iPad Mini 6 USB-C Port Replacement
    1. iPad Mini 6 USB-C Port Replacement, Apply tape to a cracked screen: step 1, image 1 of 3 iPad Mini 6 USB-C Port Replacement, Apply tape to a cracked screen: step 1, image 2 of 3 iPad Mini 6 USB-C Port Replacement, Apply tape to a cracked screen: step 1, image 3 of 3
      • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
      • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
      • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
      Ask FixBot
    1. iPad Mini 6 USB-C Port Replacement, Heat the bottom edge: step 2, image 1 of 1
      • Completely power off your device before you begin.
      • Apply a heated iOpener to the bottom edge of the device for 90 seconds to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      Ask FixBot
    2. iPad Mini 6 USB-C Port Replacement, Screen removal information: step 3, image 1 of 3 iPad Mini 6 USB-C Port Replacement, Screen removal information: step 3, image 2 of 3 iPad Mini 6 USB-C Port Replacement, Screen removal information: step 3, image 3 of 3
      • While you're waiting for the adhesive to loosen, note the following:
      • The areas at the top and bottom of the screen are sensitive to prying.
      • Don't insert a pick more than 3 mm to avoid damaging the screen.
      • There's a long circuit board attached to the screen that sits parallel to the left edge.
      • Don't insert a pick more than 1.5 mm to avoid damaging the circuit board.
      • The first two images are mirrored for demonstration purposes.
      Ask FixBot
    3. iPad Mini 6 USB-C Port Replacement, Insert an opening pick: step 4, image 1 of 3 iPad Mini 6 USB-C Port Replacement, Insert an opening pick: step 4, image 2 of 3 iPad Mini 6 USB-C Port Replacement, Insert an opening pick: step 4, image 3 of 3
      • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
      • Lift the screen with the suction handle to create a small gap between the screen and the frame.
      • Insert an opening pick into the gap between the frame and the screen.
      • Don't insert the pick more than 1.5 mm to avoid damaging the circuit board.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    4. iPad Mini 6 USB-C Port Replacement, Separate the bottom adhesive: step 5, image 1 of 3 iPad Mini 6 USB-C Port Replacement, Separate the bottom adhesive: step 5, image 2 of 3 iPad Mini 6 USB-C Port Replacement, Separate the bottom adhesive: step 5, image 3 of 3
      • Slide the pick along the bottom edge of the device towards the bottom-right corner.
      • Leave the pick in to prevent the adhesive from resealing.
      Ask FixBot
    5. iPad Mini 6 USB-C Port Replacement, Heat the right edge: step 6, image 1 of 1
      • Apply a heated iOpener to the right edge of the device for 90 seconds to loosen the adhesive underneath.
      Ask FixBot
    6. iPad Mini 6 USB-C Port Replacement, Separate the bottom-right corner adhesive: step 7, image 1 of 3 iPad Mini 6 USB-C Port Replacement, Separate the bottom-right corner adhesive: step 7, image 2 of 3 iPad Mini 6 USB-C Port Replacement, Separate the bottom-right corner adhesive: step 7, image 3 of 3
      • Rotate the opening pick around the bottom-right corner of the device.
      Ask FixBot
    7. iPad Mini 6 USB-C Port Replacement, Separate the remaining adhesive: step 8, image 1 of 2 iPad Mini 6 USB-C Port Replacement, Separate the remaining adhesive: step 8, image 2 of 2
      • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
      • When you slice near the front camera, don't insert the pick more than 1.5 mm to avoid damaging or smearing the camera.
      Ask FixBot
    8. iPad Mini 6 USB-C Port Replacement, Reposition the screen: step 9, image 1 of 3 iPad Mini 6 USB-C Port Replacement, Reposition the screen: step 9, image 2 of 3 iPad Mini 6 USB-C Port Replacement, Reposition the screen: step 9, image 3 of 3
      • If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
      • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
      • With the bottom of the device facing you, pull the right edge of the screen up and towards the left edge of the device.
      • Rest the screen upside down and parallel to the frame before continuing.
      • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
      Ask FixBot
    9. iPad Mini 6 USB-C Port Replacement, Unfasten the display cable bracket: step 10, image 1 of 2 iPad Mini 6 USB-C Port Replacement, Unfasten the display cable bracket: step 10, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the five 1.2 mm-long screws securing the frame bracket to the frame.
      Ask FixBot
    10. iPad Mini 6 USB-C Port Replacement, Remove the display cable bracket: step 11, image 1 of 2 iPad Mini 6 USB-C Port Replacement, Remove the display cable bracket: step 11, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers, or your fingers, to remove the display cable bracket from the frame.
      Ask FixBot
    11. iPad Mini 6 USB-C Port Replacement, Disconnect the display: step 12, image 1 of 3 iPad Mini 6 USB-C Port Replacement, Disconnect the display: step 12, image 2 of 3 iPad Mini 6 USB-C Port Replacement, Disconnect the display: step 12, image 3 of 3
      • Use the flat end of a spudger to pry up and disconnect the display cable's two press connectors secured to the frame.
      Ask FixBot
    12. iPad Mini 6 USB-C Port Replacement, Remove the screen: step 13, image 1 of 2 iPad Mini 6 USB-C Port Replacement, Remove the screen: step 13, image 2 of 2
      • Remove the screen from the frame.
      Ask FixBot
    1. iPad Mini 6 USB-C Port Replacement, Disconnect the battery: step 14, image 1 of 2 iPad Mini 6 USB-C Port Replacement, Disconnect the battery: step 14, image 2 of 2
      • The the flat end of a spudger to pry up and disconnect the battery's press connector secured to the frame.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    1. iPad Mini 6 USB-C Port Replacement, Disconnect the USB-C port: step 15, image 1 of 2 iPad Mini 6 USB-C Port Replacement, Disconnect the USB-C port: step 15, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the USB-C port's press connector secured to the frame.
      Ask FixBot
    2. iPad Mini 6 USB-C Port Replacement, Separate the USB-C port's adhesive: step 16, image 1 of 3 iPad Mini 6 USB-C Port Replacement, Separate the USB-C port's adhesive: step 16, image 2 of 3 iPad Mini 6 USB-C Port Replacement, Separate the USB-C port's adhesive: step 16, image 3 of 3
      • The bottom of the USB-C port's flex cable is lightly adhered to the frame.
      • Insert an opening pick between the frame and the bottom of the flex cable.
      • Slice the adhesive while prying with the pick to separate the cable from the frame.
      Ask FixBot
    3. iPad Mini 6 USB-C Port Replacement, Unfasten the USB-C port: step 17, image 1 of 2 iPad Mini 6 USB-C Port Replacement, Unfasten the USB-C port: step 17, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the two 1.7 mm screws securing the USB-C port to its bracket.
      • These screws are positioned perpendicular to the frame, so getting at them with a screwdriver may be difficult; use plenty of downward force to avoid stripping them.
      Ask FixBot
    4. iPad Mini 6 USB-C Port Replacement, Remove the USB-C port: step 18, image 1 of 2 iPad Mini 6 USB-C Port Replacement, Remove the USB-C port: step 18, image 2 of 2
      • Use your fingers to remove the USB-C port from the frame.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 6 Answers community for help.
8 other people completed this guide.
Alex Diaz-Kokaisl
250,409 Reputation
1,203 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,630 Guides authored
3 Guide Comments
Hello, on step 3 there is a tiny ribbon cable from the pcb to screen. I damaged (tore) this, is there any away to repair it? What does this flex cable go to?
Christopher Bump - Reply Share
thanks, i saved a lot of effort and my old ipad mini with this. the screen removal was the hardest due to not knoeing about the adhesive beforehand, but 10/10 works amd for so much less $ than i thoughtc
Fox P - Reply Share
Where do you get a replacement USB C port? Thanks!
jtredsox - Reply Share
Past 24 Hours: 11
Past 7 Days: 64
Past 30 Days: 277
All Time: 10,940
