iPad Mini 6 Top Speaker Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
7
Past 30 Days:
30
All Time:
261
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Use this guide to replace the top speaker in your iPad mini 6.
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to apply plenty of heat and be extremely careful during the prying stage.
You'll need replacement adhesive in order to complete this repair.
    1. iPad Mini 6 Top Speaker Replacement, Unfasten the front camera shield: step 1, image 1 of 2 iPad Mini 6 Top Speaker Replacement, Unfasten the front camera shield: step 1, image 2 of 2
      • The next 11 steps will show how to remove the top speaker.
      • Use a Phillips #000 screwdriver to remove the two 1.2 mm screws securing the front camera shield to the frame.
      Ask FixBot
    2. iPad Mini 6 Top Speaker Replacement, Remove the front camera shield: step 2, image 1 of 2 iPad Mini 6 Top Speaker Replacement, Remove the front camera shield: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers, or your fingers, to remove the front camera shield.
      Ask FixBot
    3. iPad Mini 6 Top Speaker Replacement, Disconnect the volume button board: step 3, image 1 of 2 iPad Mini 6 Top Speaker Replacement, Disconnect the volume button board: step 3, image 2 of 2
      • Use a spudger to pry up and disconnect the volume button board's press connector secured to the frame.
      Ask FixBot
    4. iPad Mini 6 Top Speaker Replacement, Reposition the volume button board's cable: step 4, image 1 of 2 iPad Mini 6 Top Speaker Replacement, Reposition the volume button board's cable: step 4, image 2 of 2
      • Use tweezers, or your fingers, to peel back the volume button board's cable from the top speaker.
      Ask FixBot
    5. iPad Mini 6 Top Speaker Replacement, Disconnect the top speaker: step 5, image 1 of 2 iPad Mini 6 Top Speaker Replacement, Disconnect the top speaker: step 5, image 2 of 2
      • Use the point of spudger to pry up and disconnect the top speaker's cable.
      • Be very careful when performing this step; apply equal force to both cords to prevent any damage to the connector.
      Ask FixBot
    6. iPad Mini 6 Top Speaker Replacement, Reposition the top speaker's cable: step 6, image 1 of 2 iPad Mini 6 Top Speaker Replacement, Reposition the top speaker's cable: step 6, image 2 of 2
      • The top speaker's cable is lightly adhered to the frame.
      • Gently peel back the cable to separate it from the frame.
      Ask FixBot
    7. iPad Mini 6 Top Speaker Replacement, Heat the top speaker: step 7, image 1 of 1
      • Apply a heated iOpener to the top-left edge of the device for 90 seconds to loosen the top speaker's adhesive.
      Ask FixBot
    8. iPad Mini 6 Top Speaker Replacement, Top speaker information: step 8, image 1 of 2 iPad Mini 6 Top Speaker Replacement, Top speaker information: step 8, image 2 of 2
      • While you're waiting for the adhesive to loosen, note the following:
      • Adhesive is located around the perimeter of the speaker.
      • Insert a pick 2 mm to separate this adhesive.
      • Adhesive is also located in the center of the speaker.
      • Insert a pick 7 mm to separate this adhesive.
      Ask FixBot
    9. iPad Mini 6 Top Speaker Replacement, Separate the top speaker's adhesive: step 9, image 1 of 3 iPad Mini 6 Top Speaker Replacement, Separate the top speaker's adhesive: step 9, image 2 of 3 iPad Mini 6 Top Speaker Replacement, Separate the top speaker's adhesive: step 9, image 3 of 3
      • Insert an opening pick between the top speaker and the frame.
      • Insert the pick at least 7 mm to separate the center adhesive.
      Ask FixBot
    10. iPad Mini 6 Top Speaker Replacement: step 10, image 1 of 3 iPad Mini 6 Top Speaker Replacement: step 10, image 2 of 3 iPad Mini 6 Top Speaker Replacement: step 10, image 3 of 3
      • Slice along the perimeter of the top speaker to separate the adhesive.
      Ask FixBot
    11. iPad Mini 6 Top Speaker Replacement, Remove the top speaker: step 11, image 1 of 3 iPad Mini 6 Top Speaker Replacement, Remove the top speaker: step 11, image 2 of 3 iPad Mini 6 Top Speaker Replacement, Remove the top speaker: step 11, image 3 of 3
      • At this point, the perimeter of the speaker should be separated from the frame. If there's still resistance around the edges of the speaker, use an opening pick to cut the adhesive again.
      • Pry up with the opening pick to completely separate the top speaker from the frame.
      • Remove the top speaker.
      Ask FixBot
Alex Diaz-Kokaisl
250,850 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,132 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 30
All Time: 261
