iPad Mini 3 Wi-Fi Front Panel Replacement
    1. iPad Mini 3 Wi-Fi Front Panel Replacement, iOpener Heating: step 1, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Replacement, iOpener Heating: step 1, image 2 of 2
      • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
      • Place the iOpener in the center of the microwave.
      • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
      Ask FixBot
    2. iPad Mini 3 Wi-Fi Front Panel Replacement: step 2, image 1 of 1
      • Heat the iOpener for thirty seconds.
      • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
      • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
      • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
      • Never touch the iOpener if it appears swollen.
      • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
      Ask FixBot
    3. iPad Mini 3 Wi-Fi Front Panel Replacement: step 3, image 1 of 1
      • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
      • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
      Ask FixBot
    4. iPad Mini 3 Wi-Fi Front Panel Replacement, Alternate iOpener heating method: step 4, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Replacement, Alternate iOpener heating method: step 4, image 2 of 2
      • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
      • Fill a pot or pan with enough water to fully submerge an iOpener.
      • Heat the water to a boil. Turn off the heat.
      • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
      • Use tongs to extract the heated iOpener from the hot water.
      • Thoroughly dry the iOpener with a towel.
      • The iOpener will be very hot, so be careful to hold it only by the end tabs.
      • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
      Ask FixBot
    1. iPad Mini 3 Wi-Fi Front Panel Replacement, LCD Shield Plate: step 5, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement, LCD Shield Plate: step 5, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement, LCD Shield Plate: step 5, image 3 of 3
      • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
      • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
      • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
      Ask FixBot
    2. iPad Mini 3 Wi-Fi Front Panel Replacement: step 6, image 1 of 1
      • Handling it by the tab, place the heated iOpener on the side of the iPad to the left of the home button assembly.
      • Let the iOpener sit for about five minutes to soften the adhesive beneath the glass.
      Ask FixBot
    3. iPad Mini 3 Wi-Fi Front Panel Replacement: step 7, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 7, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 7, image 3 of 3
      • Carefully place a suction cup halfway up the heated side.
      • Be sure the cup is completely flat on the screen to get a tight seal.
      • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
      • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
      Ask FixBot
    4. iPad Mini 3 Wi-Fi Front Panel Replacement: step 8, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 8, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 8, image 3 of 3
      • While holding the glass up with the suction cup, slide the point of an opening pick into the gap between the glass and body of the iPad.
      • Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
      • Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
      Ask FixBot
    5. iPad Mini 3 Wi-Fi Front Panel Replacement: step 9, image 1 of 1
      • Reheat and reapply the iOpener.
      • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
      • Let it rest for a few minutes to reheat the left edge of the iPad.
      Ask FixBot
    6. iPad Mini 3 Wi-Fi Front Panel Replacement: step 10, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 10, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 10, image 3 of 3
      • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
      • Throughout the rest of the procedure, if you encounter significant resistance to sliding picks beneath the glass, stop and reheat the section you're working on. Forcing the picks risks cracking the glass.
      Ask FixBot
    7. iPad Mini 3 Wi-Fi Front Panel Replacement: step 11, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 11, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 11, image 3 of 3
      • Continue moving the opening pick down the side of the display to release the adhesive.
      • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
      Ask FixBot
    8. iPad Mini 3 Wi-Fi Front Panel Replacement: step 12, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 12, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 12, image 3 of 3
      • Take the first pick you inserted and slide it up toward the top corner of the iPad.
      • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
      Ask FixBot
    9. iPad Mini 3 Wi-Fi Front Panel Replacement: step 13, image 1 of 1
      • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
      • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
      • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
      Ask FixBot
    10. iPad Mini 3 Wi-Fi Front Panel Replacement: step 14, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 14, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 14, image 3 of 3
      • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
      Ask FixBot
    11. iPad Mini 3 Wi-Fi Front Panel Replacement: step 15, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 15, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 15, image 3 of 3
      • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
      • The third image shows where the front-facing camera and housing are in the iPad.
      • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
      Ask FixBot
    12. iPad Mini 3 Wi-Fi Front Panel Replacement: step 16, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 16, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 16, image 3 of 3
      • Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
      Ask FixBot
    13. iPad Mini 3 Wi-Fi Front Panel Replacement: step 17, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 17, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 17, image 3 of 3
      • Leave the opening pick in the iPad slightly past the front-facing camera.
      • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
      • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
      Ask FixBot
    14. iPad Mini 3 Wi-Fi Front Panel Replacement: step 18, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 18, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 18, image 3 of 3
      • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
      Ask FixBot
    15. iPad Mini 3 Wi-Fi Front Panel Replacement: step 19, image 1 of 1
      • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
      • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
      Ask FixBot
    16. iPad Mini 3 Wi-Fi Front Panel Replacement: step 20, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Replacement: step 20, image 2 of 2
      • Slide the top right opening pick around the corner to fully release the top edge of the glass.
      • Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
      Ask FixBot
    17. iPad Mini 3 Wi-Fi Front Panel Replacement: step 21, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 21, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 21, image 3 of 3
      • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
      Ask FixBot
    18. iPad Mini 3 Wi-Fi Front Panel Replacement: step 22, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 22, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 22, image 3 of 3
      • Continue to slide the pick down the right edge of the iPad, releasing the adhesive.
      Ask FixBot
    19. iPad Mini 3 Wi-Fi Front Panel Replacement: step 23, image 1 of 1
      • Leave the opening picks in place and reheat the iOpener.
      • Remember not to overheat the iOpener—no more than once every ten minutes.
      • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
      Ask FixBot
    20. iPad Mini 3 Wi-Fi Front Panel Replacement: step 24, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 24, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 24, image 3 of 3
      • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
      • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
      • There are quite a few things to avoid beneath the lower bezel, so study the third image closely:
      • Antennas
      • Home button cavity
      • Digitizer cable
      • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
      Ask FixBot
    21. iPad Mini 3 Wi-Fi Front Panel Replacement: step 25, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 25, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 25, image 3 of 3
      • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
      • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
      • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
      • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
      • Leave the pick in place before moving on.
      Ask FixBot
    22. iPad Mini 3 Wi-Fi Front Panel Replacement: step 26, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 26, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 26, image 3 of 3
      • Insert the tip of one last pick next to the previous step's pick, and slide it beneath the home button.
      • Stop about an inch from the right-hand side to avoid cutting the digitizer cable.
      • Insert the pick slightly deeper and work it back toward the home button.
      • Again, be sure to only slide the pick toward the center of the iPad when it is fully inserted; otherwise you may damage the antenna beneath the glass.
      Ask FixBot
    23. iPad Mini 3 Wi-Fi Front Panel Replacement: step 27, image 1 of 1
      • Reheat and reapply the iOpener to the top bezel of the iPad.
      Ask FixBot
    24. iPad Mini 3 Wi-Fi Front Panel Replacement: step 28, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Replacement: step 28, image 2 of 2
      • Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
      • At the top of the iPad opposite the home button, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along all four edges.
      • If you encounter a significant amount of resistance, stop twisting. Leave the picks in place, reheat, and reapply the iOpener to the problem areas, and run a pick through the sticking point one more time.
      Ask FixBot
    25. iPad Mini 3 Wi-Fi Front Panel Replacement: step 29, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Replacement: step 29, image 2 of 2
      • Lift slowly and gently to further detach the adhesive along the lower edge.
      Ask FixBot
    26. iPad Mini 3 Wi-Fi Front Panel Replacement: step 30, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Replacement: step 30, image 2 of 2
      • Once all of the adhesive has been separated, open the front glass like a page in a book and rest it on your workspace.
      • If reusing the front panel assembly during reassembly, you will need to replace your display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
      Ask FixBot
    27. iPad Mini 3 Wi-Fi Front Panel Replacement: step 31, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 31, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 31, image 3 of 3
      • The front-facing camera housing may stick to the front panel; peel up the housing and place it back over the camera to protect it.
      • Rock the camera housing up on one edge to free it from the adhesive and remove it from the front panel.
      • Return the front-facing camera housing to its recess in the rear case.
      Ask FixBot
    28. iPad Mini 3 Wi-Fi Front Panel Replacement: step 32, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Replacement: step 32, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the following Phillips #00 screws securing the LCD:
      • Three 3.3 mm screws
      • One 4.5 mm screw
      • If there is tape covering any LCD screws, peel it up with tweezers.
      Ask FixBot
    29. iPad Mini 3 Wi-Fi Front Panel Replacement: step 33, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Replacement: step 33, image 2 of 2
      • Do not attempt to fully remove the LCD. It is still adhered in place and connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
      • Insert the flat end of a spudger under the LCD between it and the LCD shield plate and lift gently.
      • Be very careful not to get the spudger under the shield plate. It must be between the LCD and the shield.
      • Even bending the LCD slightly can permanently damage it, so be extremely careful as you lift.
      • You can try these alternate removal methods to reduce your chance of cracking the LCD during the removal process:
      • Run a thin string (like floss or fishing line) under the display, starting from the top then working your way down
      • Use a thin, flexible card or plastic money note to cut through the adhesive starting from the top.
      Ask FixBot
    30. iPad Mini 3 Wi-Fi Front Panel Replacement: step 34, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 34, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 34, image 3 of 3
      • The LCD is secured by mild adhesive that should be loosened before you flip the LCD up from its shield plate.
      • Insert the spudger between the LCD and LCD shield plate and slide it to the far edge of the iPad.
      Ask FixBot
    31. iPad Mini 3 Wi-Fi Front Panel Replacement: step 35, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Replacement: step 35, image 2 of 2
      • Two wide strips of tape connect the LCD to the speakers.
      • Hold the LCD with one hand, and the rear body of the iPad with the other.
      • Do not attempt to fully remove the LCD from the iPad.
      • Gently pull the LCD away from the speakers to separate the tape, being careful not to pull on the digitizer cable.
      Ask FixBot
    32. iPad Mini 3 Wi-Fi Front Panel Replacement: step 36, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Replacement: step 36, image 2 of 2
      • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
      • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
      • Be gentle and keep an eye on the LCD cables as you flip the display over.
      • Lay the LCD on the front panel glass to allow access to the display cables.
      Ask FixBot
    33. iPad Mini 3 Wi-Fi Front Panel Replacement: step 37, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 37, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 37, image 3 of 3
      • Slide the tip of a spudger between the LCD and the adhesive tabs to free the display.
      • Push gently between each of the two adhesive tabs; be careful not to damage any of the nearby cables.
      Ask FixBot
    34. iPad Mini 3 Wi-Fi Front Panel Replacement: step 38, image 1 of 1
      • Remove the seven 1.8 mm Phillips #00 screws from the LCD shield plate.
      Ask FixBot
    35. iPad Mini 3 Wi-Fi Front Panel Replacement: step 39, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 39, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 39, image 3 of 3
      • Use the flat end of a spudger to pry the LCD shield plate up and out of the iPad.
      • Remove the LCD shield plate.
      Ask FixBot
    1. iPad Mini 3 Wi-Fi Front Panel Replacement, LCD: step 40, image 1 of 1
      • Remove the following Phillips #00 screws from the display cable bracket:
      • One 2.8 mm screw
      • Three 1.4 mm screws
      Ask FixBot
    2. iPad Mini 3 Wi-Fi Front Panel Replacement: step 41, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 41, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 41, image 3 of 3
      • Remove the display cable bracket from the iPad.
      Ask FixBot
    3. iPad Mini 3 Wi-Fi Front Panel Replacement: step 42, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 42, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 42, image 3 of 3
      • Use the tip of a spudger to lift the home button cable up off of its socket on the logic board.
      • Fold the home button ribbon cable out of the way.
      Ask FixBot
    4. iPad Mini 3 Wi-Fi Front Panel Replacement: step 43, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 43, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 43, image 3 of 3
      • Use the tip of a spudger to gently lift the battery connector up off its socket on the logic board.
      • Be very careful to only pry up on the battery connector and not on the socket itself. If you pry up on the logic board socket, you may break the connector entirely.
      Ask FixBot
    5. iPad Mini 3 Wi-Fi Front Panel Replacement: step 44, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Replacement: step 44, image 2 of 2
      • Use the tip of a spudger to lift the LCD connector up off its socket on the logic board.
      • Do not pry against the large IC next to the connector, or you may break it. Gently pry from the side of the connector as shown.
      Ask FixBot
    6. iPad Mini 3 Wi-Fi Front Panel Replacement: step 45, image 1 of 1
      • Lift and remove the LCD from the iPad Mini 3.
      Ask FixBot
    1. iPad Mini 3 Wi-Fi Front Panel Replacement, Front Panel Assembly: step 46, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Replacement, Front Panel Assembly: step 46, image 2 of 2
      • Use the tip of a spudger to lift the digitizer cable connector straight up off of its socket.
      Ask FixBot
    2. iPad Mini 3 Wi-Fi Front Panel Replacement: step 47, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Replacement: step 47, image 2 of 2
      • Slide the flat end of a spudger under the battery side of the digitizer board to begin separating it from the rear case.
      Ask FixBot
    3. iPad Mini 3 Wi-Fi Front Panel Replacement: step 48, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Replacement: step 48, image 2 of 2
      • Lift the digitizer board up to free the last of the adhesive.
      Ask FixBot
    4. iPad Mini 3 Wi-Fi Front Panel Replacement: step 49, image 1 of 1
      • Lift and remove the front panel assembly from the iPad.
      Ask FixBot
    1. iPad Mini 3 Wi-Fi Front Panel Replacement, Home Button Assembly: step 50, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement, Home Button Assembly: step 50, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement, Home Button Assembly: step 50, image 3 of 3
      • Use an opening pick to break up the adhesive holding the home button ribbon cable to the digitizer cable.
      Ask FixBot
    2. iPad Mini 3 Wi-Fi Front Panel Replacement: step 51, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 51, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 51, image 3 of 3
      • Insert an opening pick between the home button ribbon cable and the digitizer.
      • Slide the pick along the front panel, towards the home button, to continue separating the home button ribbon cable from the front panel.
      Ask FixBot
    3. iPad Mini 3 Wi-Fi Front Panel Replacement: step 52, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Replacement: step 52, image 2 of 2
      • Use an opening pick to lift the home button control hardware off the back of the front panel.
      Ask FixBot
    4. iPad Mini 3 Wi-Fi Front Panel Replacement: step 53, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Replacement: step 53, image 2 of 2
      • Peel up the last of the tape holding the home button ribbon cable in place by inserting an opening pick between the cable and the digitizer.
      • Continue sliding the pick underneath the cable until it is wholly separated from the front panel
      • Do not attempt to remove the home button yet. Is is still held in place by a strongly adhered bracket and delicate gasket.
      Ask FixBot
    5. iPad Mini 3 Wi-Fi Front Panel Replacement: step 54, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 54, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 54, image 3 of 3
      • Use a plastic opening tool to pry the home button bracket off the back of the digitizer.
      • Remove the home button bracket.
      • When reapplying the home button bracket, use a dab of adhesive or high-bond double sided tape to ensure adequate adhesion.
      Ask FixBot
    6. iPad Mini 3 Wi-Fi Front Panel Replacement: step 55, image 1 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 55, image 2 of 3 iPad Mini 3 Wi-Fi Front Panel Replacement: step 55, image 3 of 3
      • Prepare an iOpener and lay it over the lower edge of the digitizer to loosen the adhesive holding the home button gasket in place.
      • Wait about two minutes before moving on to ensure the adhesive has adequate time to soften.
      • Flip the digitizer panel over and gently push the home button up out of its slot in the front panel.
      • Push slowly and apply just enough pressure to slowly separate the gasket from the glass—if you push too hard the gasket will rip.
      Ask FixBot
    7. iPad Mini 3 Wi-Fi Front Panel Replacement: step 56, image 1 of 1
      • Remove the home button assembly.
      Ask FixBot
    1. iPad Mini 3 Wi-Fi Front Panel Replacement, Front Panel: step 57, image 1 of 1
      • Only the front panel remains.
      Ask FixBot
106 other people completed this guide.
Sam Goldheart
478,447 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
18 Guide Comments
Why do you skip the part about moving the old home button to the new digitizer?
aturnaround - Reply Share
Kind of an important step. Is it easy?
Eric Thomas - Reply Share
Agreed. Regluing the home button to the new digitizer is tedious.
Tristan Punter - Reply Share
I'm pretty sure the digitizer and the LCD are glued together with OCA on the 3rd generation iPad mini... separating/replacing them requires the equipment that is used for iPhones. You can't use LOCA glue in place of OCA because apple didn't think it was a good idea to seal the backlight to the LCD. The iPad mini and the iPad air 2nd Gen are repaired the same way, which is different than the previous versions of ipads. Please correct me if I'm wrong
Vinny Buffone - Reply Share
You are incorrect. They are indeed separate.
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 169
All Time: 109,915
