Introduction
Follow this guide to remove and replace the rear camera on your iPad Air 6 11".
You'll need additional screen adhesive to complete this repair.
This guide uses images from a Wi-Fi + cellular iPad Air 6 (A2903). Your iPad may look slightly different, but the procedure's the same.
Apply strips of packing tape to the cracked glass until the whole screen is covered—this will help keep the glass contained and allow the suction cup to stick to the screen.
Only cover the glass itself—don't stick any tape to the frame.
Tool used on this step:Clampy - Anti-Clamp$24.95
The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Position the suction cups near the top-left corner of the iPad—one on the top and one on the bottom. Make sure the arms don't block the speaker grille.
Place an object under your iPad so it rests level between the suction cups.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
Use a hair dryer or heat gun to heat the screen area between the suction cups until it's slightly too hot to touch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick no deeper than 6 mm when the Anti-Clamp creates a large enough gap.
If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
Remove the Anti-Clamp and skip the next two steps.
Use a hair dryer or heat gun to heat the top-left corner of the screen until it's slightly too hot to touch.
Apply a suction handle to the top-left edge of the screen (near the speaker grille).
Heat the top edge of the iPad until it's slightly too hot to touch.
Insert another opening pick under the top-left corner of the screen.
Slide the pick along the top edge to separate the adhesive, making sure not to insert it deeper than 6 mm.
Leave the pick inserted in the corner to prevent the adhesive from resealing.
Heat the left edge of the iPad until it's slightly too hot to touch.
Slide the pick along the left edge to separate the adhesive.
Heat the bottom edge until it's slightly too hot to touch.
Insert an opening pick under the bottom-left corner of the screen.
Slide the pick along the bottom edge to separate the adhesive, making sure not to insert it deeper than 2 mm.
Heat the right edge (the edge with the front-facing camera) until it's slightly too hot to touch.
Slowly open the iPad by swinging the screen up from the left edge, like the back cover of a book.
If the screen feels hard to swing, apply more heat to the right edge.
If the screen feels stuck, use your pick to separate any missed sections of adhesive.
Lean the screen against something to keep it propped up while you're working on the iPad.
Use a JIS 00 screwdriver to remove the 2.0 mm‑long screw securing the rear camera connector cover.
Remove the cover.
Use the point of a spudger or a clean fingernail to pry up and disconnect the rear camera connector.
