iPad Pro 12.9" 4th Gen Logic Board Replacement
    1. iPad Pro 12.9" 4th Gen Logic Board Replacement, Prepare your iPad for disassembly: step 1, image 1 of 1
      • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
      • Unplug any cables and fully shut down your iPad.
      Ask FixBot
    1. iPad Pro 12.9" 4th Gen Logic Board Replacement, Heat the right edge: step 2, image 1 of 1
      • Apply a heated iOpener to the right edge of the screen for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the iPad—the screen and internal battery are susceptible to heat damage.
      Ask FixBot
    2. iPad Pro 12.9" 4th Gen Logic Board Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      Ask FixBot
    3. iPad Pro 12.9" 4th Gen Logic Board Replacement: step 4, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement: step 4, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement: step 4, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    4. iPad Pro 12.9" 4th Gen Logic Board Replacement: step 5, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement: step 5, image 2 of 2
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next step.
      Ask FixBot
    5. iPad Pro 12.9" 4th Gen Logic Board Replacement, Insert an opening pick: step 6, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Insert an opening pick: step 6, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Insert an opening pick: step 6, image 3 of 3
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Apply a suction handle to the screen as close to the center of the right edge as possible.
      • Pull up on the suction handle with a strong, steady force to create a small gap between the frame and screen.
      • The large screen is very fragile. Only create a gap big enough to insert an opening pick.
      • Insert an opening pick into the gap.
      • Don't insert the pick more than 5 mm to avoid damaging the screen.
      Ask FixBot
    6. iPad Pro 12.9" 4th Gen Logic Board Replacement, Right edge information: step 7, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Right edge information: step 7, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Right edge information: step 7, image 3 of 3
      • Along the frame's right edge, there are two cutouts for the screen magnets where the adhesive is very thin. As you slice along this edge in the next step, don't insert your opening pick deeper than 2 mm in these locations:
      • One magnet begins 2 cm from the top edge and is 2.5 cm long.
      • The second magnet begins 3 cm from the bottom edge and is 2.5 cm long.
      Ask FixBot
    7. iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the right edge adhesive: step 8, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the right edge adhesive: step 8, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the right edge adhesive: step 8, image 3 of 3
      • Slide your opening pick back and forth along the right edge of the screen to slice the adhesive.
      • Angle your pick downward and insert it no more than 2 mm near the magnet cutouts and 5 mm everywhere else.
      Ask FixBot
    8. iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the corner adhesive: step 9, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the corner adhesive: step 9, image 2 of 2
      • Rotate your opening pick around the bottom right corner of the screen.
      • Leave your pick in the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    9. iPad Pro 12.9" 4th Gen Logic Board Replacement, Heat the bottom edge: step 10, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the screen for two minutes.
      Ask FixBot
    10. iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the bottom edge adhesive: step 11, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the bottom edge adhesive: step 11, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the bottom edge adhesive: step 11, image 3 of 3
      • Insert a second opening pick in the bottom right corner of the screen.
      • Don't insert your opening pick more than 5 mm.
      • Slide your pick to the bottom left corner to slice the bottom edge adhesive.
      Ask FixBot
    11. iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the corner adhesive: step 12, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the corner adhesive: step 12, image 2 of 2
      • Rotate your opening pick around the bottom left corner of the screen.
      • Leave your pick in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    12. iPad Pro 12.9" 4th Gen Logic Board Replacement, Heat the left edge: step 13, image 1 of 1
      • Apply a heated iOpener to the left edge of the screen for two minutes.
      Ask FixBot
    13. iPad Pro 12.9" 4th Gen Logic Board Replacement, Left edge information: step 14, image 1 of 1
      • Along the left edge of the screen, there are three cutouts for cables where the adhesive is very thin. As you slice along this edge in the next step, don't insert your opening pick deeper than 2 mm in these locations:
      • The upper cutout begins 4 cm from the top edge and is 2.5 cm long.
      • The middle cutout is exactly in the middle of the frame and is 2.5 cm long.
      • The lower cutout begins 4 cm from the bottom edge and is 2.5 cm long.
      • Everywhere else, don't insert your opening pick more than 5 mm.
      Ask FixBot
    14. iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the left edge adhesive: step 15, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the left edge adhesive: step 15, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the left edge adhesive: step 15, image 3 of 3
      • Insert a third opening pick in the bottom left corner of the screen.
      • Slide your pick to the top left corner to slice the left edge adhesive.
      Ask FixBot
    15. iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the corner adhesive: step 16, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the corner adhesive: step 16, image 2 of 2
      • Rotate your opening pick around the top left corner of the screen.
      • Leave your pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    16. iPad Pro 12.9" 4th Gen Logic Board Replacement, Heat the top edge: step 17, image 1 of 1
      • Apply a heated iOpener to the top edge of the screen for two minutes.
      Ask FixBot
    17. iPad Pro 12.9" 4th Gen Logic Board Replacement, Top edge information: step 18, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Top edge information: step 18, image 2 of 2
      • While the top edge adhesive softens, note the following:
      • There are two ambient light sensors near the corners. Only insert the very tip of your pick here to avoid damaging them.
      • There are three strips of heat dispersion tape. Angle your pick upward as you slice here.
      • The front-facing camera assembly is in the center of the top edge. Don't insert your pick here to avoid damaging them.
      • Everywhere else, don't insert your pick deeper than 5 mm to avoid damaging the screen.
      Ask FixBot
    18. iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the top edge adhesive: step 19, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the top edge adhesive: step 19, image 2 of 2
      • Slide your opening pick 9 cm toward the center of the top edge to slice the adhesive, paying attention to the spots mentioned in the previous step.
      • If you slice farther than 9 cm, you will reach the front camera assembly and risk damaging its components.
      • Leave your pick inserted. You will use another pick to slice the remaining adhesive.
      Ask FixBot
    19. iPad Pro 12.9" 4th Gen Logic Board Replacement: step 20, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement: step 20, image 2 of 2
      • Insert a fourth opening pick to the right of the front camera assembly, 4 cm from the previous opening pick and 9 cm from the right edge of the screen.
      • Slide your pick to the top right corner to slice the remaining adhesive.
      Ask FixBot
    20. iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the screen: step 21, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the screen: step 21, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the screen: step 21, image 3 of 3
      • Grab two opposing corners of the screen and gently shift it around to separate it from the frame.
      • Don't fully remove the screen yet, as it's still attached by several cables.
      • If the screen feels stuck, slide your opening picks around the perimeter to separate any remaining adhesive. Pay attention to sensitive components mentioned in the previous steps.
      • Shift the screen towards the bottom right corner of the frame until the ribbon cable near the top edge is uncovered.
      Ask FixBot
    21. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the upper cable shield: step 22, image 1 of 1
      FixMat
      $36.95
      Buy
      • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
      • Use your Phillips screwdriver to remove the two screws securing the upper cable shield:
      • One 1.8 mm-long screw
      • One 2.0 mm-long screw
      • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
      Ask FixBot
    22. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the upper cable shield: step 23, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the upper cable shield: step 23, image 2 of 2
      Buy
      • Use tweezers or your fingers to grab and remove the upper cable shield.
      • During reassembly, orient the shield so the notch faces up and to the right.
      Ask FixBot
    23. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper sensors: step 24, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper sensors: step 24, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the upper sensors press connector.
      • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    24. iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the screen: step 25, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the screen: step 25, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the screen: step 25, image 3 of 3
      • Grip the right edge of the screen and fold it open like a book.
      • Don't pull on the screen—the ribbon cables near the bottom are still attached.
      • Lay the screen down over the left edge of the iPad.
      Ask FixBot
    1. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the lower cable shield: step 26, image 1 of 1
      • Use your Phillips screwdriver to remove the five screws securing the lower cable shield:
      • Four 1.1 mm screws
      • One 2.0 mm screw
      Ask FixBot
    2. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the lower cable shield: step 27, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the lower cable shield: step 27, image 2 of 2
      Buy
      • Use tweezers or your fingers to grab and remove the lower cable shield.
      Ask FixBot
    3. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the battery: step 28, image 1 of 1
      • Use your Phillips screwdriver to remove the 1.7 mm screw securing the battery connector to the logic board.
      Ask FixBot
    1. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the screen: step 29, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the screen: step 29, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the screen: step 29, image 3 of 3
      • Use the point of your spudger to pry up and disconnect the upper two display press connectors from the logic board.
      Ask FixBot
    2. iPad Pro 12.9" 4th Gen Logic Board Replacement: step 30, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement: step 30, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement: step 30, image 3 of 3
      • Use the point of your spudger to pry up and disconnect the lower two display press connectors from the logic board.
      Ask FixBot
    3. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the screen: step 31, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the screen: step 31, image 2 of 2
      • Grab and remove the screen from the frame.
      Ask FixBot
    1. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the USB-C port: step 32, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the USB-C port: step 32, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the USB-C port press connector from the logic board.
      Ask FixBot
    2. iPad Pro 12.9" 4th Gen Logic Board Replacement, Soften the adhesive: step 33, image 1 of 1
      Ask FixBot
    3. iPad Pro 12.9" 4th Gen Logic Board Replacement, Loosen the USB-C port cable: step 34, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Loosen the USB-C port cable: step 34, image 2 of 2
      • Slide an opening pick under the USB-C port cable to separate it from the logic board.
      Ask FixBot
    4. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the USB-C port: step 35, image 1 of 1
      • Use your Phillips screwdriver to remove the two 1.6 mm-long screws securing the USB-C port.
      Ask FixBot
    5. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the USB-C port: step 36, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the USB-C port: step 36, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the USB-C port: step 36, image 3 of 3
      • Grab and remove the USB-C port from its recess in the frame.
      • Use caution not to lose the grounding contacts on either side of the USB-C recess.
      • During reassembly, install the USB-C port underneath the grounding contacts.
      Ask FixBot
    1. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the upper cable shield: step 37, image 1 of 1
      • Use your Phillips screwdriver to remove the four screws securing the upper cable shield:
      • Three 1.1 mm screws
      • One 2.0 mm screw
      Ask FixBot
    2. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the upper cable shield: step 38, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the upper cable shield: step 38, image 2 of 2
      Buy
      Ask FixBot
    3. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the front camera assembly: step 39, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the front camera assembly: step 39, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the front camera assembly: step 39, image 3 of 3
      • Use the point of your spudger to pry up and disconnect the three press connectors for the IR dot-projector, front camera, and Face ID camera.
      Ask FixBot
    4. iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the camera cables: step 40, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the camera cables: step 40, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the camera cables: step 40, image 3 of 3
      • Use blunt nose tweezers to grab and peel the left and middle front camera assembly cables from the logic board.
      Ask FixBot
    5. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the bracket: step 41, image 1 of 1
      • Use your T3 Torx screwdriver to remove the two 2.2 mm screws securing the front camera assembly bracket.
      Ask FixBot
    6. iPad Pro 12.9" 4th Gen Logic Board Replacement: step 42, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement: step 42, image 2 of 2
      • Use the flat end of your spudger to pry the front camera assembly bracket from its recess.
      • The bracket is secured by heat-resistant epoxy which requires significant force to weaken. Work slowly and avoid prying against the surrounding components.
      Ask FixBot
    7. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the front camera assembly bracket: step 43, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the front camera assembly bracket: step 43, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the front camera assembly bracket: step 43, image 3 of 3
      • Use tweezers or your fingers to grab and remove the front camera assembly bracket from its recess.
      • Use a spudger to scrape and remove any residual epoxy before reinstalling the bracket.
      Ask FixBot
    1. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the rear camera shield: step 44, image 1 of 1
      • Use your Phillips screwdriver to remove the six screws securing the rear camera shield:
      • Three 1.2 mm screws
      • One 2.8 mm screw
      • One 2.6 mm screw
      • One 1.8 mm screw
      Ask FixBot
    2. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the rear camera shield: step 45, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the rear camera shield: step 45, image 2 of 2
      Buy
      • Use tweezers or your fingers to grab and remove the rear camera shield.
      • During reassembly, insert the tab on the left of the shield first.
      Ask FixBot
    3. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the power button: step 46, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the power button: step 46, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the power button: step 46, image 3 of 3
      • Use the point of your spudger to pry up and disconnect both of the power button's press connectors.
      Ask FixBot
    4. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the power button assembly: step 47, image 1 of 1
      • Use your Phillips screwdriver to remove the two 2.3 mm screws securing the power button assembly.
      Ask FixBot
    5. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the power button assembly: step 48, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the power button assembly: step 48, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the power button assembly: step 48, image 3 of 3
      • Insert the point of your spudger between the left edge of the power button assembly and the frame.
      • Pry the assembly up from its recess in the frame.
      • Grab and remove the power button assembly.
      • Use a spudger to scrape and remove any residual epoxy before reinstalling the assembly.
      Ask FixBot
    6. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the power button: step 49, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the power button: step 49, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the power button: step 49, image 3 of 3
      • Push the power button through its recess from the outside of the frame.
      • Remove the power button.
      Ask FixBot
    1. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the rear cameras: step 50, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the rear cameras: step 50, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the wide-angle camera from the logic board.
      Ask FixBot
    2. iPad Pro 12.9" 4th Gen Logic Board Replacement: step 51, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement: step 51, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement: step 51, image 3 of 3
      • Use the point of your spudger to pry up and disconnect the LiDAR sensor and ultrawide camera from the logic board.
      Ask FixBot
    3. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the rear cameras: step 52, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the rear cameras: step 52, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the rear cameras: step 52, image 3 of 3
      Buy
      • Insert the point of your spudger between the top right corner of the rear cameras and the frame.
      • Pry the cameras up until you can grab them with tweezers or your fingers.
      • Remove the rear cameras.
      Ask FixBot
    1. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the Smart Connector cover: step 53, image 1 of 1
      • Use your Phillips screwdriver to remove the two 1.9 mm screws securing the Smart Connector cover.
      Ask FixBot
    2. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the Smart Connector cover: step 54, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the Smart Connector cover: step 54, image 2 of 2
      Buy
      • Use tweezers or your fingers to grab and remove the Smart Connector cover.
      Ask FixBot
    3. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the Smart Connector: step 55, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the Smart Connector: step 55, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the Smart Connector from the bottom of the logic board.
      Ask FixBot
    4. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the speaker cable shield: step 56, image 1 of 1
      • Use your Phillips screwdriver to remove the 2.0 mm screw securing the lower left speaker cable shield.
      Ask FixBot
    5. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the speaker cable shield: step 57, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the speaker cable shield: step 57, image 2 of 2
      • Remove the lower left speaker cable shield.
      Ask FixBot
    6. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the lower speakers: step 58, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the lower speakers: step 58, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the lower speakers: step 58, image 3 of 3
      • Use the point of your spudger to pry up and disconnect the lower speaker press connectors.
      • Avoid prying against the sides of the connectors. The sockets on the logic board are delicate and may bend if pried against.
      • Disconnect all four connectors for the lower speakers.
      Ask FixBot
    7. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper speakers: step 59, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper speakers: step 59, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper speakers: step 59, image 3 of 3
      • Use the point of your spudger to pry up and disconnect all four upper speaker press connectors.
      Ask FixBot
    8. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper antenna cable: step 60, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper antenna cable: step 60, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper antenna cable: step 60, image 3 of 3
      • Use the point of your spudger to pry up and disconnect the upper antenna cable from the right edge of the logic board.
      • Pry on only the metal head of the connector. Avoid lifting the cable itself as much as possible.
      Ask FixBot
    9. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the lower antenna cable: step 61, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the lower antenna cable: step 61, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the lower antenna cable from the left edge of the logic board.
      Ask FixBot
    10. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the remaining antenna cables: step 62, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the remaining antenna cables: step 62, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the remaining antenna cables: step 62, image 3 of 3
      • Use the point of your spudger to pry up and disconnect the remaining two antenna cables from the left edge of the logic board.
      Ask FixBot
    11. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper sensor cable: step 63, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper sensor cable: step 63, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the upper sensor press connector from the logic board.
      Ask FixBot
    12. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the rear sensor cable: step 64, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the rear sensor cable: step 64, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the rear sensor press connector from the right arm of the logic board.
      Ask FixBot
    13. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the volume buttons: step 65, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the volume buttons: step 65, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the volume press connector from the right arm of the logic board.
      Ask FixBot
    14. iPad Pro 12.9" 4th Gen Logic Board Replacement, Heat the upper antenna cable: step 66, image 1 of 1
      • Apply a heated iOpener to the upper antenna cable and right arm of the logic board for two minutes.
      Ask FixBot
    15. iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the upper antenna cable: step 67, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the upper antenna cable: step 67, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the upper antenna cable: step 67, image 3 of 3
      • Use blunt nose tweezers or your fingernail to peel the tape securing the upper antenna cable to the right arm of the logic board.
      • Don't try to fully remove the cable—one more piece of tape secures it to the logic board.
      • If the tape feels stuck, pull the body of the cable with your fingers as you peel the tape.
      Ask FixBot
    16. iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the upper antenna cable: step 68, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the upper antenna cable: step 68, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the upper antenna cable: step 68, image 3 of 3
      • Peel the second strip of tape securing the upper antenna cable to the logic board near the rear camera cutouts.
      • Reposition the cable away from the logic board.
      • Don't twist or rotate the antenna cable—it's still connected to the antenna.
      Ask FixBot
    17. iPad Pro 12.9" 4th Gen Logic Board Replacement, Heat the lower antenna cable: step 69, image 1 of 1
      • Apply a heated iOpener to the lower antenna cable, located along the left edge of the logic board, for two minutes.
      Ask FixBot
    18. iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the lower antenna cable: step 70, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the lower antenna cable: step 70, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the lower antenna cable: step 70, image 3 of 3
      • Grab the lower antenna cable, just below its metal connector head.
      • Peel the cable from the left edge of the logic board.
      Ask FixBot
    19. iPad Pro 12.9" 4th Gen Logic Board Replacement: step 71, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement: step 71, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement: step 71, image 3 of 3
      • Peel the lower antenna cable from the logic board near the battery connector.
      Ask FixBot
    20. iPad Pro 12.9" 4th Gen Logic Board Replacement, Heat the logic board cover: step 72, image 1 of 1
      Ask FixBot
    21. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the logic board cover: step 73, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the logic board cover: step 73, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the logic board cover: step 73, image 3 of 3
      • Use your fingers to grab a corner of the logic board cover.
      • Peel and remove the cover from the logic board.
      • Work slowly to avoid tearing the cover.
      • The cover has many layers. Make sure the copper tape doesn't separate from the foam layer.
      Ask FixBot
    22. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the press connector bracket: step 74, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the press connector bracket: step 74, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the press connector bracket: step 74, image 3 of 3
      • Use the flat end of your spudger to slide the bottom right press connector bracket away from the logic board.
      • Use blunt nose tweezers or your fingers to remove the bracket.
      • During reassembly, orient the bracket so the outward-bent wings face the battery.
      Ask FixBot
    23. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the microphone and Apple Pencil charger: step 75, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the microphone and Apple Pencil charger: step 75, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the microphone and Apple Pencil charger: step 75, image 3 of 3
      • Use the point of your spudger to pry up and disconnect the microphone and Apple Pencil charger press connectors.
      Ask FixBot
    24. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the logic board: step 76, image 1 of 1
      • Use your Phillips screwdriver to remove the four 1.8 mm screws securing the logic board.
      Ask FixBot
    25. iPad Pro 12.9" 4th Gen Logic Board Replacement, Soften the adhesive: step 77, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Soften the adhesive: step 77, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Soften the adhesive: step 77, image 3 of 3
      • Apply several drops of highly-concentrated isopropyl alcohol (over 90%) to the bottom and right edges of the logic board.
      • Elevate the right edge of the iPad to allow the isopropyl alcohol to flow under the logic board.
      • Wait one minute for the isopropyl alcohol to penetrate.
      Ask FixBot
    26. iPad Pro 12.9" 4th Gen Logic Board Replacement: step 78, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement: step 78, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement: step 78, image 3 of 3
      • Apply isopropyl alcohol to the right arm and left edge of the logic board.
      • Elevate the left edge of the iPad to allow the isopropyl alcohol to flow under the logic board.
      Ask FixBot
    27. iPad Pro 12.9" 4th Gen Logic Board Replacement, Insert an opening pick: step 79, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Insert an opening pick: step 79, image 2 of 2
      • Insert an opening pick between the bottom edge of the logic board and the Smart Connector.
      Ask FixBot
    28. iPad Pro 12.9" 4th Gen Logic Board Replacement, Replace the battery blocker: step 80, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Replace the battery blocker: step 80, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Replace the battery blocker: step 80, image 3 of 3
      • Remove the card strips blocking the battery connector.
      • Gently insert the tip of an opening pick between the logic board and the battery connector.
      • Don't pry on the battery connector or logic board, as the spring connectors are easily damaged.
      • Leave this pick inserted until the logic board is completely removed.
      Ask FixBot
    29. iPad Pro 12.9" 4th Gen Logic Board Replacement, Pry up the left edge: step 81, image 1 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Pry up the left edge: step 81, image 2 of 3 iPad Pro 12.9" 4th Gen Logic Board Replacement, Pry up the left edge: step 81, image 3 of 3
      • Use the first opening pick to pry up the left edge of the logic board.
      • Don't forcefully lever against the battery—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      • If the logic board feels stuck, apply more isopropyl alcohol.
      Ask FixBot
    30. iPad Pro 12.9" 4th Gen Logic Board Replacement, Pry up the right arm: step 82, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Pry up the right arm: step 82, image 2 of 2
      • Use your opening pick to pry up the right arm of the logic board.
      • This arm of the logic board is thin and fragile. Be careful not to bend it.
      Ask FixBot
    31. iPad Pro 12.9" 4th Gen Logic Board Replacement, Pry up the right edge: step 83, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Pry up the right edge: step 83, image 2 of 2
      • Use your opening pick to pry up the right edge of the logic board.
      Ask FixBot
    32. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the logic board: step 84, image 1 of 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the logic board: step 84, image 2 of 2
      Tesa 61395 Tape
      $14.95
      Buy
      • Grab and remove the logic board from the frame.
      • Be careful not to reinstall the logic board on top of any cables or connectors.
      • During reassembly, apply double-sided tape such as Tesa tape to secure the logic board if the existing adhesive isn't sufficient.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 12.9" 4th Gen Answers community for help.
Clay Eickemeyer
107,989 Reputation
472 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,996 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 43
Past 30 Days: 189
All Time: 7,127
