcohol: step 89, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Apply isopropyl alcohol: step 89, image 3 of 3
      • The next three steps will demonstrate how to remove the battery board adhesive.
      • Apply high-strength (>90%) isopropyl alcohol to the battery boards between the cells.
      Ask FixBot
    10. iPad Pro 12.9" 6th Gen Battery Replacement, Separate the middle adhesive: step 90, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the middle adhesive: step 90, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement, Separate the middle adhesive: step 90, image 3 of 3
      • Be very careful with this step, as it's easy to separate the battery from its board. Note the two battery layers to avoid damaging the boards:
      • Don't slice between the battery and the board.
      • Slice between the board and the frame.
      • Insert an opening pick under the middle of the two battery cells to create an initial gap.
      Ask FixBot
    11. iPad Pro 12.9" 6th Gen Battery Replacement: step 91, image 1 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 91, image 2 of 3 iPad Pro 12.9" 6th Gen Battery Replacement: step 91, image 3 of 3
      • Insert the corner of a plastic card into the gap you just created.
      • Slide the plastic card under the battery board to separate its adhesive.
      • Repeat the slicing procedure for the other battery board.
      • At this point, the battery should be separated from the frame. If there's still resistance around the edges, slide an opening pick around the perimeter of the battery.
      Ask FixBot
    12. iPad Pro 12.9" 6th Gen Battery Replacement, Remove the battery: step 92, image 1 of 1
      • Remove the battery.
      • During reassembly, remove the old adhesive with tweezers and isopropyl alcohol and apply stretch-release adhesive strips, double sided adhesive tape, or pre-cut adhesive to secure the new battery.
      • If there are any drops of isopropyl alcohol remaining, use a lint-free cloth to wipe them away or allow the iPad to air dry before installing a new battery.
      • Don't reuse the battery after it has been removed, as doing so is a potential safety hazard.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Arthur Shi
354,437 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 15
Past 7 Days: 107
Past 30 Days: 549
All Time: 1,944
