iPad Pro 11" 1st Gen Front Camera Assembly Replacement
    1. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Prepare your iPad for disassembly: step 1, image 1 of 1
      • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
      • Unplug any cables and fully shut down your iPad.
      Ask FixBot
    1. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Screen removal information: step 2, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Screen removal information: step 2, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Screen removal information: step 2, image 3 of 3
      • While your iPad looks uniform from the outside, there are delicate components under portions of the screen. To avoid damage, follow instructions exactly as written and note the following areas as you open your iPad:
      • Camera module, ambient light sensors, proximity senor, and front microphone
      • Display cables
      • Screen magnets
      • LCD edges
      Ask FixBot
    2. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Heat the right edge: step 3, image 1 of 1
      • Apply a heated iOpener to the right edge of the screen for two minutes.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the screen and/or internal battery, so proceed with care.
      Ask FixBot
    3. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Anti-Clamp instructions: step 4, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      Ask FixBot
    4. iPad Pro 11" 1st Gen Front Camera Assembly Replacement: step 5, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement: step 5, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement: step 5, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    5. iPad Pro 11" 1st Gen Front Camera Assembly Replacement: step 6, image 1 of 2 iPad Pro 11" 1st Gen Front Camera Assembly Replacement: step 6, image 2 of 2
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next step.
      Ask FixBot
    6. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Insert an opening pick: step 7, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Insert an opening pick: step 7, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Insert an opening pick: step 7, image 3 of 3
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Apply a suction handle to the right edge of the screen, about 5 cm from the bottom edge.
      • Pull up on the suction handle with firm, constant pressure to create a gap large enough to insert an opening pick.
      • Only create a gap small enough to insert an opening pick. Overbending the screen will damage it.
      • Insert the tip of an opening pick into the gap.
      • Don't insert the opening pick more than 5 mm or you'll damage the LCD.
      Ask FixBot
    7. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the right edge adhesive: step 8, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the right edge adhesive: step 8, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the right edge adhesive: step 8, image 3 of 3
      • Insert a new opening pick in the gap you just created.
      • Slide the pick along the right edge to separate the adhesive.
      • When sliding near the volume buttons, don't insert the pick more than 2 mm or you'll damage the screen magnets.
      • Leave the pick in the top right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    8. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Heat the top edge: step 9, image 1 of 1
      • Apply a heated iOpener to the top edge of the screen for two minutes.
      Ask FixBot
    9. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Top edge information: step 10, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Top edge information: step 10, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Top edge information: step 10, image 3 of 3
      • The top edge of the iPad contains the camera module, two ambient light sensors, the proximity sensor, and front microphone. These components are fragile and easily damaged if an opening pick is inserted too far. Only separate the adhesive in the marked locations to avoid damage.
      • The two ambient light sensors can be hard to see and can be located using a flashlight or by placing the iPad under a bright light.
      • Don't insert an opening pick more than 2 mm near the top left and right edges or you'll damage the ambient light sensors.
      • Don't insert an opening pick more than 1 mm near the middle of the top edge or you'll damage the camera module, proximity sensor, and front microphone.
      Ask FixBot
    10. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the top edge adhesive: step 11, image 1 of 2 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the top edge adhesive: step 11, image 2 of 2
      • Slide the pick along the top right edge, stopping when you reach the right ambient light sensor.
      • Don't insert the opening pick more than 5 mm.
      • Leave the pick to the right of the sensor to prevent the adhesive from re-sealing.
      Ask FixBot
    11. iPad Pro 11" 1st Gen Front Camera Assembly Replacement: step 12, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement: step 12, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement: step 12, image 3 of 3
      • Insert a new opening pick to the right of the ambient light sensor.
      • Slide the pick along the middle section of the top, stopping when you reach the left ambient light sensor.
      • Don't insert the pick more than 1 mm or you'll damage the proximity sensor and front microphone.
      • Leave the pick in to prevent the adhesive from re-sealing.
      Ask FixBot
    12. iPad Pro 11" 1st Gen Front Camera Assembly Replacement: step 13, image 1 of 2 iPad Pro 11" 1st Gen Front Camera Assembly Replacement: step 13, image 2 of 2
      • Insert a new opening pick to the left of the ambient light sensor.
      • Slide the pick along the top left edge, stopping when you reach the left ambient light sensor.
      • Once the top edge adhesive has been separated, you can remove the two picks near the ambient light sensors.
      Ask FixBot
    13. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Heat the bottom edge: step 14, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the screen for two minutes.
      Ask FixBot
    14. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the bottom edge adhesive: step 15, image 1 of 2 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the bottom edge adhesive: step 15, image 2 of 2
      • Insert a new opening pick in the bottom right corner below the existing pick.
      • Don't insert the opening pick more than 2 mm when sliding on the right edge.
      • Slide the pick around the bottom right corner to separate the adhesive.
      Ask FixBot
    15. iPad Pro 11" 1st Gen Front Camera Assembly Replacement: step 16, image 1 of 2 iPad Pro 11" 1st Gen Front Camera Assembly Replacement: step 16, image 2 of 2
      • Slide the opening pick along the bottom edge, stopping at the USB-C port.
      • Don't insert the opening pick more than 5 mm when separating the bottom edge adhesive.
      • Leave the pick in to prevent the bottom edge adhesive from re-sealing.
      Ask FixBot
    16. iPad Pro 11" 1st Gen Front Camera Assembly Replacement: step 17, image 1 of 2 iPad Pro 11" 1st Gen Front Camera Assembly Replacement: step 17, image 2 of 2
      • Insert a new opening pick to the left of the USB-C port.
      • Separate the remaining bottom edge adhesive.
      • Leave the pick in the bottom left corner to prevent the bottom edge adhesive from re-sealing.
      Ask FixBot
    17. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Heat the left edge: step 18, image 1 of 1
      • Apply a heated iOpener to the left edge of the screen for two minutes.
      Ask FixBot
    18. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Left edge information: step 19, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Left edge information: step 19, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Left edge information: step 19, image 3 of 3
      • The left edge of the iPad contains several display cables. These cables are extremely fragile and easily damaged if an opening pick is inserted too far or at the wrong angle. Follow the instructions exactly as written to avoid damage.
      • The display cables are located within small indents of the frame and require an opening pick to be inserted at a 45° angle.
      • There are flat sections of the frame which require an opening pick to be inserted horizontally.
      Ask FixBot
    19. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the left edge adhesive: step 20, image 1 of 2 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the left edge adhesive: step 20, image 2 of 2
      • Insert an opening pick at a 45˚ angle just above the bottom left corner.
      • Don't insert the pick more than 5 mm or you'll damage the display cables.
      • Carefully slide the pick along the left edge, stopping when you reach the flat section of the frame.
      Ask FixBot
    20. iPad Pro 11" 1st Gen Front Camera Assembly Replacement: step 21, image 1 of 2 iPad Pro 11" 1st Gen Front Camera Assembly Replacement: step 21, image 2 of 2
      • Lower the opening pick so it is horizontal to the screen.
      • Don't insert the pick more than 5 mm.
      • Continue separating the left edge adhesive until you reach the next indented section of the frame.
      Ask FixBot
    21. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the remaining adhesive: step 22, image 1 of 1
      • Separate the remaining adhesive, making sure to follow the instructions exactly as written.
      • Slide the pick at a 45˚ downward angle and don't insert the pick more than 5 mm.
      • Slide the pick horizontally and don't insert the pick more than 5 mm.
      Ask FixBot
    22. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the screen from the frame: step 23, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the screen from the frame: step 23, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the screen from the frame: step 23, image 3 of 3
      • Grab two opposing corners of the screen and gently separate the rest of the adhesive.
      • Don't fully remove the screen as it's held in place by several ribbon cables underneath.
      • Shift the screen towards the bottom right corner of the frame until the ambient light sensor ribbon cable near the top edge is uncovered.
      Ask FixBot
    23. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Unfasten the ambient light sensor cable bracket: step 24, image 1 of 2 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Unfasten the ambient light sensor cable bracket: step 24, image 2 of 2
      FixMat
      $36.95
      Buy
      • Use a Phillips screwdriver to remove the two screws securing the ambient light sensor cable bracket to the logic board:
      • One 1.3 mm screw
      • One 2.0 mm screw
      • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
      Ask FixBot
    24. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Remove the ambient light sensor cable bracket: step 25, image 1 of 1
      Buy
      • Use tweezers or your fingers to remove the bracket.
      Ask FixBot
    25. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Disconnect the ambient light sensor cable: step 26, image 1 of 2 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Disconnect the ambient light sensor cable: step 26, image 2 of 2
      • Use the flat end of a spudger to disconnect the ambient light sensor cable by lifting straight up on the press connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    26. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Reposition the screen: step 27, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Reposition the screen: step 27, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Reposition the screen: step 27, image 3 of 3
      • Don't try to remove the screen yet, as it's still attached by delicate ribbon cables.
      • Grip the right edge of the screen and fold it open like a book.
      • Lay the screen down over the left edge of the iPad.
      Ask FixBot
    1. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Unfasten the bottom cable shield: step 28, image 1 of 2 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Unfasten the bottom cable shield: step 28, image 2 of 2
      • Use a Phillips screwdriver to remove the three 1.2 mm screws securing the bottom cable shield to the logic board.
      Ask FixBot
    2. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Remove the bottom cable shield: step 29, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Remove the bottom cable shield: step 29, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Remove the bottom cable shield: step 29, image 3 of 3
      Buy
      • Use tweezers or your fingers to remove the bottom cable shield.
      Ask FixBot
    1. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Unfasten the logic board shield: step 30, image 1 of 2 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Unfasten the logic board shield: step 30, image 2 of 2
      • Use a Phillips PH00 screwdriver to remove the eight screws securing the shield to the logic board:
      • Five 2 mm screws
      • Three 1.2 mm screws
      Ask FixBot
    2. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Heat the logic board shield: step 31, image 1 of 1
      • Apply a heated iOpener to the top of the logic board for two minutes.
      Ask FixBot
    3. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the bottom edge shield adhesive: step 32, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the bottom edge shield adhesive: step 32, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the bottom edge shield adhesive: step 32, image 3 of 3
      • Insert an opening pick between the shield and the shielding gasket on the bottom edge of the logic board.
      • Slide the pick along the bottom edge to separate the adhesive.
      Ask FixBot
    4. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the right edge shield adhesive: step 33, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the right edge shield adhesive: step 33, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the right edge shield adhesive: step 33, image 3 of 3
      • Repeat the previous step for the right edge of the logic board shield.
      Ask FixBot
    5. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the left edge shield adhesive: step 34, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the left edge shield adhesive: step 34, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the left edge shield adhesive: step 34, image 3 of 3
      • Repeat the previous step for the left edge of the logic board shield.
      Ask FixBot
    6. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Remove the logic board shield: step 35, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Remove the logic board shield: step 35, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Remove the logic board shield: step 35, image 3 of 3
      • Grip the logic board shield at the top and lift it up.
      • Stop lifting if the shield is stuck or begins to bend—a bent shield will reduce thermal transfer from the logic board. Use an opening pick to separate any remaining adhesive.
      Ask FixBot
    1. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Disconnect the IR dot projector cables: step 36, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Disconnect the IR dot projector cables: step 36, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Disconnect the IR dot projector cables: step 36, image 3 of 3
      • Use the pointed end of a spudger to disconnect the IR dot projector cable.
      Ask FixBot
    2. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Disconnect the camera cables: step 37, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Disconnect the camera cables: step 37, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Disconnect the camera cables: step 37, image 3 of 3
      • Use the pointed end of a spudger to disconnect the front-facing camera and Face ID camera.
      Ask FixBot
    3. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the IR camera cable adhesive: step 38, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the IR camera cable adhesive: step 38, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the IR camera cable adhesive: step 38, image 3 of 3
      • The IR camera cable is secured to the logic board with weak adhesive.
      • Slide an opening pick between the IR camera cable and the logic board to separate it.
      Ask FixBot
    4. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the camera cable adhesive: step 39, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the camera cable adhesive: step 39, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Separate the camera cable adhesive: step 39, image 3 of 3
      • Repeat the previous step for the camera cable.
      Ask FixBot
    5. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Unfasten the front camera module: step 40, image 1 of 2 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Unfasten the front camera module: step 40, image 2 of 2
      • Use a Torx T3 screwdriver to remove the two 2.1 mm screws securing the front camera assembly to the frame.
      Ask FixBot
    6. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Loosen the front camera assembly: step 41, image 1 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Loosen the front camera assembly: step 41, image 2 of 3 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Loosen the front camera assembly: step 41, image 3 of 3
      • Use the pointed end of a spudger to pry up and loosen the front camera assembly.
      Ask FixBot
    7. iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Remove the front camera assembly: step 42, image 1 of 2 iPad Pro 11" 1st Gen Front Camera Assembly Replacement, Remove the front camera assembly: step 42, image 2 of 2
      Buy
      • Use tweezers or your fingers to remove the front camera assembly.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 11" 1st Gen answers community for help.
Chayton Ritter
27,680 Reputation
105 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,630 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 109
All Time: 1,874
