Up to 20% off select tools
iPad Pro 12.9" 2nd gen Screen Replacement
Views: 46K
View statistics:
Past 24 Hours:
2
Past 7 Days:
30
Past 30 Days:
209
All Time:
46,362
Comments: 5
5 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
      • Follow this video guide from start to finish and enjoy!
      Ask FixBot
Did you follow all the steps? Yes! Then enjoy!
15 other people completed this guide.
Author
with
Fix It Planet
1,633 Reputation
3 Guides authored
5 Guide Comments
Kann man beim 12.9 Gen2 NUR das Glas tauschen? Das display geht 1a aber ich habe mehrere risse auf dem schutzglas. Möchte nicht dafür auch das display tauschen…..
sim sem - Reply Share
@simsem I'm wondering the same thing. Did you find out if it was possible ? Is the glass reparable without changing the whole screen itself ?
Shldnet - Reply Share
If you get the replacement screen with daughterboard attached you don’t need to solder anything.
Gregg Stanley - Reply Share
That is correct …. but if you solder it on yourself you reuse the original daughter board instead of throwing it away and save some money to boot. Seems reasonable if you can do it.
Fix It Planet - Reply Share
I replaced the screen but it the touch screen is randomly unresponsive at times. Mostly on the middle right of the screen. I would have to touch same area couple of times for it to response. The unit is on the latest iOS 15.1. Any thoughts?
Chio Phanh - Reply Share
Past 24 Hours: 2
Past 7 Days: 30
Past 30 Days: 209
All Time: 46,362
